path: root/net/mac80211/wme.c
2010-01-05mac80211: fix skb buffering issueJohannes Berg
Since I removed the master netdev, we've been keeping internal queues only, and even before that we never told the networking stack above the virtual interfaces about congestion. This means that packets are queued in mac80211 and the upper layers never know, possibly leading to memory exhaustion and other problems. This patch makes all interfaces multiqueue and uses ndo_select_queue to put the packets into queues per AC. Additionally, when the driver stops a queue, we now stop all corresponding queues for the virtual interfaces as well. The injection case will use VO by default for non-data frames, and BE for data frames, but downgrade any data frames according to ACM. It needs to be fleshed out in the future to allow chosing the queue/AC in radiotap. Reported-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org [2.6.32] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24mac80211: remove master netdevJohannes Berg
With the internal 'pending' queue system in place, we can simply put packets there instead of pushing them off to the master dev, getting rid of the master interface completely. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211: do not pass PS frames out of mac80211 againJohannes Berg
In order to handle powersave frames properly we had needed to pass these out to the device queues again, and introduce the skb->requeue bit. This, however, also has unnecessary overhead by needing to 'clean up' already tried frames, and this clean-up code is also buggy when software encryption is used. Instead of sending the frames via the master netdev queue again, simply put them into the pending queue. This also fixes a problem where frames for that particular station could be reordered when some were still on the software queues and older ones are re-injected into the software queue after them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-22wireless: move some utility functions from mac80211 to cfg80211Zhu Yi
The patch moves some utility functions from mac80211 to cfg80211. Because these functions are doing generic 802.11 operations so they are not mac80211 specific. The moving allows some fullmac drivers to be also benefit from these utility functions. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-13mac80211: make noack test availableJohannes Berg
There's this internal wifi_wme_noack_test variable that we use to set the QoS control if set. For one, it is unlikely that it is set. Secondly, if set it needs to influence the IEEE80211_TX_CTL_NO_ACK TX control flag, and finally we should also be able to set it at all, so make it available in debugfs. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16mac80211: Fix WMM ACM parsing and AC downgrade operationJouni Malinen
Incorrect local->wmm_acm bits were set for AC_BK and AC_BE. Fix this and add some comments to make it easier to understand the AC-to-UP(pair) mapping. Set the wmm_acm bits (and show WMM debug) even if the driver does not implement conf_tx() handler. In addition, fix the ACM-based AC downgrade code to not use the highest priority in error cases. We need to break the loop to get the correct AC_BK value (3) instead of returning 0 (which would indicate AC_VO). The comment here was not really very useful either, so let's provide somewhat more helpful description of the situation. Since it is very unlikely that the ACM flag would be set for AC_BK and AC_BE, these bugs are not likely to be seen in real life networks. Anyway, better do these things correctly should someone really use silly AP configuration (and to pass some functionality tests, too). Remove the TODO comment about handling ACM. Downgrading AC is perfectly valid mechanism for ACM. Eventually, we may add support for WMM-AC and send a request for a TS, but anyway, that functionality won't be here at the location of this TODO comment. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27mac80211: fix aggregation for hardware with ampdu queuesJohannes Berg
Hardware with AMPDU queues currently has broken aggregation. This patch fixes it by making all A-MPDUs go over the regular AC queues, but keeping track of the hardware queues in mac80211. As a first rough version, it actually stops the AC queue for extended periods of time, which can be removed by adding buffering internal to mac80211, but is currently not a huge problem because people rarely use multiple TIDs that are in the same AC (and iwlwifi currently doesn't operate as AP). This is a short-term fix, my current medium-term plan, which I hope to execute soon as well, but am not sure can finish before .30, looks like this: 1) rework the internal queuing layer in mac80211 that we use for fragments if the driver stopped queue in the middle of a fragmented frame to be able to queue more frames at once (rather than just a single frame with its fragments) 2) instead of stopping the entire AC queue, queue up the frames in a per-station/per-TID queue during aggregation session initiation, when the session has come up take all those frames and put them onto the queue from 1) 3) push the ampdu queue layer abstraction this patch introduces in mac80211 into the driver, and remove the virtual queue stuff from mac80211 again This plan will probably also affect ath9k in that mac80211 queues the frames instead of passing them down, even when there are no ampdu queues. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: Re-enable aggregationSujith
Wireless HW without any dedicated queues for aggregation do not need the ampdu_queues mechanism present right now in mac80211. Since mac80211 is still incomplete wrt TX MQ changes, do not allow aggregation sessions for drivers that set ampdu_queues. This is only an interim hack until Intel fixes the requeue issue. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: Luis Rodriguez <Luis.Rodriguez@Atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-27mac80211: convert to %pM away from print_macJohannes Berg
Also remove a few stray DECLARE_MAC_BUF that were no longer used at all. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-30mac80211: fixups for "make master iface not wireless"Johannes Berg
In "mac80211: make master iface not wireless" I accidentally forgot to include these changes ... leading to the expected BUG_ON errors. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-20net: Use hton[sl]() instead of __constant_hton[sl]() where applicableArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-15mac80211: share STA information with driverJohannes Berg
This patch changes mac80211 to share some more data about stations with drivers. Should help iwlwifi and ath9k when they get around to updating, and might also help with implementing rate control algorithms without internals. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Sujith Manoharan <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29mac80211: Use only precedence level of DSCP field for frame classificationDaniel Wagner
Bit 4-5 of DSCP should not be considered by classify_d1. The 802.11 QoS Priority field is only depending on the precedence level. Signed-off-by: Daniel Wagner <wagi@monom.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-02mac80211: Use queue_lock() in ieee80211_ht_agg_queue_remove().David S. Miller
qdisc_root_lock() is only %100 safe to use when the RTNL semaphore is held. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-29mac80211: partially fix skb->cb useJohannes Berg
This patch fixes mac80211 to not use the skb->cb over the queue step from virtual interfaces to the master. The patch also, for now, disables aggregation because that would still require requeuing, will fix that in a separate patch. There are two other places (software requeue and powersaving stations) where requeue can happen, but that is not currently used by any drivers/not possible to use respectively. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-20net_sched: Add qdisc_enqueue wrapperJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17pkt_sched: Kill netdev_queue lock.David S. Miller
We can simply use the qdisc->q.lock for all of the qdisc tree synchronization. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17mac80211: Reimplement WME using ->select_queue().David S. Miller
The only behavior change is that we do not drop packets under any circumstances. If that is absolutely needed, we could easily add it back. With cleanups and help from Johannes Berg. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Allocate multiple queues for TX.David S. Miller
alloc_netdev_mq() now allocates an array of netdev_queue structures for TX, based upon the queue_count argument. Furthermore, all accesses to the TX queues are now vectored through the netdev_get_tx_queue() and netdev_for_each_tx_queue() interfaces. This makes it easy to grep the tree for all things that want to get to a TX queue of a net device. Problem spots which are not really multiqueue aware yet, and only work with one queue, can easily be spotted by grepping for all netdev_get_tx_queue() calls that pass in a zero index. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move rest of qdisc state into struct netdev_queueDavid S. Miller
Now qdisc, qdisc_sleeping, and qdisc_list also live there. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move queue_lock into struct netdev_queue.David S. Miller
The lock is now an attribute of the device queue. One thing to notice is that "suspicious" places emerge which will need specific training about multiple queue handling. They are so marked with explicit "netdev->rx_queue" and "netdev->tx_queue" references. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08pkt_sched: Remove 'dev' member of struct Qdisc.David S. Miller
It can be obtained via the netdev_queue. So create a helper routine, qdisc_dev(), to make the transformations nicer looking. Now, qdisc_alloc() now no longer needs a net_device pointer argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Create netdev_queue abstraction.David S. Miller
A netdev_queue is an entity managed by a qdisc. Currently there is one RX and one TX queue, and a netdev_queue merely contains a backpointer to the net_device. The Qdisc struct is augmented with a netdev_queue pointer as well. Eventually the 'dev' Qdisc member will go away and we will have the resulting hierarchy: net_device --> netdev_queue --> Qdisc Also, qdisc_alloc() and qdisc_create_dflt() now take a netdev_queue pointer argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08mac80211: move QOS control helpers into ieee80211.hHarvey Harrison
Also remove the WLAN_IS_QOS_DATA inline after removing the last two users. This starts moving away from using rx->fc to using the header frame_control directly. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-08mac80211: remove useless tid assignment for management and control framesTomas Winkler
This patch removes useless tid assignment for management and control frames Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wan/hdlc_fr.c drivers/net/wireless/iwlwifi/iwl-4965.c drivers/net/wireless/iwlwifi/iwl3945-base.c
2008-07-02mac80211: rework debug settings and make debugging saferJohannes Berg
This patch reworks the mac80211 debug settings making them more focused and adding help text for those that didn't have one. It also removes a number of printks that can be triggered remotely and add no value, e.g. "too short deauthentication frame received - ignoring". If somebody really needs to debug that they should just add a monitor interface and look at the frames in wireshark. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-01net-sched: change tcf_destroy_chain() to clear start of filter listPatrick McHardy
Pass double tcf_proto pointers to tcf_destroy_chain() to make it clear the start of the filter list for more consistency. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/Kconfig drivers/net/wireless/rt2x00/rt2x00usb.c net/sctp/protocol.c
2008-06-14mac80211: wme.c use new helpersHarvey Harrison
2008-06-13mac80211: add missing new line in debug print HT_DEBUGTomas Winkler
This patch adds '\n' in debug printk (wme.c HT DEBUG) Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: use multi-queue master netdeviceJohannes Berg
This patch updates mac80211 and drivers to be multi-queue aware and use that instead of the internal queue mapping. Also does a number of cleanups in various pieces of the code that fall out and reduces internal mac80211 state size. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: move TX info into skb->cbJohannes Berg
This patch converts mac80211 and all drivers to have transmit information and status in skb->cb rather than allocating extra memory for it and copying all the data around. To make it fit, a union is used where only data that is necessary for all steps is kept outside of the union. A number of fixes were done by Ivo, as well as the rt2x00 part of this patch. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-15Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-4965-rs.c drivers/net/wireless/rt2x00/rt61pci.c
2008-05-12mac80211: add missing newlines in printk()Pavel Roskin
Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07mac80211: fix wme codeJohannes Berg
In commit e100bb64bf7cdeae7f742a65ee1985649a7fd1b4 (mac80211: QoS related cleanups) I accidentally changed a variable from int to u16 causing a warning that a comparison for < 0 was always false. John thought this was a missing deletion of code and removed the warning by deleting the never executed branch of code in commit 3df5ee60f1ee559b1417397461891f8b483e8089 (wireless: fix warning introduced by "mac80211: QoS related cleanups") but the problem really was my mistake of using a u16 variable for the queue variable when that variable can also contain an error code. This patch restores the original code and variable type. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07wireless: fix warning introduced by "mac80211: QoS related cleanups"John W. Linville
net/mac80211/wme.c: In function ‘wme_qdiscop_enqueue’: net/mac80211/wme.c:219: warning: comparison is always false due to limited range of data type drivers/net/wireless/p54/p54common.c: In function ‘p54_conf_tx’: drivers/net/wireless/p54/p54common.c:947: warning: comparison is always false due to limited range of data type Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07mac80211: QoS related cleanupsJohannes Berg
This * makes the queue number passed to drivers a u16 (as it will be with skb_get_queue_mapping) * removes the useless queue number defines * splits hw->queues into hw->queues/ampdu_queues * removes the debugfs files for per-queue counters * removes some dead QoS code * removes the beacon queue configuration for IBSS so that the drivers now never get a queue number bigger than (hw->queues + hw->ampdu_queues - 1) for tx and only in the range 0..hw->queues-1 for conf_tx. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-23mac80211: fix use before check of Qdisc lengthRon Rindjunsky
This patch fixes use of Qdisc length in requeue function, before we checked the reference is valid. (Adrian Bunk's catch) Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06mac80211: RCU-ify STA info structure accessJohannes Berg
This makes access to the STA hash table/list use RCU to protect against freeing of items. However, it's not a true RCU, the copy step is missing: whenever somebody changes a STA item it is simply updated. This is an existing race condition that is now somewhat understandable. This patch also fixes the race key freeing vs. STA destruction by making sure that sta_info_destroy() is always called under RTNL and frees the key. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: adjustable number of bits for qdisc poolRon Rindjunsky
This fix allows to control the number of bits that qdiscs book keeping can be done for with respect to the qdisc pool Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: A-MPDU Tx adding qdisc supportRon Rindjunsky
This patch allows qdisc support in A-MPDU Tx. a method to handle QoS <-> TID switches is present in this patch. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28[NET_SCHED]: Convert packet schedulers from rtnetlink to new netlink APIPatrick McHardy
Convert packet schedulers to use the netlink API. Unfortunately a gradual conversion is not possible without breaking compilation in the middle or adding lots of casts, so this patch converts them all in one step. The patch has been mostly generated automatically with some minor edits to at least allow seperate conversion of classifiers and actions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: Assign correct TID for local bridged packetsGuy Cohen
This patch assigns correct TID to frames transmitted between two stations in the same BSS in AP mode. The problem is that skb->protocol is not set to ETH_P_IP and it is wrong to use that field at this stage. The fix compares the LLC/Protocol headers explicitly to check if the encapsulated frame is IP frame Signed-off-by: Guy Cohen <guy.cohen@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28[MAC80211]: Use htons() where appropriate.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Move Qdisc_class_ops and Qdisc_ops in appropriate sections.Eric Dumazet
Qdisc_class_ops are const, and Qdisc_ops are mostly read. Using "const" and "__read_mostly" qualifiers helps to reduce false sharing. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: remove management interfaceJohannes Berg
Removes the management interface since it is only required for hostapd/userspace MLME, will not be in the final tree at least in this form and hostapd/userspace MLME currently do not work against this tree anyway. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: clean up whitespaceJohannes Berg
This cleans up some whitespace to make the mac80211 version in mainline diverge less from wireless-dev. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: Remove bitfields from struct ieee80211_tx_packet_dataJiri Slaby
remove bitfields from struct ieee80211_tx_packet_data [Johannes: completely clear flags in ieee80211_remove_tx_extra] Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: move QoS rx handlers into rx.cJohannes Berg
This patch moves the QoS handlers into rx.c making it possible to compile wme.c only when NET_SCHED is defined. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
