commit 05cb91085760ca378f28fc274fbf77fc4fd9886c upstream.
Only AID values 1-2007 are valid, but some APs have been
found to send random bogus values, in the reported case an
AP that was sending the AID field value 0xffff, an AID of
0x3fff (16383).
There isn't much we can do but disable powersave since
there's no way it can work properly in this case.
Reported-by: Bill C Riemers <briemers@redhat.com>
commit 28a1bcdb57d50f3038a255741ecc83e391e5282e upstream.
When I introduced in-kernel off-channel TX I
introduced a bug -- the work can't be canceled
again because the code clear the skb pointer.
Fix this by keeping track separately of whether
TX status has already been reported.
Reported-by: Jouni Malinen <j@w1.fi>
Tested-by: Jouni Malinen <j@w1.fi>
This reverts commit aac6af5534fade2b18682a0b9efad1a6c04c34c6.
net/mac80211/key.c
That commit has a race that causes a warning, as documented in the thread
here:
http://marc.info/?l=linux-wireless&m=130717684914101&w=2
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/iwlwifi/iwl-agn-tx.c
net/mac80211/sta_info.h
This adds sparse RCU annotations to most of
mac80211, only the mesh code remains to be
done.
Due the the previous patches, the annotations
are pretty simple. The only thing that this
actually changes is removing the RCU usage of
key->sta in debugfs since this pointer isn't
actually an RCU-managed pointer (it only has
a single assignment done before the key even
goes live). As that is otherwise harmless, I
decided to make it part of this patch.
When sched_scan_stopped was called by the driver, mac80211 calls
cfg80211, which in turn was calling mac80211 back with a flag
"driver_initiated". This flag was used so that mac80211 would do the
necessary cleanup but would not call the driver. This was enough to
prevent the bounce back between the driver and mac80211, but not
between mac80211 and cfg80211.
To fix this, we now do the cleanup in mac80211 before calling
cfg80211. To help with locking issues, the workqueue was moved from
cfg80211 to mac80211.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Luciano Coelho <coelho@ti.com>
Implement support for HW scheduled scan. The mac80211 code doesn't perform
scheduled scans itself, but calls the driver to start and stop scheduled
scans.
This patch also creates a trace event class to be used by drv_hw_scan
and the new drv_sched_scan_start and drv_sched_stop functions, in
order to avoid duplicate code.
Introduce a new configuration option to support AMPE from userspace.
Prior to this series we only supported authentication in userspace: an
authentication daemon would authenticate peer candidates in userspace
and hand them over to the kernel. From that point the mesh stack would
take over and establish a peer link (Mesh Peering Management).
These patches introduce support for Authenticated Mesh Peering Exchange
in userspace. The userspace daemon implements the AMPE protocol and on
successfull completion create mesh peers and install encryption keys.
Signed-off-by: Javier Cardona <javier@cozybit.com>
This adds basic support for the new WoWLAN
configuration in mac80211. The behaviour is
completely offloaded to the driver though,
with two new callbacks (suspend/resume).
Options for the driver include a complete
reconfiguration after wakeup, and exposing
all the triggers it wants to support.
drivers/net/wireless/libertas/if_cs.c
drivers/net/wireless/rtlwifi/pci.c
net/bluetooth/l2cap_sock.c
In xmit path, devices that do full hardware crypto (including
TKIP MMIC) need no tailroom. For such devices, tailroom
reservation can be skipped if all the keys are programmed into
the hardware (i.e software crypto is not used for any of the
keys) and none of the keys wants software to generate Michael
MIC.
Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com>
drivers/net/wireless/iwlwifi/iwl-core.c
drivers/net/wireless/rt2x00/rt2x00queue.c
drivers/net/wireless/rt2x00/rt2x00queue.h
To NL80211_MESH_SETUP_IE. This reflects our ability to insert any ie
into a mesh beacon, not simply path selection ies.
drivers/net/wireless/ath/ar9170/main.c
drivers/net/wireless/ath/ar9170/phy.c
drivers/net/wireless/zd1211rw/zd_rf_rf2959.c
The only thing that using crypto_blkcipher with ecb does over just using
arc4 directly is wrapping the encrypt/decrypt function into a for loop,
looping over each individual character.
To be able to do this, it pulls in around 40 kb worth of unnecessary
kernel modules (at least on a MIPS embedded device).
Using arc4 directly not only eliminates those dependencies, it also makes
the code smaller.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
For devices supported by iwlwifi sometimes
off-channel transmissions need to be handled
by the device completely. To support this
mac80211 needs to pass the frame directly
to the driver and not through the TX path
as the driver needs the frame and channel
information at the same time.
drivers/bluetooth/ath3k.c
drivers/bluetooth/btusb.c
The module parameter ieee80211_disable_40mhz_24ghz
was meant to allow disabling 40 MHz operation in
the 2.4 GHz band by default. However, it is buggy
as implemented because while it advertises to the
AP that the device doesn't support 40 MHz, it will
itself still use 40 MHz configurations.
To fix this, clear the 40 MHz bits from the sband
completely instead of overriding where used.
This should decrease un-necessary flushes, on/off channel work,
and channel changes in cases where the only scanned channel is
the current operating channel.
* Removes SCAN_OFF_CHANNEL flag, uses SDATA_STATE_OFFCHANNEL
and is-scanning flags instead.
* Add helper method to determine if we are currently configured
for the operating channel.
* Do no blindly go off/on channel in work.c Instead, only call
appropriate on/off code when we really need to change channels.
Always enable offchannel-ps mode when starting work,
and disable it when we are done.
* Consolidate ieee80211_offchannel_stop_station and
ieee80211_offchannel_stop_beaconing, call it
ieee80211_offchannel_stop_vifs instead.
* Accept non-beacon frames when scanning on operating channel.
* Scan state machine optimized to minimize on/off channel
transitions. Also, when going on-channel, go ahead and
re-enable beaconing. We're going to be there for 200ms,
so seems like some useful beaconing could happen.
Always enable offchannel-ps mode when starting software
scan, and disable it when we are done.
* Grab local->mtx earlier in __ieee80211_scan_completed_finish
so that we are protected when calling hw_config(), etc.
* Pass probe-responses up the stack if scanning on local
channel, so that mlme can take a look.
Signed-off-by: Ben Greear <greearb@candelatech.com>
On review of 'zd1211rw: implement beacon fetching and handling
ieee80211_get_buffered_bc()', Christian Lamparter noted that [1]:
Since zd_beacon_done also uploads the next beacon so long in advance,
there could be an equally long race between the outdated state of the
next beacon's DTIM broadcast traffic indicator (802.11-2007 7.3.2.6)
which -in your case- was uploaded almost a beacon interval ago and
the xmit of ieee80211_get_buffered_bc *now*.
The dtim bc/mc bit might be not set, when a mc/bc arrived after the
beacon was uploaded, but before the "beacon done event" from the
hardware. So, dozing stations don't expect the broadcast traffic
and of course, they might miss it completely.
It's probably better to fix this in mac80211 (see the attached hack).
[1] http://marc.info/?l=linux-wireless&m=129435041117256&w=2
CC: Christian Lamparter <chunkeey@googlemail.com>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
When the off-channel TX is done with remain-on-channel
offloaded to hardware, the reported cookie is wrong as
in that case we shouldn't use the SKB as the cookie but
need to instead use the corresponding r-o-c cookie
(XOR'ed with 2 to prevent API mismatches).
Fix this by keeping track of the hw_roc_skb pointer
just for the status processing and use the correct
cookie to report in this case. We can't use the
hw_roc_skb pointer itself because it is NULL'ed when
the frame is transmitted to prevent it being used
twice.
This fixes a bug where the P2P state machine in the
supplicant gets stuck because it never gets a correct
result for its transmitted frame.
When the driver has remain-on-channel offload,
implement off-channel transmission using that
primitive.
This allows drivers to support remain-on-channel
offload if they implement smarter timing or need
to use a device implementation like iwlwifi.
net/bluetooth/Makefile
This patch addresses the issue of serialization between
the main rx path and various reorder release timers.
<http://www.spinics.net/lists/linux-wireless/msg57214.html>
It converts the previously local "frames" queue into
a global rx queue [rx_skb_queue]. This way, everyone
(be it the main rx-path or some reorder release timeout)
can add frames to it.
Only one active rx handler worker [ieee80211_rx_handlers]
is needed. All other threads which have lost the race of
"runnning_rx_handler" can now simply "return", knowing that
the thread who had the "edge" will also take care of their
workload.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
This patch tackles one of the problems of my
reorder release timer patch from August.
What if the reorder release triggers and ap_sta_ps_end
(called by ieee80211_rx_h_sta_process) accidentally clears
the WLAN_STA_PS_STA flag, because 100ms ago - when the STA
was still active - frames were put into the reorder buffer.
If CONFIG_MAC80211_LEDS is not set, ieee80211_i.h was failing to compile,
because struct led_trigger is only declared when CONFIG_LEDS_TRIGGERS is
set.
This patch adds ifdefs around the tpt_led_trigger declaration in
ieee80211_i.h to avoid the problem.
Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
The throughput LED trigger was always active when
the radio was enabled. In most cases that's likely
the desired behaviour, but iwlwifi requires it to
be only active when one of the virtual interfaces
is actually "connected" in some way.
iwlwifi and other drivers like to blink their LED
based on throughput. Implement this generically in
mac80211, based on a throughput table the driver
specifies. That way, drivers can set the blink
frequencies depending on their desired behaviour
and max throughput.
All the drivers need to do is provide an LED class
device, best with blink hardware offload.
Userspace will now be allowed to toggle between the default path
selection algorithm (HWMP, implemented in the kernel), and a vendor
specific alternative. Also in the same patch, allow userspace to add
information elements to mesh beacons. This is accordance with the
Extensible Path Selection Framework specified in version 7.0 of the
802.11s draft.
Add support for split default keys (unicast
and multicast) in mac80211.
Instead of tying mesh activity to interface up,
add join and leave commands for mesh. Since we
must be backward compatible, let cfg80211 handle
joining a mesh if a mesh ID was pre-configured
when the device goes up.
Note that this therefore must modify mac80211 as
well since mac80211 needs to lose the logic to
start the mesh on interface up.
We now allow querying mesh parameters before the
mesh is connected, which simply returns defaults.
Setting them (internally renamed to "update") is
only allowed while connected. Specify them with
the new mesh join command instead where needed.
In mac80211, beaconing must now also follow the
mesh enabled/not enabled state, which is done
by testing the mesh ID.
If the nullfunc frame used to probe the AP was not acked, there is no point
in waiting for the probe timeout, so advance to the next try (or disconnect)
immediately.
If we do reach the probe timeout without having received a tx status, the
connection is probably really bad and worth disconnecting.
This implements the new off-channel TX API
in mac80211 with a new work item type. The
operation doesn't add a new work item when
we're on the right channel and there's no
wait time so that for example p2p probe
responses will be transmitted without delay.
nullfunc frames are better for connection monitoring, because probe requests
are answered even if the AP has already dropped the connection, whereas
nullfunc frames from an unassociated station will trigger a disassoc/deauth
frame from the AP (WLAN_REASON_CLASS3_FRAME_FROM_NONASSOC_STA), which allows
the station to reconnect immediately instead of waiting until it attempts to
transmit the next unicast frame.
This only works on hardware with reliable tx ACK reporting, any other hardware
needs to fall back to the probe request method.
Instead of using a fixed 2 second timeout, calculate beacon loss interval
from the advertised beacon interval and a frame count. With this beacon
loss happens after N (default 7) consecutive frames are missed which
for a typical setup (100TU beacon interval) is ~700ms (or ~1/3 previous).
Signed-off-by: Sam Leffler <sleffler@chromium.org>
The code to handle powersaving stations has a race:
when the powersave flag is lifted from a station,
we could transmit a packet that is being processed
for TX at the same time right away, even if there
are other frames queued for it. This would cause
frame reordering. To fix this, lift the flag only
under the appropriate lock that blocks TX.
Additionally, the code to allow drivers to block a
station while frames for it are on the HW queue is
never re-enabled the station, so traffic would get
stuck indefinitely. Fix this by clearing the flag
for this appropriately.
Finally, as an optimisation, don't do anything if
the driver unblocks an already unblocked station.
Chipsets with hardware based connection monitoring need to autonomically
send directed probe-request frames to the AP (in the event of beacon loss,
for example.)
For the hardware to be able to do this, it requires a template for the frame
to transmit to the AP, filled in with the BSSID and SSID of the AP, but also
the supported rate IE's.
This patch adds a function to mac80211, which allows the hardware driver to
fetch this template after association, so it can be configured to the hardware.
Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com>
Using the frame registration notification, we
can see when probe requests are requested and
notify the low-level driver via filtering. The
flag is also set in AP and IBSS modes.
This adds API to allow adding per-station GTKs,
updates mac80211 to support it, and also allows
drivers to remove a key from hwaccel again when
this may be necessary due to multiple GTKs.
When roaming while we have active BA session,
we can end up transmitting delBA frames to
the old AP while we're already on the new AP's
channel, which can cause warnings.
Simply avoid sending those frames, but still
tear down the internal session state, since
they are not really necessary anyway as we
will implicitly disassociate when sending the
association to the new AP.
Acked-by: Luis R. Rodriguez <lrodriguez@atheros.com>
The locking around ieee80211_recalc_smps is
buggy -- it cannot acquire another interface's
mutex while the iflist mutex is held because
another code path could be holding the iface
mutex and trying to acquire the iflist mutex.
But the locking is also unnecessary, we only
check "ifmgd->associated" as a bool, and don't
use the pointer (in check_mgd_smps).
Reported-by: Ben Greear <greearb@candelatech.com>
On association to an AP, after receiving beacons, the beacon_crc value is set.
The beacon_crc value is not reset in disassociation, but the BSS data may be
expired at a later point. When associating again, it's possible that a
beacon for the AP is not received, resulting in the beacon_ies to remain NULL.
After association, further beacons will not update the beacon data, as the
crc value of the beacon has not changed, and the beacon_crc still holds a
value matching the beacon. The beacon_ies will remain forever null.
One of the results of this is that WLAN power save cannot be entered, the STA
will remain foreven in active mode.
Fix this by adding a validation flag for the beacon_crc, which is cleared on
association.
This patch fixes an refcounting bug. Previously it
was possible to corrupt the per-device recv. filter
and monitor management counters when:
iw dev wlanX set monitor [new flags]
was issued on an active monitor interface.
Acked-by: Johannes Berg <johannes.berg@intel.com>
commit 8c0c709eea5cbab97fb464cd68b06f24acc58ee1
Author: Johannes Berg <johannes@sipsolutions.net>
Date: Wed Nov 25 17:46:15 2009 +0100
mac80211: move cmntr flag out of rx flags
moved the CMNTR flag into the skb RX flags for
some aggregation cleanups, but this was wrong
since the optimisation this flag tried to make
requires that it is kept across the processing
of multiple interfaces -- which isn't true for
flags in the skb. The patch not only broke the
optimisation, it also introduced a bug: under
some (common!) circumstances the flag will be
set on an already freed skb!
However, investigating this in more detail, I
found that most of the flags that we set should
be per packet, _except_ for this one, due to
a-MPDU processing. Additionally, the flags used
for processing (currently just this one) need
to be reset before processing a new packet.
Since we haven't actually seen bugs reported as
a result of the wrong flags handling (which is
not too surprising -- the only real bug case I
can come up with is an a-MSDU contained in an
a-MPDU), I'll make a different fix for rc.
Create 'stations' sub-directory under each netdev:[vif-name]
directory to hold all stations for that network device.
IEEE Std 802.11k-2008 added DS Parameter Set information element into
Probe Request frames as an optional information on 2.4 GHz band (and
mandatory, if radio measurements are enabled). This allows APs to
filter out Probe Request frames that may be received from neighboring
overlapping channels and by doing so, reduce the number of unnecessary
frames in the air. Make mac80211 add this IE into Probe Request frames
whenever the channel is known (i.e., whenever hwscan is not used).
Signed-off-by: Jouni Malinen <j@w1.fi>
If the TX rate set has been masked, the removed rates can also be
removed from the Supported Rates and Extended Supported Rates IEs in
Probe Request frames.
