[ Upstream commit 2d4212261fdf13e29728ddb5ea9d60c342cc92b5 ]
IPv6 counters updates use a different macro than IPv4.
Fixes: 36cbb2452cbaf ("udp: Increment UDP_MIB_IGNOREDMULTI for arriving unmatched multicasts")
Cc: Rick Jones <rick.jones2@hp.com>
Cc: Willem de Bruijn <willemb@google.com>
[ Upstream commit 59dca1d8a6725a121dae6c452de0b2611d5865dc ]
IPv4 interprets a negative return value from a protocol handler as a
request to redispatch to a new protocol. In contrast, IPv6 interprets a
negative value as an error, and interprets a positive value as a request
for redispatch.
UDP for IPv6 was unaware of this difference. Change __udp6_lib_rcv() to
return a positive value for redispatch. Note that the socket's
encap_rcv hook still needs to return a negative value to request
dispatch, and in the case of IPv6 packets, adjust IP6CB(skb)->nhoff to
identify the byte containing the next protocol.
Signed-off-by: Bill Sommerfeld <wsommerfeld@google.com>
[ Upstream commit 45f6fad84cc305103b28d73482b344d7f5b76f39 ]
This patch addresses multiple problems :
UDP/RAW sendmsg() need to get a stable struct ipv6_txoptions
while socket is not locked : Other threads can change np->opt
concurrently. Dmitry posted a syzkaller
(http://github.com/google/syzkaller) program desmonstrating
use-after-free.
Starting with TCP/DCCP lockless listeners, tcp_v6_syn_recv_sock()
and dccp_v6_request_recv_sock() also need to use RCU protection
to dereference np->opt once (before calling ipv6_dup_options())
This patch adds full RCU protection to np->opt
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
We have two problems in UDP stack related to bogus checksums :
1) We return -EAGAIN to application even if receive queue is not empty.
This breaks applications using edge trigger epoll()
2) Under UDP flood, we can loop forever without yielding to other
processes, potentially hanging the host, especially on non SMP.
This patch is an attempt to make things better.
We might in the future add extra support for rt applications
wanting to better control time spent doing a recv() in a hostile
environment. For example we could validate checksums before queuing
packets in socket receive queue.
Commit <5cf3d46192fc> ("udp: Simplify__udp*_lib_mcast_deliver")
simplified the filter for incoming IPv6 multicast but removed
the check of the local socket address and the UDP destination
address.
This patch restores the filter to prevent sockets bound to a IPv6
multicast IP to receive other UDP traffic link unicast.
Signed-off-by: Henning Rogge <hrogge@gmail.com>
Fixes: 5cf3d46192fc ("udp: Simplify__udp*_lib_mcast_deliver")
Signed-off-by: Sheng Yong <shengyong1@huawei.com>
The ipv6 code uses a mixture of coding styles. In some instances check for NULL
pointer is done as x != NULL and sometimes as x. x is preferred according to
checkpatch and this patch makes the code consistent by adopting the latter
form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
pointer is done as x == NULL and sometimes as !x. !x is preferred according to
form.
const qualifiers ease code review by making clear
which objects are not written in a function.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
This commit adds the same functionaliy to IPv6 that
commit 903ab86d195cca295379699299c5fc10beba31c7
Author: Herbert Xu <herbert@gondor.apana.org.au>
Date: Tue Mar 1 02:36:48 2011 +0000
udp: Add lockless transmit path
added to IPv4.
UDP transmit path can now run without a socket lock,
thus allowing multiple threads to send to a single socket
more efficiently.
This is only used when corking/MSG_MORE is not used.
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
Now that we can individually construct IPv6 skbs to send, add a
udpv6_send_skb() function to populate the udp header and send the
skb. This allows udp_v6_push_pending_frames() to re-use this
function as well as enables us to add lockless sendmsg() support.
Move convert_csum from udp_sock to inet_sock. This allows the
possibility that we can use convert checksum for different types
of sockets and also allows convert checksum to be enabled from
inet layer (what we'll want to do when enabling IP_CHECKSUM cmsg).
Signed-off-by: Tom Herbert <therbert@google.com>
The compute_score functions are a bit difficult to read.
Neaten them a bit to reduce object sizes and make them a
bit more intelligible.
Return early to avoid indentation and avoid unnecessary
initializations.
(allyesconfig, but w/ -O2 and no profiling)
$ size net/ipv[46]/udp.o.*
28680 1184 25 29889 74c1 net/ipv4/udp.o.new
28756 1184 25 29965 750d net/ipv4/udp.o.old
17600 1010 2 18612 48b4 net/ipv6/udp.o.new
17632 1010 2 18644 48d4 net/ipv6/udp.o.old
This change has no functional impact and simply addresses some coding
style issues detected by checkpatch. Specifically this change
adjusts "if" statements which also include the assignment of a
variable.
No changes to the resultant object files result as determined by objdiff.
Use the more common dynamic_debug capable net_dbg_ratelimited
and remove the LIMIT_NETDEBUG macro.
All messages are still ratelimited.
Some KERN_<LEVEL> uses are changed to KERN_DEBUG.
This may have some negative impact on messages that were
emitted at KERN_INFO that are not not enabled at all unless
DEBUG is defined or dynamic_debug is enabled. Even so,
these messages are now _not_ emitted by default.
This also eliminates the use of the net_msg_warn sysctl
"/proc/sys/net/core/warnings". For backward compatibility,
the sysctl is not removed, but it has no function. The extern
declaration of net_msg_warn is removed from sock.h and made
static in net/core/sysctl_net_core.c
Miscellanea:
o Update the sysctl documentation
o Remove the embedded uses of pr_fmt
o Coalesce format fragments
o Realign arguments
Alternative to RPS/RFS is to use hardware support for multiple
queues.
Then split a set of million of sockets into worker threads, each
one using epoll() to manage events on its own socket pool.
Ideally, we want one thread per RX/TX queue/cpu, but we have no way to
know after accept() or connect() on which queue/cpu a socket is managed.
We normally use one cpu per RX queue (IRQ smp_affinity being properly
set), so remembering on socket structure which cpu delivered last packet
is enough to solve the problem.
After accept(), connect(), or even file descriptor passing around
processes, applications can use :
int cpu;
socklen_t len = sizeof(cpu);
getsockopt(fd, SOL_SOCKET, SO_INCOMING_CPU, &cpu, &len);
And use this information to put the socket into the right silo
for optimal performance, as all networking stack should run
on the appropriate cpu, without need to send IPI (RPS/RFS).
As NIC multicast filtering isn't perfect, and some platforms are
quite content to spew broadcasts, we should not trigger an event
for skb:kfree_skb when we do not have a match for such an incoming
datagram. We do though want to avoid sweeping the matter under the
rug entirely, so increment a suitable statistic.
This incorporates feedback from David L. Stevens, Karl Neiss and Eric
Dumazet.
V3 - use bool per David Miller
Signed-off-by: Rick Jones <rick.jones2@hp.com>
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Add support for doing CHECKSUM_UNNECESSARY to CHECKSUM_COMPLETE
conversion in UDP tunneling path.
In the normal UDP path, we call skb_checksum_try_convert after locating
the UDP socket. The check is that checksum conversion is enabled for
the socket (new flag in UDP socket) and that checksum field is
non-zero.
In the UDP GRO path, we call skb_gro_checksum_try_convert after
checksum is validated and checksum field is non-zero. Since this is
already in GRO we assume that checksum conversion is always wanted.
This patch makes no changes to the logic of the code but simply addresses
coding style issues as detected by checkpatch.
Both objdump and diff -w show no differences.
A number of items are addressed in this patch:
* Multiple spaces converted to tabs
* Spaces before tabs removed.
* Spaces in pointer typing cleansed (char *)foo etc.
* Remove space after sizeof
* Ensure spacing around comparators such as if statements.
Replace open codings of (((u64) <x> * <y>) >> 32) with reciprocal_scale().
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
When dealing with ICMPv[46] Error Message, function icmp_socket_deliver()
and icmpv6_notify() do some valid checks on packet's length, but then some
protocols check packet's length redaudantly. So remove those duplicated
statements, and increase counter ICMP_MIB_INERRORS/ICMP6_MIB_INERRORS in
function icmp_socket_deliver() and icmpv6_notify() respectively.
In addition, add missed counter in udp6/udplite6 when socket is NULL.
It hasn't been used since commit 0fd7bac(net: relax rcvbuf limits).
Signed-off-by: Sorin Dumitru <sorin@returnze.ro>
Many multicast sources can have the same port which can result in a very
large list when hashing by port only. Hash by address and port instead
if this is the case. This makes multicast more similar to unicast.
On a 24-core machine receiving from 500 multicast sockets on the same
port, before this patch 80% of system CPU was used up by spin locking
and only ~25% of packets were successfully delivered.
With this patch, all packets are delivered and kernel overhead is ~8%
system CPU on spinlocks.
Signed-off-by: David Held <drheld@google.com>
Switch to using sk_nulls_for_each which shortens the code and makes it
easier to update.
When an UDP application switches from AF_INET to AF_INET6 sockets, we
have a small performance degradation for IPv4 communications because of
extra cache line misses to access ipv6only information.
This can also be noticed for TCP listeners, as ipv6_only_sock() is also
used from __inet_lookup_listener()->compute_score()
This is magnified when SO_REUSEPORT is used.
Move ipv6only into struct sock_common so that it is available at
no extra cost in lookups.
Add MIB counters for rcvbuferrors in UDP to help diagnose problems.
Signed-off-by: James M Leddy <james.leddy@redhat.com>
To avoid the confusion of having two variables, shrink the function to
only use the parameter variable for looping.
Cc: Eric Dumazet <edumazet@google.com>
Signed-off-by: Sven Wegener <sven.wegener@stealer.net>
drivers/net/xen-netback/netback.c
net/core/filter.c
A filter bug fix overlapped some cleanups and a conversion
over to some new insn generation macros.
A xen-netback bug fix overlapped the addition of multi-queue
support.
Commit efe4208 ("ipv6: make lookups simpler and faster") introduced a
regression in udp_v6_mcast_next(), resulting in multicast packets not
reaching the destination sockets under certain conditions.
The packet's IPv6 addresses are wrongly compared to the IPv6 addresses
from the function's socket argument, which indicates the starting point
for looping, instead of the loop variable. If the addresses from the
first socket do not match the packet's addresses, no socket in the list
will match.
RFC 6935 permits zero checksums to be used in IPv6 however this is
recommended only for certain tunnel protocols, it does not make
checksums completely optional like they are in IPv4.
This patch restricts the use of IPv6 zero checksums that was previously
intoduced. no_check6_tx and no_check6_rx have been added to control
the use of checksums in UDP6 RX and TX path. The normal
sk_no_check_{rx,tx} settings are not used (this avoids ambiguity when
dealing with a dual stack socket).
A helper function has been added (udp_set_no_check6) which can be
called by tunnel impelmentations to all zero checksums (send on the
socket, and accept them as valid).
Define separate fields in the sock structure for configuring disabling
checksums in both TX and RX-- sk_no_check_tx and sk_no_check_rx.
The SO_NO_CHECK socket option only affects sk_no_check_tx. Also,
removed UDP_CSUM_* defines since they are no longer necessary.
It doesn't seem like an protocols are setting anything other
than the default, and allowing to arbitrarily disable checksums
for a whole protocol seems dangerous. This can be done on a per
socket basis.
Moving validation of UDP checksum to be done in UDP not encap layer.
Commit 4068579e1e098fa81d48db9ba4432ab664c58561 ("net: Implmement
RFC 6936 (zero RX csums for UDP/IPv6)") introduced zero checksums
being allowed for IPv6, but in the case that a socket disallows a
zero checksum on RX we need to sock_put.
RFC 6936 relaxes the requirement of RFC 2460 that UDP/IPv6 packets which
are received with a zero UDP checksum value must be dropped. RFC 6936
allows zero checksums to support tunnels over UDP.
When sk_no_check is set we allow on a socket we allow a zero IPv6
UDP checksum. This is for both sending zero checksum and accepting
a zero checksum on receive.
This replaces 6 identical code snippets with a call to a new
static inline function.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
We currently don't report IPV6_RECVPKTINFO in cmsg access ancillary data
for IPv4 datagrams on IPv6 sockets.
This patch splits the ip6_datagram_recv_ctl into two functions, one
which handles both protocol families, AF_INET and AF_INET6, while the
ip6_datagram_recv_specific_ctl only handles IPv6 cmsg data.
ip6_datagram_recv_*_ctl never reported back any errors, so we can make
them return void. Also provide a helper for protocols which don't offer dual
personality to further use ip6_datagram_recv_ctl, which is exported to
modules.
I needed to shuffle the code for ping around a bit to make it easier to
implement dual personality for ping ipv6 sockets in future.
Reported-by: Gert Doering <gert@space.net>
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
pull request (net-next): ipsec-next 2013-12-19
1) Use the user supplied policy index instead of a generated one
if present. From Fan Du.
2) Make xfrm migration namespace aware. From Fan Du.
3) Make the xfrm state and policy locks namespace aware. From Fan Du.
4) Remove ancient sleeping when the SA is in acquire state,
we now queue packets to the policy instead. This replaces the
sleeping code.
5) Remove FLOWI_FLAG_CAN_SLEEP. This was used to notify xfrm about the
posibility to sleep. The sleeping code is gone, so remove it.
6) Check user specified spi for IPComp. Thr spi for IPcomp is only
16 bit wide, so check for a valid value. From Fan Du.
7) Export verify_userspi_info to check for valid user supplied spi ranges
with pfkey and netlink. From Fan Du.
8) RFC3173 states that if the total size of a compressed payload and the IPComp
header is not smaller than the size of the original payload, the IP datagram
must be sent in the original non-compressed form. These packets are dropped
by the inbound policy check because they are not transformed. Document the need
to set 'level use' for IPcomp to receive such packets anyway. From Fan Du.
Please pull or let me know if there are problems.
IPV6_PMTU_INTERFACE is the same as IPV6_PMTU_PROBE for ipv6. Add it
nontheless for symmetry with IPv4 sockets. Also drop incoming MTU
information if this mode is enabled.
The additional bit in ipv6_pinfo just eats in the padding behind the
bitfield. There are no changes to the layout of the struct at all.
This patch is following b579035ff766c9412e2b92abf5cab794bff102b6
"ipv6: remove old conditions on flow label sharing"
Since there is no reason to restrict a label to a
destination, we should not erase the destination value of a
socket with the value contained in the flow label storage.
This patch allows to really have the same flow label to more
than one destination.
Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
FLOWI_FLAG_CAN_SLEEP was used to notify xfrm about the posibility
to sleep until the needed states are resolved. This code is gone,
so FLOWI_FLAG_CAN_SLEEP is not needed anymore.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
functions
Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage
of uninitialized memory to user in recv syscalls") conditionally updated
addr_len if the msg_name is written to. The recv_error and rxpmtu
functions relied on the recvmsg functions to set up addr_len before.
As this does not happen any more we have to pass addr_len to those
functions as well and set it to the size of the corresponding sockaddr
length.
This broke traceroute and such.
Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls")
Reported-by: Brad Spengler <spender@grsecurity.net>
Reported-by: Tom Labanowski
Cc: mpb <mpb.mail@gmail.com>
Only update *addr_len when we actually fill in sockaddr, otherwise we
can return uninitialized memory from the stack to the caller in the
recvfrom, recvmmsg and recvmsg syscalls. Drop the the (addr_len == NULL)
checks because we only get called with a valid addr_len pointer either
from sock_common_recvmsg or inet_recvmsg.
If a blocking read waits on a socket which is concurrently shut down we
now return zero and set msg_msgnamelen to 0.
Reported-by: mpb <mpb.mail@gmail.com>
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
