path: root/net/irda
2011-09-16IRDA: Fix global type conflicts in net/irda/irsysctl.c v2Andi Kleen
The externs here didn't agree with the declarations in qos.c. Better would be probably to move this into a header, but since it's common practice to have naked externs with sysctls I left it for now. Cc: samuel@sortiz.org Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-rxon.c drivers/net/wireless/rtlwifi/pci.c net/netfilter/ipvs/ip_vs_core.c
2011-06-16net: Remove casts of void *Joe Perches
Unnecessary casts of void * clutter the code. These are the remainder casts after several specific patches to remove netdev_priv and dev_priv. Done via coccinelle script: $ cat cast_void_pointer.cocci @@ type T; T *pt; void *pv; @@ - pt = (T *)pv; + pt = pv; Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-06irda: iriap: Use seperate lockdep class for irias_objects->hb_spinlockDavid S. Miller
The SEQ output functions grab the obj->attrib->hb_spinlock lock of sub-objects found in the hash traversal. These locks are in a different realm than the one used for the irias_objects hash table itself. So put the latter into it's own lockdep class. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-19irda: Fix error propagation in ircomm_lmp_connect_response()David S. Miller
The variable 'ret' is set but unused, and this pointed out that errors from irlmp_connect_response() are not propagated to the caller. Note that this is currently academic since irlmp_connect_response() always returns 0. :-) Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-19irda: Kill set but unused variable 'bytes' in irlan_check_command_param()David S. Miller
2011-05-19irda: Kill set but unused variable 'clen' in ircomm_connect_indication()David S. Miller
2011-05-19irda: Kill set but unused vars 'saddr' and 'daddr' in ↵David S. Miller
irlan_provider_connect_indication() Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12net/irda/ircomm_tty.c: Use flip buffers to deliver dataAmit Virdi
use tty_insert_flip_string and tty_flip_buffer_push to deliver incoming data packets from the IrDA device instead of delivering the packets directly to the line discipline. Following later approach resulted in warning "Sleeping function called from invalid context". Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x_ethtool.c
2011-04-17irda: irproc: Fix set-but-unused variables.David S. Miller
The variable 'd' is set but unused in irda_proc_register(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17irda: irlap_event: Fix set-but-unused variables.David S. Miller
The variable 'ret' is set but unused in irlap_state_sclose(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12irda: fix locking unbalance in irda_sendmsgDave Jones
5b40964eadea40509d353318d2c82e8b7bf5e8a5 ("irda: Remove BKL instances from af_irda.c") introduced a path where we have a locking unbalance. If we pass invalid flags, we unlock a socket we never locked, resulting in this... ===================================== [ BUG: bad unlock balance detected! ] ------------------------------------- trinity/20101 is trying to release lock (sk_lock-AF_IRDA) at: [<ffffffffa057f001>] irda_sendmsg+0x207/0x21d [irda] but there are no more locks to release! other info that might help us debug this: no locks held by trinity/20101. stack backtrace: Pid: 20101, comm: trinity Not tainted 2.6.39-rc3+ #3 Call Trace: [<ffffffffa057f001>] ? irda_sendmsg+0x207/0x21d [irda] [<ffffffff81085041>] print_unlock_inbalance_bug+0xc7/0xd2 [<ffffffffa057f001>] ? irda_sendmsg+0x207/0x21d [irda] [<ffffffff81086aca>] lock_release+0xcf/0x18e [<ffffffff813ed190>] release_sock+0x2d/0x155 [<ffffffffa057f001>] irda_sendmsg+0x207/0x21d [irda] [<ffffffff813e9f8c>] __sock_sendmsg+0x69/0x75 [<ffffffff813ea105>] sock_sendmsg+0xa1/0xb6 [<ffffffff81100ca3>] ? might_fault+0x5c/0xac [<ffffffff81086b7c>] ? lock_release+0x181/0x18e [<ffffffff81100cec>] ? might_fault+0xa5/0xac [<ffffffff81100ca3>] ? might_fault+0x5c/0xac [<ffffffff81133b94>] ? fcheck_files+0xb9/0xf0 [<ffffffff813f387a>] ? copy_from_user+0x2f/0x31 [<ffffffff813f3b70>] ? verify_iovec+0x52/0xa6 [<ffffffff813eb4e3>] sys_sendmsg+0x23a/0x2b8 [<ffffffff81086b7c>] ? lock_release+0x181/0x18e [<ffffffff810773c6>] ? up_read+0x28/0x2c [<ffffffff814bec3d>] ? do_page_fault+0x360/0x3b4 [<ffffffff81087043>] ? trace_hardirqs_on_caller+0x10b/0x12f [<ffffffff810458aa>] ? finish_task_switch+0xb2/0xe3 [<ffffffff8104583e>] ? finish_task_switch+0x46/0xe3 [<ffffffff8108364a>] ? trace_hardirqs_off_caller+0x33/0x90 [<ffffffff814bbaf9>] ? retint_swapgs+0x13/0x1b [<ffffffff81087043>] ? trace_hardirqs_on_caller+0x10b/0x12f [<ffffffff810a9dd3>] ? audit_syscall_entry+0x11c/0x148 [<ffffffff8125609e>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff814c22c2>] system_call_fastpath+0x16/0x1b Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27irda: validate peer name and attribute lengthsDan Rosenberg
Length fields provided by a peer for names and attributes may be longer than the destination array sizes. Validate lengths to prevent stack buffer overflows. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27irda: prevent heap corruption on invalid nicknameDan Rosenberg
Invalid nicknames containing only spaces will result in an underflow in a memcpy size calculation, subsequently destroying the heap and panicking. v2 also catches the case where the provided nickname is longer than the buffer size, which can result in controllable heap corruption. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17tty: now phase out the ioctl file pointer for goodAlan Cox
Only oddities here are a couple of drivers that bogusly called the ldisc helpers instead of returning -ENOIOCTLCMD. Fix the bug and the rest goes away. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmset: kill the file pointer argumentAlan Cox
Doing tiocmget was such fun we should do tiocmset as well for the same reasons Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmget: kill off the passing of the struct fileAlan Cox
We don't actually need this and it causes problems for internal use of this functionality. Currently there is a single use of the FILE * pointer. That is the serial core which uses it to check tty_hung_up_p. However if that is true then IO_ERROR is also already set so the check may be removed. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/fib_frontend.c
2010-12-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) ipv4: dont create routes on down devices epic100: hamachi: yellowfin: Fix skb allocation size sundance: Fix oopses with corrupted skb_shared_info Revert "ipv4: Allow configuring subnets as local addresses" USB: mcs7830: return negative if auto negotiate fails irda: prevent integer underflow in IRLMP_ENUMDEVICES tcp: fix listening_get_next() atl1c: Do not use legacy PCI power management mac80211: fix mesh forwarding MAINTAINERS: email address change net: Fix range checks in tcf_valid_offset(). net_sched: sch_sfq: fix allot handling hostap: remove netif_stop_queue from init mac80211/rt2x00: add ieee80211_tx_status_ni() typhoon: memory corruption in typhoon_get_drvinfo() net: Add USB PID for new MOSCHIP USB ethernet controller MCS7832 variant net_sched: always clone skbs ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed. netlink: fix gcc -Wconversion compilation warning asix: add USB ID for Logitec LAN-GTJ U2A ...
2010-12-23irda: prevent integer underflow in IRLMP_ENUMDEVICESDan Rosenberg
If the user-provided len is less than the expected offset, the IRLMP_ENUMDEVICES getsockopt will do a copy_to_user() with a very large size value. While this isn't be a security issue on x86 because it will get caught by the access_ok() check, it may leak large amounts of kernel heap on other architectures. In any event, this patch fixes it. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22Net: irda: irnet: Makefile: Remove deprecated kbuild goal definitionsTracey Dent
Changed Makefile to use <modules>-y instead of <modules>-objs because -objs is deprecated and not mentioned in Documentation/kbuild/makefiles.txt. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22Net: irda: irlan: Makefile: Remove deprecated kbuild goal definitionsTracey Dent
2010-11-22Net: irda: ircomm: Makefile: Remove deprecated kbuild goal defintionsTracey Dent
2010-11-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (31 commits) net: fix kernel-doc for sk_filter_rcu_release be2net: Fix to avoid firmware update when interface is not open. netfilter: fix IP_VS dependencies net: irda: irttp: sync error paths of data- and udata-requests ipv6: Expose reachable and retrans timer values as msecs ipv6: Expose IFLA_PROTINFO timer values in msecs instead of jiffies 3c59x: fix build failure on !CONFIG_PCI ipg.c: remove id [SUNDANCE, 0x1021] net: caif: spi: fix potential NULL dereference ath9k_htc: Avoid setting QoS control for non-QoS frames net: zero kobject in rx_queue_release net: Fix duplicate volatile warning. MAINTAINERS: Add stmmac maintainer bonding: fix a race in IGMP handling cfg80211: fix can_beacon_sec_chan, reenable HT40 gianfar: fix signedness issue net: bnx2x: fix error value sign 8139cp: fix checksum broken r8169: fix checksum broken rds: Integer overflow in RDS cmsg handling ...
2010-11-18net: irda: irttp: sync error paths of data- and udata-requestsWolfram Sang
irttp_data_request() returns meaningful errorcodes, while irttp_udata_request() just returns -1 in similar situations. Sync the two and the loglevels of the accompanying output. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-16irda: irttp: allow zero byte packetsWolfram Sang
Sending zero byte packets is not neccessarily an error (AF_INET accepts it, too), so just apply a shortcut. This was discovered because of a non-working software with WINE. See http://bugs.winehq.org/show_bug.cgi?id=19397#c86 http://thread.gmane.org/gmane.linux.irda.general/1643 for very detailed debugging information and a testcase. Kudos to Wolfgang for those! Reported-by: Wolfgang Schwotzer <wolfgang.schwotzer@gmx.net> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Mike Evans <mike.evans@cardolan.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-11irda: Fix heap memory corruption in iriap.cSamuel Ortiz
While parsing the GetValuebyClass command frame, we could potentially write passed the skb->data pointer. Cc: stable@kernel.org Reported-by: Ilja Van Sprundel <ivansprundel@ioactive.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
2010-10-11irda: Fix parameter extraction stack overflowSamuel Ortiz
2010-10-11irda: Remove BKL instances from irnetSamuel Ortiz
The code intends to lock the irnet_socket, so adding a mutex to it allows for a complet BKL removal. Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
2010-10-11irda: Remove BKL instances from af_irda.cSamuel Ortiz
Most of the times, lock_kernel() was pointless or could simply be replaced by lock_sock(). Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23Fix typo configue => configure in commentsThomas Weber
Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-15irda/irnet: use noop_llseekArnd Bergmann
There may be applications trying to seek on the irnet character device, so we should use noop_llseek to avoid returning an error when the default llseek changes to no_llseek. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-14net/irda: Use static const char * const where possibleJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/main.c
2010-09-07irda: off by oneDan Carpenter
This is an off by one. We would go past the end when we NUL terminate the "value" string at end of the function. The "value" buffer is allocated in irlan_client_parse_response() or irlan_provider_parse_command(). CC: stable@kernel.org Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-30irda: Correctly clean up self->ias_obj on irda_bind() failure.David S. Miller
If irda_open_tsap() fails, the irda_bind() code tries to destroy the ->ias_obj object by hand, but does so wrongly. In particular, it fails to a) release the hashbin attached to the object and b) reset the self->ias_obj pointer to NULL. Fix both problems by using irias_delete_object() and explicitly setting self->ias_obj to NULL, just as irda_release() does. Reported-by: Tavis Ormandy <taviso@cmpxchg8b.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-21irda: use net_device_stats from struct net_deviceEric Dumazet
struct net_device has its own struct net_device_stats member, so use this one instead of a private copy in the irlan_cb struct. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19irda: fix a race in irlan_eth_xmit()Eric Dumazet
After skb is queued, its illegal to dereference it. Cache skb->len into a temporary variable. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-04ppp: make channel_ops conststephen hemminger
The PPP channel ops structure should be const. Cleanup the declarations to use standard C99 format. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net/irda: Remove unnecessary casts of private_dataJoe Perches
2010-06-12irttp: Print device parameters and statistics as unsignedBen Hutchings
Device statistics have type unsigned long and several of the device-specific parameters printed here have type __u32. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
