path: root/net/ipv6
2008-05-21net: The world is not perfect patch.Rami Rosen
Unless there will be any objection here, I suggest consider the following patch which simply removes the code for the -DI_WISH_WORLD_WERE_PERFECT in the three methods which use it. The compilation errors we get when using -DI_WISH_WORLD_WERE_PERFECT show that this code was not built and not used for really a long time. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20ipsec: Use the correct ip_local_out functionHerbert Xu
Because the IPsec output function xfrm_output_resume does its own dst_output call it should always call __ip_local_output instead of ip_local_output as the latter may invoke dst_output directly. Otherwise the return values from nf_hook and dst_output may clash as they both use the value 1 but for different purposes. When that clash occurs this can cause a packet to be used after it has been freed which usually leads to a crash. Because the offending value is only returned from dst_output with qdiscs such as HTB, this bug is normally not visible. Thanks to Marco Berizzi for his perseverance in tracking this down. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-19ipv6 addrconf: Allow infinite prefix lifetime.YOSHIFUJI Hideaki
We need to handle infinite prefix lifetime specially. With help from original reporter "Bonitch, Joseph" <Joseph.Bonitch@xerox.com>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-19ipv6 route: Fix lifetime in netlink.YOSHIFUJI Hideaki
We could not see appropriate lifetime if the route had been scheduled to expired at 0 (in jiffies). We should check rt6i_flags instead of rt6i_expires to determine whether lifetime is valid or not. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-19ipv6 addrconf: Fix route lifetime setting in corner case.YOSHIFUJI Hideaki
Because of arithmetic overflow avoidance, the actual lifetime setting (vs the value given by RA) did not increase monotonically around 0x7fffffff/HZ. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-19ndisc: Add missing strategies for per-device retrans timer/reachable time ↵YOSHIFUJI Hideaki
settings. Noticed from Al Viro <viro@ftp.linux.org.uk> via David Miller <davem@davemloft.net>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12net: Allow netdevices to specify needed head/tailroomJohannes Berg
This patch adds needed_headroom/needed_tailroom members to struct net_device and updates many places that allocate sbks to use them. Not all of them can be converted though, and I'm sure I missed some (I mostly grepped for LL_RESERVED_SPACE) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-08sit: Add missing kfree_skb() on pskb_may_pull() failure.David S. Miller
Noticed by Paul Marks <paul@pmarks.net>. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-04ip: Use inline function dst_metric() instead of direct access to dst->metric[]Satoru SATOH
There are functions to refer to the value of dst->metric[THE_METRIC-1] directly without use of a inline function "dst_metric" defined in net/dst.h. The following patch changes them to use the inline function consistently. Signed-off-by: Satoru SATOH <satoru.satoh@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02netns: Fix reassembly timer to use the right namespaceDaniel Lezcano
This trivial fix retrieves the network namespace from frag queue and use it to get the network device in the right namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02ipv6: assign PDE->data before gluing PDE into /proc treeDenis V. Lunev
Simply replace proc_create and further data assigned with proc_create_data. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: ipv6: Compilation fix for compat MCAST_MSFILTER sockopts.
2008-04-30ipv6: Compilation fix for compat MCAST_MSFILTER sockopts.Pavel Emelyanov
The last hunk from the commit dae50295 (ipv4/ipv6 compat: Fix SSM applications on 64bit kernels.) escaped from the compat_ipv6_setsockopt to the ipv6_getsockopt (I guess due to patch smartness wrt searching for context) thus breaking 32-bit and 64-bit-without-compat compilation. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (53 commits) tcp: Overflow bug in Vegas [IPv4] UFO: prevent generation of chained skb destined to UFO device iwlwifi: move the selects to the tristate drivers ipv4: annotate a few functions __init in ipconfig.c atm: ambassador: vcc_sf semaphore to mutex MAINTAINERS: The socketcan-core list is subscribers-only. netfilter: nf_conntrack: padding breaks conntrack hash on ARM ipv4: Update MTU to all related cache entries in ip_rt_frag_needed() sch_sfq: use del_timer_sync() in sfq_destroy() net: Add compat support for getsockopt (MCAST_MSFILTER) net: Several cleanups for the setsockopt compat support. ipvs: fix oops in backup for fwmark conn templates bridge: kernel panic when unloading bridge module bridge: fix error handling in br_add_if() netfilter: {nfnetlink,ip,ip6}_queue: fix skb_over_panic when enlarging packets netfilter: x_tables: fix net namespace leak when reading /proc/net/xxx_tables_names netfilter: xt_TCPOPTSTRIP: signed tcphoff for ipv6_skip_exthdr() retval tcp: Limit cwnd growth when deferring for GSO tcp: Allow send-limited cwnd to grow up to max_burst when gso disabled [netdrvr] gianfar: Determine TBIPA value dynamically ...
2008-04-29net: Add compat support for getsockopt (MCAST_MSFILTER)David L Stevens
This patch adds support for getsockopt for MCAST_MSFILTER for both IPv4 and IPv6. It depends on the previous setsockopt patch, and uses the same method. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29netfilter: {nfnetlink,ip,ip6}_queue: fix skb_over_panic when enlarging packetsArnaud Ebalard
While reinjecting *bigger* modified versions of IPv6 packets using libnetfilter_queue, things work fine on a 2.6.24 kernel (2.6.22 too) but I get the following on recents kernels (2.6.25, trace below is against today's net-2.6 git tree): skb_over_panic: text:c04fddb0 len:696 put:632 head:f7592c00 data:f7592c00 tail:0xf7592eb8 end:0xf7592e80 dev:eth0 ------------[ cut here ]------------ invalid opcode: 0000 [#1] PREEMPT Process sendd (pid: 3657, ti=f6014000 task=f77c31d0 task.ti=f6014000) Stack: c071e638 c04fddb0 000002b8 00000278 f7592c00 f7592c00 f7592eb8 f7592e80 f763c000 f6bc5200 f7592c40 f6015c34 c04cdbfc f6bc5200 00000278 f6015c60 c04fddb0 00000020 f72a10c0 f751b420 00000001 0000000a 000002b8 c065582c Call Trace: [<c04fddb0>] ? nfqnl_recv_verdict+0x1c0/0x2e0 [<c04cdbfc>] ? skb_put+0x3c/0x40 [<c04fddb0>] ? nfqnl_recv_verdict+0x1c0/0x2e0 [<c04fd115>] ? nfnetlink_rcv_msg+0xf5/0x160 [<c04fd03e>] ? nfnetlink_rcv_msg+0x1e/0x160 [<c04fd020>] ? nfnetlink_rcv_msg+0x0/0x160 [<c04f8ed7>] ? netlink_rcv_skb+0x77/0xa0 [<c04fcefc>] ? nfnetlink_rcv+0x1c/0x30 [<c04f8c73>] ? netlink_unicast+0x243/0x2b0 [<c04cfaba>] ? memcpy_fromiovec+0x4a/0x70 [<c04f9406>] ? netlink_sendmsg+0x1c6/0x270 [<c04c8244>] ? sock_sendmsg+0xc4/0xf0 [<c011970d>] ? set_next_entity+0x1d/0x50 [<c0133a80>] ? autoremove_wake_function+0x0/0x40 [<c0118f9e>] ? __wake_up_common+0x3e/0x70 [<c0342fbf>] ? n_tty_receive_buf+0x34f/0x1280 [<c011d308>] ? __wake_up+0x68/0x70 [<c02cea47>] ? copy_from_user+0x37/0x70 [<c04cfd7c>] ? verify_iovec+0x2c/0x90 [<c04c837a>] ? sys_sendmsg+0x10a/0x230 [<c011967a>] ? __dequeue_entity+0x2a/0xa0 [<c011970d>] ? set_next_entity+0x1d/0x50 [<c0345397>] ? pty_write+0x47/0x60 [<c033d59b>] ? tty_default_put_char+0x1b/0x20 [<c011d2e9>] ? __wake_up+0x49/0x70 [<c033df99>] ? tty_ldisc_deref+0x39/0x90 [<c033ff20>] ? tty_write+0x1a0/0x1b0 [<c04c93af>] ? sys_socketcall+0x7f/0x260 [<c0102ff9>] ? sysenter_past_esp+0x6a/0x91 [<c05f0000>] ? snd_intel8x0m_probe+0x270/0x6e0 ======================= Code: 00 00 89 5c 24 14 8b 98 9c 00 00 00 89 54 24 0c 89 5c 24 10 8b 40 50 89 4c 24 04 c7 04 24 38 e6 71 c0 89 44 24 08 e8 c4 46 c5 ff <0f> 0b eb fe 55 89 e5 56 89 d6 53 89 c3 83 ec 0c 8b 40 50 39 d0 EIP: [<c04ccdfc>] skb_over_panic+0x5c/0x60 SS:ESP 0068:f6015bf8 Looking at the code, I ended up in nfq_mangle() function (called by nfqnl_recv_verdict()) which performs a call to skb_copy_expand() due to the increased size of data passed to the function. AFAICT, it should ask for 'diff' instead of 'diff - skb_tailroom(e->skb)'. Because the resulting sk_buff has not enough space to support the skb_put(skb, diff) call a few lines later, this results in the call to skb_over_panic(). The patch below asks for allocation of a copy with enough space for mangled packet and the same amount of headroom as old sk_buff. While looking at how the regression appeared (e2b58a67), I noticed the same pattern in ipq_mangle_ipv6() and ipq_mangle_ipv4(). The patch corrects those locations too. Tested with bigger reinjected IPv6 packets (nfqnl_mangle() path), things are ok (2.6.25 and today's net-2.6 git tree). Signed-off-by: Arnaud Ebalard <arno@natisbad.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: iwlwifi: Allow building iwl3945 without iwl4965. wireless: Fix compile error with wifi & leds tcp: Fix slab corruption with ipv6 and tcp6fuzz ipv4/ipv6 compat: Fix SSM applications on 64bit kernels. [IPSEC]: Use digest_null directly for auth sunrpc: fix missing kernel-doc can: Fix copy_from_user() results interpretation Revert "ipv6: Fix typo in net/ipv6/Kconfig" tipc: endianness annotations ipv6: result of csum_fold() is already 16bit, no need to cast [XFRM] AUDIT: Fix flowlabel text format ambibuity.
2008-04-27ipv4/ipv6 compat: Fix SSM applications on 64bit kernels.David L Stevens
Add support on 64-bit kernels for seting 32-bit compatible MCAST* socket options. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27Revert "ipv6: Fix typo in net/ipv6/Kconfig"David S. Miller
This reverts commit 5b3f129c5592ca35b3fe8916767c58b98710478c. As requested by Maciej W. Rozycki. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27ipv6: result of csum_fold() is already 16bit, no need to castAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (48 commits) net: Fix wrong interpretation of some copy_to_user() results. xfrm: alg_key_len & alg_icv_len should be unsigned [netdrvr] tehuti: move ioctl perm check closer to function start ipv6: Fix typo in net/ipv6/Kconfig via-velocity: fix vlan receipt tg3: sparse cleanup forcedeth: realtek phy crossover detection ibm_newemac: Increase MDIO timeouts gianfar: Fix skb allocation strategy netxen: reduce stack usage of netxen_nic_flash_print smc911x: test after postfix decrement fails in smc911x_{reset,drop_pkt} net drivers: fix platform driver hotplug/coldplug forcedeth: new backoff implementation ehea: make things static phylib: Add support for board-level PHY fixups [netdrvr] atlx: code movement: move atl1 parameter parsing atlx: remove flash vendor parameter korina: misc cleanup korina: fix misplaced return statement WAN: Fix confusing insmod error code for C101 too. ...
2008-04-24ipv6: Fix typo in net/ipv6/KconfigMichael Beasley
Two is used in the wrong context here, as you are connecting to an IPv6 network over IPv4; not connecting two IPv6 networks to an IPv4 one. Signed-off-by: Michael Beasley <youvegotmoxie@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24ipv6 RAW: Disallow IPPROTO_IPV6-level IPV6_CHECKSUM socket option on ICMPv6 ↵YOSHIFUJI Hideaki
sockets. RFC3542 tells that IPV6_CHECKSUM socket option in the IPPROTO_IPV6 level is not allowed on ICMPv6 sockets. IPPROTO_RAW level IPV6_CHECKSUM socket option (a Linux extension) is still allowed. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: iwlwifi: Fix built-in compilation of iwlcore net: Unexport move_addr_to_{kernel,user} rt2x00: Select LEDS_CLASS. iwlwifi: Select LEDS_CLASS. leds: Do not guard NEW_LEDS with HAS_IOMEM [IPSEC]: Fix catch-22 with algorithm IDs above 31 time: Export set_normalized_timespec. tcp: Make use of before macro in tcp_input.c hamradio: Remove unneeded and deprecated cli()/sti() calls in dmascc.c [NETNS]: Remove empty ->init callback. [DCCP]: Convert do_gettimeofday() to getnstimeofday(). [NETNS]: Don't initialize err variable twice. [NETNS]: The ip6_fib_timer can work with garbage on net namespace stop. [IPV4]: Convert do_gettimeofday() to getnstimeofday(). [IPV4]: Make icmp_sk_init() static. [IPV6]: Make struct ip6_prohibit_entry_template static. tcp: Trivial fix to correct function name in a comment in net/ipv4/tcp.c [NET]: Expose netdevice dev_id through sysfs skbuff: fix missing kernel-doc notation [ROSE]: Fix soft lockup wrt. rose_node_list_lock
2008-04-21[NETNS]: Remove empty ->init callback.Pavel Emelyanov
The netns start-stop engine can happily live with any of init or exit callbacks set to NULL. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21[NETNS]: Don't initialize err variable twice.Pavel Emelyanov
The ip6_route_net_init() performs some unneeded actions. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21[NETNS]: The ip6_fib_timer can work with garbage on net namespace stop.Pavel Emelyanov
The del_timer() function doesn't guarantee, that the timer callback is not active by the time it exits. Thus, the fib6_net_exit() may kfree() all the data, that is required by the fib6_run_gc(). The race window is tiny, but slab poisoning can trigger this bug. Using del_timer_sync() will cure this. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21[IPV6]: Make struct ip6_prohibit_entry_template static.Adrian Bunk
This patch makes the needlessly global struct ip6_prohibit_entry_template static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-18net: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18[IPV6]: Fix dangling references on error in fib6_add().David S. Miller
Fixes bugzilla #8895 If a super-tree leaf has 'rt' assigned to it and we get an error from fib6_add_rt2node(), we'll leave a reference to 'rt' in pn->leaf and then do an unconditional dst_free(). We should prune such references. Based upon a report by Vincent Perrier. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-17[INET]: Drop the inet_inherit_port() call.Pavel Emelyanov
As I can see from the code, two places (tcp_v6_syn_recv_sock and dccp_v6_request_recv_sock) that call this one already run with BHs disabled, so it's safe to call __inet_inherit_port there. Besides (in case I missed smth with code review) the calltrace tcp_v6_syn_recv_sock `- tcp_v4_syn_recv_sock `- __inet_inherit_port and the similar for DCCP are valid, but assumes BHs to be disabled. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[NETNS]: Add netns refcnt debug for dst ops.Denis V. Lunev
2008-04-16[IP6TUNNEL]: Allow to create IP6 tunnels in net namespaces.Pavel Emelyanov
And no need in some IPPROTO_XXX enabling, since ipv6 code doesn't have any filtering. So, just set proper net and mark device with NETNS_LOCAL. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[IP6TUNNEL]: Use proper net instead of init_net stubs.Pavel Emelyanov
All the ip_route_output_key(), dev_get_by_...() and ipv6_chk_addr() calls are now stubbed with init_net. Fortunately, all the places already have where to get the proper net from. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[IP6TUNNEL]: Make tunnels hashes per-net.Pavel Emelyanov
Move hashes in the struct ip6_tnl_net, replace tnls_xxx[] with ip6n->tnlx_xxx[] and handle init and exit appropriately. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[IP6TUNNEL]: Make the fallback tunnel device per-net.Pavel Emelyanov
All the code, that reference it already has the ip6_tnl_net pointer, so s/ip6_fb_tnl_dev/ip6n->fb_tnl_dev/ and move creation/releasing code into net init/exit ops. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[IP6TUNNEL]: Use proper net in hash-lookup functions.Pavel Emelyanov
Calls to ip6_tnl_lookup were stubbed with init_net - give them a proper one. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[IP6TUNNEL]: Add (ip6_tnl_)net argument to some calls.Pavel Emelyanov
Hashes and fallback device used in them will be per-net. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[IP6TUNNEL]: Introduce empty ip6_tnl_net structure and net ops.Pavel Emelyanov
2008-04-16[SIT]: Allow to create SIT tunnels in net namespaces.Pavel Emelyanov
Set proper net and mark a new device as NETNS_LOCAL before registering. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[SIT]: Use proper net in routing calls.Pavel Emelyanov
I.e. replace init_net stubs in ip_route_output_key() calls. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[SIT]: Make tunnels hashes per-net.Pavel Emelyanov
Just move all the hashes on the sit_net structure and patch the rest of the code appropriately. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[SIT]: Make the fallback tunnel device per-netPavel Emelyanov
Allocate and register one in sit_init_net, use sitn->fb_tunnel_dev over the code and unregister one in sit_exit_net. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[SIT]: Use proper net in hash-lookup functions.Pavel Emelyanov
Replace introduced in the previous patch init_net stubs with the proper net pointer. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[SIT]: Add net/sit_net argument to some functions.Pavel Emelyanov
... to make them prepared for future hashes and fallback device move on the struct sit_net. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[SIT]: Introduce empty struct sit_net and init/exit net ops.Pavel Emelyanov
2008-04-14Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6.26
2008-04-14[SOCK]: Add some notes about per-bind-bucket sock lookup.Pavel Emelyanov
I was asked about "why don't we perform a sk_net filtering in bind_conflict calls, like we do in other sock lookup places" for a couple of times. Can we please add a comment about why we do not need one? Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-14[NETFILTER]: nf_conntrack: replace NF_CT_DUMP_TUPLE macro indrection by ↵Jan Engelhardt
function call Directly call IPv4 and IPv6 variants where the address family is easily known. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
