commit 2a9de3af21aa8c31cd68b0b39330d69f8c1e59df upstream.
The vti6_rcv function performs some tests on the retrieved tunnel
including checking the IP protocol, the XFRM input policy, the
source and destination address.
In all but one places the skb is released in the error case. When
the input policy check fails the network packet is leaked.
Using the same goto-label discard in this case to fix this problem.
Fixes: ed1efb2aefbb ("ipv6: Add support for IPsec virtual tunnel interfaces")
Signed-off-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
Reviewed-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
commit f1ed10264ed6b66b9cd5e8461cffce69be482356 upstream.
I forgot the 4in6/6in4 cases in my previous patch. Let's fix them.
Fixes: 95224166a903 ("vti[6]: fix packet tx through bpf_redirect()")
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
commit b6f6118901d1e867ac9177bbff3b00b185bd4fdc upstream.
IPV6_ADDRFORM is able to transform IPv6 socket to IPv4 one.
While this operation sounds illogical, we have to support it.
One of the things it does for TCP socket is to switch sk->sk_prot
to tcp_prot.
We now have other layers playing with sk->sk_prot, so we should make
sure to not interfere with them.
This patch makes sure sk_prot is the default pointer for TCP IPv6 socket.
syzbot reported :
BUG: kernel NULL pointer dereference, address: 0000000000000000
PGD a0113067 P4D a0113067 PUD a8771067 PMD 0
Oops: 0010 [#1] PREEMPT SMP KASAN
CPU: 0 PID: 10686 Comm: syz-executor.0 Not tainted 5.6.0-rc2-syzkaller #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
RIP: 0010:0x0
Code: Bad RIP value.
RSP: 0018:ffffc9000281fce0 EFLAGS: 00010246
RAX: 1ffffffff15f48ac RBX: ffffffff8afa4560 RCX: dffffc0000000000
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff8880a69a8f40
RBP: ffffc9000281fd10 R08: ffffffff86ed9b0c R09: ffffed1014d351f5
R10: ffffed1014d351f5 R11: 0000000000000000 R12: ffff8880920d3098
R13: 1ffff1101241a613 R14: ffff8880a69a8f40 R15: 0000000000000000
FS: 00007f2ae75db700(0000) GS:ffff8880aea00000(0000) knlGS:0000000000000000
CR2: ffffffffffffffd6 CR3: 00000000a3b85000 CR4: 00000000001406f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
inet_release+0x165/0x1c0 net/ipv4/af_inet.c:427
__sock_release net/socket.c:605 [inline]
sock_close+0xe1/0x260 net/socket.c:1283
__fput+0x2e4/0x740 fs/file_table.c:280
____fput+0x15/0x20 fs/file_table.c:313
task_work_run+0x176/0x1b0 kernel/task_work.c:113
tracehook_notify_resume include/linux/tracehook.h:188 [inline]
exit_to_usermode_loop arch/x86/entry/common.c:164 [inline]
prepare_exit_to_usermode+0x480/0x5b0 arch/x86/entry/common.c:195
syscall_return_slowpath+0x113/0x4a0 arch/x86/entry/common.c:278
do_syscall_64+0x11f/0x1c0 arch/x86/entry/common.c:304
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x45c429
Code: ad b6 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 7b b6 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f2ae75dac78 EFLAGS: 00000246 ORIG_RAX: 0000000000000036
RAX: 0000000000000000 RBX: 00007f2ae75db6d4 RCX: 000000000045c429
RDX: 0000000000000001 RSI: 000000000000011a RDI: 0000000000000004
RBP: 000000000076bf20 R08: 0000000000000038 R09: 0000000000000000
R10: 0000000020000180 R11: 0000000000000246 R12: 00000000ffffffff
R13: 0000000000000a9d R14: 00000000004ccfb4 R15: 000000000076bf2c
Modules linked in:
CR2: 0000000000000000
---[ end trace 82567b5207e87bae ]---
RIP: 0010:0x0
Fixes: 604326b41a6f ("bpf, sockmap: convert to generic sk_msg interface")
Reported-by: syzbot+1938db17e275e85dc328@syzkaller.appspotmail.com
Cc: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit e404b8c7cfb31654c9024d497cec58a501501692 ]
After commit 27596472473a ("ipv6: fix ECMP route replacement") it is no
longer possible to replace an ECMP-able route by a non ECMP-able route.
For example,
ip route add 2001:db8::1/128 via fe80::1 dev dummy0
ip route replace 2001:db8::1/128 dev dummy0
does not work as expected.
Tweak the replacement logic so that point 3 in the log of the above commit
becomes:
3. If the new route is not ECMP-able, and no matching non-ECMP-able route
exists, replace matching ECMP-able route (if any) or add the new route.
We can now summarize the entire replace semantics to:
When doing a replace, prefer replacing a matching route of the same
"ECMP-able-ness" as the replace argument. If there is no such candidate,
fallback to the first route found.
Fixes: 27596472473a ("ipv6: fix ECMP route replacement")
Signed-off-by: Benjamin Poirier <bpoirier@cumulusnetworks.com>
Reviewed-by: Michal Kubecek <mkubecek@suse.cz>
[ Upstream commit afecdb376bd81d7e16578f0cfe82a1aec7ae18f3 ]
When splitting an RTA_MULTIPATH request into multiple routes and adding the
second and later components, we must not simply remove NLM_F_REPLACE but
instead replace it by NLM_F_CREATE. Otherwise, it may look like the netlink
message was malformed.
For example,
ip route add 2001:db8::1/128 dev dummy0
ip route change 2001:db8::1/128 nexthop via fe80::30:1 dev dummy0 \
nexthop via fe80::30:2 dev dummy0
results in the following warnings:
[ 1035.057019] IPv6: RTM_NEWROUTE with no NLM_F_CREATE or NLM_F_REPLACE
[ 1035.057517] IPv6: NLM_F_CREATE should be set when creating new route
This patch makes the nlmsg sequence look equivalent for __ip6_ins_rt() to
what it would get if the multipath route had been added in multiple netlink
operations:
ip route append 2001:db8::1/128 nexthop via fe80::30:2 dev dummy0
Reviewed-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 95224166a9032ff5d08fca633d37113078ce7d01 ]
With an ebpf program that redirects packets through a vti[6] interface,
the packets are dropped because no dst is attached.
This could also be reproduced with an AF_PACKET socket, with the following
python script (vti1 is an ip_vti interface):
import socket
send_s = socket.socket(socket.AF_PACKET, socket.SOCK_RAW, 0)
# scapy
# p = IP(src='10.100.0.2', dst='10.200.0.1')/ICMP(type='echo-request')
# raw(p)
req = b'E\x00\x00\x1c\x00\x01\x00\x00@\x01e\xb2\nd\x00\x02\n\xc8\x00\x01\x08\x00\xf7\xff\x00\x00\x00\x00'
send_s.sendto(req, ('vti1', 0x800, 0, 0))
[ Upstream commit ae7352d384a552d8c799c242e74a934809990a71 ]
Both IPv6 and 6lowpan are calling inet_frags_fini() too soon.
inet_frags_fini() is dismantling a kmem_cache, that might be needed
later when unregister_pernet_subsys() eventually has to remove
frags queues from hash tables and free them.
This fixes potential use-after-free, and is a prereq for the following patch.
Fixes: d4ad4d22e7ac ("inet: frags: use kmem_cache for inet_frag_queue")
[ Upstream commit 6af1799aaf3f1bc8defedddfa00df3192445bbf3 ]
This began with a syzbot report. syzkaller was injecting
IPv6 TCP SYN packets having a v4mapped source address.
After an unsuccessful 4-tuple lookup, TCP creates a request
socket (SYN_RECV) and calls reqsk_queue_hash_req()
reqsk_queue_hash_req() calls sk_ehashfn(sk)
At this point we have AF_INET6 sockets, and the heuristic
used by sk_ehashfn() to either hash the IPv4 or IPv6 addresses
is to use ipv6_addr_v4mapped(&sk->sk_v6_daddr)
For the particular spoofed packet, we end up hashing V4 addresses
which were not initialized by the TCP IPv6 stack, so KMSAN fired
a warning.
I first fixed sk_ehashfn() to test both source and destination addresses,
but then faced various problems, including user-space programs
like packetdrill that had similar assumptions.
Instead of trying to fix the whole ecosystem, it is better
to admit that we have a dual stack behavior, and that we
can not build linux kernels without V4 stack anyway.
The dual stack API automatically forces the traffic to be IPv4
if v4mapped addresses are used at bind() or connect(), so it makes
no sense to allow IPv6 traffic to use the same v4mapped class.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: Florian Westphal <fw@strlen.de>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit d23dbc479a8e813db4161a695d67da0e36557846 ]
The '.exit' functions from 'pernet_operations' structure should be marked
as __net_exit, not __net_init.
Fixes: d862e5461423 ("net: ipv6: Implement /proc/net/icmp6.")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
commit df453700e8d81b1bdafdf684365ee2b9431fb702 upstream.
According to Amit Klein and Benny Pinkas, IP ID generation is too weak
and might be used by attackers.
Even with recent net_hash_mix() fix (netns: provide pure entropy for net_hash_mix())
having 64bit key and Jenkins hash is risky.
It is time to switch to siphash and its 128bit keys.
Reported-by: Amit Klein <aksecurity@gmail.com>
Reported-by: Benny Pinkas <benny@pinkas.net>
[bwh: Backported to 4.4: adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit 99253eb750fda6a644d5188fb26c43bad8d5a745 ]
Commit 5e1859fbcc3c ("ipv4: ipmr: various fixes and cleanups") fixed
the issue for ipv4 ipmr:
ip_mroute_setsockopt() & ip_mroute_getsockopt() should not
access/set raw_sk(sk)->ipmr_table before making sure the socket
is a raw socket, and protocol is IGMP
The same fix should be done for ipv6 ipmr as well.
This patch can fix the panic caused by overwriting the same offset
as ipmr_table as in raw_sk(sk) when accessing other type's socket
by ip_mroute_setsockopt().
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit 65a3c497c0e965a552008db8bc2653f62bc925a1 ]
Before taking a refcount, make sure the object is not already
scheduled for deletion.
Same fix is needed in ipv6_flowlabel_opt()
Fixes: 18367681a10b ("ipv6 flowlabel: Convert np->ipv6_fl_list to RCU.")
Cc: Willem de Bruijn <willemb@google.com>
[ Upstream commit 72f7cfab6f93a8ea825fab8ccfb016d064269f7f ]
IPv6 does not consider if the socket is bound to a device when binding
to an address. The result is that a socket can be bound to eth0 and
then bound to the address of eth1. If the device is a VRF, the result
is that a socket can only be bound to an address in the default VRF.
Resolve by considering the device if sk_bound_dev_if is set.
Signed-off-by: Mike Manning <mmanning@vyatta.att-mail.com>
Tested-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 6ee02a54ef990a71bf542b6f0a4e3321de9d9c66 ]
When unloading xfrm6_tunnel module, xfrm6_tunnel_fini directly
frees the xfrm6_tunnel_spi_kmem. Maybe someone has gotten the
xfrm6_tunnel_spi, so need to wait it.
Fixes: 91cc3bb0b04ff("xfrm6_tunnel: RCU conversion")
Signed-off-by: Su Yanjun <suyj.fnst@cn.fujitsu.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
[ Upstream commit ff6ab32bd4e073976e4d8797b4d514a172cfe6cb ]
VRF netdev mtu isn't typically set and have an mtu of 65536. When the
link of a tunnel is set, the tunnel mtu is changed from 1480 to the link
mtu minus tunnel header. In the case of VRF netdev is the link, then the
tunnel mtu becomes 65516. So, fix it by not setting the tunnel mtu in
this case.
Signed-off-by: Stephen Suryaputra <ssuryaextr@gmail.com>
commit 8651be8f14a12d24f203f283601d9b0418c389ff upstream.
Baozeng reported this deadlock case:
CPU0 CPU1
lock([ 165.136033] sk_lock-AF_INET6);
lock([ 165.136033] rtnl_mutex);
Similar to commit 87e9f0315952
("ipv4: fix a potential deadlock in mcast getsockopt() path")
this is due to we still have a case, ipv6_sock_mc_close(),
where we acquire sk_lock before rtnl_lock. Close this deadlock
with the similar solution, that is always acquire rtnl lock first.
Fixes: baf606d9c9b1 ("ipv4,ipv6: grab rtnl before locking the socket")
Reported-by: Baozeng Ding <sploving1@gmail.com>
Tested-by: Baozeng Ding <sploving1@gmail.com>
Cc: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Reviewed-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Cc: Zubin Mithra <zsm@chromium.org>
[ Upstream commit 95c169251bf734aa555a1e8043e4d88ec97a04ec ]
A request for a flowlabel fails in process or user exclusive mode must
fail if the caller pid or uid does not match. Invert the test.
Previously, the test was unsafe wrt PID recycling, but indeed tested
for inequality: fl1->owner != fl->owner
Fixes: 4f82f45730c68 ("net ip6 flowlabel: Make owner a union of struct pid* and kuid_t")
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 6c0afef5fb0c27758f4d52b2210c61b6bd8b4470 ]
syzbot was able to catch a use-after-free read in pid_nr_ns() [1]
ip6fl_seq_show() seems to use RCU protection, dereferencing fl->owner.pid
but fl_free() releases fl->owner.pid before rcu grace period is started.
[1]
BUG: KASAN: use-after-free in pid_nr_ns+0x128/0x140 kernel/pid.c:407
Read of size 4 at addr ffff888094012a04 by task syz-executor.0/18087
CPU: 0 PID: 18087 Comm: syz-executor.0 Not tainted 5.1.0-rc6+ #89
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x172/0x1f0 lib/dump_stack.c:113
print_address_description.cold+0x7c/0x20d mm/kasan/report.c:187
kasan_report.cold+0x1b/0x40 mm/kasan/report.c:317
__asan_report_load4_noabort+0x14/0x20 mm/kasan/generic_report.c:131
ip6fl_seq_show+0x2f8/0x4f0 net/ipv6/ip6_flowlabel.c:794
seq_read+0xad3/0x1130 fs/seq_file.c:268
proc_reg_read+0x1fe/0x2c0 fs/proc/inode.c:227
do_loop_readv_writev fs/read_write.c:701 [inline]
do_loop_readv_writev fs/read_write.c:688 [inline]
do_iter_read+0x4a9/0x660 fs/read_write.c:922
vfs_readv+0xf0/0x160 fs/read_write.c:984
kernel_readv fs/splice.c:358 [inline]
default_file_splice_read+0x475/0x890 fs/splice.c:413
do_splice_to+0x12a/0x190 fs/splice.c:876
splice_direct_to_actor+0x2d2/0x970 fs/splice.c:953
do_splice_direct+0x1da/0x2a0 fs/splice.c:1062
do_sendfile+0x597/0xd00 fs/read_write.c:1443
__do_sys_sendfile64 fs/read_write.c:1498 [inline]
__se_sys_sendfile64 fs/read_write.c:1490 [inline]
__x64_sys_sendfile64+0x15a/0x220 fs/read_write.c:1490
do_syscall_64+0x103/0x610 arch/x86/entry/common.c:290
RIP: 0033:0x458da9
Code: ad b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 7b b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f300d24bc78 EFLAGS: 00000246 ORIG_RAX: 0000000000000028
RAX: ffffffffffffffda RBX: 0000000000000004 RCX: 0000000000458da9
RDX: 00000000200000c0 RSI: 0000000000000008 RDI: 0000000000000007
RBP: 000000000073bf00 R08: 0000000000000000 R09: 0000000000000000
R10: 000000000000005a R11: 0000000000000246 R12: 00007f300d24c6d4
R13: 00000000004c5fa3 R14: 00000000004da748 R15: 00000000ffffffff
Allocated by task 17543:
save_stack+0x45/0xd0 mm/kasan/common.c:75
set_track mm/kasan/common.c:87 [inline]
__kasan_kmalloc mm/kasan/common.c:497 [inline]
__kasan_kmalloc.constprop.0+0xcf/0xe0 mm/kasan/common.c:470
kasan_slab_alloc+0xf/0x20 mm/kasan/common.c:505
slab_post_alloc_hook mm/slab.h:437 [inline]
slab_alloc mm/slab.c:3393 [inline]
kmem_cache_alloc+0x11a/0x6f0 mm/slab.c:3555
alloc_pid+0x55/0x8f0 kernel/pid.c:168
copy_process.part.0+0x3b08/0x7980 kernel/fork.c:1932
copy_process kernel/fork.c:1709 [inline]
_do_fork+0x257/0xfd0 kernel/fork.c:2226
__do_sys_clone kernel/fork.c:2333 [inline]
__se_sys_clone kernel/fork.c:2327 [inline]
__x64_sys_clone+0xbf/0x150 kernel/fork.c:2327
Freed by task 7789:
__kasan_slab_free+0x102/0x150 mm/kasan/common.c:459
kasan_slab_free+0xe/0x10 mm/kasan/common.c:467
__cache_free mm/slab.c:3499 [inline]
kmem_cache_free+0x86/0x260 mm/slab.c:3765
put_pid.part.0+0x111/0x150 kernel/pid.c:111
put_pid+0x20/0x30 kernel/pid.c:105
fl_free+0xbe/0xe0 net/ipv6/ip6_flowlabel.c:102
ip6_fl_gc+0x295/0x3e0 net/ipv6/ip6_flowlabel.c:152
call_timer_fn+0x190/0x720 kernel/time/timer.c:1325
expire_timers kernel/time/timer.c:1362 [inline]
__run_timers kernel/time/timer.c:1681 [inline]
__run_timers kernel/time/timer.c:1649 [inline]
run_timer_softirq+0x652/0x1700 kernel/time/timer.c:1694
__do_softirq+0x266/0x95a kernel/softirq.c:293
The buggy address belongs to the object at ffff888094012a00
which belongs to the cache pid_2 of size 88
The buggy address is located 4 bytes inside of
88-byte region [ffff888094012a00, ffff888094012a58)
The buggy address belongs to the page:
page:ffffea0002500480 count:1 mapcount:0 mapping:ffff88809a483080 index:0xffff888094012980
flags: 0x1fffc0000000200(slab)
raw: 01fffc0000000200 ffffea00018a3508 ffffea0002524a88 ffff88809a483080
raw: ffff888094012980 ffff888094012000 000000010000001b 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff888094012900: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
ffff888094012980: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
>ffff888094012a00: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
ffff888094012a80: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
ffff888094012b00: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
Fixes: 4f82f45730c6 ("net ip6 flowlabel: Make owner a union of struct pid * and kuid_t")
Cc: Eric W. Biederman <ebiederm@xmission.com>
[ Upstream commit b2e54b09a3d29c4db883b920274ca8dca4d9f04d ]
The device type for ip6 tunnels is set to
ARPHRD_TUNNEL6. However, the ip4ip6_err function
is expecting the device type of the tunnel to be
ARPHRD_TUNNEL. Since the device types do not
match, the function exits and the ICMP error
packet is not sent to the originating host. Note
that the device type for IPv4 tunnels is set to
ARPHRD_TUNNEL.
Fix is to expect a tunnel device type of
ARPHRD_TUNNEL6 instead. Now the tunnel device
type matches and the ICMP error packet is sent
Signed-off-by: Sheena Mira-ato <sheena.mira-ato@alliedtelesis.co.nz>
[ Upstream commit bb9bd814ebf04f579be466ba61fc922625508807 ]
ipip6 tunnels run iptunnel_pull_header on received skbs. This can
determine the following use-after-free accessing iph pointer since
the packet will be 'uncloned' running pskb_expand_head if it is a
cloned gso skb (e.g if the packet has been sent though a veth device)
[ 706.369655] BUG: KASAN: use-after-free in ipip6_rcv+0x1678/0x16e0 [sit]
[ 706.449056] Read of size 1 at addr ffffe01b6bd855f5 by task ksoftirqd/1/=
[ 706.669494] Hardware name: HPE ProLiant m400 Server/ProLiant m400 Server, BIOS U02 08/19/2016
[ 706.771839] Call trace:
[ 706.801159] dump_backtrace+0x0/0x2f8
[ 706.845079] show_stack+0x24/0x30
[ 706.884833] dump_stack+0xe0/0x11c
[ 706.925629] print_address_description+0x68/0x260
[ 706.982070] kasan_report+0x178/0x340
[ 707.025995] __asan_report_load1_noabort+0x30/0x40
[ 707.083481] ipip6_rcv+0x1678/0x16e0 [sit]
[ 707.132623] tunnel64_rcv+0xd4/0x200 [tunnel4]
[ 707.185940] ip_local_deliver_finish+0x3b8/0x988
[ 707.241338] ip_local_deliver+0x144/0x470
[ 707.289436] ip_rcv_finish+0x43c/0x14b0
[ 707.335447] ip_rcv+0x628/0x1138
[ 707.374151] __netif_receive_skb_core+0x1670/0x2600
[ 707.432680] __netif_receive_skb+0x28/0x190
[ 707.482859] process_backlog+0x1d0/0x610
[ 707.529913] net_rx_action+0x37c/0xf68
[ 707.574882] __do_softirq+0x288/0x1018
[ 707.619852] run_ksoftirqd+0x70/0xa8
[ 707.662734] smpboot_thread_fn+0x3a4/0x9e8
[ 707.711875] kthread+0x2c8/0x350
[ 707.750583] ret_from_fork+0x10/0x18
[ 707.811302] Allocated by task 16982:
[ 707.854182] kasan_kmalloc.part.1+0x40/0x108
[ 707.905405] kasan_kmalloc+0xb4/0xc8
[ 707.948291] kasan_slab_alloc+0x14/0x20
[ 707.994309] __kmalloc_node_track_caller+0x158/0x5e0
[ 708.053902] __kmalloc_reserve.isra.8+0x54/0xe0
[ 708.108280] __alloc_skb+0xd8/0x400
[ 708.150139] sk_stream_alloc_skb+0xa4/0x638
[ 708.200346] tcp_sendmsg_locked+0x818/0x2b90
[ 708.251581] tcp_sendmsg+0x40/0x60
[ 708.292376] inet_sendmsg+0xf0/0x520
[ 708.335259] sock_sendmsg+0xac/0xf8
[ 708.377096] sock_write_iter+0x1c0/0x2c0
[ 708.424154] new_sync_write+0x358/0x4a8
[ 708.470162] __vfs_write+0xc4/0xf8
[ 708.510950] vfs_write+0x12c/0x3d0
[ 708.551739] ksys_write+0xcc/0x178
[ 708.592533] __arm64_sys_write+0x70/0xa0
[ 708.639593] el0_svc_handler+0x13c/0x298
[ 708.686646] el0_svc+0x8/0xc
[ 708.739019] Freed by task 17:
[ 708.774597] __kasan_slab_free+0x114/0x228
[ 708.823736] kasan_slab_free+0x10/0x18
[ 708.868703] kfree+0x100/0x3d8
[ 708.905320] skb_free_head+0x7c/0x98
[ 708.948204] skb_release_data+0x320/0x490
[ 708.996301] pskb_expand_head+0x60c/0x970
[ 709.044399] __iptunnel_pull_header+0x3b8/0x5d0
[ 709.098770] ipip6_rcv+0x41c/0x16e0 [sit]
[ 709.146873] tunnel64_rcv+0xd4/0x200 [tunnel4]
[ 709.200195] ip_local_deliver_finish+0x3b8/0x988
[ 709.255596] ip_local_deliver+0x144/0x470
[ 709.303692] ip_rcv_finish+0x43c/0x14b0
[ 709.349705] ip_rcv+0x628/0x1138
[ 709.388413] __netif_receive_skb_core+0x1670/0x2600
[ 709.446943] __netif_receive_skb+0x28/0x190
[ 709.497120] process_backlog+0x1d0/0x610
[ 709.544169] net_rx_action+0x37c/0xf68
[ 709.589131] __do_softirq+0x288/0x1018
[ 709.651938] The buggy address belongs to the object at ffffe01b6bd85580
which belongs to the cache kmalloc-1024 of size 1024
[ 709.804356] The buggy address is located 117 bytes inside of
1024-byte region [ffffe01b6bd85580, ffffe01b6bd85980)
[ 709.946340] The buggy address belongs to the page:
[ 710.003824] page:ffff7ff806daf600 count:1 mapcount:0 mapping:ffffe01c4001f600 index:0x0
[ 710.099914] flags: 0xfffff8000000100(slab)
[ 710.149059] raw: 0fffff8000000100 dead000000000100 dead000000000200 ffffe01c4001f600
[ 710.242011] raw: 0000000000000000 0000000000380038 00000001ffffffff 0000000000000000
[ 710.334966] page dumped because: kasan: bad access detected
Fix it resetting iph pointer after iptunnel_pull_header
Fixes: a09a4c8dd1ec ("tunnels: Remove encapsulation offloads on decap")
Tested-by: Jianlin Shi <jishi@redhat.com>
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit ef0efcd3bd3fd0589732b67fb586ffd3c8705806 ]
At the beginning of ip6_fragment func, the prevhdr pointer is
obtained in the ip6_find_1stfragopt func.
However, all the pointers pointing into skb header may change
when calling skb_checksum_help func with
skb->ip_summed = CHECKSUM_PARTIAL condition.
The prevhdr pointe will be dangling if it is not reloaded after
calling __skb_linearize func in skb_checksum_help func.
Here, I add a variable, nexthdr_offset, to evaluate the offset,
which does not changes even after calling __skb_linearize func.
Fixes: 405c92f7a541 ("ipv6: add defensive check for CHECKSUM_PARTIAL skbs in ip_fragment")
Signed-off-by: Junwei Hu <hujunwei4@huawei.com>
Reported-by: Wenhao Zhang <zhangwenhao8@huawei.com>
Reported-by: syzbot+e8ce541d095e486074fc@syzkaller.appspotmail.com
Reviewed-by: Zhiqiang Liu <liuzhiqiang26@huawei.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit 89e4130939a20304f4059ab72179da81f5347528 ]
When a dual stack tcp listener accepts an ipv4 flow,
it should not attempt to use an ipv6 header or tcp_v6_iif() helper.
Fixes: 1397ed35f22d ("ipv6: add flowinfo for tcp6 pkt_options for all cases")
Fixes: df3687ffc665 ("ipv6: add the IPV6_FL_F_REFLECT flag to IPV6_FL_A_GET")
[ Upstream commit dcb94b88c09ce82a80e188d49bcffdc83ba215a6 ]
IPv6 ping socket error handler doesn't correctly convert the new 32 bit
mtu to host endianness before using.
Cc: Lorenzo Colitti <lorenzo@google.com>
Fixes: 6d0bfe22611602f ("net: ipv6: Add IPv6 support to the ping socket.")
Acked-by: Lorenzo Colitti <lorenzo@google.com>
[ Upstream commit 97f0082a0592212fc15d4680f5a4d80f79a1687c ]
Set rtm_table to RT_TABLE_COMPAT for ipv6 for tables > 255 to
keep legacy software happy. This is similar to what was done for
ipv4 in commit 709772e6e065 ("net: Fix routing tables with
id > 255 for legacy software").
Signed-off-by: Kalash Nainwal <kalash@arista.com>
[ Upstream commit a843dc4ebaecd15fca1f4d35a97210f72ea1473b ]
In func check_6rd,tunnel->ip6rd.relay_prefixlen may equal to
32,so UBSAN complain about it.
UBSAN: Undefined behaviour in net/ipv6/sit.c:781:47
shift exponent 32 is too large for 32-bit type 'unsigned int'
CPU: 6 PID: 20036 Comm: syz-executor.0 Not tainted 4.19.27 #2
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1
04/01/2014
Call Trace:
dump_stack+0xca/0x13e lib/dump_stack.c:113
ubsan_epilogue+0xe/0x81 lib/ubsan.c:159
__ubsan_handle_shift_out_of_bounds+0x293/0x2e8 lib/ubsan.c:425
check_6rd.constprop.9+0x433/0x4e0 net/ipv6/sit.c:781
try_6rd net/ipv6/sit.c:806 [inline]
ipip6_tunnel_xmit net/ipv6/sit.c:866 [inline]
sit_tunnel_xmit+0x141c/0x2720 net/ipv6/sit.c:1033
__netdev_start_xmit include/linux/netdevice.h:4300 [inline]
netdev_start_xmit include/linux/netdevice.h:4309 [inline]
xmit_one net/core/dev.c:3243 [inline]
dev_hard_start_xmit+0x17c/0x780 net/core/dev.c:3259
__dev_queue_xmit+0x1656/0x2500 net/core/dev.c:3829
neigh_output include/net/neighbour.h:501 [inline]
ip6_finish_output2+0xa36/0x2290 net/ipv6/ip6_output.c:120
ip6_finish_output+0x3e7/0xa20 net/ipv6/ip6_output.c:154
NF_HOOK_COND include/linux/netfilter.h:278 [inline]
ip6_output+0x1e2/0x720 net/ipv6/ip6_output.c:171
dst_output include/net/dst.h:444 [inline]
ip6_local_out+0x99/0x170 net/ipv6/output_core.c:176
ip6_send_skb+0x9d/0x2f0 net/ipv6/ip6_output.c:1697
ip6_push_pending_frames+0xc0/0x100 net/ipv6/ip6_output.c:1717
rawv6_push_pending_frames net/ipv6/raw.c:616 [inline]
rawv6_sendmsg+0x2435/0x3530 net/ipv6/raw.c:946
inet_sendmsg+0xf8/0x5c0 net/ipv4/af_inet.c:798
sock_sendmsg_nosec net/socket.c:621 [inline]
sock_sendmsg+0xc8/0x110 net/socket.c:631
___sys_sendmsg+0x6cf/0x890 net/socket.c:2114
__sys_sendmsg+0xf0/0x1b0 net/socket.c:2152
do_syscall_64+0xc8/0x580 arch/x86/entry/common.c:290
Signed-off-by: linmiaohe <linmiaohe@huawei.com>
GET_ENTRIES
commit b301f2538759933cf9ff1f7c4f968da72e3f0757 upstream.
Make sure the table names via getsockopt GET_ENTRIES is nul-terminated
in ebtables and all the x_tables variants and their respective compat
code. Uncovered by KASAN.
commit 30c7be26fd3587abcb69587f781098e3ca2d565b upstream.
In commits 93821778def10 ("udp: Fix rcv socket locking") and
f7ad74fef3af ("net/ipv6/udp: UDP encapsulation: break backlog_rcv into
__udpv6_queue_rcv_skb") UDP backlog handlers were renamed, but UDPlite
was forgotten.
This leads to crashes if UDPlite header is pulled twice, which happens
starting from commit e6afc8ace6dd ("udp: remove headers from UDP packets
before queueing")
Bug found by syzkaller team, thanks a lot guys !
Note that backlog use in UDP/UDPlite is scheduled to be removed starting
from linux-4.10, so this patch is only needed up to linux-4.9
Fixes: 93821778def1 ("udp: Fix rcv socket locking")
Fixes: f7ad74fef3af ("net/ipv6/udp: UDP encapsulation: break backlog_rcv into __udpv6_queue_rcv_skb")
Fixes: e6afc8ace6dd ("udp: remove headers from UDP packets before queueing")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
[ Upstream commit 87c11f1ddbbad38ad8bad47af133a8208985fbdf ]
Similar to commit 44f49dd8b5a6 ("ipmr: fix possible race resulting from
improper usage of IP_INC_STATS_BH() in preemptible context."), we cannot
assume preemption is disabled when incrementing the counter and
accessing a per-CPU variable.
Preemption can be enabled when we add a route in process context that
corresponds to packets stored in the unresolved queue, which are then
forwarded using this route [1].
Fix this by using IP6_INC_STATS() which takes care of disabling
preemption on architectures where it is needed.
[1]
[ 157.451447] BUG: using __this_cpu_add() in preemptible [00000000] code: smcrouted/2314
[ 157.460409] caller is ip6mr_forward2+0x73e/0x10e0
[ 157.460434] CPU: 3 PID: 2314 Comm: smcrouted Not tainted 5.0.0-rc7-custom-03635-g22f2712113f1 #1336
[ 157.460449] Hardware name: Mellanox Technologies Ltd. MSN2100-CB2FO/SA001017, BIOS 5.6.5 06/07/2016
[ 157.460461] Call Trace:
[ 157.460486] dump_stack+0xf9/0x1be
[ 157.460553] check_preemption_disabled+0x1d6/0x200
[ 157.460576] ip6mr_forward2+0x73e/0x10e0
[ 157.460705] ip6_mr_forward+0x9a0/0x1510
[ 157.460771] ip6mr_mfc_add+0x16b3/0x1e00
[ 157.461155] ip6_mroute_setsockopt+0x3cb/0x13c0
[ 157.461384] do_ipv6_setsockopt.isra.8+0x348/0x4060
[ 157.462013] ipv6_setsockopt+0x90/0x110
[ 157.462036] rawv6_setsockopt+0x4a/0x120
[ 157.462058] __sys_setsockopt+0x16b/0x340
[ 157.462198] __x64_sys_setsockopt+0xbf/0x160
[ 157.462220] do_syscall_64+0x14d/0x610
[ 157.462349] entry_SYSCALL_64_after_hwframe+0x49/0xbe
Fixes: 0912ea38de61 ("[IPV6] MROUTE: Add stats in multicast routing module method ip6_mr_forward().")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reported-by: Amit Cohen <amitc@mellanox.com>
[ Upstream commit 173656accaf583698bac3f9e269884ba60d51ef4 ]
If we disabled IPv6 from the kernel command line (ipv6.disable=1), we should
not call ip6_err_gen_icmpv6_unreach(). This:
ip link add sit1 type sit local 192.0.2.1 remote 192.0.2.2 ttl 1
ip link set sit1 up
ip addr add 198.51.100.1/24 dev sit1
ping 198.51.100.2
if IPv6 is disabled at boot time, will crash the kernel.
v2: there's no need to use in6_dev_get(), use __in6_dev_get() instead,
as we only need to check that idev exists and we are under
rcu_read_lock() (from netif_receive_skb_internal()).
Reported-by: Jianlin Shi <jishi@redhat.com>
Fixes: ca15a078bd90 ("sit: generate icmpv6 error when receiving icmpv4 error")
Cc: Oussama Ghorbel <ghorbel@pivasoftware.com>
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Reviewed-by: Stefano Brivio <sbrivio@redhat.com>
[ Upstream commit e75913c93f7cd5f338ab373c34c93a655bd309cb ]
Follow those steps:
# ip addr add 2001:123::1/32 dev eth0
# ip addr add 2001:123:456::2/64 dev eth0
# ip addr del 2001:123::1/32 dev eth0
# ip addr del 2001:123:456::2/64 dev eth0
and then prefix route of 2001:123::1/32 will still exist.
This is because ipv6_prefix_equal in check_cleanup_prefix_route
func does not check whether two IPv6 addresses have the same
prefix length. If the prefix of one address starts with another
shorter address prefix, even though their prefix lengths are
different, the return value of ipv6_prefix_equal is true.
Here I add a check of whether two addresses have the same prefix
to decide whether their prefixes are equal.
Fixes: 5b84efecb7d9 ("ipv6 addrconf: don't cleanup prefix route for IFA_F_NOPREFIXROUTE")
Signed-off-by: Zhiqiang Liu <liuzhiqiang26@huawei.com>
[ Upstream commit fa89a4593b927b3f59c3b69379f31d3b22272e4e ]
gcc warn this:
net/ipv6/xfrm6_tunnel.c:143 __xfrm6_tunnel_alloc_spi() warn:
always true condition '(spi <= 4294967295) => (0-u32max <= u32max)'
'spi' is u32, which always not greater than XFRM6_TUNNEL_SPI_MAX
because of wrap around. So the second forloop will never reach.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
commit 5d407b071dc369c26a38398326ee2be53651cfe4 upstream.
A kernel crash occurrs when defragmented packet is fragmented
in ip_do_fragment().
In defragment routine, skb_orphan() is called and
skb->ip_defrag_offset is set. but skb->sk and
skb->ip_defrag_offset are same union member. so that
frag->sk is not NULL.
Hence crash occurrs in skb->sk check routine in ip_do_fragment() when
defragmented packet is fragmented.
test commands:
%iptables -t nat -I POSTROUTING -j MASQUERADE
%hping3 192.168.4.2 -s 1000 -p 2000 -d 60000
splat looks like:
[ 261.069429] kernel BUG at net/ipv4/ip_output.c:636!
[ 261.075753] invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC KASAN PTI
[ 261.083854] CPU: 1 PID: 1349 Comm: hping3 Not tainted 4.19.0-rc2+ #3
[ 261.100977] RIP: 0010:ip_do_fragment+0x1613/0x2600
[ 261.106945] Code: e8 e2 38 e3 fe 4c 8b 44 24 18 48 8b 74 24 08 e9 92 f6 ff ff 80 3c 02 00 0f 85 da 07 00 00 48 8b b5 d0 00 00 00 e9 25 f6 ff ff <0f> 0b 0f 0b 44 8b 54 24 58 4c 8b 4c 24 18 4c 8b 5c 24 60 4c 8b 6c
[ 261.127015] RSP: 0018:ffff8801031cf2c0 EFLAGS: 00010202
[ 261.134156] RAX: 1ffff1002297537b RBX: ffffed0020639e6e RCX: 0000000000000004
[ 261.142156] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff880114ba9bd8
[ 261.150157] RBP: ffff880114ba8a40 R08: ffffed0022975395 R09: ffffed0022975395
[ 261.158157] R10: 0000000000000001 R11: ffffed0022975394 R12: ffff880114ba9ca4
[ 261.166159] R13: 0000000000000010 R14: ffff880114ba9bc0 R15: dffffc0000000000
[ 261.174169] FS: 00007fbae2199700(0000) GS:ffff88011b400000(0000) knlGS:0000000000000000
[ 261.183012] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 261.189013] CR2: 00005579244fe000 CR3: 0000000119bf4000 CR4: 00000000001006e0
[ 261.198158] Call Trace:
[ 261.199018] ? dst_output+0x180/0x180
[ 261.205011] ? save_trace+0x300/0x300
[ 261.209018] ? ip_copy_metadata+0xb00/0xb00
[ 261.213034] ? sched_clock_local+0xd4/0x140
[ 261.218158] ? kill_l4proto+0x120/0x120 [nf_conntrack]
[ 261.223014] ? rt_cpu_seq_stop+0x10/0x10
[ 261.227014] ? find_held_lock+0x39/0x1c0
[ 261.233008] ip_finish_output+0x51d/0xb50
[ 261.237006] ? ip_fragment.constprop.56+0x220/0x220
[ 261.243011] ? nf_ct_l4proto_register_one+0x5b0/0x5b0 [nf_conntrack]
[ 261.250152] ? rcu_is_watching+0x77/0x120
[ 261.255010] ? nf_nat_ipv4_out+0x1e/0x2b0 [nf_nat_ipv4]
[ 261.261033] ? nf_hook_slow+0xb1/0x160
[ 261.265007] ip_output+0x1c7/0x710
[ 261.269005] ? ip_mc_output+0x13f0/0x13f0
[ 261.273002] ? __local_bh_enable_ip+0xe9/0x1b0
[ 261.278152] ? ip_fragment.constprop.56+0x220/0x220
[ 261.282996] ? nf_hook_slow+0xb1/0x160
[ 261.287007] raw_sendmsg+0x21f9/0x4420
[ 261.291008] ? dst_output+0x180/0x180
[ 261.297003] ? sched_clock_cpu+0x126/0x170
[ 261.301003] ? find_held_lock+0x39/0x1c0
[ 261.306155] ? stop_critical_timings+0x420/0x420
[ 261.311004] ? check_flags.part.36+0x450/0x450
[ 261.315005] ? _raw_spin_unlock_irq+0x29/0x40
[ 261.320995] ? _raw_spin_unlock_irq+0x29/0x40
[ 261.326142] ? cyc2ns_read_end+0x10/0x10
[ 261.330139] ? raw_bind+0x280/0x280
[ 261.334138] ? sched_clock_cpu+0x126/0x170
[ 261.338995] ? check_flags.part.36+0x450/0x450
[ 261.342991] ? __lock_acquire+0x4500/0x4500
[ 261.348994] ? inet_sendmsg+0x11c/0x500
[ 261.352989] ? dst_output+0x180/0x180
[ 261.357012] inet_sendmsg+0x11c/0x500
v2:
- clear skb->sk at reassembly routine.(Eric Dumarzet)
Fixes: fa0f527358bd ("ip: use rb trees for IP frag queue.")
Suggested-by: Eric Dumazet <edumazet@google.com>
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Signed-off-by: Mao Wenan <maowenan@huawei.com>
commit fa0f527358bd900ef92f925878ed6bfbd51305cc upstream.
Similar to TCP OOO RX queue, it makes sense to use rb trees to store
IP fragments, so that OOO fragments are inserted faster.
Tested:
- a follow-up patch contains a rather comprehensive ip defrag
self-test (functional)
- ran neper `udp_stream -c -H <host> -F 100 -l 300 -T 20`:
netstat --statistics
Ip:
282078937 total packets received
0 forwarded
0 incoming packets discarded
946760 incoming packets delivered
18743456 requests sent out
101 fragments dropped after timeout
282077129 reassemblies required
944952 packets reassembled ok
262734239 packet reassembles failed
(The numbers/stats above are somewhat better re:
reassemblies vs a kernel without this patchset. More
comprehensive performance testing TBD).
Reported-by: Jann Horn <jannh@google.com>
Reported-by: Juha-Matti Tilli <juha-matti.tilli@iki.fi>
Signed-off-by: Peter Oskolkov <posk@google.com>
- Keep using frag_kfree_skb() in inet_frag_destroy()
- Adjust context]
commit 0ed4229b08c13c84a3c301a08defdc9e7f4467e6 upstream.
don't bother with pathological cases, they only waste cycles.
IPv6 requires a minimum MTU of 1280 so we should never see fragments
smaller than this (except last frag).
v3: don't use awkward "-offset + len"
v2: drop IPv4 part, which added same check w. IPV4_MIN_MTU (68).
There were concerns that there could be even smaller frags
generated by intermediate nodes, e.g. on radio networks.
Cc: Peter Oskolkov <posk@google.com>
Cc: Eric Dumazet <edumazet@google.com>
[bwh: Backported to 4.4: In nf_ct_frag6_gather() use clone instead of skb,
and goto ret_orig in case of error]
commit 3d23401283e80ceb03f765842787e0e79ff598b7 upstream.
Giving an integer to proc_doulongvec_minmax() is dangerous on 64bit arches,
since linker might place next to it a non zero value preventing a change
to ip6frag_low_thresh.
ip6frag_low_thresh is not used anymore in the kernel, but we do not
want to prematuraly break user scripts wanting to change it.
Since specifying a minimal value of 0 for proc_doulongvec_minmax()
is moot, let's remove these zero values in all defrag units.
Fixes: 6e00f7dd5e4e ("ipv6: frags: fix /proc/sys/net/ipv6/ip6frag_low_thresh")
Reported-by: Maciej Żenczykowski <maze@google.com>
commit 05c0b86b9696802fd0ce5676a92a63f1b455bdf3 upstream.
Make it similar to IPv4 ip_expire(), and release the lock
before calling icmp functions.
commit 3e67f106f619dcfaf6f4e2039599bdb69848c714 upstream.
Some users are willing to provision huge amounts of memory to be able
to perform reassembly reasonnably well under pressure.
Current memory tracking is using one atomic_t and integers.
Switch to atomic_long_t so that 64bit arches can use more than 2GB,
without any cost for 32bit arches.
Note that this patch avoids an overflow error, if high_thresh was set
to ~2GB, since this test in inet_frag_alloc() was never true :
if (... || frag_mem_limit(nf) > nf->high_thresh)
Tested:
$ echo 16000000000 >/proc/sys/net/ipv4/ipfrag_high_thresh
<frag DDOS>
$ grep FRAG /proc/net/sockstat
FRAG: inuse 14705885 memory 16000002880
$ nstat -n ; sleep 1 ; nstat | grep Reas
IpReasmReqds 3317150 0.0
IpReasmFails 3317112 0.0
commit 2d44ed22e607f9a285b049de2263e3840673a260 upstream.
This function is obsolete, after rhashtable addition to inet defrag.
commit 399d1404be660d355192ff4df5ccc3f4159ec1e4 upstream.
This refactors ip_expire() since one indentation level is removed.
Note: in the future, we should try hard to avoid the skb_clone()
since this is a serious performance cost.
Under DDOS, the ICMP message wont be sent because of rate limits.
Fact that ip6_expire_frag_queue() does not use skb_clone() is
disturbing too. Presumably IPv6 should have the same
issue than the one we fixed in commit ec4fbd64751d
("inet: frag: release spinlock before calling icmp_send()")
commit 6befe4a78b1553edb6eed3a78b4bcd9748526672 upstream.
Remove sum_frag_mem_limit(), ip_frag_mem() & ip6_frag_mem()
Also since we use rhashtable we can bring back the number of fragments
in "grep FRAG /proc/net/sockstat /proc/net/sockstat6" that was
removed in commit 434d305405ab ("inet: frag: don't account number
of fragment queues")
commit 648700f76b03b7e8149d13cc2bdb3355035258a9 upstream.
Some applications still rely on IP fragmentation, and to be fair linux
reassembly unit is not working under any serious load.
It uses static hash tables of 1024 buckets, and up to 128 items per bucket (!!!)
A work queue is supposed to garbage collect items when host is under memory
pressure, and doing a hash rebuild, changing seed used in hash computations.
This work queue blocks softirqs for up to 25 ms when doing a hash rebuild,
occurring every 5 seconds if host is under fire.
Then there is the problem of sharing this hash table for all netns.
It is time to switch to rhashtables, and allocate one of them per netns
to speedup netns dismantle, since this is a critical metric these days.
Lookup is now using RCU. A followup patch will even remove
the refcount hold/release left from prior implementation and save
a couple of atomic operations.
Before this patch, 16 cpus (16 RX queue NIC) could not handle more
than 1 Mpps frags DDOS.
After the patch, I reach 9 Mpps without any tuning, and can use up to 2GB
of storage for the fragments (exact number depends on frags being evicted
after timeout)
FRAG: inuse 1966916 memory 2140004608
A followup patch will change the limits for 64bit arches.
Cc: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Alexander Aring <alex.aring@gmail.com>
Cc: Stefan Schmidt <stefan@osg.samsung.com>
commit 5b975bab23615cd0fdf67af6c9298eb01c4b9f61 upstream.
We want to call inet_frags_init() earlier.
This is a prereq to "inet: frags: use rhashtables for reassembly units"
[bwh: Backported to 4.4: Also delete a redundant assignment to
ip6_frags.skb_free]
commit 093ba72914b696521e4885756a68a3332782c8de upstream.
In order to simplify the API, add a pointer to struct inet_frags.
This will allow us to make things less complex.
These functions no longer have a struct inet_frags parameter :
inet_frag_destroy(struct inet_frag_queue *q /*, struct inet_frags *f */)
inet_frag_put(struct inet_frag_queue *q /*, struct inet_frags *f */)
inet_frag_kill(struct inet_frag_queue *q /*, struct inet_frags *f */)
inet_frags_exit_net(struct netns_frags *nf /*, struct inet_frags *f */)
ip6_expire_frag_queue(struct net *net, struct frag_queue *fq)
[bwh: Backported to 4.4: inet_frag_{kill,put}() are called in some
different places; update all calls]
commit 787bea7748a76130566f881c2342a0be4127d182 upstream.
We will soon initialize one rhashtable per struct netns_frags
in inet_frags_init_net().
This patch changes the return value to eventually propagate an
error.
[ Upstream commit c5ee066333ebc322a24a00a743ed941a0c68617e ]
to an address. The result is that a socket can be bound to eth0 and then
bound to the address of eth1. If the device is a VRF, the result is that
This problem exists from the beginning of git history.
Signed-off-by: David Ahern <dsahern@gmail.com>
[ Upstream commit d4a7e9bb74b5aaf07b89f6531c080b1130bdf019 ]
I realized the last patch calls dev_get_by_index_rcu in a branch not
holding the rcu lock. Add the calls to rcu_read_lock and rcu_read_unlock.
Fixes: ec90ad334986 ("ipv6: Consider sk_bound_dev_if when binding a socket to a v4 mapped address")
[ Upstream commit ec90ad334986fa5856d11dd272f7f22fa86c55c4 ]
Similar to c5ee066333eb ("ipv6: Consider sk_bound_dev_if when binding a
socket to an address"), binding a socket to v4 mapped addresses needs to
consider if the socket is bound to a device.
This problem also exists from the beginning of git history.
[ Upstream commit 4a06fa67c4da20148803525151845276cdb995c1 ]
Commit 2efd4fca703a ("ip: in cmsg IP(V6)_ORIGDSTADDR call
pskb_may_pull") avoided a read beyond the end of the skb linear
segment by calling pskb_may_pull.
That function can trigger a BUG_ON in pskb_expand_head if the skb is
shared, which it is when when peeking. It can also return ENOMEM.
Avoid both by switching to safer skb_header_pointer.
Fixes: 2efd4fca703a ("ip: in cmsg IP(V6)_ORIGDSTADDR call pskb_may_pull")
[ Upstream commit 7d033c9f6a7fd3821af75620a0257db87c2b552a ]
This patch makes sure the flow label in the IPv6 header
forged in ipv6_local_error() is initialized.
BUG: KMSAN: kernel-infoleak in _copy_to_user+0x16b/0x1f0 lib/usercopy.c:32
CPU: 1 PID: 24675 Comm: syz-executor1 Not tainted 4.20.0-rc7+ #4
Call Trace:
dump_stack+0x173/0x1d0 lib/dump_stack.c:113
kmsan_report+0x12e/0x2a0 mm/kmsan/kmsan.c:613
kmsan_internal_check_memory+0x455/0xb00 mm/kmsan/kmsan.c:675
kmsan_copy_to_user+0xab/0xc0 mm/kmsan/kmsan_hooks.c:601
copy_to_user include/linux/uaccess.h:177 [inline]
move_addr_to_user+0x2e9/0x4f0 net/socket.c:227
___sys_recvmsg+0x5d7/0x1140 net/socket.c:2284
__sys_recvmsg net/socket.c:2327 [inline]
__do_sys_recvmsg net/socket.c:2337 [inline]
__se_sys_recvmsg+0x2fa/0x450 net/socket.c:2334
__x64_sys_recvmsg+0x4a/0x70 net/socket.c:2334
do_syscall_64+0xbc/0xf0 arch/x86/entry/common.c:291
entry_SYSCALL_64_after_hwframe+0x63/0xe7
RIP: 0033:0x457ec9
Code: 6d b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 3b b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f8750c06c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002f
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000457ec9
RDX: 0000000000002000 RSI: 0000000020000400 RDI: 0000000000000005
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f8750c076d4
R13: 00000000004c4a60 R14: 00000000004d8140 R15: 00000000ffffffff
Uninit was stored to memory at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:204 [inline]
kmsan_save_stack mm/kmsan/kmsan.c:219 [inline]
kmsan_internal_chain_origin+0x134/0x230 mm/kmsan/kmsan.c:439
__msan_chain_origin+0x70/0xe0 mm/kmsan/kmsan_instr.c:200
ipv6_recv_error+0x1e3f/0x1eb0 net/ipv6/datagram.c:475
udpv6_recvmsg+0x398/0x2ab0 net/ipv6/udp.c:335
inet_recvmsg+0x4fb/0x600 net/ipv4/af_inet.c:830
sock_recvmsg_nosec net/socket.c:794 [inline]
sock_recvmsg+0x1d1/0x230 net/socket.c:801
___sys_recvmsg+0x4d5/0x1140 net/socket.c:2278
Uninit was created at:
kmsan_internal_poison_shadow+0x92/0x150 mm/kmsan/kmsan.c:158
kmsan_kmalloc+0xa6/0x130 mm/kmsan/kmsan_hooks.c:176
kmsan_slab_alloc+0xe/0x10 mm/kmsan/kmsan_hooks.c:185
slab_post_alloc_hook mm/slab.h:446 [inline]
slab_alloc_node mm/slub.c:2759 [inline]
__kmalloc_node_track_caller+0xe18/0x1030 mm/slub.c:4383
__kmalloc_reserve net/core/skbuff.c:137 [inline]
__alloc_skb+0x309/0xa20 net/core/skbuff.c:205
alloc_skb include/linux/skbuff.h:998 [inline]
ipv6_local_error+0x1a7/0x9e0 net/ipv6/datagram.c:334
__ip6_append_data+0x129f/0x4fd0 net/ipv6/ip6_output.c:1311
ip6_make_skb+0x6cc/0xcf0 net/ipv6/ip6_output.c:1775
udpv6_sendmsg+0x3f8e/0x45d0 net/ipv6/udp.c:1384
inet_sendmsg+0x54a/0x720 net/ipv4/af_inet.c:798
sock_sendmsg net/socket.c:631 [inline]
__sys_sendto+0x8c4/0xac0 net/socket.c:1788
__do_sys_sendto net/socket.c:1800 [inline]
__se_sys_sendto+0x107/0x130 net/socket.c:1796
__x64_sys_sendto+0x6e/0x90 net/socket.c:1796
Bytes 4-7 of 28 are uninitialized
Memory access of size 28 starts at ffff8881937bfce0
Data copied to user address 0000000020000000
[ Upstream commit fb24274546310872eeeaf3d1d53799d8414aa0f2 ]
syzbot reported the use of uninitialized udp6_addr::sin6_scope_id.
We can just set ::sin6_scope_id to zero, as tunnels are unlikely
to use an IPv6 address that needs a scope id and there is no
interface to bind in this context.
For net-next, it looks different as we have cfg->bind_ifindex there
so we can probably call ipv6_iface_scope_id().
Same for ::sin6_flowinfo, tunnels don't use it.
Fixes: 8024e02879dd ("udp: Add udp_sock_create for UDP tunnels to open listener socket")
Reported-by: syzbot+c56449ed3652e6720f30@syzkaller.appspotmail.com
Cc: Jon Maloy <jon.maloy@ericsson.com>
