path: root/net/llc
2014-09-28net_dma: simple removalDan Williams
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used and there is no plan to fix it. This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards. Reverting the remainder of the net_dma induced changes is deferred to subsequent patches. Marked for stable due to Roman's report of a memory leak in dma_pin_iovec_pages(): https://lkml.org/lkml/2014/9/3/177 Cc: Dave Jiang <dave.jiang@intel.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: David Whipple <whipple@securedatainnovations.ch> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Cc: <stable@vger.kernel.org> Reported-by: Roman Gushchin <klamm@yandex-team.ru> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2014-01-28llc: remove noisy WARN from llc_mac_hdr_initDave Jones
Sending malformed llc packets triggers this spew, which seems excessive. WARNING: CPU: 1 PID: 6917 at net/llc/llc_output.c:46 llc_mac_hdr_init+0x85/0x90 [llc]() device type not supported: 0 CPU: 1 PID: 6917 Comm: trinity-c1 Not tainted 3.13.0+ #95 0000000000000009 00000000007e257d ffff88009232fbe8 ffffffffac737325 ffff88009232fc30 ffff88009232fc20 ffffffffac06d28d ffff88020e07f180 ffff88009232fec0 00000000000000c8 0000000000000000 ffff88009232fe70 Call Trace: [<ffffffffac737325>] dump_stack+0x4e/0x7a [<ffffffffac06d28d>] warn_slowpath_common+0x7d/0xa0 [<ffffffffac06d30c>] warn_slowpath_fmt+0x5c/0x80 [<ffffffffc01736d5>] llc_mac_hdr_init+0x85/0x90 [llc] [<ffffffffc0173759>] llc_build_and_send_ui_pkt+0x79/0x90 [llc] [<ffffffffc057cdba>] llc_ui_sendmsg+0x23a/0x400 [llc2] [<ffffffffac605d8c>] sock_sendmsg+0x9c/0xe0 [<ffffffffac185a37>] ? might_fault+0x47/0x50 [<ffffffffac606321>] SYSC_sendto+0x121/0x1c0 [<ffffffffac011847>] ? syscall_trace_enter+0x207/0x270 [<ffffffffac6071ce>] SyS_sendto+0xe/0x10 [<ffffffffac74aaa4>] tracesys+0xdd/0xe2 Until 2009, this was a printk, when it was changed in bf9ae5386bc: "llc: use dev_hard_header". Let userland figure out what -EINVAL means by itself. Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-18net: add build-time checks for msg->msg_name sizeSteffen Hurrle
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg handler msg_name and msg_namelen logic"). DECLARE_SOCKADDR validates that the structure we use for writing the name information to is not larger than the buffer which is reserved for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR consistently in sendmsg code paths. Signed-off-by: Steffen Hurrle <steffen@hurrle.net> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c net/ipv6/ip6_tunnel.c net/ipv6/ip6_vti.c ipv6 tunnel statistic bug fixes conflicting with consolidation into generic sw per-cpu net stats. qlogic conflict between queue counting bug fix and the addition of multiple MAC address support. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-03llc: make lock staticstephen hemminger
The llc_sap_list_lock does not need to be global, only acquired in core. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-02net: llc: fix use after free in llc_ui_recvmsgDaniel Borkmann
While commit 30a584d944fb fixes datagram interface in LLC, a use after free bug has been introduced for SOCK_STREAM sockets that do not make use of MSG_PEEK. The flow is as follow ... if (!(flags & MSG_PEEK)) { ... sk_eat_skb(sk, skb, false); ... } ... if (used + offset < skb->len) continue; ... where sk_eat_skb() calls __kfree_skb(). Therefore, cache original length and work on skb_len to check partial reads. Fixes: 30a584d944fb ("[LLX]: SOCK_DGRAM interface fixes") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-27llc: "foo* bar" should be "foo *bar"Weilong Chen
Signed-off-by: Weilong Chen <chenweilong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-03llc: Use normal etherdevice.h testsJoe Perches
Convert the llc_<foo> static inlines to the equivalents from etherdevice.h and remove the llc_<foo> static inline functions. llc_mac_null -> is_zero_ether_addr llc_mac_multicast -> is_multicast_ether_addr llc_mac_match -> ether_addr_equal Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-15net: proc_fs: trivial: print UIDs as unsigned intFrancesco Fusco
UIDs are printed in the proc_fs as signed int, whereas they are unsigned int. Signed-off-by: Francesco Fusco <ffusco@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07llc: Fix missing msg_namelen update in llc_ui_recvmsg()Mathias Krause
For stream sockets the code misses to update the msg_namelen member to 0 and therefore makes net/socket.c leak the local, uninitialized sockaddr_storage variable to userland -- 128 bytes of kernel stack memory. The msg_namelen update is also missing for datagram sockets in case the socket is shutting down during receive. Fix both issues by setting msg_namelen to 0 early. It will be updated later if we're going to fill the msg_name member. Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-18net: Allow userns root to control llc, netfilter, netlink, packet, and xfrmEric W. Biederman
Allow an unpriviled user who has created a user namespace, and then created a network namespace to effectively use the new network namespace, by reducing capable(CAP_NET_ADMIN) and capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns, CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls. Allow creation of af_key sockets. Allow creation of llc sockets. Allow creation of af_packet sockets. Allow sending xfrm netlink control messages. Allow binding to netlink multicast groups. Allow sending to netlink multicast groups. Allow adding and dropping netlink multicast groups. Allow sending to all netlink multicast groups and port ids. Allow reading the netfilter SO_IP_SET socket option. Allow sending netfilter netlink messages. Allow setting and getting ip_vs netfilter socket options. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-17llc: Remove stray reference to sysctl_llc_station_ack_timeout.David S. Miller
2012-09-17llc2: Collapse remainder of state machine into simple if-else if-statementBen Hutchings
Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-17llc2: Remove explicit indexing of state action arraysBen Hutchings
These arrays are accessed by iteration in llc_exec_station_trans_actions(). There must not be any zero-filled gaps in them, so the explicit indices are pointless. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-17llc2: Remove the station send queueBen Hutchings
We only ever put one skb on the send queue, and then immediately send it. Remove the queue and call dev_queue_xmit() directly. This leaves struct llc_station empty, so remove that as well. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-17llc2: Collapse the station event receive pathBen Hutchings
We only ever put one skb on the event queue, and then immediately process it. Remove the queue and fold together the related functions, removing several blatantly false comments. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-17llc2: Remove dead code for state machineBen Hutchings
The initial state is UP and there is no way to enter the other states as the required event type is never generated. Delete all states, event types, and other dead code. The only thing left is handling of the XID and TEST commands. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-17llc2: Remove pointless indirection through llc_stat_state_trans_endBen Hutchings
2012-08-24Merge branch 'for-next' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace This is an initial merge in of Eric Biederman's work to start adding user namespace support to the networking. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-15llc: fix info leak via getsockname()Mathias Krause
The LLC code wrongly returns 0, i.e. "success", when the socket is zapped. Together with the uninitialized uaddrlen pointer argument from sys_getsockname this leads to an arbitrary memory leak of up to 128 bytes kernel stack via the getsockname() syscall. Return an error instead when the socket is zapped to prevent the info leak. Also remove the unnecessary memset(0). We don't directly write to the memory pointed by uaddr but memcpy() a local structure at the end of the function that is properly initialized. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14userns: Print out socket uids in a user namespace aware fashion.Eric W. Biederman
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Sridhar Samudrala <sri@us.ibm.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-08-14llc: Fix races between llc2 handler use and (un)registrationBen Hutchings
When registering the handlers, any state they rely on must be completely initialised first. When unregistering, we must wait until they are definitely no longer running. llc_rcv() must also avoid reading the handler pointers again after checking for NULL. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14llc2: Call llc_station_exit() on llc2_init() failure pathBen Hutchings
Otherwise the station packet handler will remain registered even though the module is unloaded. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14llc2: Fix silent failure of llc_station_init()Ben Hutchings
llc_station_init() creates and processes an event skb with no effect other than to change the state from DOWN to UP. Allocation failure is reported, but then ignored by its caller, llc2_init(). Remove this possibility by simply initialising the state as UP. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-06llc: free the right skbSorin Dumitru
We are freeing skb instead of nskb, resulting in a double free on skb and a leak from nskb. Signed-off-by: Sorin Dumitru <sdumitru@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-10net: Fix (nearly-)kernel-doc comments for various functionsBen Hutchings
Fix incorrect start markers, wrapped summary lines, missing section breaks, incorrect separators, and some name mismatches. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-17net: include/net/sock.h cleanupEric Dumazet
bool/const conversions where possible __inline__ -> inline space cleanups Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-15net: delete all instances of special processing for token ringPaul Gortmaker
We are going to delete the Token ring support. This removes any special processing in the core networking for token ring, (aside from net/tr.c itself), leaving the drivers and remaining tokenring support present but inert. The mass removal of the drivers and net/tr.c will be in a separate commit, so that the history of these files that we still care about won't have the giant deletion tied into their history. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-05-15net: Convert net_ratelimit uses to net_<level>_ratelimitedJoe Perches
Standardize the net core ratelimited logging functions. Coalesce formats, align arguments. Change a printk then vprintk sequence to use printf extension %pV. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-23net: add a limit parameter to sk_add_backlog()Eric Dumazet
sk_add_backlog() & sk_rcvqueues_full() hard coded sk_rcvbuf as the memory limit. We need to make this limit a parameter for TCP use. No functional change expected in this patch, all callers still using the old sk_rcvbuf limit. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Maciej Żenczykowski <maze@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Cc: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net llc: Don't use sysctl tables with .child entries.Eric W. Biederman
The sysctl core no longer natively understands sysctl tables with .child entries. Kill the intermediate tables and use register_net_sysctl directly to remove the need for compatibility code. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Move all of the network sysctls without a namespace into init_net.Eric W. Biederman
This makes it clearer which sysctls are relative to your current network namespace. This makes it a little less error prone by not exposing sysctls for the initial network namespace in other namespaces. This is the same way we handle all of our other network interfaces to userspace and I can't honestly remember why we didn't do this for sysctls right from the start. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-24llc: Fix race condition in llc_ui_recvmsgRadu Iliescu
There is a race on sk_receive_queue between llc_ui_recvmsg and sock_queue_rcv_skb. Our current solution is to protect skb_eat in llc_ui_recvmsg with the queue spinlock. Signed-off-by: Radu Iliescu <riliescu@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-19llc: llc_cmsg_rcv was getting called after sk_eat_skb.Alex Juncu
Received non stream protocol packets were calling llc_cmsg_rcv that used a skb after that skb was released by sk_eat_skb. This caused received STP packets to generate kernel panics. Signed-off-by: Alexandru Juncu <ajuncu@ixiacom.com> Signed-off-by: Kunjan Naik <knaik@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-11llc: Fix length check in llc_fixup_skb().David S. Miller
Fixes bugzilla #32872 The LLC stack pretends to support non-linear skbs but there is a direct use of skb_tail_pointer() in llc_fixup_skb(). Use pskb_may_pull() to see if data_size bytes remain and can be accessed linearly in the packet, instead of direct pointer checks. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-28llc: avoid skb_clone() if there is only one handlerChangli Gao
Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08net: RCU conversion of dev_getbyhwaddr() and arp_ioctl()Eric Dumazet
Le dimanche 05 décembre 2010 à 09:19 +0100, Eric Dumazet a écrit : > Hmm.. > > If somebody can explain why RTNL is held in arp_ioctl() (and therefore > in arp_req_delete()), we might first remove RTNL use in arp_ioctl() so > that your patch can be applied. > > Right now it is not good, because RTNL wont be necessarly held when you > are going to call arp_invalidate() ? While doing this analysis, I found a refcount bug in llc, I'll send a patch for net-2.6 Meanwhile, here is the patch for net-next-2.6 Your patch then can be applied after mine. Thanks [PATCH] net: RCU conversion of dev_getbyhwaddr() and arp_ioctl() dev_getbyhwaddr() was called under RTNL. Rename it to dev_getbyhwaddr_rcu() and change all its caller to now use RCU locking instead of RTNL. Change arp_ioctl() to use RCU instead of RTNL locking. Note: this fix a dev refcount bug in llc Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-16net/llc: storing negative error codes in unsigned shortDan Carpenter
If the alloc_skb() fails then we return 65431 instead of -ENOBUFS (-105). Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-13net/llc: make opt unsigned in llc_ui_setsockopt()Dan Carpenter
The members of struct llc_sock are unsigned so if we pass a negative value for "opt" it can cause a sign bug. Also it can cause an integer overflow when we multiply "opt * HZ". CC: stable@kernel.org Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ar9170/usb.c drivers/scsi/iscsi_tcp.c net/ipv4/ipmr.c
2010-05-10net: Fix FDDI and TR config checks in ipv4 arp and LLC.David S. Miller
Need to check both CONFIG_FOO and CONFIG_FOO_MODULE Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24llc: cleanup: remove dead code from llc_init()Dan Carpenter
We don't need "dev" any more after: a5a04819c5740cb1aa217af2cc8f5ef26f33d744 [LLC]: station source mac address Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-05net: backlog functions renameZhu Yi
sk_add_backlog -> __sk_add_backlog sk_add_backlog_limited -> sk_add_backlog Signed-off-by: Zhu Yi <yi.zhu@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
