[ Upstream commit a3300ef4bbb1f1e33ff0400e1e6cf7733d988f4f ]
Brett Ciphery reported that new ipv6 addresses failed to get installed
because the addrconf generated dsts where counted against the dst gc
limit. We don't need to count those routes like we currently don't count
administratively added routes.
Because the max_addresses check enforces a limit on unbounded address
generation first in case someone plays with router advertisments, we
are still safe here.
Reported-by: Brett Ciphery <brett.ciphery@windriver.com>
[ Upstream commit f104a567e673f382b09542a8dc3500aa689957b4 ]
As the rfc 4191 said, the Router Preference and Lifetime values in a
::/0 Route Information Option should override the preference and lifetime
values in the Router Advertisement header. But when the kernel deals with
a ::/0 Route Information Option, the rt6_get_route_info() always return
NULL, that means that overriding will not happen, because those default
routers were added without flag RTF_ROUTEINFO in rt6_add_dflt_router().
In order to deal with that condition, we should call rt6_get_dflt_router
when the prefix length is 0.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
This patch is based on 3.2.y branch, the one used by reporter. Please let me
know if it should be different. Thanks.
The patch which introduced the regression was applied on stables:
3.0.64 3.4.31 3.7.8 3.2.39
The patch which introduced the regression was for stable trees only.
---8<---
Commit 0d6a77079c475033cb622c07c5a880b392ef664e "ipv6: do not create
neighbor entries for local delivery" introduced a regression on
which routes to local delivery would not work anymore. Like this:
$ ip -6 route add local 2001::/64 dev lo
$ ping6 -c1 2001::9
PING 2001::9(2001::9) 56 data bytes
ping: sendmsg: Invalid argument
As this is a local delivery, that commit would not allow the creation of a
neighbor entry and thus the packet cannot be sent.
But as TPROXY scenario actually needs to avoid the neighbor entry creation only
for input flow, this patch now limits previous patch to input flow, keeping
output as before that patch.
Reported-by: Debabrata Banerjee <dbavatar@gmail.com>
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
CC: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 1eb4f758286884e7566627164bca4c4a16952a83 ]
We could end up expiring a route which is part of an ecmp route set. Doing
so would invalidate the rt->rt6i_nsiblings calculations and could provoke
the following panic:
[ 80.144667] ------------[ cut here ]------------
[ 80.145172] kernel BUG at net/ipv6/ip6_fib.c:733!
[ 80.145172] invalid opcode: 0000 [#1] SMP
[ 80.145172] Modules linked in: 8021q nf_conntrack_netbios_ns nf_conntrack_broadcast ipt_MASQUERADE ip6table_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 iptable_nat nf_nat_ipv4 nf_nat iptable_mangle nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ebtable_filter ebtables ip6table_filter ip6_tables
+snd_hda_intel snd_hda_codec snd_hwdep snd_seq snd_seq_device snd_pcm snd_page_alloc snd_timer virtio_balloon snd soundcore i2c_piix4 i2c_core virtio_net virtio_blk
[ 80.145172] CPU: 1 PID: 786 Comm: ping6 Not tainted 3.10.0+ #118
[ 80.145172] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 80.145172] task: ffff880117fa0000 ti: ffff880118770000 task.ti: ffff880118770000
[ 80.145172] RIP: 0010:[<ffffffff815f3b5d>] [<ffffffff815f3b5d>] fib6_add+0x75d/0x830
[ 80.145172] RSP: 0018:ffff880118771798 EFLAGS: 00010202
[ 80.145172] RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff88011350e480
[ 80.145172] RDX: ffff88011350e238 RSI: 0000000000000004 RDI: ffff88011350f738
[ 80.145172] RBP: ffff880118771848 R08: ffff880117903280 R09: 0000000000000001
[ 80.145172] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88011350f680
[ 80.145172] R13: ffff880117903280 R14: ffff880118771890 R15: ffff88011350ef90
[ 80.145172] FS: 00007f02b5127740(0000) GS:ffff88011fd00000(0000) knlGS:0000000000000000
[ 80.145172] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 80.145172] CR2: 00007f981322a000 CR3: 00000001181b1000 CR4: 00000000000006e0
[ 80.145172] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 80.145172] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 80.145172] Stack:
[ 80.145172] 0000000000000001 ffff880100000000 ffff880100000000 ffff880117903280
[ 80.145172] 0000000000000000 ffff880119a4cf00 0000000000000400 00000000000007fa
[ 80.145172] 0000000000000000 0000000000000000 0000000000000000 ffff88011350f680
[ 80.145172] Call Trace:
[ 80.145172] [<ffffffff815eeceb>] ? rt6_bind_peer+0x4b/0x90
[ 80.145172] [<ffffffff815ed985>] __ip6_ins_rt+0x45/0x70
[ 80.145172] [<ffffffff815eee35>] ip6_ins_rt+0x35/0x40
[ 80.145172] [<ffffffff815ef1e4>] ip6_pol_route.isra.44+0x3a4/0x4b0
[ 80.145172] [<ffffffff815ef34a>] ip6_pol_route_output+0x2a/0x30
[ 80.145172] [<ffffffff81616077>] fib6_rule_action+0xd7/0x210
[ 80.145172] [<ffffffff815ef320>] ? ip6_pol_route_input+0x30/0x30
[ 80.145172] [<ffffffff81553026>] fib_rules_lookup+0xc6/0x140
[ 80.145172] [<ffffffff81616374>] fib6_rule_lookup+0x44/0x80
[ 80.145172] [<ffffffff815edea3>] ip6_route_output+0x73/0xb0
[ 80.145172] [<ffffffff815dfdf3>] ip6_dst_lookup_tail+0x2c3/0x2e0
[ 80.145172] [<ffffffff813007b1>] ? list_del+0x11/0x40
[ 80.145172] [<ffffffff81082a4c>] ? remove_wait_queue+0x3c/0x50
[ 80.145172] [<ffffffff815dfe4d>] ip6_dst_lookup_flow+0x3d/0xa0
[ 80.145172] [<ffffffff815fda77>] rawv6_sendmsg+0x267/0xc20
[ 80.145172] [<ffffffff815a8a83>] inet_sendmsg+0x63/0xb0
[ 80.145172] [<ffffffff8128eb93>] ? selinux_socket_sendmsg+0x23/0x30
[ 80.145172] [<ffffffff815218d6>] sock_sendmsg+0xa6/0xd0
[ 80.145172] [<ffffffff81524a68>] SYSC_sendto+0x128/0x180
[ 80.145172] [<ffffffff8109825c>] ? update_curr+0xec/0x170
[ 80.145172] [<ffffffff81041d09>] ? kvm_clock_get_cycles+0x9/0x10
[ 80.145172] [<ffffffff810afd1e>] ? __getnstimeofday+0x3e/0xd0
[ 80.145172] [<ffffffff8152509e>] SyS_sendto+0xe/0x10
[ 80.145172] [<ffffffff8164efd9>] system_call_fastpath+0x16/0x1b
[ 80.145172] Code: fe ff ff 41 f6 45 2a 06 0f 85 ca fe ff ff 49 8b 7e 08 4c 89 ee e8 94 ef ff ff e9 b9 fe ff ff 48 8b 82 28 05 00 00 e9 01 ff ff ff <0f> 0b 49 8b 54 24 30 0d 00 00 40 00 89 83 14 01 00 00 48 89 53
[ 80.145172] RIP [<ffffffff815f3b5d>] fib6_add+0x75d/0x830
[ 80.145172] RSP <ffff880118771798>
[ 80.387413] ---[ end trace 02f20b7a8b81ed95 ]---
[ 80.390154] Kernel panic - not syncing: Fatal exception in interrupt
Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit 3e8b0ac3e41e3c882222a5522d5df7212438ab51 ]
Setting net.ipv6.conf.<interface>.accept_ra=2 causes the kernel
to accept RAs even when forwarding is enabled. However, enabling
forwarding purges all default routes on the system, breaking
connectivity until the next RA is received. Fix this by not
purging default routes on interfaces that have accept_ra=2.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit bd30e947207e2ea0ff2c08f5b4a03025ddce48d3 ]
They will be created at output, if ever needed. This avoids creating
empty neighbor entries when TPROXYing/Forwarding packets for addresses
that are not even directly reachable.
Note that IPv4 already handles it this way. No neighbor entries are
created for local input.
Tested by myself and customer.
[ Upstream commit 14edd87dc67311556f1254a8f29cf4dd6cb5b7d1 ]
Commit a02e4b7dae4551(Demark default hoplimit as zero) only changes the
hoplimit checking condition and default value in ip6_dst_hoplimit, not
zeros all hoplimit default value.
Keep the zeroing ip6_template_metrics[RTAX_HOPLIMIT - 1] to force it as
const, cause as a37e6e344910(net: force dst_default_metrics to const
section)
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
[ Upstream commit 6825a26c2dc21eb4f8df9c06d3786ddec97cf53b ]
as we hold dst_entry before we call __ip6_del_rt,
so we should alse call dst_release not only return
-ENOENT when the rt6_info is ip6_null_entry.
and we already hold the dst entry, so I think it's
safe to call dst_release out of the write-read lock.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
[ Upstream commit d189634ecab947c10f6f832258b103d0bbfe73cc ]
/proc/net/ipv6_route reflects the contents of fib_table_hash. The proc
handler is installed in ip6_route_net_init() whereas fib_table_hash is
allocated in fib6_net_init() _after_ the proc handler has been installed.
This opens up a short time frame to access fib_table_hash with its pants
down.
Move the registration of the proc files to a later point in the init
order to avoid the race.
Tested :-)
Signed-off-by: Thomas Graf <tgraf@suug.ch>
If the ipv6 dst cache which copy from the dst generated by ICMPV6 RA packet.
this dst cache will not check expire because it has no RTF_EXPIRES flag.
So this dst cache will always be used until the dst gc run.
Change the struct dst_entry,add a union contains new pointer from and expires.
When rt6_info.rt6i_flags has no RTF_EXPIRES flag,the dst.expires has no use.
we can use this field to point to where the dst cache copy from.
The dst.from is only used in IPV6.
rt6_check_expired check if rt6_info.dst.from is expired.
ip6_rt_copy only set dst.from when the ort has flag RTF_ADDRCONF
and RTF_DEFAULT.then hold the ort.
ip6_dst_destroy release the ort.
Add some functions to operate the RTF_EXPIRES flag and expires(from) together.
and change the code to use these new adding functions.
Changes from v5:
modify ip6_route_add and ndisc_router_discovery to use new adding functions.
Only set dst.from when the ort has flag RTF_ADDRCONF
In IPv4, if an RTA_IIF attribute is specified within an RTM_GETROUTE
message, then a route is searched as if a packet was received on the
specified 'iif' interface.
However in IPv6, RTA_IIF is not interpreted in the same way:
'inet6_rtm_getroute()' always calls 'ip6_route_output()', regardless the
RTA_IIF attribute.
As a result, in IPv6 there's no way to use RTM_GETROUTE in order to look
for a route as if a packet was received on a specific interface.
Fix 'inet6_rtm_getroute()' so that RTA_IIF is interpreted as "lookup a
route as if a packet was received on the specified interface", similar
to IPv4's 'inet_rtm_getroute()' interpretation.
Reported-by: Ami Koren <amikoren@yahoo.com>
Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
Commit f2c31e32b378 (net: fix NULL dereferences in check_peer_redir() )
added a regression in rt6_fill_node(), leading to rcu_read_lock()
imbalance.
Thats because NLA_PUT() can make a jump to nla_put_failure label.
Fix this by using nla_put()
Many thanks to Ben Greear for his help
Reported-by: Ben Greear <greearb@candelatech.com>
Reported-by: Dave Jones <davej@redhat.com>
Tested-by: Ben Greear <greearb@candelatech.com>
commit 87a115783 ( ipv6: Move xfrm_lookup() call down into
icmp6_dst_alloc().) forgot to convert one error path, leading
to crashes in mld_sendpack()
Many thanks to Dave Jones for providing a very complete bug report.
Suggested by YOSHIFUJI Hideaki.
In the future the ipv4/ipv6 route gateway will take on two types
of values:
1) INADDR_ANY/IN6ADDR_ANY, for local network routes, and in this case
the neighbour must be obtained using the destination address in
ipv4/ipv6 header as the lookup key.
2) Everything else, the actual nexthop route address.
So if the gateway is not inaddr-any we use it, otherwise we must use
the packet's destination address.
release idev when ip6_neigh_lookup failed in icmp6_dst_alloc
Signed-off-by: RongQing.Li <roy.qing.li@gmail.com>
During some debugging I needed to look into how /proc/net/ipv6_route
operated and in my digging I found its calling fib6_clean_all() which uses
"write_lock_bh(&table->tb6_lock)" before doing the walk of the table. I
found this on 2.6.32, but reading the code I believe the same basic idea
exists currently. Looking at the rtnetlink code they are only calling
"read_lock_bh(&table->tb6_lock);" via fib6_dump_table(). While I realize
reading from proc isn't the recommended way of fetching the ipv6 route
table; taking a write lock seems unnecessary and would probably cause
network performance issues.
To verify this I loaded up the ipv6 route table and then ran iperf in 3
cases:
* doing nothing
* reading ipv6 route table via proc
(while :; do cat /proc/net/ipv6_route > /dev/null; done)
* reading ipv6 route table via rtnetlink
(while :; do ip -6 route show table all > /dev/null; done)
* Load the ipv6 route table up with:
* for ((i = 0;i < 4000;i++)); do ip route add unreachable 2000::$i; done
* iperf commands:
* client: iperf -i 1 -V -c <ipv6 addr>
* server: iperf -V -s
* iperf results - 3 runs each (in Mbits/sec)
* nothing: client: 927,927,927 server: 927,927,927
* proc: client: 179,97,96,113 server: 142,112,133
* iproute: client: 928,927,928 server: 927,927,927
lock_stat shows taking the write lock is causing the slowdown. Using this
info I decided to write a version of fib6_clean_all() which replaces
write_lock_bh(&table->tb6_lock) with read_lock_bh(&table->tb6_lock). With
this new function I see the same results as with my rtnetlink iperf test.
Signed-off-by: Josh Hunt <joshhunt00@gmail.com>
In some of the rt6_bind_neighbour() call sites, it hasn't hooked
up the rt->dst.dev pointer yet, so we'd deref a NULL pointer when
obtaining dev->ifindex for the neighbour hash function computation.
Just pass the netdevice explicitly in to fix this problem.
Reported-by: Bjarke Istrup Pedersen <gurligebis@gentoo.org>
I missed this while adding ipv6 support to inet_peer.
It just obscures that the netdevice pointer and the expires value are
implemented in the dst_entry sub-object of the ipv6 route.
And it makes grepping for dst_entry member uses much harder too.
Also, create and use an rt6_bind_neighbour() in net/ipv6/route.c to
consolidate some common logic.
RDBG() wasn't even used, and the messages printed by RT6_DEBUG() were
far from useful. Just get rid of all this stuff, we can replace it
with something more suitable if we want.
drivers/net/ethernet/freescale/fsl_pq_mdio.c
net/batman-adv/translation-table.c
net/ipv6/route.c
rt6_alloc_cow().
After commit 8e2ec639173f325977818c45011ee176ef2b11f6 ("ipv6: don't
use inetpeer to store metrics for routes.") the test in rt6_alloc_cow()
for setting the ANYCAST flag is now wrong.
'rt' will always now have a plen of 128, because it is set explicitly
to 128 by ip6_rt_copy.
So to restore the semantics of the test, check the destination prefix
length of 'ort'.
Don't just succeed with a route that has a NULL neighbour attached.
This follows the behavior of addrconf_dst_alloc().
Allowing this kind of route to end up with a NULL neigh attached will
result in packet drops on output until the route is somehow
invalidated, since nothing will meanwhile try to lookup the neigh
again.
A statistic is bumped for the case where we see a neigh-less route on
output, but the resulting packet drop is otherwise silent in nature,
and frankly it's a hard error for this to happen and ipv6 should do
what ipv4 does which is say something in the kernel logs.
And return error pointers.
To reflect the fact that a refrence is not obtained to the
resulting neighbour entry.
Acked-by: Roland Dreier <roland@purestorage.com>
like rt6_lookup, but allows caller to pass in flowi6 structure.
Will be used by the upcoming ipv6 netfilter reverse path filter
match.
It's only used in net/ipv6/route.c and the NULL device check is
superfluous for all of the existing call sites.
Just expand the __ndisc_lookup_errno() call at each location.
1) x == NULL --> !x
2) x != NULL --> x
3) (x&BIT) --> (x & BIT)
4) (BIT1|BIT2) --> (BIT1 | BIT2)
5) proper argument and struct member alignment
net/ipv4/inet_diag.c
We move all mtu handling from dst_mtu() down to the protocol
layer. So each protocol can implement the mtu handling in
a different manner.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
We plan to invoke the dst_opt->default_mtu() method unconditioally
from dst_mtu(). So rename the method to dst_opt->mtu() to match
the name with the new meaning.
As it is, we return null as the default mtu of blackhole routes.
This may lead to a propagation of a bogus pmtu if the default_mtu
method of a blackhole route is invoked. So return dst->dev->mtu
as the default mtu instead.
C assignment can handle struct in6_addr copying.
NLM_F_CREATE
The support for NLM_F_* flags at IPv6 routing requests.
Warn if NLM_F_CREATE flag is not defined for RTM_NEWROUTE request,
creating new table. Later NLM_F_CREATE may be required for
new route creation.
Patch created against linux-3.2-rc1
Signed-off-by: Matti Vaittinen <Mazziesaccount@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
in func icmp6_dst_alloc,dst_metric_set call ipv6_cow_metrics to set metric.
ipv6_cow_metrics may will call rt6_bind_peer to set rt6_info->rt6i_peer.
So,we should move ipv6_addr_copy before dst_metric_set to make sure rt6_bind_peer success.
return value of dst_alloc must be checked before use
Signed-off-by: Madalin Bucur <madalin.bucur@freescale.com>
Current IPv6 implementation uses inetpeer to store metrics for
routes. The problem of inetpeer is that it doesn't take subnet
prefix length in to consideration. If two routes have the same
address but different prefix length, they share same inetpeer.
So changing metrics of one route also affects the other. The
fix is to allocate separate metrics storage for each route.
Signed-off-by: Zheng Yan <zheng.z.yan@intel.com>
Gergely Kalman reported crashes in check_peer_redir().
It appears commit f39925dbde778 (ipv4: Cache learned redirect
information in inetpeer.) added a race, leading to possible NULL ptr
dereference.
Since we can now change dst neighbour, we should make sure a reader can
safely use a neighbour.
Add RCU protection to dst neighbour, and make sure check_peer_redir()
can be called safely by different cpus in parallel.
As neighbours are already freed after one RCU grace period, this patch
should not add typical RCU penalty (cache cold effects)
Many thanks to Gergely for providing a pretty report pointing to the
bug.
Reported-by: Gergely Kalman <synapse@hippy.csoma.elte.hu>
We currently cow metrics a bit too soon in IPv6 case : All routes are
tied to a single inetpeer entry.
Change ip6_rt_copy() to get destination address as second argument, so
that we fill rt6i_dst before the dst_copy_metrics() call.
icmp6_dst_alloc() must set rt6i_dst before calling dst_metric_set(), or
else the cow is done while rt6i_dst is still NULL.
If orig route points to readonly metrics, we can share the pointer
instead of performing the memory allocation and copy.
In the future dst entries will be neigh-less. In that environment we
need to have an easy transition point for current users of
dst->neighbour outside of the packet output fast path.
dst_{get,set}_neighbour()
It just makes it harder to see 1) what the code is doing
and 2) grep for all users of dst{->,.}neighbour
