path: root/net/mac80211/wme.c
2014-11-19mac80211: synchronously reserve TID per stationLiad Kaufman
In TDLS (e.g., TDLS off-channel) there is a requirement for some drivers to supply an unused TID between the AP and the device to the FW, to allow sending PTI requests and to allow the FW to aggregate on a specific TID for better throughput. To ensure that the allocated TID is indeed unused, this patch introduces an API for blocking the driver from TXing on that TID. Signed-off-by: Liad Kaufman <liad.kaufman@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-11-04mac80211: 802.11p OCB mode supportRostislav Lisovy
This patch adds 802.11p OCB (Outside the Context of a BSS) mode support. When communicating in OCB mode a mandatory wildcard BSSID (48 '1' bits) is used. The EDCA parameters handling function was changed to support 802.11p specific values. The insertion of a newly discovered STAs is done in the similar way as in the IBSS mode -- through the deferred insertion. The OCB mode uses a periodic 'housekeeping task' for expiration of disconnected STAs (in the similar manner as in the MESH mode). New Kconfig option for verbose OCB debugging outputs is added. Signed-off-by: Rostislav Lisovy <rostislav.lisovy@fel.cvut.cz> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-10-22mac80211: add WMM admission control supportJohannes Berg
Use the currently existing APIs between mac80211 and the low level driver to implement WMM admission control. The low level driver needs to report the media time used by each transmitted packet in ieee80211_tx_status. Based on that information, mac80211 will modify the QoS parameters of the admission controlled Access Category when the limit is reached. Once the original QoS parameters can be restored, mac80211 will do so. One issue with this approach is that management frames will also erroneously be downgraded, but the upside is that the implementation is simple. In the future, it can be extended to driver- or device-based implementations that are better. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-09-05mac80211: add Intel Mobile Communications copyrightJohannes Berg
Our legal structure changed at some point (see wikipedia), but we forgot to immediately switch over to the new copyright notice. For files that we have modified in the time since the change, add the proper copyright notice now. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-08-15mac80211: don't duplicate station QoS capability dataJohannes Berg
We currently track the QoS capability twice: for all peer stations in the WLAN_STA_WME flag, and for any clients associated to an AP interface separately for drivers in the sta->sta.wme field. Remove the WLAN_STA_WME flag and track the capability only in the driver-visible field, getting rid of the limitation that the field is only valid in AP mode. Reviewed-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-12mac80211: send control port protocol frames to the VO queueFelix Fietkau
Improves reliability of wifi connections with WPA, since authentication frames are prioritized over normal traffic and also typically exempt from aggregation. Cc: stable@vger.kernel.org Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-19mac80211: Add support for QoS mappingKyeyoon Park
Implement set_qos_map() handler for mac80211 to enable QoS mapping functionality. Signed-off-by: Kyeyoon Park <kyeyoonp@qca.qualcomm.com> Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-19cfg80211: Add support for QoS mappingKyeyoon Park
This allows QoS mapping from external networks to be implemented as defined in IEEE Std 802.11-2012, 10.24.9. APs can use this to advertise DSCP ranges and exceptions for mapping frames to a specific UP over Wi-Fi. The payload of the QoS Map Set element (IEEE Std 802.11-2012, 8.4.2.97) is sent to the driver through the new NL80211_ATTR_QOS_MAP attribute to configure the local behavior either on the AP (based on local configuration) or on a station (based on information received from the AP). Signed-off-by: Kyeyoon Park <kyeyoonp@qca.qualcomm.com> Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-04mac80211: mesh power save basicsMarco Porsch
Add routines to - maintain a PS mode for each peer and a non-peer PS mode - indicate own PS mode in transmitted frames - track neighbor STAs power modes - buffer frames when neighbors are in PS mode - add TIM and Awake Window IE to beacons - release frames in Mesh Peer Service Periods Add local_pm to sta_info to represent the link-specific power mode at this station towards the remote station. When a peer link is established, use the default power mode stored in mesh config. Update the PS status if the peering status of a neighbor changes. Maintain a mesh power mode for non-peer mesh STAs. Set the non-peer power mode to active mode during peering. Authenticated mesh peering is currently not working when either node is configured to be in power save mode. Indicate the current power mode in transmitted frames. Use QoS Nulls to indicate mesh power mode transitions. For performance reasons, calls to the function setting the frame flags are placed in HWMP routing routines, as there the STA pointer is already available. Add peer_pm to sta_info to represent the peer's link-specific power mode towards the local station. Add nonpeer_pm to represent the peer's power mode towards all non-peer stations. Track power modes based on received frames. Add the ps_data structure to ieee80211_if_mesh (for TIM map, PS neighbor counter and group-addressed frame buffer). Set WLAN_STA_PS flag for STA in PS mode to use the unicast frame buffering routines in the tx path. Update num_sta_ps to buffer and release group-addressed frames after DTIM beacons. Announce the awake window duration in beacons if in light or deep sleep mode towards any peer or non-peer. Create a TIM IE similarly to AP mode and add it to mesh beacons. Parse received Awake Window IEs and check TIM IEs for buffered frames. Release frames towards peers in mesh Peer Service Periods. Use the corresponding trigger frames and monitor the MPSP status. Append a QoS Null as trigger frame if neccessary to properly end the MPSP. Currently, in HT channels MPSPs behave imperfectly and show large delay spikes and frame losses. Signed-off-by: Marco Porsch <marco@cozybit.com> Signed-off-by: Ivan Bezyazychnyy <ivan.bezyazychnyy@gmail.com> Signed-off-by: Mike Krinkin <krinkin.m.u@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-26mac80211: refactor ieee80211_set_qos_hdrMarco Porsch
Return early if not a QoS Data frame. Give proper documentation. Signed-off-by: Marco Porsch <marco.porsch@etit.tu-chemnitz.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-20mac80211: save wmm_acm per sdataYoni Divinsky
Save and configure the wmm_acm per sdata, rather than per hardware. If wmm_acm is saved per hardware when running two interfaces simultaneously on the same hardware one interface's wmm policy will be affected by the other interface. Signed-off-by: Yoni Divinsky <yoni.divinsky@ti.com> Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-04-10mac80211: use IEEE80211_NUM_ACSJohannes Berg
When comparing hw->queues to determine if the device is QoS capable, use IEEE80211_NUM_ACS instead of just 4. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-10mac80211: decouple # of netdev queues from HW queuesJohannes Berg
When we get more hardware queues, we'll still want to only have netdev queues per AC, so set it up in that way. If the hardware doesn't support QoS (by not supporting at least 4 queues) the netdevs get a single queue only (this is no change in behavior as there are no drivers with 2 or 3 queues today.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-10mac80211: make ieee80211_downgrade_queue staticJohannes Berg
There's no reason for it to not be static. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: fix forwarded mesh frame queue mappingThomas Pedersen
We can't rely on ieee80211_select_queue() to do its job at this point since the skb->protocol is not yet known. Instead, factor out and reuse the queue mapping logic for injected frames. Also, to mitigate congestion, forwarded frames should be dropped if the outgoing queue was stopped. This was not correctly implemented as we were not checking the right queue. Furthermore, we were dropping frames that had arrived to their destination if that queue was stopped. Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: Add NoAck per tid supportSimon Wunderlich
This patch contains the processing changes in mac80211. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: remove debugfs noack testSimon Wunderlich
This feature has been superseded by the NoAck per Queue feature. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09mac80211: simplify mesh frame queue mapping and QoSJavier Cardona
We only need to set the skb queue twice: 1. by the netdev, on local TX. 2. when forwarding a mesh frame. We only need to set the qos header twice: 1. by mac80211, on local TX. 2. when putting a frame on the mpath->frame_queue We also don't need the RA in order to set the proper queue mapping since all mesh STAs are QoS, indicate this and do it once when the frame is received. Also fixes an issue where the QoS header and queue mapping was not set for unicast forwarded frames. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09mac80211: QoS multicast frames have No Ack policyThomas Pedersen
Previously QoS multicast frames had the Normal Acknowledgment QoS control bits set. This would cause broadcast frames to be discarded by peers with which we have a BA session, since their sequence number would fall outside the allowed range. Set No Ack QoS control bits on multicast QoS frames and filter these in de-aggregation code. Signed-off-by: Thomas Pedersen <thomas@cozybit.com> v2: Use proper QoS Ack Policy ctl field mask (Christian) v3: Clean up conditional (Johannes) Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09mac80211: preserve EOSP in QoS headerJohannes Berg
Janusz reported that the EOSP bit in mac80211 was getting cleared all the time. I had not found this since I tested uAPSD with a device that always set the bit itself. Preserve the bit when building the QoS header. Reported-by: Janusz Dziedzic <janusz.dziedzic@gmail.com> Tested-by: Janusz Dziedzic <janusz.dziedzic@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-30mac80211: optimise station flagsJohannes Berg
The flaglock in struct sta_info has long been something that I wanted to get rid of, this finally does the conversion to atomic bitops. The conversion itself is straight-forward in most places, a few things needed to change a bit since we can no longer use multiple bits at the same time. On x86-64, this is a fairly significant code size reduction: text data bss dec hex 427861 23648 1008 452517 6e7a5 before 425383 23648 976 450007 6ddd7 after Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-14mac80211: Mesh data frames must have the QoS headerJavier Cardona
Per sec 7.1.3.5 of draft 12.0 of 802.11s, mesh frames indicate the presence of the mesh control header in their QoS header. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-14mac80211: Start implementing QoS support for mesh interfacesJavier Cardona
In order to support QoS in mesh, we need to assign queue mapping only after the next hop has been resolved, both for forwarded and locally originated frames. Also, now that this is fixed, remove the XXX comment in ieee80211_select_queue(). Also, V-Shy Ho reported that the queue mapping was not being applied to the forwarded frame (fwd_skb instead of skb). Fixed that as well. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-27wireless: unify QoS control field definitionsJohannes Berg
Move all that mac80211 has into the generic ieee80211.h header file and use them. At the same time move them from mask+shift to just bits and rename them for consistent names. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22mac80211: cleanup select_queueJohannes Berg
There's a redundant rcu_read_lock/unlock pair, a redundant variable, and a few redundant accesses to the 1d_to_ac array. Fix this to make the code neater and easier to follow. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-17mac80211: defines for AC numbersJohannes Berg
In many places we've just hardcoded the AC numbers -- which is a relic from the original mac80211 (d80211). Add constants for them so we know what we're talking about. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-05mac80211: fix skb buffering issueJohannes Berg
Since I removed the master netdev, we've been keeping internal queues only, and even before that we never told the networking stack above the virtual interfaces about congestion. This means that packets are queued in mac80211 and the upper layers never know, possibly leading to memory exhaustion and other problems. This patch makes all interfaces multiqueue and uses ndo_select_queue to put the packets into queues per AC. Additionally, when the driver stops a queue, we now stop all corresponding queues for the virtual interfaces as well. The injection case will use VO by default for non-data frames, and BE for data frames, but downgrade any data frames according to ACM. It needs to be fleshed out in the future to allow chosing the queue/AC in radiotap. Reported-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org [2.6.32] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24mac80211: remove master netdevJohannes Berg
With the internal 'pending' queue system in place, we can simply put packets there instead of pushing them off to the master dev, getting rid of the master interface completely. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211: do not pass PS frames out of mac80211 againJohannes Berg
In order to handle powersave frames properly we had needed to pass these out to the device queues again, and introduce the skb->requeue bit. This, however, also has unnecessary overhead by needing to 'clean up' already tried frames, and this clean-up code is also buggy when software encryption is used. Instead of sending the frames via the master netdev queue again, simply put them into the pending queue. This also fixes a problem where frames for that particular station could be reordered when some were still on the software queues and older ones are re-injected into the software queue after them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-22wireless: move some utility functions from mac80211 to cfg80211Zhu Yi
The patch moves some utility functions from mac80211 to cfg80211. Because these functions are doing generic 802.11 operations so they are not mac80211 specific. The moving allows some fullmac drivers to be also benefit from these utility functions. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-13mac80211: make noack test availableJohannes Berg
There's this internal wifi_wme_noack_test variable that we use to set the QoS control if set. For one, it is unlikely that it is set. Secondly, if set it needs to influence the IEEE80211_TX_CTL_NO_ACK TX control flag, and finally we should also be able to set it at all, so make it available in debugfs. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16mac80211: Fix WMM ACM parsing and AC downgrade operationJouni Malinen
Incorrect local->wmm_acm bits were set for AC_BK and AC_BE. Fix this and add some comments to make it easier to understand the AC-to-UP(pair) mapping. Set the wmm_acm bits (and show WMM debug) even if the driver does not implement conf_tx() handler. In addition, fix the ACM-based AC downgrade code to not use the highest priority in error cases. We need to break the loop to get the correct AC_BK value (3) instead of returning 0 (which would indicate AC_VO). The comment here was not really very useful either, so let's provide somewhat more helpful description of the situation. Since it is very unlikely that the ACM flag would be set for AC_BK and AC_BE, these bugs are not likely to be seen in real life networks. Anyway, better do these things correctly should someone really use silly AP configuration (and to pass some functionality tests, too). Remove the TODO comment about handling ACM. Downgrading AC is perfectly valid mechanism for ACM. Eventually, we may add support for WMM-AC and send a request for a TS, but anyway, that functionality won't be here at the location of this TODO comment. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27mac80211: fix aggregation for hardware with ampdu queuesJohannes Berg
Hardware with AMPDU queues currently has broken aggregation. This patch fixes it by making all A-MPDUs go over the regular AC queues, but keeping track of the hardware queues in mac80211. As a first rough version, it actually stops the AC queue for extended periods of time, which can be removed by adding buffering internal to mac80211, but is currently not a huge problem because people rarely use multiple TIDs that are in the same AC (and iwlwifi currently doesn't operate as AP). This is a short-term fix, my current medium-term plan, which I hope to execute soon as well, but am not sure can finish before .30, looks like this: 1) rework the internal queuing layer in mac80211 that we use for fragments if the driver stopped queue in the middle of a fragmented frame to be able to queue more frames at once (rather than just a single frame with its fragments) 2) instead of stopping the entire AC queue, queue up the frames in a per-station/per-TID queue during aggregation session initiation, when the session has come up take all those frames and put them onto the queue from 1) 3) push the ampdu queue layer abstraction this patch introduces in mac80211 into the driver, and remove the virtual queue stuff from mac80211 again This plan will probably also affect ath9k in that mac80211 queues the frames instead of passing them down, even when there are no ampdu queues. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: Re-enable aggregationSujith
Wireless HW without any dedicated queues for aggregation do not need the ampdu_queues mechanism present right now in mac80211. Since mac80211 is still incomplete wrt TX MQ changes, do not allow aggregation sessions for drivers that set ampdu_queues. This is only an interim hack until Intel fixes the requeue issue. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: Luis Rodriguez <Luis.Rodriguez@Atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-27mac80211: convert to %pM away from print_macJohannes Berg
Also remove a few stray DECLARE_MAC_BUF that were no longer used at all. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-30mac80211: fixups for "make master iface not wireless"Johannes Berg
In "mac80211: make master iface not wireless" I accidentally forgot to include these changes ... leading to the expected BUG_ON errors. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-20net: Use hton[sl]() instead of __constant_hton[sl]() where applicableArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-15mac80211: share STA information with driverJohannes Berg
This patch changes mac80211 to share some more data about stations with drivers. Should help iwlwifi and ath9k when they get around to updating, and might also help with implementing rate control algorithms without internals. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Sujith Manoharan <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29mac80211: Use only precedence level of DSCP field for frame classificationDaniel Wagner
Bit 4-5 of DSCP should not be considered by classify_d1. The 802.11 QoS Priority field is only depending on the precedence level. Signed-off-by: Daniel Wagner <wagi@monom.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-02mac80211: Use queue_lock() in ieee80211_ht_agg_queue_remove().David S. Miller
qdisc_root_lock() is only %100 safe to use when the RTNL semaphore is held. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-29mac80211: partially fix skb->cb useJohannes Berg
This patch fixes mac80211 to not use the skb->cb over the queue step from virtual interfaces to the master. The patch also, for now, disables aggregation because that would still require requeuing, will fix that in a separate patch. There are two other places (software requeue and powersaving stations) where requeue can happen, but that is not currently used by any drivers/not possible to use respectively. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-20net_sched: Add qdisc_enqueue wrapperJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17pkt_sched: Kill netdev_queue lock.David S. Miller
We can simply use the qdisc->q.lock for all of the qdisc tree synchronization. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17mac80211: Reimplement WME using ->select_queue().David S. Miller
The only behavior change is that we do not drop packets under any circumstances. If that is absolutely needed, we could easily add it back. With cleanups and help from Johannes Berg. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Allocate multiple queues for TX.David S. Miller
alloc_netdev_mq() now allocates an array of netdev_queue structures for TX, based upon the queue_count argument. Furthermore, all accesses to the TX queues are now vectored through the netdev_get_tx_queue() and netdev_for_each_tx_queue() interfaces. This makes it easy to grep the tree for all things that want to get to a TX queue of a net device. Problem spots which are not really multiqueue aware yet, and only work with one queue, can easily be spotted by grepping for all netdev_get_tx_queue() calls that pass in a zero index. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move rest of qdisc state into struct netdev_queueDavid S. Miller
Now qdisc, qdisc_sleeping, and qdisc_list also live there. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move queue_lock into struct netdev_queue.David S. Miller
The lock is now an attribute of the device queue. One thing to notice is that "suspicious" places emerge which will need specific training about multiple queue handling. They are so marked with explicit "netdev->rx_queue" and "netdev->tx_queue" references. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08pkt_sched: Remove 'dev' member of struct Qdisc.David S. Miller
It can be obtained via the netdev_queue. So create a helper routine, qdisc_dev(), to make the transformations nicer looking. Now, qdisc_alloc() now no longer needs a net_device pointer argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Create netdev_queue abstraction.David S. Miller
A netdev_queue is an entity managed by a qdisc. Currently there is one RX and one TX queue, and a netdev_queue merely contains a backpointer to the net_device. The Qdisc struct is augmented with a netdev_queue pointer as well. Eventually the 'dev' Qdisc member will go away and we will have the resulting hierarchy: net_device --> netdev_queue --> Qdisc Also, qdisc_alloc() and qdisc_create_dflt() now take a netdev_queue pointer argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08mac80211: move QOS control helpers into ieee80211.hHarvey Harrison
Also remove the WLAN_IS_QOS_DATA inline after removing the last two users. This starts moving away from using rx->fc to using the header frame_control directly. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
