path: root/net/mac80211/cfg.c
2012-03-06mac80211: fix mesh airtime link metric estimatingThomas Pedersen
Airtime link metric estimation was broken in HT mesh, use cfg80211_calculate_bitrate to get the right rate value. Also factor out tx rate copying from sta_set_sinfo(). Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05{nl,cfg,mac}80211: Implement RSSI threshold for mesh peeringAshok Nagarajan
Mesh peer links are established only if average rssi of the peer candidate satisfies the threshold. This is not in 802.11s specification but was requested by David Fulgham, an open80211s user. This is a way to avoid marginal peer links with stations that are barely within range. This patch adds a new mesh configuration parameter, mesh_rssi_threshold. This feature is supported only for hardwares that report signal in dBm. Signed-off-by: Ashok Nagarajan <ashok@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-29cfg80211: remove cookies from callbacksJohannes Berg
In "cfg80211: no cookies in cfg80211_send_XXX()" Holger Schurig removed the cookies in the calls from mac80211 to cfg80211, but the ones in the other direction were left in. Remove them now. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-22cfg80211: restructure AP/GO mode APIJohannes Berg
The AP/GO mode API isn't very clearly defined, it has "set beacon" and "new beacon" etc. Modify the API to the following: * start AP -- all settings * change beacon -- new beacon data * stop AP -- stop AP mode operation This also reflects in the nl80211 API, rename the commands there correspondingly (but keep the old names for compatibility.) Overall, this makes it much clearer what's going on in the API. Kalle developed the ath6kl changes, I created the rest of the patch. Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-06mac80211: redesign auth/assocJohannes Berg
This is the second part of the auth/assoc redesign, the mac80211 part. This moves the auth/assoc code out of the work abstraction and into the MLME, so that we don't flip channels all the time etc. The only downside is that when we are associated, we need to drop the association in order to create a connection to another AP, but for most drivers this is actually desirable and the ability to do was never used by any applications. If we want to implement resource reservation with FT-OTA, we'd probably best do it with explicit R-O-C in wpa_s. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-30mac80211: add support for mcs masksSimon Wunderlich
* Handle MCS masks set by the user. * Match rates provided by the rate control algorithm to the mask set, also in HT mode, and switch back to legacy mode if necessary. * add debugfs files to observate the rate selection Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-30mac80211: station state transition error handlingJohannes Berg
In the future, when we start notifying drivers, state transitions could potentially fail. To make it easier to distinguish between programming bugs and driver failures: * rename sta_info_move_state() to sta_info_pre_move_state() which can only be called before the station is inserted (and check this with a new station flag). * rename sta_info_move_state_checked() to just plain sta_info_move_state(), as it will be the regular function that can fail for more than just one reason (bad transition or an error from the driver) This makes the programming model easier -- one of the functions can only be called before insertion and can't fail, the other can fail. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-27{nl,cfg,mac}80211: Add support of setting non-forwarding entity in MeshChun-Yeow Yeoh
A mesh node that joins the mesh network is by default a forwarding entity. This patch allows the mesh node to set as non-forwarding entity. Whenever dot11MeshForwarding is set to 0, the mesh node can prevent itself from forwarding the traffic which is not destined to him. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-27mac80211: make CQM RSSI support per virtual interfaceJohannes Berg
Similar to the previous beacon filtering patch, make CQM RSSI support depend on the flags that the driver set for virtual interfaces. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24mac80211: check sta_apply_parameters() return valueEliad Peller
Bail out if sta_apply_parameters() returns an error. Signed-off-by: Eliad Peller <eliad@wizery.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-13mac80211: fix no-op authorized transitionsJohannes Berg
When userspace attempts to authorize a station that is already authorized, nothing happens as you'd expect. Similarly, when it unauthorizes a station that is associated, nothing happens. However, when it unauthorizes a station that isn't even associated yet, we erroneously try to move the station to associated. This seems to happen occasionally as a result of a race when wpa_supplicant attempts to unauthorize the port in managed mode. Particularly with my new patches to keep stations, it can then move a station into ASSOCIATED state before we have really associated, which is really confusing. I introduced this bug in "mac80211: refactor station state transitions" Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-12net: reintroduce missing rcu_assign_pointer() callsEric Dumazet
commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTER) did a lot of incorrect changes, since it did a complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x, y). We miss needed barriers, even on x86, when y is not NULL. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-19cfg80211: Return beacon loss count in stationPaul Stewart
If station info contains a beacon loss count, return it to userspace. Signed-off-by: Paul Stewart <pstew@chromium.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-15mac80211: refactor station state transitionsJohannes Berg
Station entries can have various states, the most important ones being auth, assoc and authorized. This patch prepares us for telling the driver about these states, we don't want to confuse drivers with strange transitions, so with this we enforce that they move in the right order between them (back and forth); some transitions might happen before the driver even knows about the station, but at least runtime transitions will be ordered correctly. As a consequence, IBSS and MESH stations will now have the ASSOC flag set (so they can transition to AUTHORIZED), and we can get rid of a special case in TX processing. When freeing a station, unwind the state so that other parts of the code (or drivers later) can rely on the transitions. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-15mac80211: use station mutex in configurationJohannes Berg
There's no need to use RCU here, we can just lock the station mutex instead. This allows the code to sleep, which is necessary for later patches. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-15mac80211: remove duplicate TDLS peer verificationJohannes Berg
This is already checked in cfg80211, so no need to repeat the checks here. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-15cfg80211: validate nl80211 station handling betterJohannes Berg
The nl80211 station handling code is a bit messy and doesn't do a lot of validation. It seems like this could be an issue for drivers that don't use mac80211 to validate everything. As cfg80211 doesn't keep station state, move the validation of allowing supported_rates to change for TDLS only in station mode to mac80211. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28{nl,cfg,mac}80211: implement dot11MeshHWMPperrMinIntervalThomas Pedersen
As per 802.11mb 13.9.11.3 Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28{nl,cfg,mac}80211: Allow Setting Multicast Rate in MeshChun-Yeow Yeoh
Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: dereference RCU protected probe_resp pointer correctlyArik Nemtsov
This fixes a sparse warning: cfg.c:502:13: warning: incorrect type in assignment (different address spaces) cfg.c:502:13: expected struct sk_buff *old cfg.c:502:13: got struct sk_buff [noderef] <asn:4>*probe_resp Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: Add NoAck per tid supportSimon Wunderlich
This patch contains the processing changes in mac80211. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-21mac80211: Support ht-cap over-rides.Ben Greear
This implements ht-cap over-rides for mac80211 drivers. HT may be disabled, making an /a/b/g/n station act like an a/b/g station. HT40 may be disabled forcing the station to be HT20 even if the AP and local hardware support HT40. MAX-AMSDU may be disabled. AMPDU-Density may be increased. AMPDU-Factor may be decreased. This has been successfully tested with ath9k using patched wpa_supplicant and iw. Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-11mac80211: fix warning in ieee80211_probe_clientJohannes Berg
The warning is spurious -- if !sta we always exit without using the unassigned qos variable, and if we do find the sta we assign it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-11mac80211: Save probe response data for bssArik Nemtsov
Allow setting a probe response template for an interface operating in AP mode. Low level drivers are notified about changes in the probe response template and are able to retrieve a copy of the current probe response. This data can, for example, be uploaded to hardware as a template. Signed-off-by: Guy Eilam <guy@wizery.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-11mac80211/cfg80211: report monitor channel in wireless extensionsJohannes Berg
Just add API to get the channel & report it. Trivial really. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-11mac80211: init rate-control for TDLS sta when supp-rates are knownArik Nemtsov
Initialize rate control algorithms only when supported rates are known for a TDLS peer sta. Direct Tx between peers is not allowed before the link is enabled. In turn, this only occurs after a change_station() call that sets supported rates. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09mac80211: Also report the STA's TDLS flag via nl80211Helmut Schaa
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09cfg80211/mac80211: allow management TX to not wait for ACKJohannes Berg
For probe responses it can be useful to not wait for ACK to avoid retransmissions if the station that sent the probe is already on the next channel, so allow userspace to request not caring about the ACK with a new nl80211 flag. Since mac80211 needs to be updated for the new function prototype anyway implement it right away -- it's just a few lines of code. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09mac80211: support client probeJohannes Berg
Support probing clients with null data frames in AP mode. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09mac80211: add support for control port protocol in AP modeJohannes Berg
This will allow us to support dynamic WEP with 802.1X properly in mac80211 by not encrypting outgoing and accepting unencrypted incoming frames. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
2011-11-08mac80211: fix confusing parenthesesJohannes Berg
There's an extra pair of parentheses here that is simply confusing because it implies a nesting that doesn't actually exist. Just remove it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-02mac80211: Fix TDLS support validation in add_station handlerJouni Malinen
We need to verify whether the command is successful before allocating the station entry to avoid extra processing. This also fixes a memory leak on the error path. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-17Merge branch 'master' of ↵John W. Linville
git://git.infradead.org/users/linville/wireless-next into for-davem
2011-10-14mac80211: Provide station flags to cfg80211Helmut Schaa
Only station flags that are already defined in nl80211 are added for now. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-11mac80211: fix offchannel TX cookie matchingJohannes Berg
When I introduced in-kernel off-channel TX I introduced a bug -- the work can't be canceled again because the code clear the skb pointer. Fix this by keeping track separately of whether TX status has already been reported. Cc: stable@kernel.org [2.6.38+] Reported-by: Jouni Malinen <j@w1.fi> Tested-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-11Merge branch 'master' of ↵John W. Linville
git://git.infradead.org/users/linville/wireless-next into for-davem Conflicts: Documentation/feature-removal-schedule.txt
2011-09-30mac80211: optimise station flagsJohannes Berg
The flaglock in struct sta_info has long been something that I wanted to get rid of, this finally does the conversion to atomic bitops. The conversion itself is straight-forward in most places, a few things needed to change a bit since we can no longer use multiple bits at the same time. On x86-64, this is a fairly significant code size reduction: text data bss dec hex 427861 23648 1008 452517 6e7a5 before 425383 23648 976 450007 6ddd7 after Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-30mac80211: data path modification for TDLS peersArik Nemtsov
Mark the STA entries of enabled TDLS peers with a new "peer authorized" flag. During link setup, allow special TDLS setup frames through the AP, but otherwise drop all packets destined to the peer. This is required by the TDLS (802.11z) specification in order to prevent reordering of MSDUs between the AP and direct paths. When setup completes and the peer is authorized, send data directly, bypassing the AP. In the Rx path, allow data to be received directly from TDLS peers. Signed-off-by: Arik Nemtsov <arik@wizery.com> Cc: Kalyan C Gaddam <chakkal@iit.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-30nl80211/mac80211: allow adding TDLS peers as stationsArik Nemtsov
When adding a TDLS peer STA, mark it with a new flag in both nl80211 and mac80211. Before adding a peer, make sure the wiphy supports TDLS and our operating mode is appropriate (managed). In addition, make sure all peers are removed on disassociation. A TDLS peer is first added just before link setup is initiated. In later setup stages we have more info about peer supported rates, capabilities, etc. This info is reported via nl80211_set_station(). Signed-off-by: Arik Nemtsov <arik@wizery.com> Cc: Kalyan C Gaddam <chakkal@iit.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-30mac80211: handle TDLS high-level commands and framesArik Nemtsov
Register and implement the TDLS cfg80211 callback functions. Internally prepare and send TDLS management frames. We incorporate local STA capabilities and supported rates with extra IEs given by usermode. The resulting packet is either encapsulated in a data frame, or assembled as an action frame. It is transmitted either directly or through the AP, as mandated by the TDLS specification. Declare support for the TDLS external setup wiphy capability. This tells usermode to handle link setup and discovery on its own, and use the kernel driver for sending TDLS mgmt packets. Signed-off-by: Arik Nemtsov <arik@wizery.com> Cc: Kalyan C Gaddam <chakkal@iit.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-30cfg80211/mac80211: apply station uAPSD parameters selectivelyJohannes Berg
Currently, when hostapd sets the station as authorized we also overwrite its uAPSD parameter. This obviously leads to buggy behaviour (later, with my patches that actually add uAPSD support). To fix this, only apply those parameters if they were actually set in nl80211, and to achieve that add a bitmap of things to apply. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-30Merge branch 'master' of ↵John W. Linville
git://git.infradead.org/users/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/wl12xx/main.c
2011-09-27mac80211: save tx params per sdataEliad Peller
save and configure tx param per sdata, rather than per hardware. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-27cfg80211/mac80211: add netdev param to set_txq_params()Eliad Peller
tx params are currently configured per hw, although they should be configured per interface. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-27mac80211: Send the management frame at requested rateRajkumar Manoharan
Whenever the scan request or tx_mgmt is requesting not to use CCK rate for managemet frames through NL80211_ATTR_TX_NO_CCK_RATE attribute, then mac80211 should select appropriate least non-CCK rate. This could help to send P2P probes and P2P action frames at non 11b rates without diabling 11b rates globally. Cc: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-27nl80211/cfg80211: Add support to disable CCK rate for management frameRajkumar Manoharan
Add a new nl80211 attribute to specify whether to send the management frames in CCK rate or not. As of now the wpa_supplicant is disabling CCK rate at P2P init itself. So this patch helps to send P2P probe request/probe response/action frames being sent at non CCK rate in 2GHz without disabling 11b rates. This attribute is used with NL80211_CMD_TRIGGER_SCAN and NL80211_CMD_FRAME commands to disable CCK rate for management frame transmission. Cc: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-19Merge branch 'master' of ssh://infradead/~/public_git/wireless-next into ↵John W. Linville
for-davem
2011-09-14mac80211: add ssid config to bss information in AP-modeArik Nemtsov
Set SSID information from nl80211 beacon parameters. Advertise changes in SSID to low level drivers. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-13mac80211: Remove mesh paths when an interface is removedJavier Cardona
When an interface is removed, the mesh paths associated with it should also be removed. This fixes a bug we observed when reloading a device driver module without reloading mac80211s. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
