[ Upstream commit eed4d839b0cdf9d84b0a9bc63de90fd5e1e886fb ]
Use dst_entry held by sk_dst_get() to retrieve tunnel's PMTU.
The dst_mtu(__sk_dst_get(tunnel->sock)) call was racy. __sk_dst_get()
could return NULL if tunnel->sock->sk_dst_cache was reset just before the
call, thus making dst_mtu() dereference a NULL pointer:
[ 1937.661598] BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
[ 1937.664005] IP: [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] PGD daf0c067 PUD d9f93067 PMD 0
[ 1937.664005] Oops: 0000 [#1] SMP
[ 1937.664005] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core ip6table_filter ip6_tables iptable_filter ip_tables ebtable_nat ebtables x_tables udp_tunnel pppoe pppox ppp_generic slhc deflate ctr twofish_generic twofish_x86_64_3way xts lrw gf128mul glue_helper twofish_x86_64 twofish_common blowfish_generic blowfish_x86_64 blowfish_common des_generic cbc xcbc rmd160 sha512_generic hmac crypto_null af_key xfrm_algo 8021q garp bridge stp llc tun atmtcp clip atm ext3 mbcache jbd iTCO_wdt coretemp kvm_intel iTCO_vendor_support kvm pcspkr evdev ehci_pci lpc_ich mfd_core i5400_edac edac_core i5k_amb shpchp button processor thermal_sys xfs crc32c_generic libcrc32c dm_mod usbhid sg hid sr_mod sd_mod cdrom crc_t10dif crct10dif_common ata_generic ahci ata_piix tg3 libahci libata uhci_hcd ptp ehci_hcd pps_core usbcore scsi_mod libphy usb_common [last unloaded: l2tp_core]
[ 1937.664005] CPU: 0 PID: 10022 Comm: l2tpstress Tainted: G O 3.17.0-rc1 #1
[ 1937.664005] Hardware name: HP ProLiant DL160 G5, BIOS O12 08/22/2008
[ 1937.664005] task: ffff8800d8fda790 ti: ffff8800c43c4000 task.ti: ffff8800c43c4000
[ 1937.664005] RIP: 0010:[<ffffffffa049db88>] [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] RSP: 0018:ffff8800c43c7de8 EFLAGS: 00010282
[ 1937.664005] RAX: ffff8800da8a7240 RBX: ffff8800d8c64600 RCX: 000001c325a137b5
[ 1937.664005] RDX: 8c6318c6318c6320 RSI: 000000000000010c RDI: 0000000000000000
[ 1937.664005] RBP: ffff8800c43c7ea8 R08: 0000000000000000 R09: 0000000000000000
[ 1937.664005] R10: ffffffffa048e2c0 R11: ffff8800d8c64600 R12: ffff8800ca7a5000
[ 1937.664005] R13: ffff8800c439bf40 R14: 000000000000000c R15: 0000000000000009
[ 1937.664005] FS: 00007fd7f610f700(0000) GS:ffff88011a600000(0000) knlGS:0000000000000000
[ 1937.664005] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 1937.664005] CR2: 0000000000000020 CR3: 00000000d9d75000 CR4: 00000000000027e0
[ 1937.664005] Stack:
[ 1937.664005] ffffffffa049da80 ffff8800d8fda790 000000000000005b ffff880000000009
[ 1937.664005] ffff8800daf3f200 0000000000000003 ffff8800c43c7e48 ffffffff81109b57
[ 1937.664005] ffffffff81109b0e ffffffff8114c566 0000000000000000 0000000000000000
[ 1937.664005] Call Trace:
[ 1937.664005] [<ffffffffa049da80>] ? pppol2tp_connect+0x235/0x41e [l2tp_ppp]
[ 1937.664005] [<ffffffff81109b57>] ? might_fault+0x9e/0xa5
[ 1937.664005] [<ffffffff81109b0e>] ? might_fault+0x55/0xa5
[ 1937.664005] [<ffffffff8114c566>] ? rcu_read_unlock+0x1c/0x26
[ 1937.664005] [<ffffffff81309196>] SYSC_connect+0x87/0xb1
[ 1937.664005] [<ffffffff813e56f7>] ? sysret_check+0x1b/0x56
[ 1937.664005] [<ffffffff8107590d>] ? trace_hardirqs_on_caller+0x145/0x1a1
[ 1937.664005] [<ffffffff81213dee>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[ 1937.664005] [<ffffffff8114c262>] ? spin_lock+0x9/0xb
[ 1937.664005] [<ffffffff813092b4>] SyS_connect+0x9/0xb
[ 1937.664005] [<ffffffff813e56d2>] system_call_fastpath+0x16/0x1b
[ 1937.664005] Code: 10 2a 84 81 e8 65 76 bd e0 65 ff 0c 25 10 bb 00 00 4d 85 ed 74 37 48 8b 85 60 ff ff ff 48 8b 80 88 01 00 00 48 8b b8 10 02 00 00 <48> 8b 47 20 ff 50 20 85 c0 74 0f 83 e8 28 89 83 10 01 00 00 89
[ 1937.664005] RIP [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] RSP <ffff8800c43c7de8>
[ 1939.559375] ---[ end trace 82d44500f28f8708 ]---
Fixes: f34c4a35d879 ("l2tp: take PMTU from tunnel UDP socket")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
commit 3cf521f7dc87c031617fd47e4b7aa2593c2f3daf upstream.
The l2tp [get|set]sockopt() code has fallen back to the UDP functions
for socket option levels != SOL_PPPOL2TP since day one, but that has
never actually worked, since the l2tp socket isn't an inet socket.
As David Miller points out:
"If we wanted this to work, it'd have to look up the tunnel and then
use tunnel->sk, but I wonder how useful that would be"
Since this can never have worked so nobody could possibly have depended
on that functionality, just remove the broken code and return -EINVAL.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Acked-by: James Chapman <jchapman@katalix.com>
Acked-by: David Miller <davem@davemloft.net>
Cc: Phil Turnbull <phil.turnbull@oracle.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Willy Tarreau <w@1wt.eu>
[ Upstream commit f34c4a35d87949fbb0e0f31eba3c054e9f8199ba ]
When l2tp driver tries to get PMTU for the tunnel destination, it uses
the pointer to struct sock that represents PPPoX socket, while it
should use the pointer that represents UDP socket of the tunnel.
Signed-off-by: Dmitry Petukhov <dmgenp@gmail.com>
As pppol2tp_recv() never queues up packets to plain L2TP sockets,
pppol2tp_recvmsg() never returns data to userspace, thus making
the recv*() system calls unusable.
Instead of dropping packets when the L2TP socket isn't bound to a PPP
channel, this patch adds them to its reception queue.
Commit e0d4435f "l2tp: Update PPP-over-L2TP driver to work over L2TPv3"
broke the PPPOL2TP_SO_SENDSEQ setsockopt. The L2TP header length was
previously computed by pppol2tp_l2t_header_len() before each call to
l2tp_xmit_skb(). Now that header length is retrieved from the hdr_len
session field, this field must be updated every time the L2TP header
format is modified, or l2tp_xmit_skb() won't push the right amount of
data for the L2TP header.
This patch uses l2tp_session_set_header_len() to adjust hdr_len every
time sequencing is (de)activated from userspace (either by the
PPPOL2TP_SO_SENDSEQ setsockopt or the L2TP_ATTR_SEND_SEQ netlink
attribute).
Some ipv6 protocols cannot handle ipv4 addresses, so we must not allow
connecting and binding to them. sendmsg logic does already check msg->name
for this but must trust already connected sockets which could be set up
for connection to ipv4 address family.
Per-socket flag ipv6only is of no use here, as it is under users control
by setsockopt.
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Avoid needless export of local functions
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
pull request (net-next): ipsec-next 2013-12-19
1) Use the user supplied policy index instead of a generated one
if present. From Fan Du.
2) Make xfrm migration namespace aware. From Fan Du.
3) Make the xfrm state and policy locks namespace aware. From Fan Du.
4) Remove ancient sleeping when the SA is in acquire state,
we now queue packets to the policy instead. This replaces the
sleeping code.
5) Remove FLOWI_FLAG_CAN_SLEEP. This was used to notify xfrm about the
posibility to sleep. The sleeping code is gone, so remove it.
6) Check user specified spi for IPComp. Thr spi for IPcomp is only
16 bit wide, so check for a valid value. From Fan Du.
7) Export verify_userspi_info to check for valid user supplied spi ranges
with pfkey and netlink. From Fan Du.
8) RFC3173 states that if the total size of a compressed payload and the IPComp
header is not smaller than the size of the original payload, the IP datagram
must be sent in the original non-compressed form. These packets are dropped
by the inbound policy check because they are not transformed. Document the need
to set 'level use' for IPcomp to receive such packets anyway. From Fan Du.
Please pull or let me know if there are problems.
This patch is following b579035ff766c9412e2b92abf5cab794bff102b6
"ipv6: remove old conditions on flow label sharing"
Since there is no reason to restrict a label to a
destination, we should not erase the destination value of a
socket with the value contained in the flow label storage.
This patch allows to really have the same flow label to more
than one destination.
Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
FLOWI_FLAG_CAN_SLEEP was used to notify xfrm about the posibility
to sleep until the needed states are resolved. This code is gone,
so FLOWI_FLAG_CAN_SLEEP is not needed anymore.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
functions
Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage
of uninitialized memory to user in recv syscalls") conditionally updated
addr_len if the msg_name is written to. The recv_error and rxpmtu
functions relied on the recvmsg functions to set up addr_len before.
As this does not happen any more we have to pass addr_len to those
functions as well and set it to the size of the corresponding sockaddr
length.
This broke traceroute and such.
Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls")
Reported-by: Brad Spengler <spender@grsecurity.net>
Reported-by: Tom Labanowski
Cc: mpb <mpb.mail@gmail.com>
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
As suggested by David Miller, make genl_register_family_with_ops()
a macro and pass only the array, evaluating ARRAY_SIZE() in the
macro, this is a little safer.
The openvswitch has some indirection, assing ops/n_ops directly in
that code. This might ultimately just assign the pointers in the
family initializations, saving the struct genl_family_and_ops and
code (once mcast groups are handled differently.)
Only update *addr_len when we actually fill in sockaddr, otherwise we
can return uninitialized memory from the stack to the caller in the
recvfrom, recvmmsg and recvmsg syscalls. Drop the the (addr_len == NULL)
checks because we only get called with a valid addr_len pointer either
from sock_common_recvmsg or inet_recvmsg.
If a blocking read waits on a socket which is concurrently shut down we
now return zero and set msg_msgnamelen to 0.
Reported-by: mpb <mpb.mail@gmail.com>
Now that genl_ops are no longer modified in place when
registering, they can be made const. This patch was done
mostly with spatch:
identifier ops;
+const
struct genl_ops ops[] = {
(except the struct thing in net/openvswitch/datapath.c)
drivers/net/usb/qmi_wwan.c
include/net/dst.h
Trivial merge conflicts, both were overlapping changes.
There are a mix of function prototypes with and without extern
in the kernel sources. Standardize on not using extern for
function prototypes.
Function prototypes don't need to be written with extern.
extern is assumed by the compiler. Its use is as unnecessary as
using auto to declare automatic/local variables in a block.
François Cachereul made a very nice bug report and suspected
the bh_lock_sock() / bh_unlok_sock() pair used in l2tp_xmit_skb() from
process context was not good.
This problem was added by commit 6af88da14ee284aaad6e4326da09a89191ab6165
("l2tp: Fix locking in l2tp_core.c").
l2tp_eth_dev_xmit() runs from BH context, so we must disable BH
from other l2tp_xmit_skb() users.
[ 452.060011] BUG: soft lockup - CPU#1 stuck for 23s! [accel-pppd:6662]
[ 452.061757] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core pppoe pppox
ppp_generic slhc ipv6 ext3 mbcache jbd virtio_balloon xfs exportfs dm_mod
virtio_blk ata_generic virtio_net floppy ata_piix libata virtio_pci virtio_ring virtio [last unloaded: scsi_wait_scan]
[ 452.064012] CPU 1
[ 452.080015] BUG: soft lockup - CPU#2 stuck for 23s! [accel-pppd:6643]
[ 452.080015] CPU 2
[ 452.080015]
[ 452.080015] Pid: 6643, comm: accel-pppd Not tainted 3.2.46.mini #1 Bochs Bochs
[ 452.080015] RIP: 0010:[<ffffffff81059f6c>] [<ffffffff81059f6c>] do_raw_spin_lock+0x17/0x1f
[ 452.080015] RSP: 0018:ffff88007125fc18 EFLAGS: 00000293
[ 452.080015] RAX: 000000000000aba9 RBX: ffffffff811d0703 RCX: 0000000000000000
[ 452.080015] RDX: 00000000000000ab RSI: ffff8800711f6896 RDI: ffff8800745c8110
[ 452.080015] RBP: ffff88007125fc18 R08: 0000000000000020 R09: 0000000000000000
[ 452.080015] R10: 0000000000000000 R11: 0000000000000280 R12: 0000000000000286
[ 452.080015] R13: 0000000000000020 R14: 0000000000000240 R15: 0000000000000000
[ 452.080015] FS: 00007fdc0cc24700(0000) GS:ffff8800b6f00000(0000) knlGS:0000000000000000
[ 452.080015] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 452.080015] CR2: 00007fdb054899b8 CR3: 0000000074404000 CR4: 00000000000006a0
[ 452.080015] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 452.080015] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 452.080015] Process accel-pppd (pid: 6643, threadinfo ffff88007125e000, task ffff8800b27e6dd0)
[ 452.080015] Stack:
[ 452.080015] ffff88007125fc28 ffffffff81256559 ffff88007125fc98 ffffffffa01b2bd1
[ 452.080015] ffff88007125fc58 000000000000000c 00000000029490d0 0000009c71dbe25e
[ 452.080015] 000000000000005c 000000080000000e 0000000000000000 ffff880071170600
[ 452.080015] Call Trace:
[ 452.080015] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10
[ 452.080015] [<ffffffffa01b2bd1>] l2tp_xmit_skb+0x189/0x4ac [l2tp_core]
[ 452.080015] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp]
[ 452.080015] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24
[ 452.080015] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6
[ 452.080015] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616
[ 452.080015] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c
[ 452.080015] [<ffffffff810bbd21>] ? fget_light+0x75/0x89
[ 452.080015] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56
[ 452.080015] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b
[ 452.080015] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b
[ 452.080015] Code: 81 48 89 e5 72 0c 31 c0 48 81 ff 45 66 25 81 0f 92 c0 5d c3 55 b8 00 01 00 00 48 89 e5 f0 66 0f c1 07 0f b6 d4 38 d0 74 06 f3 90 <8a> 07 eb f6 5d c3 90 90 55 48 89 e5 9c 58 0f 1f 44 00 00 5d c3
[ 452.064012]
[ 452.064012] Pid: 6662, comm: accel-pppd Not tainted 3.2.46.mini #1 Bochs Bochs
[ 452.064012] RIP: 0010:[<ffffffff81059f6e>] [<ffffffff81059f6e>] do_raw_spin_lock+0x19/0x1f
[ 452.064012] RSP: 0018:ffff8800b6e83ba0 EFLAGS: 00000297
[ 452.064012] RAX: 000000000000aaa9 RBX: ffff8800b6e83b40 RCX: 0000000000000002
[ 452.064012] RDX: 00000000000000aa RSI: 000000000000000a RDI: ffff8800745c8110
[ 452.064012] RBP: ffff8800b6e83ba0 R08: 000000000000c802 R09: 000000000000001c
[ 452.064012] R10: ffff880071096c4e R11: 0000000000000006 R12: ffff8800b6e83b18
[ 452.064012] R13: ffffffff8125d51e R14: ffff8800b6e83ba0 R15: ffff880072a589c0
[ 452.064012] FS: 00007fdc0b81e700(0000) GS:ffff8800b6e80000(0000) knlGS:0000000000000000
[ 452.064012] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 452.064012] CR2: 0000000000625208 CR3: 0000000074404000 CR4: 00000000000006a0
[ 452.064012] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 452.064012] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 452.064012] Process accel-pppd (pid: 6662, threadinfo ffff88007129a000, task ffff8800744f7410)
[ 452.064012] Stack:
[ 452.064012] ffff8800b6e83bb0 ffffffff81256559 ffff8800b6e83bc0 ffffffff8121c64a
[ 452.064012] ffff8800b6e83bf0 ffffffff8121ec7a ffff880072a589c0 ffff880071096c62
[ 452.064012] 0000000000000011 ffffffff81430024 ffff8800b6e83c80 ffffffff8121f276
[ 452.064012] Call Trace:
[ 452.064012] <IRQ>
[ 452.064012] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10
[ 452.064012] [<ffffffff8121c64a>] spin_lock+0x9/0xb
[ 452.064012] [<ffffffff8121ec7a>] udp_queue_rcv_skb+0x186/0x269
[ 452.064012] [<ffffffff8121f276>] __udp4_lib_rcv+0x297/0x4ae
[ 452.064012] [<ffffffff8121c178>] ? raw_rcv+0xe9/0xf0
[ 452.064012] [<ffffffff8121f4a7>] udp_rcv+0x1a/0x1c
[ 452.064012] [<ffffffff811fe385>] ip_local_deliver_finish+0x12b/0x1a5
[ 452.064012] [<ffffffff811fe54e>] ip_local_deliver+0x53/0x84
[ 452.064012] [<ffffffff811fe1d0>] ip_rcv_finish+0x2bc/0x2f3
[ 452.064012] [<ffffffff811fe78f>] ip_rcv+0x210/0x269
[ 452.064012] [<ffffffff8101911e>] ? kvm_clock_get_cycles+0x9/0xb
[ 452.064012] [<ffffffff811d88cd>] __netif_receive_skb+0x3a5/0x3f7
[ 452.064012] [<ffffffff811d8eba>] netif_receive_skb+0x57/0x5e
[ 452.064012] [<ffffffff811cf30f>] ? __netdev_alloc_skb+0x1f/0x3b
[ 452.064012] [<ffffffffa0049126>] virtnet_poll+0x4ba/0x5a4 [virtio_net]
[ 452.064012] [<ffffffff811d9417>] net_rx_action+0x73/0x184
[ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core]
[ 452.064012] [<ffffffff810343b9>] __do_softirq+0xc3/0x1a8
[ 452.064012] [<ffffffff81013b56>] ? ack_APIC_irq+0x10/0x12
[ 452.064012] [<ffffffff81256559>] ? _raw_spin_lock+0xe/0x10
[ 452.064012] [<ffffffff8125e0ac>] call_softirq+0x1c/0x26
[ 452.064012] [<ffffffff81003587>] do_softirq+0x45/0x82
[ 452.064012] [<ffffffff81034667>] irq_exit+0x42/0x9c
[ 452.064012] [<ffffffff8125e146>] do_IRQ+0x8e/0xa5
[ 452.064012] [<ffffffff8125676e>] common_interrupt+0x6e/0x6e
[ 452.064012] <EOI>
[ 452.064012] [<ffffffff810b82a1>] ? kfree+0x8a/0xa3
[ 452.064012] [<ffffffffa01b2c25>] ? l2tp_xmit_skb+0x1dd/0x4ac [l2tp_core]
[ 452.064012] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp]
[ 452.064012] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24
[ 452.064012] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6
[ 452.064012] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616
[ 452.064012] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c
[ 452.064012] [<ffffffff810bbd21>] ? fget_light+0x75/0x89
[ 452.064012] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56
[ 452.064012] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b
[ 452.064012] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b
[ 452.064012] Code: 89 e5 72 0c 31 c0 48 81 ff 45 66 25 81 0f 92 c0 5d c3 55 b8 00 01 00 00 48 89 e5 f0 66 0f c1 07 0f b6 d4 38 d0 74 06 f3 90 8a 07 <eb> f6 5d c3 90 90 55 48 89 e5 9c 58 0f 1f 44 00 00 5d c3 55 48
[ 452.064012] <IRQ> [<ffffffff81256559>] _raw_spin_lock+0xe/0x10
[ 452.064012] <EOI> [<ffffffff810b82a1>] ? kfree+0x8a/0xa3
Reported-by: François Cachereul <f.cachereul@alphalink.fr>
Tested-by: François Cachereul <f.cachereul@alphalink.fr>
Cc: James Chapman <jchapman@katalix.com>
TCP listener refactoring, part 4 :
To speed up inet lookups, we moved IPv4 addresses from inet to struct
sock_common
Now is time to do the same for IPv6, because it permits us to have fast
lookups for all kind of sockets, including upcoming SYN_RECV.
Getting IPv6 addresses in TCP lookups currently requires two extra cache
lines, plus a dereference (and memory stall).
inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6
This patch is way bigger than its IPv4 counter part, because for IPv4,
we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6,
it's not doable easily.
inet6_sk(sk)->daddr becomes sk->sk_v6_daddr
inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr
And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr
at the same offset.
We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic
macro.
net/l2tp/l2tp_core.c: In function ‘l2tp_verify_udp_checksum’:
net/l2tp/l2tp_core.c:499:22: warning: unused variable ‘tunnel’ [-Wunused-variable]
Create a helper "l2tp_tunnel()" to facilitate this, and as a side
effect get rid of a bunch of unnecessary void pointer casts.
IPv4 mapped addresses cause kernel panic.
The patch juste check whether the IPv6 address is an IPv4 mapped
address. If so, use IPv4 API instead of IPv6.
[ 940.026915] general protection fault: 0000 [#1]
[ 940.026915] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core pppox ppp_generic slhc loop psmouse
[ 940.026915] CPU: 0 PID: 3184 Comm: memcheck-amd64- Not tainted 3.11.0+ #1
[ 940.026915] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
[ 940.026915] task: ffff880007130e20 ti: ffff88000737e000 task.ti: ffff88000737e000
[ 940.026915] RIP: 0010:[<ffffffff81333780>] [<ffffffff81333780>] ip6_xmit+0x276/0x326
[ 940.026915] RSP: 0018:ffff88000737fd28 EFLAGS: 00010286
[ 940.026915] RAX: c748521a75ceff48 RBX: ffff880000c30800 RCX: 0000000000000000
[ 940.026915] RDX: ffff88000075cc4e RSI: 0000000000000028 RDI: ffff8800060e5a40
[ 940.026915] RBP: ffff8800060e5a40 R08: 0000000000000000 R09: ffff88000075cc90
[ 940.026915] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88000737fda0
[ 940.026915] R13: 0000000000000000 R14: 0000000000002000 R15: ffff880005d3b580
[ 940.026915] FS: 00007f163dc5e800(0000) GS:ffffffff81623000(0000) knlGS:0000000000000000
[ 940.026915] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 940.026915] CR2: 00000004032dc940 CR3: 0000000005c25000 CR4: 00000000000006f0
[ 940.026915] Stack:
[ 940.026915] ffff88000075cc4e ffffffff81694e90 ffff880000c30b38 0000000000000020
[ 940.026915] 11000000523c4bac ffff88000737fdb4 0000000000000000 ffff880000c30800
[ 940.026915] ffff880005d3b580 ffff880000c30b38 ffff8800060e5a40 0000000000000020
[ 940.026915] Call Trace:
[ 940.026915] [<ffffffff81356cc3>] ? inet6_csk_xmit+0xa4/0xc4
[ 940.026915] [<ffffffffa0038535>] ? l2tp_xmit_skb+0x503/0x55a [l2tp_core]
[ 940.026915] [<ffffffff812b8d3b>] ? pskb_expand_head+0x161/0x214
[ 940.026915] [<ffffffffa003e91d>] ? pppol2tp_xmit+0xf2/0x143 [l2tp_ppp]
[ 940.026915] [<ffffffffa00292e0>] ? ppp_channel_push+0x36/0x8b [ppp_generic]
[ 940.026915] [<ffffffffa00293fe>] ? ppp_write+0xaf/0xc5 [ppp_generic]
[ 940.026915] [<ffffffff8110ead4>] ? vfs_write+0xa2/0x106
[ 940.026915] [<ffffffff8110edd6>] ? SyS_write+0x56/0x8a
[ 940.026915] [<ffffffff81378ac0>] ? system_call_fastpath+0x16/0x1b
[ 940.026915] Code: 00 49 8b 8f d8 00 00 00 66 83 7c 11 02 00 74 60 49
8b 47 58 48 83 e0 fe 48 8b 80 18 01 00 00 48 85 c0 74 13 48 8b 80 78 02
00 00 <48> ff 40 28 41 8b 57 68 48 01 50 30 48 8b 54 24 08 49 c7 c1 51
[ 940.026915] RIP [<ffffffff81333780>] ip6_xmit+0x276/0x326
[ 940.026915] RSP <ffff88000737fd28>
[ 940.057945] ---[ end trace be8aba9a61c8b7f3 ]---
[ 940.058583] Kernel panic - not syncing: Fatal exception in interrupt
Signed-off-by: François CACHEREUL <f.cachereul@alphalink.fr>
If L2TP data sequence numbers are enabled and reordering is not
enabled, data reception stops if a packet is lost since the kernel
waits for a sequence number that is never resent. (When reordering is
enabled, data reception restarts when the reorder timeout expires.) If
no reorder timeout is set, we should count the number of in-sequence
packets after the out-of-sequence (OOS) condition is detected, and reset
sequence number state after a number of such packets are received.
For now, the number of in-sequence packets while in OOS state which
cause the sequence number state to be reset is hard-coded to 5. This
could be configurable later.
Signed-off-by: James Chapman <jchapman@katalix.com>
The L2TP datapath is not currently RFC-compliant when sequence numbers
are used in L2TP data packets. According to the L2TP RFC, any received
sequence number NR greater than or equal to the next expected NR is
acceptable, where the "greater than or equal to" test is determined by
the NR wrap point. This differs for L2TPv2 and L2TPv3, so add state in
the session context to hold the max NR value and the NR window size in
order to do the acceptable sequence number value check. These might be
configurable later, but for now we derive it from the tunnel L2TP
version, which determines the sequence number field size.
This change moves some code handling data sequence numbers into a
separate function to avoid too much indentation. This is to prepare
for some changes to data sequence number handling in subsequent
patches.
Add missing .owner of struct pppox_proto. This prevents the
module from being removed from underneath its users.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
PPPoL2TP sockets should comply with the standard send*() return values
(i.e. return number of bytes sent instead of 0 upon success).
Copy user data after PPP framing header. This prevents erasure of the
added PPP header and avoids leaking two bytes of uninitialised memory
at the end of skb's data buffer.
drivers/nfc/microread/mei.c
net/netfilter/nfnetlink_queue_core.c
Pull in 'net' to get Eric Biederman's AF_UNIX fix, upon which
some cleanups are going to go on-top.
The L2TP code for IPv6 fails to initialize the l2tp_conn_id member of
struct sockaddr_l2tpip6 and therefore leaks four bytes kernel stack
in l2tp_ip6_recvmsg() in case msg_name is set.
Initialize l2tp_conn_id with 0 to avoid the info leak.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
This is a cut and paste typo. We call ->ref() a second time instead
of ->deref().
If we postpone unhashing of l2tp sessions until the structure is freed, we
risk:
1. further packets arriving and getting queued while the pseudowire is being
closed down
2. the recv path hitting "scheduling while atomic" errors in the case that
recv drops the last reference to a session and calls l2tp_session_free
while in atomic context
As such, l2tp sessions should be unhashed from l2tp_core data structures early
in the teardown process prior to calling pseudowire close. For pseudowires
like l2tp_ppp which have multiple shutdown codepaths, provide an unhash hook.
Signed-off-by: Tom Parkin <tparkin@katalix.com>
l2tp's u64_stats writers were incorrectly synchronised, making it possible to
deadlock a 64bit machine running a 32bit kernel simply by sending the l2tp
code netlink commands while passing data through l2tp sessions.
Previous discussion on netdev determined that alternative solutions such as
spinlock writer synchronisation or per-cpu data would bring unjustified
overhead, given that most users interested in high volume traffic will likely
be running 64bit kernels on 64bit hardware.
As such, this patch replaces l2tp's use of u64_stats with atomic_long_t,
thereby avoiding the deadlock.
Ref:
http://marc.info/?l=linux-netdev&m=134029167910731&w=2
http://marc.info/?l=linux-netdev&m=134079868111131&w=2
If userspace deletes a ppp pseudowire using the netlink API, either by
directly deleting the session or by deleting the tunnel that contains the
session, we need to tear down the corresponding pppox channel.
Rather than trying to manage two pppox unbind codepaths, switch the netlink
and l2tp_core session_close handlers to close via. the l2tp_ppp socket
.release handler.
Add calls to l2tp_session_queue_purge as a part of l2tp_tunnel_closeall
and l2tp_session_delete. Pseudowire implementations which are deleted only
via. l2tp_core l2tp_session_delete calls can dispense with their own code for
flushing the reorder queue.
If an l2tp session is deleted, it is necessary to delete skbs in-flight
on the session's reorder queue before taking it down.
Rather than having each pseudowire implementation reaching into the
l2tp_session struct to handle this itself, provide a function in l2tp_core to
purge the session queue.
It is valid for an existing struct sock object to have a NULL sk_socket
pointer, so don't BUG_ON in l2tp_tunnel_del_work if that should occur.
When looking up the tunnel socket in struct l2tp_tunnel, hold a reference
whether the socket was created by the kernel or by userspace.
When a user deletes a tunnel using netlink, all the sessions in the tunnel
should also be deleted. Since running sessions will pin the tunnel socket
with the references they hold, have the l2tp_tunnel_delete close all sessions
in a tunnel before finally closing the tunnel socket.
l2tp_core hooks UDP's .destroy handler to gain advance warning of a tunnel
socket being closed from userspace. We need to do the same thing for
IP-encapsulation sockets.
l2tp_core internally uses l2tp_tunnel_closeall to close all sessions in a
tunnel when a UDP-encapsulation socket is destroyed. We need to do something
similar for IP-encapsulation sockets.
Export l2tp_tunnel_closeall as a GPL symbol to enable l2tp_ip and l2tp_ip6 to
call it from their .destroy handlers.
L2TP sessions hold a reference to the tunnel socket to prevent it going away
while sessions are still active. However, since tunnel destruction is handled
by the sock sk_destruct callback there is a catch-22: a tunnel with sessions
cannot be deleted since each session holds a reference to the tunnel socket.
If userspace closes a managed tunnel socket, or dies, the tunnel will persist
and it will be neccessary to individually delete the sessions using netlink
commands. This is ugly.
To prevent this occuring, this patch leverages the udp encapsulation socket
destroy callback to gain early notification when the tunnel socket is closed.
This allows us to safely close the sessions running in the tunnel, dropping
the tunnel socket references in the process. The tunnel socket is then
destroyed as normal, and the tunnel resources deallocated in sk_destruct.
While we're at it, ensure that l2tp_tunnel_closeall correctly drops session
references to allow the sessions to be deleted rather than leaking.
Pull networking fixes from David Miller:
"A moderately sized pile of fixes, some specifically for merge window
introduced regressions although others are for longer standing items
and have been queued up for -stable.
I'm kind of tired of all the RDS protocol bugs over the years, to be
honest, it's way out of proportion to the number of people who
actually use it.
1) Fix missing range initialization in netfilter IPSET, from Jozsef
Kadlecsik.
2) ieee80211_local->tim_lock needs to use BH disabling, from Johannes
Berg.
3) Fix DMA syncing in SFC driver, from Ben Hutchings.
4) Fix regression in BOND device MAC address setting, from Jiri
Pirko.
5) Missing usb_free_urb in ISDN Hisax driver, from Marina Makienko.
6) Fix UDP checksumming in bnx2x driver for 57710 and 57711 chips,
fix from Dmitry Kravkov.
7) Missing cfgspace_lock initialization in BCMA driver.
8) Validate parameter size for SCTP assoc stats getsockopt(), from
Guenter Roeck.
9) Fix SCTP association hangs, from Lee A Roberts.
10) Fix jumbo frame handling in r8169, from Francois Romieu.
11) Fix phy_device memory leak, from Petr Malat.
12) Omit trailing FCS from frames received in BGMAC driver, from Hauke
Mehrtens.
13) Missing socket refcount release in L2TP, from Guillaume Nault.
14) sctp_endpoint_init should respect passed in gfp_t, rather than use
GFP_KERNEL unconditionally. From Dan Carpenter.
15) Add AISX AX88179 USB driver, from Freddy Xin.
16) Remove MAINTAINERS entries for drivers deleted during the merge
window, from Cesar Eduardo Barros.
17) RDS protocol can try to allocate huge amounts of memory, check
that the user's request length makes sense, from Cong Wang.
18) SCTP should use the provided KMALLOC_MAX_SIZE instead of it's own,
bogus, definition. From Cong Wang.
19) Fix deadlocks in FEC driver by moving TX reclaim into NAPI poll,
from Frank Li. Also, fix a build error introduced in the merge
window.
20) Fix bogus purging of default routes in ipv6, from Lorenzo Colitti.
21) Don't double count RTT measurements when we leave the TCP receive
fast path, from Neal Cardwell."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (61 commits)
tcp: fix double-counted receiver RTT when leaving receiver fast path
CAIF: fix sparse warning for caif_usb
rds: simplify a warning message
net: fec: fix build error in no MXC platform
net: ipv6: Don't purge default router if accept_ra=2
net: fec: put tx to napi poll function to fix dead lock
sctp: use KMALLOC_MAX_SIZE instead of its own MAX_KMALLOC_SIZE
rds: limit the size allocated by rds_message_alloc()
MAINTAINERS: remove eexpress
MAINTAINERS: remove drivers/net/wan/cycx*
MAINTAINERS: remove 3c505
caif_dev: fix sparse warnings for caif_flow_cb
ax88179_178a: ASIX AX88179_178A USB 3.0/2.0 to gigabit ethernet adapter driver
sctp: use the passed in gfp flags instead GFP_KERNEL
ipv[4|6]: correct dropwatch false positive in local_deliver_finish
l2tp: Restore socket refcount when sendmsg succeeds
net/phy: micrel: Disable asymmetric pause for KSZ9021
bgmac: omit the fcs
phy: Fix phy_device_free memory leak
bnx2x: Fix KR2 work-around condition
The sendmsg() syscall handler for PPPoL2TP doesn't decrease the socket
reference counter after successful transmissions. Any successful
sendmsg() call from userspace will then increase the reference counter
forever, thus preventing the kernel's session and tunnel data from
being freed later on.
The problem only happens when writing directly on L2TP sockets.
PPP sockets attached to L2TP are unaffected as the PPP subsystem
uses pppol2tp_xmit() which symmetrically increase/decrease reference
counters.
This patch adds the missing call to sock_put() before returning from
pppol2tp_sendmsg().
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
Fix up trivial conflicts
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
proc_net_remove is only used to remove proc entries
that under /proc/net,it's not a general function for
removing proc entries of netns. if we want to remove
some proc entries which under /proc/net/stat/, we still
need to call remove_proc_entry.
this patch use remove_proc_entry to replace proc_net_remove.
we can remove proc_net_remove after this patch.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Right now, some modules such as bonding use proc_create
to create proc entries under /proc/net/, and other modules
such as ipv4 use proc_net_fops_create.
It looks a little chaos.this patch changes all of
proc_net_fops_create to proc_create. we can remove
proc_net_fops_create after this patch.
Synchronize with 'net' in order to sort out some l2tp, wireless, and
ipv6 GRE fixes that will be built on top of in 'net-next'.
Andrew Savchenko reported a DNS failure and we diagnosed that
some UDP sockets were unable to send more packets because their
sk_wmem_alloc was corrupted after a while (tx_queue column in
following trace)
$ cat /proc/net/udp
sl local_address rem_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode ref pointer drops
459: 00000000:0270 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4507 2 ffff88003d612380 0
466: 00000000:0277 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4802 2 ffff88003d613180 0
470: 076A070A:007B 00000000:0000 07 FFFF4600:00000000 00:00000000 00000000 123 0 5552 2 ffff880039974380 0
470: 010213AC:007B 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4986 2 ffff88003dbd3180 0
470: 010013AC:007B 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4985 2 ffff88003dbd2e00 0
470: 00FCA8C0:007B 00000000:0000 07 FFFFFB00:00000000 00:00000000 00000000 0 0 4984 2 ffff88003dbd2a80 0
Playing with skb->truesize is tricky, especially when
skb is attached to a socket, as we can fool memory charging.
Just remove this code, its not worth trying to be ultra
precise in xmit path.
Reported-by: Andrew Savchenko <bircoph@gmail.com>
Tested-by: Andrew Savchenko <bircoph@gmail.com>
