commit f8d1ccf15568268c76f913b45ecdd33134387f1a upstream.
When receiving failed PLCP frames is enabled, there
won't be a rate pointer when we add the radiotap
header and thus the kernel will crash. Fix this by
not assuming the rate pointer is always valid. It's
still always valid for frames that have good PLCP
though, and that is checked & enforced.
This was broken by my
commit fc88518916793af8ad6a02e05ff254d95c36d875
Author: Johannes Berg <johannes.berg@intel.com>
Date: Fri Jul 30 13:23:12 2010 +0200
mac80211: don't check rates on PLCP error frames
where I removed the check in this case but didn't
take into account that the rate info would be used.
Reported-by: Xiaokang Qin <xiaokang.qin@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/iwlwifi/iwl-agn-tx.c
net/mac80211/sta_info.h
Currently the devices that have already stripped IEEE 802.11
header from the AMSDU SKB can not use ieee80211_amsdu_to_8023s
routine. This patch enhances ieee80211_amsdu_to_8023s() API by
changing mandatory removing of IEEE 802.11 header from AMSDU
to optional.
Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
These definitions need to be exposed now that we can set the peer link
states via NL80211_ATTR_STA_PLINK_STATE. They were already being
(opaquely) reported by NL80211_STA_INFO_PLINK_STATE.
Signed-off-by: Javier Cardona <javier@cozybit.com>
Implement support for HW scheduled scan. The mac80211 code doesn't perform
scheduled scans itself, but calls the driver to start and stop scheduled
scans.
This patch also creates a trace event class to be used by drv_hw_scan
and the new drv_sched_scan_start and drv_sched_stop functions, in
order to avoid duplicate code.
Signed-off-by: Luciano Coelho <coelho@ti.com>
Note: This breaks compatibility with previous mesh protocol instances.
drivers/net/wireless/libertas/if_cs.c
drivers/net/wireless/rtlwifi/pci.c
net/bluetooth/l2cap_sock.c
Currently, mac80211 handles MIC failures differently
depending on whenever they are detected by the stack's
own software crypto or when are handed down from the
driver.
This patch tries to unify both by moving the special
branch out of mac80211 rx hotpath and into into the
software crypto part. This has the advantage that we
can run a few more sanity checks on the data and verify
if the key type was TKIP. This is very handy because
several devices generate false postive MIC failure
reports. Like carl9170, ath9k and wl12xx:
<http://www.spinics.net/lists/linux-wireless/msg68494.html>
"mac80211: report MIC failure for truncated packets in AP mode"
Cc: Luciano Coelho <coelho@ti.com>
Cc: Arik Nemtsov <arik@wizery.com>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
The release timer has to expire "just" after a
frame is up for release. Currently, if the timer
callback starts on time, the "!time_after" check
above will start a new timer instead of
releasing the frames.
drivers/net/wireless/iwlwifi/iwl-core.c
drivers/net/wireless/rt2x00/rt2x00queue.c
drivers/net/wireless/rt2x00/rt2x00queue.h
Apparently this was confusing still ... add a
note that the byte is needed as padding.
This makes it easier to handle moving stations to VLAN interfaces that are
part of a different bridge.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
drivers/net/wireless/ath/ar9170/main.c
drivers/net/wireless/ath/ar9170/phy.c
drivers/net/wireless/zd1211rw/zd_rf_rf2959.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits)
net: Add support for SMSC LAN9530, LAN9730 and LAN89530
mlx4_en: Restoring RX buffer pointer in case of failure
mlx4: Sensing link type at device initialization
ipv4: Fix "Set rt->rt_iif more sanely on output routes."
MAINTAINERS: add entry for Xen network backend
be2net: Fix suspend/resume operation
be2net: Rename some struct members for clarity
pppoe: drop PPPOX_ZOMBIEs in pppoe_flush_dev
dsa/mv88e6131: add support for mv88e6085 switch
ipv6: Enable RFS sk_rxhash tracking for ipv6 sockets (v2)
be2net: Fix a potential crash during shutdown.
bna: Fix for handling firmware heartbeat failure
can: mcp251x: Allow pass IRQ flags through platform data.
smsc911x: fix mac_lock acquision before calling smsc911x_mac_read
iwlwifi: accept EEPROM version 0x423 for iwl6000
rt2x00: fix cancelling uninitialized work
rtlwifi: Fix some warnings/bugs
p54usb: IDs for two new devices
wl12xx: fix potential buffer overflow in testmode nvs push
zd1211rw: reset rx idle timer from tasklet
drivers/net/wireless/rtlwifi/efuse.c
drivers/net/wireless/rtlwifi/rtl8192c/fw_common.c
net/bluetooth/mgmt.c
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
Cleaning the ieee80211_rx_data.flags field here is wrong, instead the
flags should be valid accross processing the frame on different
interfaces. Fix this by removing the incorrect flags=0 assignment.
Introduced in commit 554891e63a29af35cc6bb403ef34e319518114d0
(mac80211: move packet flags into packet).
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
Took me a minute to figure this out, maybe
it's better documented...
Suppose the aggregation reorder buffer looks like this:
x-T-R1-y-R2,
where x and y are frames that have not been received, T is a received
frame that has timed out, and R1,R2 are received frames that have not
yet timed out. The proper behavior in this scenario is to move the
window past x (skipping it), release T and R1, and leave the window at y
until y is received or R2 times out.
As written, this code will instead leave the window at R1, because it
has not yet timed out. Fix this by exiting the reorder loop only when
the frame that has not timed out AND there are skipped frames earlier in
the current valid window.
Signed-off-by: Daniel Halperin <dhalperi@cs.washington.edu>
The flag isn't very descriptive -- the intention
is that the driver provides a TSF timestamp at
the beginning of the MPDU -- make that clearer
by renaming the flag to RX_FLAG_MACTIME_MPDU.
ieee80211_rx_h_check returned RX_DROP_MONITOR in case the if statement
in question was true but the same return value is also used directly
after the if clause. Hence, we can just drop the whole if clause and as
such simplify the code.
mac80211 now supports passing MCS index to radiotap, so update the
comments regarding this
Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com>
Since 4-addr frames completely override the source address which will
make it into the converted 802.3 frames, receiving frames for other
4-addr stations will confuse the bridging code.
To be able to handle traffic for all connected devices, the bridge
code will automatically turn on promiscuous mode, which triggers
this problem.
Reported-by: Steve Brown <sbrown@cortland.com>
This should decrease un-necessary flushes, on/off channel work,
and channel changes in cases where the only scanned channel is
the current operating channel.
* Removes SCAN_OFF_CHANNEL flag, uses SDATA_STATE_OFFCHANNEL
and is-scanning flags instead.
* Add helper method to determine if we are currently configured
for the operating channel.
* Do no blindly go off/on channel in work.c Instead, only call
appropriate on/off code when we really need to change channels.
Always enable offchannel-ps mode when starting work,
and disable it when we are done.
* Consolidate ieee80211_offchannel_stop_station and
ieee80211_offchannel_stop_beaconing, call it
ieee80211_offchannel_stop_vifs instead.
* Accept non-beacon frames when scanning on operating channel.
* Scan state machine optimized to minimize on/off channel
transitions. Also, when going on-channel, go ahead and
re-enable beaconing. We're going to be there for 200ms,
so seems like some useful beaconing could happen.
Always enable offchannel-ps mode when starting software
scan, and disable it when we are done.
* Grab local->mtx earlier in __ieee80211_scan_completed_finish
so that we are protected when calling hw_config(), etc.
* Pass probe-responses up the stack if scanning on local
channel, so that mlme can take a look.
Signed-off-by: Ben Greear <greearb@candelatech.com>
I can't think of a valid use case for this aside from debugging (which can
also be done with a real monitor interface), and dropping these frames saves
some precious CPU cycles.
While leaving oper channel, STA informs sleep state to AP to
stop sending data. Till sending ack for the nullfunc, AP
continues to send the data to STA which restarts ps_timer that
is causing unnecessary nullfunc exchange on timer expiry
when the STA was already moved to offchannel. So don't restart ps_timer
on data reception during scan. This issue was identified by
the following warning.
WARNING: at net/mac80211/tx.c:661 invoke_tx_handlers+0xf07/0x1330 [mac80211]
wlan0: Dropped data frame as no usable bitrate found while scanning and
associated. Target station: 00:03:7f:0b:a6:1b on 5 GHz band
Call Trace:
[<ffffffffa0413ba7>] invoke_tx_handlers+0xf07/0x1330 [mac80211]
[<ffffffffa0414056>] ieee80211_tx+0x86/0x2c0 [mac80211]
[<ffffffffa0414345>] ieee80211_xmit+0xb5/0x1d0 [mac80211]
[<ffffffffa04037e0>] ieee80211_dynamic_ps_enable_work+0x0/0xb0 [mac80211]
[<ffffffffa04158cf>] ieee80211_tx_skb+0x4f/0x60 [mac80211]
[<ffffffffa04026e6>] ieee80211_send_nullfunc+0x46/0x60 [mac80211]
[<ffffffffa0403885>] ieee80211_dynamic_ps_enable_work+0xa5/0xb0 [mac80211]
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com>
Beacons from external BSSes are required for updating overlapping BSS
info (i.e. ERP protection). Pass them up unconditionally.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
When operating in AP mode the wl1271 hardware filters out null-data
packets as well as management packets. This makes it impossible for
mac80211 to monitor the PS mode by using the PM bit of incoming frames.
Implement a HW flag to indicate that mac80211 should ignore the PM bit.
In addition, expose ieee80211_sta_ps_transition() to make low-level
drivers capable of controlling PS-mode.
This adds the MCS information we currently get
from the drivers into radiotap.
This particular error isn't about multicast.
When running as a 4-addr station against an AP that has the 4-addr VLAN
interface and the main 3-addr AP interface bridged together, sometimes
frames originating from the station were looping back from the 3-addr AP
interface, causing the bridge code to emit warnings about receiving frames
with its own source address.
I'm not sure why this is happening yet, but I think it's a good idea to
drop all frames (except 802.1x/EAP frames) that do not match the configured
addressing mode, including 4-address frames sent to a 3-address station.
User test reports indicate that the problem goes away with this patch.
net/bluetooth/Makefile
This reverts enables the reorder release timer once again.
The issues laid out in:
<http://www.spinics.net/lists/linux-wireless/msg57214.html>
Have been addressed by:
mac80211: serialize rx path workers
mac80211: ignore PSM bit of reordered frames
This patch addresses the issue of serialization between
the main rx path and various reorder release timers.
It converts the previously local "frames" queue into
a global rx queue [rx_skb_queue]. This way, everyone
(be it the main rx-path or some reorder release timeout)
can add frames to it.
Only one active rx handler worker [ieee80211_rx_handlers]
is needed. All other threads which have lost the race of
"runnning_rx_handler" can now simply "return", knowing that
the thread who had the "edge" will also take care of their
workload.
This patch tackles one of the problems of my
reorder release timer patch from August.
What if the reorder release triggers and ap_sta_ps_end
(called by ieee80211_rx_h_sta_process) accidentally clears
the WLAN_STA_PS_STA flag, because 100ms ago - when the STA
was still active - frames were put into the reorder buffer.
Commit b51aff057c9d0ef6c529dc25fd9f775faf7b6c63 said:
Under memory pressure, the mac80211 mesh code
may helpfully print a message that it failed
to clone a mesh frame and then will proceed
to crash trying to use it anyway. Fix that.
Avoid the reference whenever the frame copy is unsuccessful
regardless of the debug message being suppressed or printed.
Cc: stable@kernel.org [2.6.27+]
Signed-off-by: Milton Miller <miltonm@bga.com>
net/ipv4/fib_frontend.c
iwlwifi and other drivers like to blink their LED
based on throughput. Implement this generically in
mac80211, based on a throughput table the driver
specifies. That way, drivers can set the blink
frequencies depending on their desired behaviour
and max throughput.
All the drivers need to do is provide an LED class
device, best with blink hardware offload.
Acked-by: Javier Cardona <javier@cozybit.com>
Let path selection frames for protocols other than HWMP be sent to
userspace via NL80211_CMD_REGISTER_FRAME. Also allow userspace to send
and receive mesh path selection frames.
Add a new notification to indicate that a received, unprotected
Deauthentication or Disassociation frame was dropped due to
management frame protection being in use. This notification is
needed to allow user space (e.g., wpa_supplicant) to implement
SA Query procedure to recover from association state mismatch
between an AP and STA.
This is needed to avoid getting stuck in non-working state when MFP
(IEEE 802.11w) is used and a protected Deauthentication or
Disassociation frame is dropped for any reason. After that, the
station would silently discard any unprotected Deauthentication or
Disassociation frame that could be indicating that the AP does not
have association for the STA (when the Reason Code would be 6 or 7).
IEEE Std 802.11w-2009, 11.13 describes this recovery mechanism.
Signed-off-by: Jouni Malinen <j@w1.fi>
Using the default key for "any key set" isn't
quite what we should do. It works, but with the
upcoming changes it makes life unnecessarily
complex, so do something better here and really
check for "any key".
Extend nl80211 to report an exponential weighted moving average (EWMA) of the
signal value. Since the signal value usually fluctuates between different
packets, an average can be more useful than the value of the last packet.
This uses the recently added generic EWMA library function.
v2: fix ABI breakage and change factor to be a power of 2.
Signed-off-by: Bruno Randolf <br1@einfach.org>
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
Remove a superfluous ieee80211_is_data check as that was checked a few
lines before already and we wont't get here for non-data frames at all.
Second, the frame was already converted to 802.3 header format and
reading the fc and addr1 fields was only possible because the 802.3
header is short enough and didn't overwrite the relevant parts of the
802.11 header. Make the code more obvious by checking the ethernet
header's h_dest field.
Furthermore reorder the conditions to reduce the number of checks
when dynamic powersave is not needed (AP mode for example).
Th commit titled "mac80211: clean up rx handling wrt. found_sta"
removed found_sta variable which caused a MIC failure event
to be reported twice for a single failure to supplicant resulted
in STA disconnect.
This should fix WPA specific countermeasures WiFi test case (5.2.17)
issues with mac80211 based drivers which report MIC failure events in
rx status.
Cc: Stable <stable@kernel.org> (2.6.37)
Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com>
