path: root/net/ipv6/route.c
2009-12-18netns: fix net.ipv6.route.gc_min_interval_ms in netnsAlexey Dobriyan
sysctl table was copied, all right, but ->data for net.ipv6.route.gc_min_interval_ms was not reinitialized for "!= &init_net" case. In init_net everthing works by accident due to correct ->data initialization in source table. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-10-07IPv6: use ipv6_addr_copy() in ip6_route_redirect()Brian Haley
Change ip6_route_redirect() to use ipv6_addr_copy(). Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16ipv6: Ignore route option with ROUTER_PREF_INVALIDJens Rosenboom
RFC4191 says that "If the Reserved (10) value is received, the Route Information Option MUST be ignored.", so this patch makes us conform to the RFC. This is different to the usage of the Default Router Preference, where an invalid value must indeed be treated as PREF_MEDIUM. Signed-off-by: Jens Rosenboom <me@jayr.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netns: embed ip6_dst_ops directlyAlexey Dobriyan
struct net::ipv6.ip6_dst_ops is separatedly dynamically allocated, but there is no fundamental reason for it. Embed it directly into struct netns_ipv6. For that: * move struct dst_ops into separate header to fix circular dependencies I honestly tried not to, it's pretty impossible to do other way * drop dynamical allocation, allocate together with netns For a change, remove struct dst_ops::dst_net, it's deducible by using container_of() given dst_ops pointer. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-23ipv6: Use correct data types for ICMPv6 type and codeBrian Haley
Change all the code that deals directly with ICMPv6 type and code values to use u8 instead of a signed int as that's the actual data type. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-20IPv6: set RTPROT_KERNEL to initial routeJean-Mickael Guerin
The use of unspecified protocol in IPv6 initial route prevents quagga to install IPv6 default route: # show ipv6 route S ::/0 [1/0] via fe80::1, eth1_0 K>* ::/0 is directly connected, lo, rej C>* ::1/128 is directly connected, lo C>* fe80::/64 is directly connected, eth1_0 # ip -6 route fe80::/64 dev eth1_0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit -1 ff00::/8 dev eth1_0 metric 256 mtu 1500 advmss 1440 hoplimit -1 unreachable default dev lo proto none metric -1 error -101 hoplimit 255 The attached patch ensures RTPROT_KERNEL to the default initial route and fixes the problem for quagga. This is similar to "ipv6: protocol for address routes" f410a1fba7afa79d2992620e874a343fdba28332. # show ipv6 route S>* ::/0 [1/0] via fe80::1, eth1_0 C>* ::1/128 is directly connected, lo C>* fe80::/64 is directly connected, eth1_0 # ip -6 route fe80::/64 dev eth1_0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit -1 fe80::/64 dev eth1_0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit -1 ff00::/8 dev eth1_0 metric 256 mtu 1500 advmss 1440 hoplimit -1 default via fe80::1 dev eth1_0 proto zebra metric 1024 mtu 1500 advmss 1440 hoplimit -1 unreachable default dev lo proto kernel metric -1 error -101 hoplimit 255 Signed-off-by: Jean-Mickael Guerin <jean-mickael.guerin@6wind.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24netlink: change nlmsg_notify() return value logicPablo Neira Ayuso
This patch changes the return value of nlmsg_notify() as follows: If NETLINK_BROADCAST_ERROR is set by any of the listeners and an error in the delivery happened, return the broadcast error; else if there are no listeners apart from the socket that requested a change with the echo flag, return the result of the unicast notification. Thus, with this patch, the unicast notification is handled in the same way of a broadcast listener that has set the NETLINK_BROADCAST_ERROR socket flag. This patch is useful in case that the caller of nlmsg_notify() wants to know the result of the delivery of a netlink notification (including the broadcast delivery) and take any action in case that the delivery failed. For example, ctnetlink can drop packets if the event delivery failed to provide reliable logging and state-synchronization at the cost of dropping packets. This patch also modifies the rtnetlink code to ignore the return value of rtnl_notify() in all callers. The function rtnl_notify() (before this patch) returned the error of the unicast notification which makes rtnl_set_sk_err() reports errors to all listeners. This is not of any help since the origin of the change (the socket that requested the echoing) notices the ENOBUFS error if the notification fails and should resync itself. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-27IPv6: Fix multicast routing bugs.Thomas Goff
This patch addresses the IPv6 multicast routing issues described below. It was tested with XORP 1.4/1.5 as the IPv6 PIM-SM routing daemon against FreeBSD peers. net/ipv6/ip6_input.c: - Don't try to forward link-local multicast packets. - Don't reset skb2->dev before calling ip6_mr_input() so packets can be identified as coming from the PIM register vif properly. net/ipv6/ip6mr.c: - Fix incoming PIM register messages processing: * The IPv6 pseudo-header should be included when checksumming PIM messages (RFC 4601 section 4.9; RFC 3973 section 4.7.1). * Packets decapsulated from PIM register messages should have skb->protocol ETH_P_IPV6. - Enable/disable IPv6 multicast forwarding on the corresponding interface when a routing daemon adds/removes a multicast virtual interface. - Remove incorrect skb_pull() to fix userspace signaling. - Enable/disable global IPv6 multicast forwarding when an IPv6 multicast routing socket is opened/closed. net/ipv6/route.c: - Don't use strict routing logic for packets decapsulated from PIM register messages (similar to disabling rp_filter for the IPv4 case). Signed-off-by: Thomas Goff <thomas.goff@boeing.com> Reviewed-by: Fred Templin <fred.l.templin@boeing.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-08remove lots of double-semicolonsFernando Carrijo
Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Theodore Ts'o <tytso@mit.edu> Acked-by: Mark Fasheh <mfasheh@suse.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04ipv6: Fix sporadic sendmsg -EINVAL when sending to multicast groups.David S. Miller
Thanks to excellent diagnosis by Eduard Guzovsky. The core problem is that on a network with lots of active multicast traffic, the neighbour cache can fill up. If we try to allocate a new route and thus neighbour cache entry, the bog-standard GC attempt the neighbour layer does in ineffective because route entries hold a reference to the existing neighbour entries and GC can only liberate entries with no references. IPV4 already has a way to handle this, by doing a route cache GC in such situations (when neigh attach returns -ENOBUFS). So simply mimick this on the ipv6 side. Tested-by: Eduard Guzovsky <eguzovsky@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-10netns: ip6mr: enable namespace support in ipv6 multicast forwarding codeBenjamin Thery
This last patch makes the appropriate changes to use and propagate the network namespace where needed in IPv6 multicast forwarding code. This consists mainly in replacing all the remaining init_net occurences with current netns pointer retrieved from sockets, net devices or mfc6_caches depending on the routines' contexts. Some routines receive a new 'struct net' parameter to propagate the current netns: * ip6mr_get_route * ip6mr_cache_report * ip6mr_cache_find * ip6mr_cache_unresolved * mif6_add/mif6_delete * ip6mr_mfc_add/ip6mr_mfc_delete * ip6mr_reg_vif All the IPv6 multicast forwarding variables moved to struct netns_ipv6 by the previous patches are now referenced in the correct namespace. Changelog: ========== * Take into account the net associated to mfc6_cache when matching entries in mfc_unres_queue list. * Call mroute_clean_tables() in ip6mr_net_exit() to free memory allocated per-namespace. * Call dev_net_set() in ip6mr_reg_vif() to initialize dev->nd_net correctly. Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-11net: remove struct dst_entry::entry_sizeAlexey Dobriyan
Unused after kmem_cache_zalloc() conversion. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %#p6 format specifier with %pi6Harvey Harrison
gcc warns when using the # modifier with the %p format specifier, so we can't use this to omit the colons when needed, introduces %pi6 instead. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net: replace all current users of NIP6_SEQFMT with %#p6Harvey Harrison
The define in kernel.h can be done away with at a later time. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08netns: add net parameter to IP6_INC_STATSDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07ipv6: initialize ip6_route sysctl vars in ip6_route_net_init()Peter Zijlstra
This makes that ip6_route_net_init() does all of the route init code. There used to be a race between ip6_route_net_init() and ip6_net_init() and someone relying on the combined result was left out cold. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07ipv6: clean up ip6_route_net_init() error handlingPeter Zijlstra
ip6_route_net_init() error handling looked less than solid, fix 'er up. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath9k/core.c drivers/net/wireless/ath9k/main.c net/core/dev.c
2008-10-01XFRM,IPv6: initialize ip6_dst_blackhole_ops.kmem_cachepArnaud Ebalard
ip6_dst_blackhole_ops.kmem_cachep is not expected to be NULL (i.e. to be initialized) when dst_alloc() is called from ip6_dst_blackhole(). Otherwise, it results in the following (xfrm_larval_drop is now set to 1 by default): [ 78.697642] Unable to handle kernel paging request for data at address 0x0000004c [ 78.703449] Faulting instruction address: 0xc0097f54 [ 78.786896] Oops: Kernel access of bad area, sig: 11 [#1] [ 78.792791] PowerMac [ 78.798383] Modules linked in: btusb usbhid bluetooth b43 mac80211 cfg80211 ehci_hcd ohci_hcd sungem sungem_phy usbcore ssb [ 78.804263] NIP: c0097f54 LR: c0334a28 CTR: c002d430 [ 78.809997] REGS: eef19ad0 TRAP: 0300 Not tainted (2.6.27-rc5) [ 78.815743] MSR: 00001032 <ME,IR,DR> CR: 22242482 XER: 20000000 [ 78.821550] DAR: 0000004c, DSISR: 40000000 [ 78.827278] TASK = eef0df40[3035] 'mip6d' THREAD: eef18000 [ 78.827408] GPR00: 00001032 eef19b80 eef0df40 00000000 00008020 eef19c30 00000001 00000000 [ 78.833249] GPR08: eee5101c c05a5c10 ef9ad500 00000000 24242422 1005787c 00000000 1004f960 [ 78.839151] GPR16: 00000000 10024e90 10050040 48030018 0fe44150 00000000 00000000 eef19c30 [ 78.845046] GPR24: eef19e44 00000000 eef19bf8 efb37c14 eef19bf8 00008020 00009032 c0596064 [ 78.856671] NIP [c0097f54] kmem_cache_alloc+0x20/0x94 [ 78.862581] LR [c0334a28] dst_alloc+0x40/0xc4 [ 78.868451] Call Trace: [ 78.874252] [eef19b80] [c03c1810] ip6_dst_lookup_tail+0x1c8/0x1dc (unreliable) [ 78.880222] [eef19ba0] [c0334a28] dst_alloc+0x40/0xc4 [ 78.886164] [eef19bb0] [c03cd698] ip6_dst_blackhole+0x28/0x1cc [ 78.892090] [eef19be0] [c03d9be8] rawv6_sendmsg+0x75c/0xc88 [ 78.897999] [eef19cb0] [c038bca4] inet_sendmsg+0x4c/0x78 [ 78.903907] [eef19cd0] [c03207c8] sock_sendmsg+0xac/0xe4 [ 78.909734] [eef19db0] [c03209e4] sys_sendmsg+0x1e4/0x2a0 [ 78.915540] [eef19f00] [c03220a8] sys_socketcall+0xfc/0x210 [ 78.921406] [eef19f40] [c0014b3c] ret_from_syscall+0x0/0x38 [ 78.927295] --- Exception: c01 at 0xfe2d730 [ 78.927297] LR = 0xfe2d71c [ 78.939019] Instruction dump: [ 78.944835] 91640018 9144001c 900a0000 4bffff44 9421ffe0 7c0802a6 bf810010 7c9d2378 [ 78.950694] 90010024 7fc000a6 57c0045e 7c000124 <83e3004c> 8383005c 2f9f0000 419e0050 [ 78.956464] ---[ end trace 05fa1ed7972487a1 ]--- As commented by Benjamin Thery, the bug was introduced by f2fc6a54585a1be6669613a31fbaba2ecbadcd36, while adding network namespaces support to ipv6 routes. Signed-off-by: Arnaud Ebalard <arno@natisbad.org> Acked-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-10ipv6: On interface down/unregister, purge icmp routes too.David S. Miller
Johannes Berg reported that occaisionally, bringing an interface down or unregistering it would hang for up to 30 seconds. Using debugging output he provided it became clear that ICMP6 routes were the culprit. The problem is that ICMP6 routes live in their own world totally separate from normal ipv6 routes. So there are all kinds of special cases throughout the ipv6 code to handle this. While we should really try to unify all of this stuff somehow, for the time being let's fix this by purging the ICMP6 routes that match the device in question during rt6_ifdown(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-14netns: Add network namespace argument to rt6_fill_node() and ↵Brian Haley
ipv6_dev_get_saddr() ipv6_dev_get_saddr() blindly de-references dst_dev to get the network namespace, but some callers might pass NULL. Change callers to pass a namespace pointer instead. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13ipv6: Fix OOPS, ip -f inet6 route get fec0::1, linux-2.6.26, ↵Brian Haley
ip6_route_output, rt6_fill_node+0x175 Alexey Dobriyan wrote: > On Thu, Aug 07, 2008 at 07:00:56PM +0200, John Gumb wrote: >> Scenario: no ipv6 default route set. > >> # ip -f inet6 route get fec0::1 >> >> BUG: unable to handle kernel NULL pointer dereference at 00000000 >> IP: [<c0369b85>] rt6_fill_node+0x175/0x3b0 >> EIP is at rt6_fill_node+0x175/0x3b0 > > 0xffffffff80424dd3 is in rt6_fill_node (net/ipv6/route.c:2191). > 2186 } else > 2187 #endif > 2188 NLA_PUT_U32(skb, RTA_IIF, iif); > 2189 } else if (dst) { > 2190 struct in6_addr saddr_buf; > 2191 ====> if (ipv6_dev_get_saddr(ip6_dst_idev(&rt->u.dst)->dev, > ^^^^^^^^^^^^^^^^^^^^^^^^ > NULL > > 2192 dst, 0, &saddr_buf) == 0) > 2193 NLA_PUT(skb, RTA_PREFSRC, 16, &saddr_buf); > 2194 } The commit that changed this can't be reverted easily, but the patch below works for me. Fix NULL de-reference in rt6_fill_node() when there's no IPv6 input device present in the dst entry. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-06ipv6: replace dst_metric() with dst_mtu() in net/ipv6/route.c.Rami Rosen
This patch replaces dst_metric() with dst_mtu() in net/ipv6/route.c. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22ipv6: icmp6_dst_gc return changeStephen Hemminger
Change icmp6_dst_gc to return the one value the caller cares about rather than using call by reference. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19ipv6 netns: Make several "global" sysctl variables namespace aware.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18proc: consolidate per-net single-release callersPavel Emelyanov
They are symmetrical to single_open ones :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18proc: consolidate per-net single_open callersPavel Emelyanov
There are already 7 of them - time to kill some duplicate code. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-03ipv6 route: Prefer outgoing interface with source address assigned.YOSHIFUJI Hideaki
Outgoing interface is selected by the route decision if unspecified. Let's prefer routes via interface(s) with the address assigned if we have multiple routes with same cost. With help from Naohiro Ooiwa <nooiwa@miraclelinux.com>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-07-03ipv6: Assume the loopback address in link-local scope.YOSHIFUJI Hideaki
Handle interface property strictly when looking up a route for the loopback address (RFC4291 2.5.3). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-06-28Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl4965-base.c
2008-06-27ipv6 route: Convert rt6_device_match() to use RT6_LOOKUP_F_xxx flags.YOSHIFUJI Hideaki
The commit 77d16f450ae0452d7d4b009f78debb1294fb435c ("[IPV6] ROUTE: Unify RT6_F_xxx and RT6_SELECT_F_xxx flags") intended to pass various routing lookup hints around RT6_LOOKUP_F_xxx flags, but conversion was missing for rt6_device_match(). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smc911x.c
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-12ipv6 route: Fix route lifetime in netlink message.YOSHIFUJI Hideaki
1) We may have route lifetime larger than INT_MAX. In that case we had wired value in lifetime. Use INT_MAX if lifetime does not fit in s32. 2) Lifetime is valid iif RTF_EXPIRES is set. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-06-05[IPV6] ADDRCONF: Allow longer lifetime on 64bit archs.YOSHIFUJI Hideaki
- Allow longer lifetimes (>= 0x7fffffff/HZ) on 64bit archs by using unsigned long. - Shadow this arithmetic overflow workaround by introducing helper functions: addrconf_timeout_fixup() and addrconf_finite_timeout(). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-05-20ipsec: Use the correct ip_local_out functionHerbert Xu
Because the IPsec output function xfrm_output_resume does its own dst_output call it should always call __ip_local_output instead of ip_local_output as the latter may invoke dst_output directly. Otherwise the return values from nf_hook and dst_output may clash as they both use the value 1 but for different purposes. When that clash occurs this can cause a packet to be used after it has been freed which usually leads to a crash. Because the offending value is only returned from dst_output with qdiscs such as HTB, this bug is normally not visible. Thanks to Marco Berizzi for his perseverance in tracking this down. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-19ipv6 addrconf: Allow infinite prefix lifetime.YOSHIFUJI Hideaki
We need to handle infinite prefix lifetime specially. With help from original reporter "Bonitch, Joseph" <Joseph.Bonitch@xerox.com>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-19ipv6 route: Fix lifetime in netlink.YOSHIFUJI Hideaki
We could not see appropriate lifetime if the route had been scheduled to expired at 0 (in jiffies). We should check rt6i_flags instead of rt6i_expires to determine whether lifetime is valid or not. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-19ipv6 addrconf: Fix route lifetime setting in corner case.YOSHIFUJI Hideaki
Because of arithmetic overflow avoidance, the actual lifetime setting (vs the value given by RA) did not increase monotonically around 0x7fffffff/HZ. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-04ip: Use inline function dst_metric() instead of direct access to dst->metric[]Satoru SATOH
There are functions to refer to the value of dst->metric[THE_METRIC-1] directly without use of a inline function "dst_metric" defined in net/dst.h. The following patch changes them to use the inline function consistently. Signed-off-by: Satoru SATOH <satoru.satoh@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21[NETNS]: Don't initialize err variable twice.Pavel Emelyanov
The ip6_route_net_init() performs some unneeded actions. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21[IPV6]: Make struct ip6_prohibit_entry_template static.Adrian Bunk
This patch makes the needlessly global struct ip6_prohibit_entry_template static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[NETNS]: Add netns refcnt debug for dst ops.Denis V. Lunev
2008-04-12[IPV6]: Make address arguments const.YOSHIFUJI Hideaki
- net/ipv6/addrconf.c: ipv6_get_ifaddr(), ipv6_dev_get_saddr() - net/ipv6/mcast.c: ipv6_sock_mc_join(), ipv6_sock_mc_drop(), inet6_mc_check(), ipv6_dev_mc_inc(), __ipv6_dev_mc_dec(), ipv6_dev_mc_dec(), ipv6_chk_mcast_addr() - net/ipv6/route.c: rt6_lookup(), icmp6_dst_alloc() - net/ipv6/ip6_output.c: ip6_nd_hdr() - net/ipv6/ndisc.c: ndisc_send_ns(), ndisc_send_rs(), ndisc_send_redirect(), ndisc_get_neigh(), __ndisc_send() Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
