git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 5.3:
API:
- Test shash interface directly in testmgr
- cra_driver_name is now mandatory
Algorithms:
- Replace arc4 crypto_cipher with library helper
- Implement 5 way interleave for ECB, CBC and CTR on arm64
- Add xxhash
- Add continuous self-test on noise source to drbg
- Update jitter RNG
Drivers:
- Add support for SHA204A random number generator
- Add support for 7211 in iproc-rng200
- Fix fuzz test failures in inside-secure
- Fix fuzz test failures in talitos
- Fix fuzz test failures in qat"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (143 commits)
crypto: stm32/hash - remove interruptible condition for dma
crypto: stm32/hash - Fix hmac issue more than 256 bytes
crypto: stm32/crc32 - rename driver file
crypto: amcc - remove memset after dma_alloc_coherent
crypto: ccp - Switch to SPDX license identifiers
crypto: ccp - Validate the the error value used to index error messages
crypto: doc - Fix formatting of new crypto engine content
crypto: doc - Add parameter documentation
crypto: arm64/aes-ce - implement 5 way interleave for ECB, CBC and CTR
crypto: arm64/aes-ce - add 5 way interleave routines
crypto: talitos - drop icv_ool
crypto: talitos - fix hash on SEC1.
crypto: talitos - move struct talitos_edesc into talitos.h
lib/scatterlist: Fix mapping iterator when sg->offset is greater than PAGE_SIZE
crypto/NX: Set receive window credits to max number of CRBs in RxFIFO
crypto: asymmetric_keys - select CRYPTO_HASH where needed
crypto: serpent - mark __serpent_setkey_sbox noinline
crypto: testmgr - dynamically allocate crypto_shash
crypto: testmgr - dynamically allocate testvec_config
crypto: talitos - eliminate unneeded 'done' functions at build time
The WEP code in the mac80211 subsystem currently uses the crypto
API to access the arc4 (RC4) cipher, which is overly complicated,
and doesn't really have an upside in this particular case, since
ciphers are always synchronous and therefore always implemented in
software. Given that we have no accelerated software implementations
either, it is much more straightforward to invoke a generic library
interface directly.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
Lubomir Rintel recently pointed out a dead link for o11s.org, and
repointed it to a still live, but also stale website. As far as I
know, no one is updating the content at open80211s.org.
Since this Kconfig text was originally written, though, the 802.11s
mesh drafts were approved and ultimately rolled into 802.11 proper.
Meanwhile, the implementation has converged on the final standard,
so we can lose all of the text here and provide something that's a
little more helpful and accurate.
Signed-off-by: Bob Copeland <bobcopeland@fb.com>
Reviewed-by: Lubomir Rintel <lkundrak@v3.sk>
Reviewed-by: Steve deRosier <derosier@cal-sierra.com>
Legacy-only devices are not very common and the overhead of the extra
code for HT and VHT rates is not big enough to justify all those extra
lines of code to make it optional.
Signed-off-by: Felix Fietkau <nbd@nbd.name>
Switch the FILS AEAD code to use a cmac(aes) shash instantiated by the
crypto API rather than reusing the open coded implementation in
aes_cmac_vector(). This makes the code more understandable, and allows
platforms to implement cmac(aes) in a more secure (*) and efficient way
than is typically possible when using the AES cipher directly.
So replace the crypto_cipher by a crypto_shash, and update the aes_s2v()
routine to call the shash interface directly.
* In particular, the generic table based AES implementation is sensitive
to known-plaintext timing attacks on the key, to which AES based MAC
algorithms are especially vulnerable, given that their plaintext is not
usually secret. Time invariant alternatives are available (e.g., based
on SIMD algorithms), but may incur a setup cost that is prohibitive when
operating on a single block at a time, which is why they don't usually
expose the cipher API.
Instead of using the out-of-line average calculation, use the new
DECLARE_EWMA() macro to declare a signal EWMA, and use that.
This actually *reduces* the code size slightly (on x86-64) while
also reducing the station info size by 80 bytes.
Since these counters can only be read through debugfs, there's
very little point in maintaining them all the time. However,
even just making them depend on debugfs is pointless - they're
not normally used. Additionally a number of them aren't even
concurrency safe.
Move them under MAC80211_DEBUG_COUNTERS so they're normally
not even compiled in.
Allow debug builds to configure the station hash table maximum
size in order to run with hash collisions in limited scenarios
such as hwsim testing. The default remains 0 which effectively
means no limit.
This allows mac80211 to configure GCMP and GCMP-256 to the driver and
also use software-implementation within mac80211 when the driver does
not support this with hardware accelaration.
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
[remove a spurious newline]
This patch adds 802.11p OCB (Outside the Context of a BSS) mode
support.
When communicating in OCB mode a mandatory wildcard BSSID
(48 '1' bits) is used.
The EDCA parameters handling function was changed to support
802.11p specific values.
The insertion of a newly discovered STAs is done in the similar way
as in the IBSS mode -- through the deferred insertion.
The OCB mode uses a periodic 'housekeeping task' for expiration of
disconnected STAs (in the similar manner as in the MESH mode).
New Kconfig option for verbose OCB debugging outputs is added.
Signed-off-by: Rostislav Lisovy <rostislav.lisovy@fel.cvut.cz>
When the new CONFIG_MAC80211_RC_MINSTREL_VHT is not set (default 'N'),
there is no behavioral change including in sampling and MCS_GROUP_RATES
remains 8.
Otherwise MCS_GROUP_RATES is 10, and a module parameter *vht_only*
(default 'true'), restricts the rates selection to VHT when VHT is
supported.
Regarding the debugfs stats buffer:
It is explicitly increased from 8k to 32k to fit every rates incl. when
both HT and VHT rates are enabled, as for the format, before:
type rate tpt eprob *prob ret *ok(*cum) ok( cum)
HT20/LGI ABCDP MCS0 0.0 0.0 0.0 1 0( 0) 0( 0)
after:
VHT40/LGI MCS5/2 0.0 0.0 0.0 0 0( 0) 0( 0)
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
Cc: Felix Fietkau <nbd@openwrt.org>
Minstrel has long since proven its worth.
Process the CSA frame according to the procedures define in IEEE Std
802.11-2012 section 10.9.8.4.3 as follow:
* The mesh channel switch parameters element (MCSP) must be availabe.
* If the MCSP's TTL is 1, drop the frame but still process the CSA.
* If the MCSP's precedence value is less than or equal to the current
precedence value, drop the frame and do not process the CSA.
* The CSA frame is forwarded after TTL is decremented by 1 and the
initiator field is set to 0. Transmit restrict field and others
are maintained as is.
* No beacon or probe response frame are handled here.
Also, introduce the debug message used for mesh CSA purpose.
Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@cozybit.com>
Use the generic CCM aead chaining mode driver rather than a local
implementation that sits right on top of the core AES cipher.
This allows the use of accelerated implementations of either
CCM as a whole or the CTR mode which it encapsulates.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
Fix up trivial conflicts
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
Add routines to
- maintain a PS mode for each peer and a non-peer PS mode
- indicate own PS mode in transmitted frames
- track neighbor STAs power modes
- buffer frames when neighbors are in PS mode
- add TIM and Awake Window IE to beacons
- release frames in Mesh Peer Service Periods
Add local_pm to sta_info to represent the link-specific power
mode at this station towards the remote station. When a peer
link is established, use the default power mode stored in mesh
config. Update the PS status if the peering status of a neighbor
changes.
Maintain a mesh power mode for non-peer mesh STAs. Set the
non-peer power mode to active mode during peering. Authenticated
mesh peering is currently not working when either node is
configured to be in power save mode.
Indicate the current power mode in transmitted frames. Use QoS
Nulls to indicate mesh power mode transitions.
For performance reasons, calls to the function setting the frame
flags are placed in HWMP routing routines, as there the STA
pointer is already available.
Add peer_pm to sta_info to represent the peer's link-specific
power mode towards the local station. Add nonpeer_pm to
represent the peer's power mode towards all non-peer stations.
Track power modes based on received frames.
Add the ps_data structure to ieee80211_if_mesh (for TIM map, PS
neighbor counter and group-addressed frame buffer).
Set WLAN_STA_PS flag for STA in PS mode to use the unicast frame
buffering routines in the tx path. Update num_sta_ps to buffer
and release group-addressed frames after DTIM beacons.
Announce the awake window duration in beacons if in light or
deep sleep mode towards any peer or non-peer. Create a TIM IE
similarly to AP mode and add it to mesh beacons. Parse received
Awake Window IEs and check TIM IEs for buffered frames.
Release frames towards peers in mesh Peer Service Periods. Use
the corresponding trigger frames and monitor the MPSP status.
Append a QoS Null as trigger frame if neccessary to properly end
the MPSP. Currently, in HT channels MPSPs behave imperfectly and
show large delay spikes and frame losses.
Signed-off-by: Marco Porsch <marco@cozybit.com>
Signed-off-by: Ivan Bezyazychnyy <ivan.bezyazychnyy@gmail.com>
Signed-off-by: Mike Krinkin <krinkin.m.u@gmail.com>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: "John W. Linville" <linville@tuxdriver.com>
CC: Johannes Berg <johannes@sipsolutions.net>
CC: "David S. Miller" <davem@davemloft.net>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Marco Porsch <marco.porsch@etit.tu-chemnitz.de>
It can be very useful to have all debug messages
available when debugging, but hard to correlate
between different sources, so add a trace event
for all mac80211 debug messages.
There are a few things that make the logging and
debugging in mac80211 less useful than it should
be right now:
* a lot of messages should be pr_info, not pr_debug
* wholesale use of pr_debug makes it require *both*
Kconfig and dynamic configuration
* there are still a lot of ifdefs
* the style is very inconsistent, sometimes the
sdata->name is printed in front
Clean up everything, introducing new macros and
separating out the station MLME debugging into
a new Kconfig symbol.
The TKIP code hasn't been changed in a very long
time, so it seems unlikely that anyone really has
a need for the TKIP debug code. Remove it.
This patch adds MBSS extensible synchronization framework (Sec.
13.13.2 of IEEE Std. 802.11-2012).
The framework is implemented via an ops table which defines the
following functions:
rx_bcn_presp() - this is called every time a mesh beacon is
received.
adjust_tbtt() - this is called immediately before a beacon is about
to be transmitted.
The default neighbor offset synchronization defined in the standard is
implemented. We also provide template functions for vendor specific
methods.
When neighbor offset synchronization is active (which is the default)
mesh neighbors in the same MBSS will track timing offsets to each other
and compensate clock drift.
In our tests we observed that this mesh synchronization implementation
successfully corrected drifts between stations of ~2PPM while
introducing a jitter of ~20us.
It is also possible to test this framework on mac80211_hwsim simulated
phys to see how it behaves under different topologies, over poor links,
etc.
Signed-off-by: Marco Porsch <marco.porsch@s2005.tu-chemnitz.de>
Signed-off-by: Pavel Zubarev <pavel.zubarev@gmail.com>
Signed-off-by: Javier Cardona <javier@cozybit.com>
There's little point in this config symbol, if
tracing is disabled the overhead is negligible
and if you think it's too bad you can always
turn off tracing completely.
Also remove the part where we don't have sparse
check the tracing code -- it seems that it can
now deal with it (or the code changed).
Register and implement the TDLS cfg80211 callback functions.
Internally prepare and send TDLS management frames. We incorporate
local STA capabilities and supported rates with extra IEs given by
usermode. The resulting packet is either encapsulated in a data frame,
or assembled as an action frame. It is transmitted either directly or
through the AP, as mandated by the TDLS specification.
Declare support for the TDLS external setup wiphy capability. This
tells usermode to handle link setup and discovery on its own, and use the
kernel driver for sending TDLS mgmt packets.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
Cc: Kalyan C Gaddam <chakkal@iit.edu>
make hwmp_dbg print the relevant sdata->name by default and improve
formatting. Also add mpath_dbg macro for debugging of mesh path
operations.
The only thing that using crypto_blkcipher with ecb does over just using
arc4 directly is wrapping the encrypt/decrypt function into a for loop,
looping over each individual character.
To be able to do this, it pulls in around 40 kb worth of unnecessary
kernel modules (at least on a MIPS embedded device).
Using arc4 directly not only eliminates those dependencies, it also makes
the code smaller.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
... Otherwise it is displayed when mac80211 isn't
even turned on, which is completely pointless.
"def_bool n" without prompt is pointless, this should be just "bool".
Signed-off-by: Jan Beulich <jbeulich@novell.com>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
net/ipv4/fib_frontend.c
Extend nl80211 to report an exponential weighted moving average (EWMA) of the
signal value. Since the signal value usually fluctuates between different
packets, an average can be more useful than the value of the last packet.
This uses the recently added generic EWMA library function.
v2: fix ABI breakage and change factor to be a power of 2.
Signed-off-by: Bruno Randolf <br1@einfach.org>
It's not useful to build LED triggers when there's no LEDs that can be
triggered by them. Therefore, fix up the dependencies so that this
cannot happen, and fix a few users that select triggers to depend on
LEDS_CLASS as well (there is also one user that also selects LEDS_CLASS,
which is OK).
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Tested-by: Ingo Molnar <mingo@elte.hu>
Cc: Arnd Hannemann <arnd@arndnet.de>
Cc: Richard Purdie <rpurdie@linux.intel.com>
This reverts commit 86107fd170bc379869250eb7e1bd393a3a70e8ae.
This patch inadvertantly changed the userland ABI.
Allow selection of minstrel_ht as default rate control algorithm. At
the moment minstrel_ht can only be requested by the driver code but
not selected as default in make menuconfig. Fix this by using
minstrel_ht when minstrel was selected as default and minstrel_ht
is available.
This change won't affect legacy devices as minstrel_ht falls back to
minstrel in that case.
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
Enhance tracing by adding tracing for a variety of
callbacks that the drivers call, and also for
internal calls (currently limited to queue status).
This can aid debugging what is going on in mac80211
in interaction with drivers, since we can now see
what drivers call and not just what mac80211 calls
in the driver.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
I discovered that if EMBEDDED=y, one can accidentally build a mac80211 stack
and drivers w/ no rate control algorithm. For drivers like RTL8187 that don't
supply their own RC algorithms, this will cause ieee80211_register_hw to
fail (making the driver unusable).
This will tell kconfig to provide a warning if no rate control algorithms
have been selected. That'll at least warn the user; users that know that
their drivers supply a rate control algorithm can safely ignore the
warning, and those who don't know (or who expect to be using multiple
drivers) can select a default RC algorithm.
Signed-off-by: Andres Salomon <dilinger@collabora.co.uk>
Cc: stable@kernel.org
The payload alignment warning enabled by MAC80211_DEBUG_PACKET_ALIGNMENT is
difficult. To fix it, a firmware change is needed but in most cases that's
very difficult. So the benefit from the warning is low and most probably
it just creates more confusion for people who just enable all warnings
(like it did for me).
Remove the unaligned IP payload warning and the kconfig option. But
leave the unaligned packet warning, it will be enabled with
MAC80211_VERBOSE_DEBUG.
Signed-off-by: Kalle Valo <kalle.valo@nokia.com>
Add MAC80211_VERBOSE_MHWMP_DEBUG, a debugging option for HWMP
frame processing.
Signed-off-by: Rui Paulo <rpaulo@gmail.com>
Reviewed-by: Andrey Yurovsky <andrey@cozybit.com>
Tested-by: Brian Cavagnolo <brian@cozybit.com>
We can just display this upon enabling mac80211 with an
'if MAC80211 != n' check.
Cc: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
This prevents calling rcu_synchronize from within the tx path by moving the
table growth code to the mesh workqueue.
Move mesh_table_free and mesh_table_grow from mesh.c to mesh_pathtbl.c and
declare them static.
Also, re-enable mesh in Kconfig and update the configuration description.
Tested-by: Andrey Yurovsky <andrey@cozybit.com>
Finally! This is what you've all been waiting for!
This patch makes cfg80211 take care of wext emulation
_completely_ by itself, drivers that don't need things
cfg80211 doesn't do yet don't even need to be aware of
wireless extensions.
This means we can also clean up mac80211's and iwm's
Kconfig and make it possible to build them w/o wext
now!
RIP wext.
This makes mac80211 use the event tracing framework
to log all operations as given to the driver. This
will need to be extended with more information, but
as a start it should be good.
drivers/net/wireless/iwmc3200wifi/netdev.c
net/wireless/scan.c
My kvm instance was complaining a lot about sleeping
in atomic contexts in the mesh code, and it turns out
that both mesh_path_add() and mpp_path_add() need to
be able to sleep (they even use synchronize_rcu()!).
I put in a might_sleep() to annotate that, but I see
no way, at least right now, of actually making sure
those functions are only called from process context
since they are both called during TX and RX and the
mesh code itself even calls them with rcu_read_lock()
"held".
Therefore, let's disable it completely for now.
It's possible that I'm only seeing this because the
hwsim's beaconing is broken and thus the peers aren't
discovered right away, but it is possible that this
happens even if beaconing is working, for a peer that
doesn't exist or so.
It should be possible to solve this by deferring the
freeing of the tables to call_rcu() instead of using
synchronize_rcu(), and also using atomic allocations,
but maybe it makes more sense to rework the code to
not call these from atomic contexts and defer more of
the work to the workqueue. Right now, I can't work on
either of those solutions though.
Just on/off and timeout, and with a hacky cfg80211 method
until we figure out what we want, though this is probably
sufficient as we want to use pm_qos for wifi everywhere.
