Now that there is a one-to-one correspondance between neighbour
and hh_cache entries, we no longer need:
1) dynamic allocation
2) attachment to dst->hh
3) refcounting
Initialization of the hh_cache entry is indicated by hh_len
being non-zero, and such initialization is always done with
the neighbour's lock held as a writer.
RFC 6164 requires that routers MUST disable Subnet-Router anycast
for the prefix when /127 prefixes are used.
No need for matching code in addrconf_leave_anycast() as it
will silently ignore any attempt to leave an unknown anycast
address.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Reinhard Max also pointed out that the error should EAFNOSUPPORT according
to POSIX.
The Linux manpages have it as EINVAL, some other OSes (Minix, HPUX, perhaps BSD) use
EAFNOSUPPORT. Windows uses WSAEFAULT according to MSDN.
Other protocols error values in their af bind() methods in current mainline git as far
as a brief look shows:
EAFNOSUPPORT: atm, appletalk, l2tp, llc, phonet, rxrpc
EINVAL: ax25, bluetooth, decnet, econet, ieee802154, iucv, netlink, netrom, packet, rds, rose, unix, x25,
No check?: can/raw, ipv6/raw, irda, l2tp/l2tp_ip
Ciao, Marcus
Signed-off-by: Marcus Meissner <meissner@suse.de>
Cc: Reinhard Max <max@suse.de>
IPV6, unlike IPV4, doesn't have a routing cache.
Routing table entries, as well as clones made in response
to route lookup requests, all live in the same table. And
all of these things are together collected in the destination
cache table for ipv6.
This means that routing table entries count against the garbage
collection limits, even though such entries cannot ever be reclaimed
and are added explicitly by the administrator (rather than being
created in response to lookups).
Therefore it makes no sense to count ipv6 routing table entries
against the GC limits.
Add a DST_NOCOUNT destination cache entry flag, and skip the counting
if it is set. Use this flag bit in ipv6 when adding routing table
entries.
This blows away any flags already set in the entry.
Make the case labels the same indent as the switch.
git diff -w shows 80 column reflowing,
removal of a useless break after return, and moving
open brace after case instead of separate line.
Consider this scenario: When the size of the first received udp packet
is bigger than the receive buffer, MSG_TRUNC bit is set in msg->msg_flags.
However, if checksum error happens and this is a blocking socket, it will
goto try_again loop to receive the next packet. But if the size of the
next udp packet is smaller than receive buffer, MSG_TRUNC flag should not
be set, but because MSG_TRUNC bit is not cleared in msg->msg_flags before
receive the next packet, MSG_TRUNC is still set, which is wrong.
Fix this problem by clearing MSG_TRUNC flag when starting over for a
new packet.
Signed-off-by: Xufeng Zhang <xufeng.zhang@windriver.com>
udpv6_recvmsg() function is not using the correct variable to determine
whether or not the socket is in non-blocking operation, this will lead
to unexpected behavior when a UDP checksum error occurs.
Consider a non-blocking udp receive scenario: when udpv6_recvmsg() is
called by sock_common_recvmsg(), MSG_DONTWAIT bit of flags variable in
udpv6_recvmsg() is cleared by "flags & ~MSG_DONTWAIT" in this call:
err = sk->sk_prot->recvmsg(iocb, sk, msg, size, flags & MSG_DONTWAIT,
flags & ~MSG_DONTWAIT, &addr_len);
i.e. with udpv6_recvmsg() getting these values:
int noblock = flags & MSG_DONTWAIT
int flags = flags & ~MSG_DONTWAIT
So, when udp checksum error occurs, the execution will go to
csum_copy_err, and then the problem happens:
csum_copy_err:
if (flags & MSG_DONTWAIT)
return -EAGAIN;
goto try_again;
But it will always go to try_again as MSG_DONTWAIT has been cleared
from flags at call time -- only noblock contains the original value
of MSG_DONTWAIT, so the test should be:
if (noblock)
return -EAGAIN;
This is also consistent with what the ipv4/udp code does.
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
net/netfilter/ipvs/ip_vs_core.c
Le jeudi 16 juin 2011 à 23:38 -0400, David Miller a écrit :
> From: Ben Hutchings <bhutchings@solarflare.com>
> Date: Fri, 17 Jun 2011 00:50:46 +0100
> > On Wed, 2011-06-15 at 04:15 +0200, Eric Dumazet wrote:
> >> @@ -1594,6 +1594,7 @@ int tcp_v4_do_rcv(struct sock *sk, struct sk_buff *skb)
> >> goto discard;
> >> if (nsk != sk) {
> >> + sock_rps_save_rxhash(nsk, skb->rxhash);
> >> if (tcp_child_process(sk, nsk, skb)) {
> >> rsk = nsk;
> >> goto reset;
> > I haven't tried this, but it looks reasonable to me.
> > What about IPv6? The logic in tcp_v6_do_rcv() looks very similar.
> Indeed ipv6 side needs the same fix.
> Eric please add that part and resubmit. And in fact I might stick
> this into net-2.6 instead of net-next-2.6
OK, here is the net-2.6 based one then, thanks !
[PATCH v2] net: rfs: enable RFS before first data packet is received
First packet received on a passive tcp flow is not correctly RFS
steered.
One sock_rps_record_flow() call is missing in inet_accept()
But before that, we also must record rxhash when child socket is setup.
CC: Tom Herbert <therbert@google.com>
CC: Ben Hutchings <bhutchings@solarflare.com>
CC: Jamal Hadi Salim <hadi@cyberus.ca>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
By default, when broadcast or multicast packet are sent from a local
application, they are sent to the interface then looped by the kernel
to other local applications, going throught netfilter hooks in the
process.
These looped packet have their MAC header removed from the skb by the
kernel looping code. This confuse various netfilter's netlink queue,
netlink log and the legacy ip_queue, because they try to extract a
hardware address from these packets, but extracts a part of the IP
header instead.
This patch prevent NFQUEUE, NFLOG and ip_QUEUE to include a MAC header
if there is none in the packet.
Signed-off-by: Nicolas Cavallari <cavallar@lri.fr>
The message size allocated for rtnl ifinfo dumps was limited to
a single page. This is not enough for additional interface info
available with devices that support SR-IOV and caused a bug in
which VF info would not be displayed if more than approximately
40 VFs were created per interface.
Implement a new function pointer for the rtnl_register service that will
calculate the amount of data required for the ifinfo dump and allocate
enough data to satisfy the request.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
This patch lowers the default initRTO from 3secs to 1sec per
RFC2988bis. It falls back to 3secs if the SYN or SYN-ACK packet
has been retransmitted, AND the TCP timestamp option is not on.
It also adds support to take RTT sample during 3WHS on the passive
open side, just like its active open counterpart, and uses it, if
valid, to seed the initRTO for the data transmission phase.
The patch also resets ssthresh to its initial default at the
beginning of the data transmission phase, and reduces cwnd to 1 if
there has been MORE THAN ONE retransmission during 3WHS per RFC5681.
Signed-off-by: H.K. Jerry Chu <hkchu@google.com>
Use same logic as SIT tunnel to handle link local address
for GRE tunnel. OSPFv3 requires link-local address to function.
Same check as for IPv4, also do for IPv6.
(If you passed in a IPv4 sockaddr_in here, the sizeof check
in the line before would have triggered already though.)
Netlink message lengths can't be negative, so use unsigned variables.
Signed-off-by: Dave Jones <davej@redhat.com>
This patch fixes a refcount leak of ct objects that may occur if
l4proto->error() assigns one conntrack object to one skbuff. In
that case, we have to skip further processing in nf_conntrack_in().
With this patch, we can also fix wrong return values (-NF_ACCEPT)
for special cases in ICMP[v6] that should not bump the invalid/error
statistic counters.
Reported-by: Zoltan Menyhart <Zoltan.Menyhart@bull.net>
Following error is raised (and other similar ones) :
net/ipv4/netfilter/nf_nat_standalone.c: In function ‘nf_nat_fn’:
net/ipv4/netfilter/nf_nat_standalone.c:119:2: warning: case value ‘4’
not in enumerated type ‘enum ip_conntrack_info’
gcc barfs on adding two enum values and getting a not enumerated
result :
case IP_CT_RELATED+IP_CT_IS_REPLY:
Add missing enum values
CC: David Miller <davem@davemloft.net>
The %pK format specifier is designed to hide exposed kernel pointers,
specifically via /proc interfaces. Exposing these pointers provides an
easy target for kernel write vulnerabilities, since they reveal the
locations of writable structures containing easily triggerable function
pointers. The behavior of %pK depends on the kptr_restrict sysctl.
If kptr_restrict is set to 0, no deviation from the standard %p behavior
occurs. If kptr_restrict is set to 1, the default, if the current user
(intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG
(currently in the LSM tree), kernel pointers using %pK are printed as 0's.
If kptr_restrict is set to 2, kernel pointers using %pK are printed as
0's regardless of privileges. Replacing with 0's was chosen over the
default "(null)", which cannot be parsed by userland %p, which expects
"(nil)".
The supporting code for kptr_restrict and %pK are currently in the -mm
tree. This patch converts users of %p in net/ to %pK. Cases of printing
pointers to the syslog are not covered, since this would eliminate useful
information for postmortem debugging and the reading of the syslog is
already optionally protected by the dmesg_restrict sysctl.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Thomas Graf <tgraf@infradead.org>
Cc: Eugene Teo <eugeneteo@kernel.org>
Cc: Kees Cook <kees.cook@canonical.com>
Cc: Eric Paris <eparis@parisplace.org>
Like ipv4, just return xfrm6_rcv_spi()'s return value directly.
commit c3968a857a6b6c3d2ef4ead35776b055fb664d74
('ipv6: RTA_PREFSRC support for ipv6 route source address selection')
added support for ipv6 prefsrc as an alternative to ipv6 addrlabels,
but it did not work because the prefsrc entry was not copied.
Cc: Daniel Walter <sahne@0x90.at>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits)
Revert "rcu: Decrease memory-barrier usage based on semi-formal proof"
net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree
batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu
batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree()
batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu
net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu()
net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu()
net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu()
perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu()
perf,rcu: convert call_rcu(free_ctx) to kfree_rcu()
net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(net_generic_release) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu()
security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu()
net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu()
net,rcu: convert call_rcu(xps_map_release) to kfree_rcu()
net,rcu: convert call_rcu(rps_map_release) to kfree_rcu()
ipv6 has per device ICMP SNMP counters, taking too much space because
they use percpu storage.
needed size per device is :
(512+4)*sizeof(long)*number_of_possible_cpus*2
On a 32bit kernel, 16 possible cpus, this wastes more than 64kbytes of
memory per ipv6 enabled network device, taken in vmalloc pool.
Since ICMP messages are rare, just use shared counters (atomic_long_t)
Per network space ICMP counters are still using percpu memory, we might
also convert them to shared counters in a future patch.
CC: Denys Fedoryshchenko <denys@visp.net.lb>
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-3.6
drivers/net/benet/be_main.c
As it is, we assign the outer modes output function to the dst entry
when we create the xfrm bundle. This leads to two problems on interfamily
scenarios. We might insert ipv4 packets into ip6_fragment when called
from xfrm6_output. The system crashes if we try to fragment an ipv4
packet with ip6_fragment. This issue was introduced with git commit
ad0081e4 (ipv6: Fragment locally generated tunnel-mode IPSec6 packets
as needed). The second issue is, that we might insert ipv4 packets in
netfilter6 and vice versa on interfamily scenarios.
With this patch we assign the inner mode output function to the dst entry
when we create the xfrm bundle. So xfrm4_output/xfrm6_output from the inner
mode is used and the right fragmentation and netfilter functions are called.
We switch then to outer mode with the output_finish functions.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
The IPv6 header is not zeroed out in alloc_skb so we must initialize
it properly unless we want to see IPv6 packets with random TOS fields
floating around. The current implementation resets the flow label
but this could be changed if deemed necessary.
We stumbled upon this issue when trying to apply a mangle rule to
the RST packet generated by the REJECT target module.
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
This allows us to acquire the exact route keying information from the
protocol, however that might be managed.
It handles all of the possibilities, from the simplest case of storing
the key in inet->cork.fl to the more complex setup SCTP has where
individual transports determine the flow.
The RCU callback prl_entry_destroy_rcu() just calls kfree(), so we can
use kfree_rcu() instead of call_rcu().
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: "Pekka Savola (ipv6)" <pekkas@netcore.fi>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The rcu callback ipv6_mc_socklist_reclaim() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(ipv6_mc_socklist_reclaim).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
The rcu callback inet6_ifa_finish_destroy_rcu() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(inet6_ifa_finish_destroy_rcu).
The rcu callback in6_dev_finish_destroy_rcu() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(in6_dev_finish_destroy_rcu).
When we fast path datagram sends to avoid locking by putting
the inet_cork on the stack we use up lots of space that isn't
necessary.
This is because inet_cork contains a "struct flowi" which isn't
used in these code paths.
Split inet_cork to two parts, "inet_cork" and "inet_cork_full".
Only the latter of which has the "struct flowi" and is what is
stored in inet_sock.
drivers/net/tg3.c
Force dev_alloc_name() to be called from register_netdevice() by
dev_get_valid_name(). That allows to remove multiple explicit
dev_alloc_name() calls.
The possibility to call dev_alloc_name in advance remains.
This also fixes veth creation regresion caused by
84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Instead of rt->rt_{dst,src}
ctl_table_headers registered with register_net_sysctl_table should
have been unregistered with the equivalent unregister_net_sysctl_table
Signed-off-by: Lucian Adrian Grijincu <lucian.grijincu@gmail.com>
Four years ago, Patrick made a change to hold rtnl mutex during netlink
dump callbacks.
I believe it was a wrong move. This slows down concurrent dumps, making
good old /proc/net/ files faster than rtnetlink in some situations.
This occurred to me because one "ip link show dev ..." was _very_ slow
on a workload adding/removing network devices in background.
All dump callbacks are able to use RCU locking now, so this patch does
roughly a revert of commits :
1c2d670f366 : [RTNETLINK]: Hold rtnl_mutex during netlink dump callbacks
6313c1e0992 : [RTNETLINK]: Remove unnecessary locking in dump callbacks
This let writers fight for rtnl mutex and readers going full speed.
It also takes care of phonet : phonet_route_get() is now called from rcu
read section. I renamed it to phonet_route_get_rcu()
Cc: Remi Denis-Courmont <remi.denis-courmont@nokia.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
For backward compatibility, we should retain the module parameters and
sysfs attributes to control the number of peer notifications
(gratuitous ARPs and unsolicited NAs) sent after bonding failover.
Also, it is possible for failover to take place even though the new
active slave does not have link up, and in that case the peer
notification should be deferred until it does.
Change ipv4 and ipv6 so they do not automatically send peer
notifications on bonding failover.
Change the bonding driver to send separate NETDEV_NOTIFY_PEERS
notifications when the link is up, as many times as requested. Since
it does not directly control which protocols send notifications, make
num_grat_arp and num_unsol_na aliases for a single parameter. Bump
the bonding version number and update its documentation.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
Acked-by: Brian Haley <brian.haley@hp.com>
Make dst_alloc() and it's users explicitly initialize the entire
entry.
The zero'ing done by kmem_cache_zalloc() was almost entirely
redundant.
Now the dst->dev, dev->obsolete, and dst->flags values can
be specified as well.
Although these are equivalent, but the skb_checksum_start_offset() is more readable.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
We lack proper synchronization to manipulate inet->opt ip_options
Problem is ip_make_skb() calls ip_setup_cork() and
ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options),
without any protection against another thread manipulating inet->opt.
Another thread can change inet->opt pointer and free old one under us.
Use RCU to protect inet->opt (changed to inet->inet_opt).
Instead of handling atomic refcounts, just copy ip_options when
necessary, to avoid cache line dirtying.
We cant insert an rcu_head in struct ip_options since its included in
skb->cb[], so this patch is large because I had to introduce a new
ip_options_rcu structure.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
When we use IPsec extended sequence numbers, we may overwrite
the last scatterlist of the associated data by the scatterlist
for the skb. This patch fixes this by placing the scatterlist
for the skb right behind the last scatterlist of the associated
data. esp4 does it already like that.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Resolved logic conflicts causing a build failure due to
drivers/net/r8169.c changes using a patch from Stephen Rothwell.
Since commit 62fa8a846d7d (net: Implement read-only protection and COW'ing
of metrics.) the kernel throws an oops.
[ 101.620985] BUG: unable to handle kernel NULL pointer dereference at
(null)
[ 101.621050] IP: [< (null)>] (null)
[ 101.621084] PGD 6e53c067 PUD 3dd6a067 PMD 0
[ 101.621122] Oops: 0010 [#1] SMP
[ 101.621153] last sysfs file: /sys/devices/virtual/ppp/ppp/uevent
[ 101.621192] CPU 2
[ 101.621206] Modules linked in: l2tp_ppp pppox ppp_generic slhc
l2tp_netlink l2tp_core deflate zlib_deflate twofish_x86_64
twofish_common des_generic cbc ecb sha1_generic hmac af_key
iptable_filter snd_pcm_oss snd_mixer_oss snd_seq snd_seq_device loop
snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_intel snd_hda_codec
snd_pcm snd_timer snd i2c_i801 iTCO_wdt psmouse soundcore snd_page_alloc
evdev uhci_hcd ehci_hcd thermal
[ 101.621552]
[ 101.621567] Pid: 5129, comm: openl2tpd Not tainted 2.6.39-rc4-Quad #3
Gigabyte Technology Co., Ltd. G33-DS3R/G33-DS3R
[ 101.621637] RIP: 0010:[<0000000000000000>] [< (null)>] (null)
[ 101.621684] RSP: 0018:ffff88003ddeba60 EFLAGS: 00010202
[ 101.621716] RAX: ffff88003ddb5600 RBX: ffff88003ddb5600 RCX:
0000000000000020
[ 101.621758] RDX: ffffffff81a69a00 RSI: ffffffff81b7ee61 RDI:
ffff88003ddb5600
[ 101.621800] RBP: ffff8800537cd900 R08: 0000000000000000 R09:
ffff88003ddb5600
[ 101.621840] R10: 0000000000000005 R11: 0000000000014b38 R12:
ffff88003ddb5600
[ 101.621881] R13: ffffffff81b7e480 R14: ffffffff81b7e8b8 R15:
ffff88003ddebad8
[ 101.621924] FS: 00007f06e4182700(0000) GS:ffff88007fd00000(0000)
knlGS:0000000000000000
[ 101.621971] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 101.622005] CR2: 0000000000000000 CR3: 0000000045274000 CR4:
00000000000006e0
[ 101.622046] DR0: 0000000000000000 DR1: 0000000000000000 DR2:
0000000000000000
[ 101.622087] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7:
0000000000000400
[ 101.622129] Process openl2tpd (pid: 5129, threadinfo
ffff88003ddea000, task ffff88003de9a280)
[ 101.622177] Stack:
[ 101.622191] ffffffff81447efa ffff88007d3ded80 ffff88003de9a280
ffff88007d3ded80
[ 101.622245] 0000000000000001 ffff88003ddebbb8 ffffffff8148d5a7
0000000000000212
[ 101.622299] ffff88003dcea000 ffff88003dcea188 ffffffff00000001
ffffffff81b7e480
[ 101.622353] Call Trace:
[ 101.622374] [<ffffffff81447efa>] ? ipv4_blackhole_route+0x1ba/0x210
[ 101.622415] [<ffffffff8148d5a7>] ? xfrm_lookup+0x417/0x510
[ 101.622450] [<ffffffff8127672a>] ? extract_buf+0x9a/0x140
[ 101.622485] [<ffffffff8144c6a0>] ? __ip_flush_pending_frames+0x70/0x70
[ 101.622526] [<ffffffff8146fbbf>] ? udp_sendmsg+0x62f/0x810
[ 101.622562] [<ffffffff813f98a6>] ? sock_sendmsg+0x116/0x130
[ 101.622599] [<ffffffff8109df58>] ? find_get_page+0x18/0x90
[ 101.622633] [<ffffffff8109fd6a>] ? filemap_fault+0x12a/0x4b0
[ 101.622668] [<ffffffff813fb5c4>] ? move_addr_to_kernel+0x64/0x90
[ 101.622706] [<ffffffff81405d5a>] ? verify_iovec+0x7a/0xf0
[ 101.622739] [<ffffffff813fc772>] ? sys_sendmsg+0x292/0x420
[ 101.622774] [<ffffffff810b994a>] ? handle_pte_fault+0x8a/0x7c0
[ 101.622810] [<ffffffff810b76fe>] ? __pte_alloc+0xae/0x130
[ 101.622844] [<ffffffff810ba2f8>] ? handle_mm_fault+0x138/0x380
[ 101.622880] [<ffffffff81024af9>] ? do_page_fault+0x189/0x410
[ 101.622915] [<ffffffff813fbe03>] ? sys_getsockname+0xf3/0x110
[ 101.622952] [<ffffffff81450c4d>] ? ip_setsockopt+0x4d/0xa0
[ 101.622986] [<ffffffff813f9932>] ? sockfd_lookup_light+0x22/0x90
[ 101.623024] [<ffffffff814b61fb>] ? system_call_fastpath+0x16/0x1b
[ 101.623060] Code: Bad RIP value.
[ 101.623090] RIP [< (null)>] (null)
[ 101.623125] RSP <ffff88003ddeba60>
[ 101.623146] CR2: 0000000000000000
[ 101.650871] ---[ end trace ca3856a7d8e8dad4 ]---
[ 101.651011] __sk_free: optmem leakage (160 bytes) detected.
The oops happens in dst_metrics_write_ptr()
include/net/dst.h:124: return dst->ops->cow_metrics(dst, p);
dst->ops->cow_metrics is NULL and causes the oops.
Provide cow_metrics() methods, like we did in commit 214f45c91bb
(net: provide default_advmss() methods to blackhole dst_ops)
Signed-off-by: Held Bernhard <berny156@gmx.de>
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
