path: root/net/iucv
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-14net: delete __cpuinit usage from all net filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. This removes all the net/* uses of the __cpuinit macros from all C files. [1] https://lkml.org/lkml/2013/5/20/589 Cc: "David S. Miller" <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-08af_iucv: fix recvmsg by replacing skb_pull() functionUrsula Braun
When receiving data messages, the "BUG_ON(skb->len < skb->data_len)" in the skb_pull() function triggers a kernel panic. Replace the skb_pull logic by a per skb offset as advised by Eric Dumazet. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <blaschka@linux.vnet.ibm.com> Reviewed-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/nfc/microread/mei.c net/netfilter/nfnetlink_queue_core.c Pull in 'net' to get Eric Biederman's AF_UNIX fix, upon which some cleanups are going to go on-top. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07iucv: Fix missing msg_namelen update in iucv_sock_recvmsg()Mathias Krause
The current code does not fill the msg_name member in case it is set. It also does not set the msg_namelen member to 0 and therefore makes net/socket.c leak the local, uninitialized sockaddr_storage variable to userland -- 128 bytes of kernel stack memory. Fix that by simply setting msg_namelen to 0 as obviously nobody cared about iucv_sock_recvmsg() not filling the msg_name in case it was set. Cc: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-02net: fix smatch warnings inside datagram_pollJacob Keller
Commit 7d4c04fc170087119727119074e72445f2bb192b ("net: add option to enable error queue packets waking select") has an issue due to operator precedence causing the bit-wise OR to bind to the sock_flags call instead of the result of the terniary conditional. This fixes the *_poll functions to work properly. The old code results in "mask |= POLLPRI" instead of what was intended, which is to only include POLLPRI when the socket option is enabled. Signed-off-by: Jacob Keller <jacob.e.keller@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-31net: add option to enable error queue packets waking selectKeller, Jacob E
Currently, when a socket receives something on the error queue it only wakes up the socket on select if it is in the "read" list, that is the socket has something to read. It is useful also to wake the socket if it is in the error list, which would enable software to wait on error queue packets without waking up for regular data on the socket. The main use case is for receiving timestamped transmit packets which return the timestamp to the socket via the error queue. This enables an application to select on the socket for the error queue only instead of for the regular traffic. -v2- * Added the SO_SELECT_ERR_QUEUE socket option to every architechture specific file * Modified every socket poll function that checks error queue Signed-off-by: Jacob Keller <jacob.e.keller@intel.com> Cc: Jeffrey Kirsher <jeffrey.t.kirsher@intel.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Matthew Vick <matthew.vick@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-14iucv: fix kernel panic at rebootHendrik Brueckner
The iucv base layer is initialized during the registration of the first iucv handler. If no handler is registered and the iucv_reboot_event() notifier is called, a missing check can cause a kernel panic in iucv_block_cpu(). To solve this issue, check the IRQ masks invoke iucv_block_cpu() for enabled CPUs only. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-08s390/irq: remove split irq fields from /proc/statHeiko Carstens
Now that irq sum accounting for /proc/stat's "intr" line works again we have the oddity that the sum field (first field) contains only the sum of the second (external irqs) and third field (I/O interrupts). The reason for that is that these two fields are already sums of all other fields. So if we would sum up everything we would count every interrupt twice. This is broken since the split interrupt accounting was merged two years ago: 052ff461c8427629aee887ccc27478fc7373237c "[S390] irq: have detailed statistics for interrupt types". To fix this remove the split interrupt fields from /proc/stat's "intr" line again and only have them in /proc/interrupts. This restores the old behaviour, seems to be the only sane fix and mimics a behaviour from other architectures where /proc/interrupts also contains more than /proc/stat's "intr" line does. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-06-15net: remove skb_orphan_try()Eric Dumazet
Orphaning skb in dev_hard_start_xmit() makes bonding behavior unfriendly for applications sending big UDP bursts : Once packets pass the bonding device and come to real device, they might hit a full qdisc and be dropped. Without orphaning, the sender is automatically throttled because sk->sk_wmemalloc reaches sk->sk_sndbuf (assuming sk_sndbuf is not too big) We could try to defer the orphaning adding another test in dev_hard_start_xmit(), but all this seems of little gain, now that BQL tends to make packets more likely to be parked in Qdisc queues instead of NIC TX ring, in cases where performance matters. Reverts commits : fc6055a5ba31 net: Introduce skb_orphan_try() 87fd308cfc6b net: skb_tx_hash() fix relative to skb_orphan_try() and removes SKBTX_DRV_NEEDS_SK_REF flag Reported-and-bisected-by: Jean-Michel Hautbois <jhautbois@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Oliver Hartkopp <socketcan@hartkopp.net> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 patches from Martin Schwidefsky: "The biggest patch is the rework of the smp code, something I wanted to do for some time. There are some patches for our various dump methods and one new thing: z/VM LGR detection. LGR stands for linux-guest- relocation and is the guest migration feature of z/VM. For debugging purposes we keep a log of the systems where a specific guest has lived." Fix up trivial conflict in arch/s390/kernel/smp.c due to the scheduler cleanup having removed some code next to removed s390 code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: [S390] kernel: Pass correct stack for smp_call_ipl_cpu() [S390] Ensure that vmcore_info pointer is never accessed directly [S390] dasd: prevent validate server for offline devices [S390] Remove monolithic build option for zcrypt driver. [S390] stack dump: fix indentation in output [S390] kernel: Add OS info memory interface [S390] Use block_sigmask() [S390] kernel: Add z/VM LGR detection [S390] irq: external interrupt code passing [S390] irq: set __ARCH_IRQ_EXIT_IRQS_DISABLED [S390] zfcpdump: Implement async sdias event processing [S390] Use copy_to_absolute_zero() instead of "stura/sturg" [S390] rework idle code [S390] rework smp code [S390] rename lowcore field [S390] Fix gcc 4.6.0 compile warning
2012-03-11[S390] irq: external interrupt code passingHeiko Carstens
The external interrupt handlers have a parameter called ext_int_code. Besides the name this paramter does not only contain the ext_int_code but in addition also the "cpu address" (POP) which caused the external interrupt. To make the code a bit more obvious pass a struct instead so the called function can easily distinguish between external interrupt code and cpu address. The cpu address field however is named "subcode" since some external interrupt sources do not pass a cpu address but a different parameter (or none at all). Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-03-07af_iucv: add shutdown for HS transportUrsula Braun
AF_IUCV sockets offer a shutdown function. This patch makes sure shutdown works for HS transport as well. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-07af_iucv: handle netdev eventsUrsula Braun
In case of transport through HiperSockets the underlying network interface may switch to DOWN state or the underlying network device may recover. In both cases the socket must change to IUCV_DISCONN state. If the interface goes down, af_iucv has a chance to notify its connection peer in addition. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-08af_iucv: allow retrieval of maximum message sizeUrsula Braun
For HS transport the maximum message size depends on the MTU-size of the HS-device bound to the AF_IUCV socket. This patch adds a getsockopt option MSGSIZE returning the maximum message size that can be handled for this AF_IUCV socket. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-08af_iucv: change net_device handling for HS transportUrsula Braun
This patch saves the net_device in the iucv_sock structure during bind in order to fasten skb sending. In addition some other small improvements are made for HS transport: - error checking when sending skbs - locking changes in afiucv_hs_callback_txnotify - skb freeing in afiucv_hs_callback_txnotify And finally it contains code cleanup to get rid of iucv_skb_queue_purge. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-08af_iucv: block writing if msg limit is exceededUrsula Braun
When polling on an AF_IUCV socket, writing should be blocked if the number of pending messages exceeds a defined limit. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-08af_iucv: remove IUCV-pathes completelyUrsula Braun
A SEVER is missing in the callback of a receiving SEVERED. This may inhibit z/VM to remove the corresponding IUCV-path completely. This patch adds a SEVER in iucv_callback_connrej (together with additional locking. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-20af_iucv: get rid of state IUCV_SEVEREDUrsula Braun
af_iucv differs unnecessarily between state IUCV_SEVERED and IUCV_DISCONN. This patch removes state IUCV_SEVERED. While simplifying af_iucv, this patch removes the 2nd invocation of cpcmd as well. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-20af_iucv: remove unused timer infrastructureUrsula Braun
af_iucv contains timer infrastructure which is not exploited. This patch removes the timer related code parts. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-20af_iucv: release reference to HS deviceUrsula Braun
For HiperSockets transport skbs sent are bound to one of the available HiperSockets devices. Add missing release of reference to a HiperSockets device before freeing an skb. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-20af_iucv: accelerate close for HS transportUrsula Braun
Closing an af_iucv socket may wait for confirmation of outstanding send requests. This patch adds confirmation code for the new HiperSockets transport. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-20af_iucv: support ancillary data with HS transportUrsula Braun
The AF_IUCV address family offers support for ancillary data. This patch enables usage of ancillary data with the new HiperSockets transport. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-13net: more accurate skb truesizeEric Dumazet
skb truesize currently accounts for sk_buff struct and part of skb head. kmalloc() roundings are also ignored. Considering that skb_shared_info is larger than sk_buff, its time to take it into account for better memory accounting. This patch introduces SKB_TRUESIZE(X) macro to centralize various assumptions into a single place. At skb alloc phase, we put skb_shared_info struct at the exact end of skb head, to allow a better use of memory (lowering number of reallocations), since kmalloc() gives us power-of-two memory blocks. Unless SLUB/SLUB debug is active, both skb->head and skb_shared_info are aligned to cache lines, as before. Note: This patch might trigger performance regressions because of misconfigured protocol stacks, hitting per socket or global memory limits that were previously not reached. But its a necessary step for a more accurate memory accounting. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Andi Kleen <ak@linux.intel.com> CC: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-13af_iucv: add HiperSockets transportUrsula Braun
The current transport mechanism for af_iucv is the z/VM offered communications facility IUCV. To provide equivalent support when running Linux in an LPAR, HiperSockets transport is added to the AF_IUCV address family. It requires explicit binding of an AF_IUCV socket to a HiperSockets device. A new packet_type ETH_P_AF_IUCV is announced. An af_iucv specific transport header is defined preceding the skb data. A small protocol is implemented for connecting and for flow control/congestion management. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Reviewed-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-13af_iucv: cleanup - use iucv_sk(sk) earlyUrsula Braun
Code cleanup making make use of local variable for struct iucv_sock. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-13af_iucv: use loadable iucv interfaceFrank Blaschka
For future af_iucv extensions the module should be able to run in LPAR mode too. For this we use the new dynamic loading iucv interface. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-13iucv: kernel option for z/VM IUCV and HiperSocketsUrsula Braun
When adding HiperSockets transport to AF_IUCV Sockets, af_iucv either depends on IUCV or QETH_L3 (or both). This patch introduces the necessary changes for kernel configuration. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-13iucv: introduce loadable iucv interfaceFrank Blaschka
This patch adds a symbol to dynamically load iucv functions. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24[S390] iucv cr0 enablement bitMartin Schwidefsky
Do not set the cr0 enablement bit for iucv by default in head[31|64].S, move the enablement to iucv_init in the iucv base layer. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-26[S390] irq: merge irq.c and s390_ext.cHeiko Carstens
Merge irq.c and s390_ext.c into irq.c. That way all external interrupt related functions are together. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-13convert old cpumask API into new oneKOSAKI Motohiro
Adapt new API. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13af_iucv: get rid of compile warningUrsula Braun
-Wunused-but-set-variable generates compile warnings. The affected variables are removed. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13iucv: get rid of compile warningUrsula Braun
-Wunused-but-set-variable generates a compile warning. The affected variable is removed. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-05[S390] irq: have detailed statistics for interrupt typesHeiko Carstens
Up to now /proc/interrupts only has statistics for external and i/o interrupts but doesn't split up them any further. This patch adds a line for every single interrupt source so that it is possible to easier tell what the machine is/was doing. Part of the output now looks like this; CPU0 CPU2 CPU4 EXT: 3898 4232 2305 I/O: 782 315 245 CLK: 1029 1964 727 [EXT] Clock Comparator IPI: 2868 2267 1577 [EXT] Signal Processor TMR: 0 0 0 [EXT] CPU Timer TAL: 0 0 0 [EXT] Timing Alert PFL: 0 0 0 [EXT] Pseudo Page Fault [...] NMI: 0 1 1 [NMI] Machine Checks Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-25[S390] cleanup lowcore access from external interruptsMartin Schwidefsky
Read external interrupts parameters from the lowcore in the first level interrupt handler in entry[64].S. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-06-03net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in net/ and include/ (except netfilter) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (22 commits) netlink: bug fix: wrong size was calculated for vfinfo list blob netlink: bug fix: don't overrun skbs on vf_port dump xt_tee: use skb_dst_drop() netdev/fec: fix ifconfig eth0 down hang issue cnic: Fix context memory init. on 5709. drivers/net: Eliminate a NULL pointer dereference drivers/net/hamradio: Eliminate a NULL pointer dereference be2net: Patch removes redundant while statement in loop. ipv6: Add GSO support on forwarding path net: fix __neigh_event_send() vhost: fix the memory leak which will happen when memory_access_ok fails vhost-net: fix to check the return value of copy_to/from_user() correctly vhost: fix to check the return value of copy_to/from_user() correctly vhost: Fix host panic if ioctl called with wrong index net: fix lock_sock_bh/unlock_sock_bh net/iucv: Add missing spin_unlock net: ll_temac: fix checksum offload logic net: ll_temac: fix interrupt bug when interrupt 0 is used sctp: dubious bitfields in sctp_transport ipmr: off by one in __ipmr_fill_mroute() ...
2010-05-27iucv: convert cpu notifier to return encapsulate errno valueAkinobu Mita
By the previous modification, the cpu notifier can return encapsulate errno value. This converts the cpu notifiers for iucv. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26net/iucv: Add missing spin_unlockJulia Lawall
Add a spin_unlock missing on the error path. There seems like no reason why the lock should continue to be held if the kzalloc fail. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E1; @@ * spin_lock(E1,...); <+... when != E1 if (...) { ... when != E1 * return ...; } ...+> * spin_unlock(E1,...); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-01net: sock_def_readable() and friends RCU conversionEric Dumazet
sk_callback_lock rwlock actually protects sk->sk_sleep pointer, so we need two atomic operations (and associated dirtying) per incoming packet. RCU conversion is pretty much needed : 1) Add a new structure, called "struct socket_wq" to hold all fields that will need rcu_read_lock() protection (currently: a wait_queue_head_t and a struct fasync_struct pointer). [Future patch will add a list anchor for wakeup coalescing] 2) Attach one of such structure to each "struct socket" created in sock_alloc_inode(). 3) Respect RCU grace period when freeing a "struct socket_wq" 4) Change sk_sleep pointer in "struct sock" by sk_wq, pointer to "struct socket_wq" 5) Change sk_sleep() function to use new sk->sk_wq instead of sk->sk_sleep 6) Change sk_has_sleeper() to wq_has_sleeper() that must be used inside a rcu_read_lock() section. 7) Change all sk_has_sleeper() callers to : - Use rcu_read_lock() instead of read_lock(&sk->sk_callback_lock) - Use wq_has_sleeper() to eventually wakeup tasks. - Use rcu_read_unlock() instead of read_unlock(&sk->sk_callback_lock) 8) sock_wake_async() is modified to use rcu protection as well. 9) Exceptions : macvtap, drivers/net/tun.c, af_unix use integrated "struct socket_wq" instead of dynamically allocated ones. They dont need rcu freeing. Some cleanups or followups are probably needed, (possible sk_callback_lock conversion to a spinlock for example...). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-13iucv: add work_queue cleanup for suspendUrsula Braun
If iucv_work_queue is not empty during kernel freeze, a kernel panic occurs. This suspend-patch adds flushing of the work queue for pending connection requests and severing of remaining pending connections. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
