git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial fixes from Greg KH:
"Here are some tty and serial driver fixes for 4.0-rc3.
Along with the atime fix that you know about, here are some other
serial driver bugfixes as well. Most notable is a wait_until_sent
bugfix that was traced back to being around since before 2.6.12 that
Johan has fixed up.
All have been in linux-next successfully"
* tag 'tty-4.0-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
TTY: fix tty_wait_until_sent maximum timeout
TTY: fix tty_wait_until_sent on 64-bit machines
USB: serial: fix infinite wait_until_sent timeout
TTY: bfin_jtag_comm: remove incorrect wait_until_sent operation
net: irda: fix wait_until_sent poll timeout
serial: uapi: Declare all userspace-visible io types
serial: core: Fix iotype userspace breakage
serial: sprd: Fix missing spin_unlock in sprd_handle_irq()
console: Fix console name size mismatch
tty: fix up atime/mtime mess, take four
serial: 8250_dw: Fix get_mctrl behaviour
serial:8250:8250_pci: delete unneeded quirk entries
serial:8250:8250_pci: fix redundant entry report for WCH_CH352_2S
Change email address for 8250_pci
serial: 8250: Revert "tty: serial: 8250_core: read only RX if there is something in the FIFO"
Revert "tty/serial: of_serial: add DT alias ID handling"
In case an infinite timeout (0) is requested, the irda wait_until_sent
implementation would use a zero poll timeout rather than the default
200ms.
Note that wait_until_sent is currently never called with a 0-timeout
argument due to a bug in tty_wait_until_sent.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: stable <stable@vger.kernel.org> # v2.6.12
Signed-off-by: Johan Hovold <johan@kernel.org>
Use helper functions to access current->state.
Direct assignments are prone to races and therefore buggy.
current->state = TASK_RUNNING can be replaced by __set_current_state()
Thanks to Peter Zijlstra for the exact definition of the problem.
Suggested-By: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Making things const is a good thing.
(x86-64 defconfig with all irda)
$ size net/irda/built-in.o*
109276 1868 244 111388 1b31c net/irda/built-in.o.new
108828 2316 244 111388 1b31c net/irda/built-in.o.old
Fix the build failures that result from the use of pr_debug
without the referenced char * arrays being defined.
Use the normal kernel debugging mechanism which also
enables dynamic_debug at the same time.
Other miscellanea:
o Remove sysctl for irda_debug
o Remove function tracing like uses (use ftrace instead)
o Coalesce formats
o Realign arguments
o Remove unnecessary OOM messages
And use the more common mechanisms directly.
Other miscellanea:
o Coalesce formats
o Add missing newlines
o Realign arguments
o Remove unnecessary OOM message logging as
there's a generic stack dump already on OOM.
Since at least before 2.6.30, it has not been possible to observe
a hung up file pointer in a tty driver's open() method unless/until
the driver open() releases the tty_lock() (eg., before blocking).
This is because tty_open() adds the file pointer while holding
the tty_lock() _and_ doesn't release the lock until after calling
the tty driver's open() method. [ Before tty_lock(), this was
lock_kernel(). ]
Since __tty_hangup() first waits on the tty_lock() before
enumerating and hanging up the open file pointers, either
__tty_hangup() will wait for the tty_lock() or tty_open() will
not yet have added the file pointer. For example,
CPU 0 | CPU 1
tty_open | __tty_hangup
tty_lock | ..
tty_reopen | tty_lock / blocks
tty_add_file(tty, filp) |
tty->ops->open(tty, filp) |
tty_port_open |
tty_port_block_til_ready |
while (1) |
tty_unlock | / unblocks
schedule | for each filp on tty->tty_files
| f_ops = tty_hung_up_fops;
| tty_unlock
tty_lock |
tty_unlock |
Note that since tty_port_block_til_ready() and similar drop
the tty_lock while blocking, when woken, the file pointer
must then be tested for having been hung up.
Also, fix bit-rotted drivers that used extra_count to track the
port->count bump.
CC: Mikael Starvik <starvik@axis.com>
CC: Samuel Ortiz <samuel@sortiz.org>
CC: "David S. Miller" <davem@davemloft.net>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
Make sure to check ASYNC_INITIALISED before raising DTR when waking up
from blocked open in ircomm_tty_block_til_ready.
Currently DTR could get raised at hang up as a blocked process would
raise DTR unconditionally before checking for hang up and returning.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Hi Greg,
I'm unsure if you or Dave should take that one as it's for one a TTY
patch but also living under net/. So I'm uncertain and let you decide!
Thanks,
Mathias
-- >8 --
Subject: [PATCH] TTY: ircomm, use GFP_KERNEL in ircomm_open()
We're clearly running in non-atomic context as our only call site is
able to call wait_event_interruptible(). So we're safe to use GFP_KERNEL
here instead of GFP_ATOMIC.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
It allows for cleaning up on a considerable amount of places. They did
port_get, hangup, kref_put. Now the only thing needed is to call
tty_port_tty_hangup which does exactly that. And they can also decide
whether to consider CLOCAL or completely ignore that.
DTR/RTS need to be raised, regardless of the open() mode, but not
if the port has already shutdown.
Without a memory and compiler barrier, the task state change
can migrate relative to the condition testing in a blocking loop.
However, the task state change must be visible across all cpus
prior to testing those conditions. Failing to do this can result
in the familiar 'lost wakeup' and this task will hang until killed.
Although tty_lock() already protects concurrent update to
blocked_open, that fails to meet the separation-of-concerns between
tty_port and tty.
Saving the port count bump is unsafe. If the tty is hung up while
this open was blocking, the port count is zeroed.
Explicitly check if the tty was hung up while blocking, and correct
the port count if not.
The option allows you to remove TTY and compile without errors. This
saves space on systems that won't support TTY interfaces anyway.
bloat-o-meter output is below.
The bulk of this patch consists of Kconfig changes adding "depends on
TTY" to various serial devices and similar drivers that require the TTY
layer. Ideally, these dependencies would occur on a common intermediate
symbol such as SERIO, but most drivers "select SERIO" rather than
"depends on SERIO", and "select" does not respect dependencies.
bloat-o-meter output comparing our previous minimal to new minimal by
removing TTY. The list is filtered to not show removed entries with awk
'$3 != "-"' as the list was very long.
add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350)
function old new delta
chr_dev_init 166 170 +4
allow_signal 80 82 +2
static.__warned 143 142 -1
disallow_signal 63 62 -1
__set_special_pids 95 94 -1
unregister_console 126 121 -5
start_kernel 546 541 -5
register_console 593 588 -5
copy_from_user 45 40 -5
sys_setsid 128 120 -8
sys_vhangup 32 19 -13
do_exit 1543 1526 -17
bitmap_zero 60 40 -20
arch_local_irq_save 137 117 -20
release_task 674 652 -22
static.spin_unlock_irqrestore 308 260 -48
Signed-off-by: Joe Millenbach <jmillenbach@gmail.com>
Reviewed-by: Jamey Sharp <jamey@minilop.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Now, we start converting tty buffer functions to actually use
tty_port. This will allow us to get rid of the need of tty in many
call sites. Only tty_port will needed and hence no more
tty_port_tty_get in those paths.
Now, the one where most of tty_port_tty_get gets removed:
tty_flip_buffer_push.
IOW we also closed all the races in drivers not using tty_port_tty_get
at all yet.
Also we move tty_flip_buffer_push declaration from include/linux/tty.h
to include/linux/tty_flip.h to all others while we are changing it
anyway.
One point is to have less places where we actually need tty pointer.
The other is that low_latency is bound to buffer processing and
buffers are now in tty_port. So it makes sense to move low_latency to
tty_port too.
tty_insert_flip_string this time.
After commit "TTY: move tty buffers to tty_port", the tty buffers are
not freed in some drivers. This is because tty_port_destructor is not
called whenever a tty_port is freed. This was an assumption I counted
with but was unfortunately untrue. So fix the drivers to fulfil this
assumption.
To be sure, the TTY buffers (and later some stuff) are gone along with
the tty_port, we have to call tty_port_destroy at tear-down places.
This is mostly where the structure containing a tty_port is freed.
This patch does exactly that -- put tty_port_destroy at those places.
Commit 9c650ffc ("TTY: ircomm_tty, add tty install") split _open() to
_install() and _open(). It also moved the initialization of driver_data
out of open(), but never added it to install() - causing a NULL ptr
deref whenever the driver was used.
Acked-by: Jiri Slaby <jslaby@suse.cz>
In most of the time, the driver needs to check if the cts flow control
is enabled. But now, the driver checks the ASYNC_CTS_FLOW flag manually,
which is not a grace way. So add a new wraper function to make the code
tidy and clean.
Signed-off-by: Huang Shijie <shijie8@gmail.com>
This has two outcomes:
* we give the TTY layer a tty_port
* we do not find the info structure every time open is called on that
tty
Cc: Samuel Ortiz <samuel@sortiz.org>
Acked-by: Alan Cox <alan@linux.intel.com>
This will let us sort out a whole pile of tty related races. The
alternative would be to keep points and refcount the termios objects.
However
1. They are tiny anyway
2. Many devices don't use the stored copies
3. We can remove a pty special case
Signed-off-by: Alan Cox <alan@linux.intel.com>
Again, the code is identical, so leverage the helper code.
Cc: netdev@vger.kernel.org
These will be used by the tty_port wait_til_ready later. (Now they are
used by our code.)
In some functions we use tty_port heavily. So let us have a local
pointer to that variable instead of having self->port all over the
code.
This also includes a switch to tty refcounting. It makes sure, the
code no longer can access a freed TTY struct.
Sometimes the only thing needed is to pass tty down to the callies.
Use self->spinlock only for ctrl_skb and tx_skb. TTY stuff is now
protected by tty_port->lock. This is needed for further cleanup (and
conversion to tty_port helpers).
This also closes the race in the end of close.
Switch to tty_port->flags. And while at it, remove redefined flags for
them.
Switch to tty_port->count and blocked_open.
Switch to tty_port->close_delay and closing_wait.
And use close/open_wait from there.
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
Checking if tty->index is in bounds is not needed. The tty has the
index set in the initial open. This is done in get_tty_driver. And it
can be only in interval <0,driver->num).
So remove the tests which check exactly this interval. Some are
left untouched as they check against the current backing device count.
(Leaving apart that the check is racy in most of the cases.)
All num, magic and owner are set by alloc_tty_driver. No need to
re-set them on each allocation site.
pti driver sets something different to what it passes to
alloc_tty_driver. It is not a bug, since we don't use the lines
parameter in any way. Anyway this is fixed, and now we do the right
thing.
Acked-by: Tilman Schmidt <tilman@imap.cc>
Let's use the newly added helper to avoid stalls in drivers which are
not yet ported to tty_port helpers.
Those which are broken (call tty_wait_until_sent with irqs disabled)
are left untouched. They are in a deeper trouble than we are trying to
solve here. This includes amiserial, 68328serial, 68360serial and
crisv10.
Unnecessary casts of void * clutter the code.
These are the remainder casts after several specific
patches to remove netdev_priv and dev_priv.
Done via coccinelle script:
$ cat cast_void_pointer.cocci
type T;
T *pt;
void *pv;
- pt = (T *)pv;
+ pt = pv;
Acked-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
The variable 'ret' is set but unused, and this pointed out that
errors from irlmp_connect_response() are not propagated to the
caller.
Note that this is currently academic since irlmp_connect_response()
always returns 0. :-)
use tty_insert_flip_string and tty_flip_buffer_push to deliver incoming data
packets from the IrDA device instead of delivering the packets directly to the
line discipline. Following later approach resulted in warning "Sleeping function
called from invalid context".
Signed-off-by: Amit Virdi <amit.virdi@st.com>
Only oddities here are a couple of drivers that bogusly called the ldisc
helpers instead of returning -ENOIOCTLCMD. Fix the bug and the rest goes
away.
Doing tiocmget was such fun we should do tiocmset as well for the same
reasons
We don't actually need this and it causes problems for internal use of
this functionality. Currently there is a single use of the FILE * pointer.
That is the serial core which uses it to check tty_hung_up_p. However if
that is true then IO_ERROR is also already set so the check may be removed.
Changed Makefile to use <modules>-y instead of <modules>-objs
because -objs is deprecated and not mentioned in
Documentation/kbuild/makefiles.txt.
Signed-off-by: Tracey Dent <tdent48227@gmail.com>
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
