[ Upstream commit bbdb32cb5b73597386913d052165423b9d736145 ]
While testing L2TP functionality, I came across a bug in getsockname(). The
IP address returned within the pppol2tp_addr's addr memember was not being
set to the IP address in use. This bug is caused by using inet_sk() on the
wrong socket (the L2TP socket rather than the underlying UDP socket), and was
likely introduced during the addition of L2TPv3 support.
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
Signed-off-by: James Chapman <jchapman@katalix.com>
[ Upstream commit 68315801dbf3ab2001679fd2074c9dc5dcf87dfa ]
When a packet is received on an L2TP IP socket (L2TPv3 IP link
encapsulation), the l2tpip socket's backlog_rcv function calls
xfrm4_policy_check(). This is not necessary, since it was called
before the skb was added to the backlog. With CONFIG_NET_NS enabled,
xfrm4_policy_check() will oops if skb->dev is null, so this trivial
patch removes the call.
This bug has always been present, but only when CONFIG_NET_NS is
enabled does it cause problems. Most users are probably using UDP
encapsulation for L2TP, hence the problem has only recently
surfaced.
EIP: 0060:[<c12bb62b>] EFLAGS: 00210246 CPU: 0
EIP is at l2tp_ip_recvmsg+0xd4/0x2a7
EAX: 00000001 EBX: d77b5180 ECX: 00000000 EDX: 00200246
ESI: 00000000 EDI: d63cbd30 EBP: d63cbd18 ESP: d63cbcf4
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Call Trace:
[<c1218568>] sock_common_recvmsg+0x31/0x46
[<c1215c92>] __sock_recvmsg_nosec+0x45/0x4d
[<c12163a1>] __sock_recvmsg+0x31/0x3b
[<c1216828>] sock_recvmsg+0x96/0xab
[<c10b2693>] ? might_fault+0x47/0x81
[<c1167fd0>] ? _copy_from_user+0x31/0x115
[<c121e8c8>] ? copy_from_user+0x8/0xa
[<c121ebd6>] ? verify_iovec+0x3e/0x78
[<c1216604>] __sys_recvmsg+0x10a/0x1aa
[<c1216792>] ? sock_recvmsg+0x0/0xab
[<c105a99b>] ? __lock_acquire+0xbdf/0xbee
[<c12d5a99>] ? do_page_fault+0x193/0x375
[<c10d1200>] ? fcheck_files+0x9b/0xca
[<c10d1259>] ? fget_light+0x2a/0x9c
[<c1216bbb>] sys_recvmsg+0x2b/0x43
[<c1218145>] sys_socketcall+0x16d/0x1a5
[<c11679f0>] ? trace_hardirqs_on_thunk+0xc/0x10
[<c100305f>] sysenter_do_call+0x12/0x38
Code: c6 05 8c ea a8 c1 01 e8 0c d4 d9 ff 85 f6 74 07 3e ff 86 80 00 00 00 b9 17 b6 2b c1 ba 01 00 00 00 b8 78 ed 48 c1 e8 23 f6 d9 ff <ff> 76 0c 68 28 e3 30 c1 68 2d 44 41 c1 e8 89 57 01 00 83 c4 0c
[ Upstream commit 835acf5da239b91edb9f7ebe36516999e156e6ee ]
l2tp_xmit_skb() can leak one skb if skb_cow_head() returns an error.
[ Upstream commit 550fd08c2cebad61c548def135f67aba284c6162 ]
After the last patch, We are left in a state in which only drivers calling
ether_setup have IFF_TX_SKB_SHARING set (we assume that drivers touching real
hardware call ether_setup for their net_devices and don't hold any state in
their skbs. There are a handful of drivers that violate this assumption of
course, and need to be fixed up. This patch identifies those drivers, and marks
them as not being able to support the safe transmission of skbs by clearning the
IFF_TX_SKB_SHARING flag in priv_flags
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Karsten Keil <isdn@linux-pingi.de>
CC: "David S. Miller" <davem@davemloft.net>
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Patrick McHardy <kaber@trash.net>
CC: Krzysztof Halasa <khc@pm.waw.pl>
CC: "John W. Linville" <linville@tuxdriver.com>
CC: Greg Kroah-Hartman <gregkh@suse.de>
CC: Marcel Holtmann <marcel@holtmann.org>
CC: Johannes Berg <johannes@sipsolutions.net>
More fallout from struct net lifetime rules review: PTR_ERR() is *already*
negative and failing ->open() should return negatives on failure.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
While trying to remove useless synchronize_rcu() calls, I found l2tp is
indeed incorrectly using two of such calls, but also bumps tunnel
refcount after list insertion.
tunnel refcount must be incremented before being made publically visible
by rcu readers.
This fix can be applied to 2.6.35+ and might need a backport for older
kernels, since things were shuffled in commit fd558d186df2c
(l2tp: Split pppol2tp patch into separate l2tp and ppp parts)
CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
CC: James Chapman <jchapman@katalix.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
This allows us to acquire the exact route keying information from the
protocol, however that might be managed.
It handles all of the possibilities, from the simplest case of storing
the key in inet->cork.fl to the more complex setup SCTP has where
individual transports determine the flow.
Now that the socket is consistently locked in these two routines,
this transformation is legal.
l2tp_xmit_skb() must take the socket lock. It makes use of ip_queue_xmit()
which expects to execute in a socket atomic context.
Since we execute this function in software interrupts, we cannot use the
usual lock_sock()/release_sock() sequence, instead we have to use
bh_lock_sock() and see if a user has the socket locked, and if so drop
the packet.
Both l2tp_ip_connect() and l2tp_ip_sendmsg() must take the socket
lock. They both modify socket state non-atomically, and in particular
l2tp_ip_sendmsg() increments socket private counters without using
atomic operations.
Now that output route lookups update the flow with
destination address selection, we can fetch it from
fl4->daddr instead of rt->rt_dst
source address selection, we can fetch it from
fl4->saddr instead of rt->rt_src
We don't actually hold the socket lock at this point, so the
rcu_dereference_protected() isn't' correct. Thanks to Eric
Dumazet for pointing this out.
Thankfully, we're only interested in fetching the faddr value
if srr is enabled, so we can simply make this an RCU sequence
and use plain rcu_dereference().
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
We lack proper synchronization to manipulate inet->opt ip_options
Problem is ip_make_skb() calls ip_setup_cork() and
ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options),
without any protection against another thread manipulating inet->opt.
Another thread can change inet->opt pointer and free old one under us.
Use RCU to protect inet->opt (changed to inet->inet_opt).
Instead of handling atomic refcounts, just copy ip_options when
necessary, to avoid cache line dirtying.
We cant insert an rcu_head in struct ip_options since its included in
skb->cb[], so this patch is large because I had to introduce a new
ip_options_rcu structure.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
These functions are used together as a unit for route resolution
during connect(). They address the chicken-and-egg problem that
exists when ports need to be allocated during connect() processing,
yet such port allocations require addressing information from the
routing code.
It's currently more heavy handed than it needs to be, and in
particular we allocate and initialize a flow object twice.
Let the callers provide the on-stack flow object. That way we only
need to initialize it once in the ip_route_connect() call.
Later, if ip_route_newports() needs to do anything, it re-uses that
flow object as-is except for the ports which it updates before the
route re-lookup.
Also, describe why this set of facilities are needed and how it works
in a big comment.
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
These changes were incorrectly fixed by codespell. They were now
manually corrected.
The variable 'ret' is set but unused in l2tp_nl_register_ops().
This was obviously meant to maintain error codes which are
returned to the caller, make it so.
A struct used in the l2tp_eth driver for registering network namespace
ops was incorrectly marked as __net_initdata, leading to oops when
module unloaded.
BUG: unable to handle kernel paging request at ffffffffa00ec098
IP: [<ffffffff8123dbd8>] ops_exit_list+0x7/0x4b
PGD 142d067 PUD 1431063 PMD 195da8067 PTE 0
Oops: 0000 [#1] SMP
last sysfs file: /sys/module/l2tp_eth/refcnt
Call Trace:
[<ffffffff8123dc94>] ? unregister_pernet_operations+0x32/0x93
[<ffffffff8123dd20>] ? unregister_pernet_device+0x2b/0x38
[<ffffffff81068b6e>] ? sys_delete_module+0x1b8/0x222
[<ffffffff810c7300>] ? do_munmap+0x254/0x318
[<ffffffff812c64e5>] ? page_fault+0x25/0x30
[<ffffffff812c6952>] ? system_call_fastpath+0x16/0x1b
The idea here is this minimizes the number of places one has to edit
in order to make changes to how flows are defined and used.
Instead of on the stack.
This boolean state is now available in the flow flags.
Since that is what the current vague "flags" argument means.
Since that's what the current vague "flags" thing means.
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
net/llc/af_llc.c
Using the SOCK_DGRAM enum results in
"net-pf-2-proto-SOCK_DGRAM-type-115", so use the numeric value like it
is done in net/dccp.
Use the macros defined for the members of flowi to clean the code up.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
'sparse' spotted that the parameters to kzalloc in l2tp_dfs_seq_open
were swapped.
Tested on current git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git
at 1792f17b7210280a3d7ff29da9614ba779cfcedb build, boots and I can see that directory,
but there again I could see /sys/kernel/debug/l2tp with it swapped; I don't have
any l2tp in use.
Signed-off-by: Dr. David Alan Gilbert <linux@treblig.org>
Causes these build failures on PowerPC:
net/l2tp/l2tp_core.c:1228: error: __ksymtab_l2tp_tunnel_closeall causes a section type conflict
net/l2tp/l2tp_core.c:1006: error: __ksymtab_l2tp_xmit_core causes a section type conflict
net/l2tp/l2tp_core.c:847: error: __ksymtab_l2tp_udp_recv_core causes a section type conflict
Also moved the refcound inlines from l2tp_core.h to l2tp_core.c
since only used in that one file.
Acked-by: James Chapman <jchapman@katalix.com>
net/mac80211/main.c
Kill last_rx use in l2tp and two net drivers
close https://bugzilla.kernel.org/show_bug.cgi?id=16529
Before calling dev_forward_skb(), we should make sure skb head contains
at least an ethernet header, even if length included in upper layer said
so. Use pskb_may_pull() to make sure this ethernet header is present in
skb head.
Reported-by: Thomas Heil <heil@terminal-consulting.de>
Reported-by: Ian Campbell <Ian.Campbell@eu.citrix.com>
The PPP channel ops structure should be const.
Cleanup the declarations to use standard C99 format.
remove useless union keyword in rtable, rt6_info and dn_route.
Since there is only one member in a union, the union keyword isn't useful.
Since .size is set properly in "struct pernet_operations l2tp_eth_net_ops",
allocating space for "struct l2tp_eth_net" by hand is not correct, even causes
memory leakage.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Since .size is set properly in "struct pernet_operations l2tp_net_ops",
allocating space for "struct l2tp_net" by hand is not correct, even causes
memory leakage.
As Herbert Xu said: we should be able to simply replace ipfragok
with skb->local_df. commit f88037(sctp: Drop ipfargok in sctp_xmit function)
has droped ipfragok and set local_df value properly.
The patch kills the ipfragok parameter of .queue_xmit().
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Followup to commit 789a4a2c
(l2tp: Add support for static unmanaged L2TPv3 tunnels)
One missing init in l2tp_tunnel_sock_create() could access random kernel
memory, and a bit field should be unsigned.
We have to check CONFIG_L2TP_DEBUGFS_MODULE as well as
CONFIG_L2TP_DEBUGFS.
This patch adds support for static (unmanaged) L2TPv3 tunnels, where
the tunnel socket is created by the kernel rather than being created
by userspace. This means L2TP tunnels and sessions can be created
manually, without needing an L2TP control protocol implemented in
userspace. This might be useful where the user wants a simple ethernet
over IP tunnel.
A patch to iproute2 adds a new command set under "ip l2tp" to make use
of this feature. This will be submitted separately.
Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com>
The existing pppol2tp driver exports debug info to
/proc/net/pppol2tp. Rather than adding info to that file for the new
functionality added in this patch series, we add new files in debugfs,
leaving the old /proc file for backwards compatibility (L2TPv2 only).
Currently only one file is provided: l2tp/tunnels, which lists
internal debug info for all l2tp tunnels and sessions. More files may
be added later. The info is for debug and problem analysis only -
userspace apps should use netlink to obtain status about l2tp tunnels
and sessions.
Although debugfs does not support net namespaces, the tunnels and
sessions dumped in l2tp/tunnels are only those in the net namespace of
the process reading the file.
This driver presents a regular net_device for each L2TP ethernet
pseudowire instance. These interfaces are named l2tpethN by default,
though userspace can specify an alternative name when the L2TP
session is created, if preferred. When the pseudowire is established,
regular Linux networking utilities may be used to configure the
interface, i.e. give it IP address info or add it to a bridge. Any
data passed over the interface is carried over an L2TP tunnel.
Reader/write locks are discouraged because they are slower than spin
locks. So this patch converts the rwlocks used in the per_net structs
to rcu.
In L2TPv3, we need to create/delete/modify/query L2TP tunnel and
session contexts. The number of parameters is significant. So let's
use netlink. Userspace uses this API to control L2TP tunnel/session
contexts in the kernel.
The previous pppol2tp driver was managed using [gs]etsockopt(). This
API is retained for backwards compatibility. Unlike L2TPv2 which
carries only PPP frames, L2TPv3 can carry raw ethernet frames or other
frame types and these do not always have an associated socket
family. Therefore, we need a way to use L2TP sessions that doesn't
require a socket type for each supported frame type. Hence netlink is
used.
