path: root/net/irda/irda_device.c
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-06-16net: Remove casts of void *Joe Perches
Unnecessary casts of void * clutter the code. These are the remainder casts after several specific patches to remove netdev_priv and dev_priv. Done via coccinelle script: $ cat cast_void_pointer.cocci @@ type T; T *pt; void *pv; @@ - pt = (T *)pv; + pt = pv; Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-03-21irda: net_device_ops ioctl fixStephen Hemminger
Need to reference net_device_ops not old pointer. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05net: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IrDA]: Irport removal - part 1Adrian Bunk
This patch removes IrPORT and the old dongle drivers (all off them have replacement drivers). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-18[IrDA]: Fix IrDA build failureSamuel Ortiz
When having built-in IrDA, we hit the following error: `irda_sysctl_unregister' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irda_proc_unregister' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irsock_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irttp_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `iriap_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irda_device_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irlap_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irlmp_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o make[1]: *** [.tmp_vmlinux1] Error 1 make: *** [_all] Error 2 This is due to the irda_init fix recently added, where we call __exit routines from an __init one. It is a build failure that I didn't catch because it doesn't show up when building IrDA as a module. My apologies for that. The following patch fixes that failure and is against your net-2.6 tree. I hope it can make it to the merge window, and stable@kernel.org is CCed on this mail. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[IRDA] irda_device_dongle_init: fix kzalloc(GFP_KERNEL) in spinlockAndrew Morton
Fix http://bugzilla.kernel.org/show_bug.cgi?id=8343 Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IRDA: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-09[IRDA]: Set proper IrLAP device address lengthSamuel Ortiz
This patch set IrDA's addr_len properly, i.e to 4 bytes, the size of the IrLAP device address. Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-04[PATCH] ISA DMA Kconfig fixes - part 4 (irda)Al Viro
* net/irda/irda_device.c::irda_setup_dma() made conditional on ISA_DMA_API (it uses helpers in question and irda is usable on platforms that don't have them at all - think of USB IRDA, for example). * irda drivers that depend on ISA DMA marked as dependent on ISA_DMA_API Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] x86_64: Make IRDA devices are not really ISA devices not depend on ↵Andi Kleen
CONFIG_ISA This allows to use them on x86-64 Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] irda_device() oops fixJean Tourrilhes
Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
