path: root/net/mac80211
2012-08-19mac80211: cancel mesh path timerJohannes Berg
commit dd4c9260e7f23f2e951cbfb2726e468c6d30306c upstream. The mesh path timer needs to be canceled when leaving the mesh as otherwise it could fire after the interface has been removed already. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-07-12mac80211: correct behaviour on unrecognised action framesJohannes Berg
commit 4b5ebccc40843104d980f0714bc86bfcd5568941 upstream. When receiving an "individually addressed" action frame, the receiver is required to return it to the sender. mac80211 gets this wrong as it also returns group addressed (mcast) frames to the sender. Fix this and update the reference to the new 802.11 standards version since things were shuffled around significantly. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-06-19mac80211: clean up remain-on-channel on interface stopJohannes Berg
commit 71ecfa1893034eeb1c93e02e22ee2ad26d080858 upstream. When any interface goes down, it could be the one that we were doing a remain-on-channel with. We therefore need to cancel the remain-on-channel and flush the related work structs so they don't run after the interface has been removed or even destroyed. It's also possible in this case that an off-channel SKB was never transmitted, so free it if this is the case. Note that this can also happen if the driver finishes the off-channel period without ever starting it. Reported-by: Nirav Shah <nirav.j2.shah@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-06-10mac80211: fix ADDBA declined after suspend with wowlanEyal Shapira
commit 7b21aea04d084916ac4e0e8852dcc9cd60ec0d1d upstream. WLAN_STA_BLOCK_BA is set while suspending but doesn't get cleared when resuming in case of wowlan. This causes further ADDBA requests received to be rejected. Fix it by clearing it in the wowlan path as well. Signed-off-by: Eyal Shapira <eyal@wizery.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-11mac80211: fix AP mode EAP tx for VLAN stationsFelix Fietkau
commit 66f2c99af3d6f2d0aa1120884cf1c60613ef61c0 upstream. EAP frames for stations in an AP VLAN are sent on the main AP interface to avoid race conditions wrt. moving stations. For that to work properly, sta_info_get_bss must be used instead of sta_info_get when sending EAP packets. Previously this was only done for cooked monitor injected packets, so this patch adds a check for tx->skb->protocol to the same place. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-04-13mac80211: fix possible tid_rx->reorder_timer use after freeStanislaw Gruszka
commit d72308bff5c2fa207949a5925b020bce74495e33 upstream. Is possible that we will arm the tid_rx->reorder_timer after del_timer_sync() in ___ieee80211_stop_rx_ba_session(). We need to stop timer after RCU grace period finish, so move it to ieee80211_free_tid_rx(). Timer will not be armed again, as rcu_dereference(sta->ampdu_mlme.tid_rx[tid]) will return NULL. Debug object detected problem with the following warning: ODEBUG: free active (active state 0) object type: timer_list hint: sta_rx_agg_reorder_timer_expired+0x0/0xf0 [mac80211] Bug report (with all warning messages): https://bugzilla.redhat.com/show_bug.cgi?id=804007 Reported-by: "jan p. springer" <jsd@igroup.org> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12mac80211: zero initialize count field in ieee80211_tx_rateMohammed Shafi Shajakhan
commit 8617b093d0031837a7be9b32bc674580cfb5f6b5 upstream. rate control algorithms concludes the rate as invalid with rate[i].idx < -1 , while they do also check for rate[i].count is non-zero. it would be safer to zero initialize the 'count' field. recently we had a ath9k rate control crash where the ath9k rate control in ath_tx_status assumed to check only for rate[i].count being non-zero in one instance and ended up in using invalid rate index for 'connection monitoring NULL func frames' which eventually lead to the crash. thanks to Pavel Roskin for fixing it and finding the root cause. https://bugzilla.redhat.com/show_bug.cgi?id=768639 Cc: Pavel Roskin <proski@gnu.org> Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29mac80211: Fix a rwlock bad magic bugMohammed Shafi Shajakhan
commit b57e6b560fc2a2742910ac5ca0eb2c46e45aeac2 upstream. read_lock(&tpt_trig->trig.leddev_list_lock) is accessed via the path ieee80211_open (->) ieee80211_do_open (->) ieee80211_mod_tpt_led_trig (->) ieee80211_start_tpt_led_trig (->) tpt_trig_timer before initializing it. the intilization of this read/write lock happens via the path ieee80211_led_init (->) led_trigger_register, but we are doing 'ieee80211_led_init' after 'ieeee80211_if_add' where we register netdev_ops. so we access leddev_list_lock before initializing it and causes the following bug in chrome laptops with AR928X cards with the following script while true do sudo modprobe -v ath9k sleep 3 sudo modprobe -r ath9k sleep 3 done BUG: rwlock bad magic on CPU#1, wpa_supplicant/358, f5b9eccc Pid: 358, comm: wpa_supplicant Not tainted 3.0.13 #1 Call Trace: [<8137b9df>] rwlock_bug+0x3d/0x47 [<81179830>] do_raw_read_lock+0x19/0x29 [<8137f063>] _raw_read_lock+0xd/0xf [<f9081957>] tpt_trig_timer+0xc3/0x145 [mac80211] [<f9081f3a>] ieee80211_mod_tpt_led_trig+0x152/0x174 [mac80211] [<f9076a3f>] ieee80211_do_open+0x11e/0x42e [mac80211] [<f9075390>] ? ieee80211_check_concurrent_iface+0x26/0x13c [mac80211] [<f9076d97>] ieee80211_open+0x48/0x4c [mac80211] [<812dbed8>] __dev_open+0x82/0xab [<812dc0c9>] __dev_change_flags+0x9c/0x113 [<812dc1ae>] dev_change_flags+0x18/0x44 [<8132144f>] devinet_ioctl+0x243/0x51a [<81321ba9>] inet_ioctl+0x93/0xac [<812cc951>] sock_ioctl+0x1c6/0x1ea [<812cc78b>] ? might_fault+0x20/0x20 [<810b1ebb>] do_vfs_ioctl+0x46e/0x4a2 [<810a6ebb>] ? fget_light+0x2f/0x70 [<812ce549>] ? sys_recvmsg+0x3e/0x48 [<810b1f35>] sys_ioctl+0x46/0x69 [<8137fa77>] sysenter_do_call+0x12/0x2 Cc: Gary Morain <gmorain@google.com> Cc: Paul Stewart <pstew@google.com> Cc: Abhijit Pradhan <abhijit@qca.qualcomm.com> Cc: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com> Cc: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Acked-by: Johannes Berg <johannes.berg@intel.com> Tested-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com> Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-20mac80211: timeout a single frame in the rx reorder bufferEliad Peller
commit 07ae2dfcf4f7143ce191c6436da1c33f179af0d6 upstream. The current code checks for stored_mpdu_num > 1, causing the reorder_timer to be triggered indefinitely, but the frame is never timed-out (until the next packet is received) Signed-off-by: Eliad Peller <eliad@wizery.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03net: reintroduce missing rcu_assign_pointer() callsEric Dumazet
[ Upstream commit cf778b00e96df6d64f8e21b8395d1f8a859ecdc7 ] commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTER) did a lot of incorrect changes, since it did a complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x, y). We miss needed barriers, even on x86, when y is not NULL. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03mac80211: fix work removal on deauth requestJohannes Berg
commit bc4934bc61d0a11fd62c5187ff83645628f8be8b upstream. When deauth is requested while an auth or assoc work item is in progress, we currently delete it without regard for any state it might need to clean up. Fix it by cleaning up for those items. In the case Pontus found, the problem manifested itself as such: authenticate with 00:23:69:aa:dd:7b (try 1) authenticated failed to insert Dummy STA entry for the AP (error -17) deauthenticating from 00:23:69:aa:dd:7b by local choice (reason=2) It could also happen differently if the driver uses the tx_sync callback. We can't just call the ->done() method of the work items because that will lock up due to the locking in cfg80211. This fix isn't very clean, but that seems acceptable since I have patches pending to remove this code completely. Reported-by: Pontus Fuchs <pontus.fuchs@gmail.com> Tested-by: Pontus Fuchs <pontus.fuchs@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-25mac80211: revert on-channel work optimisationsJohannes Berg
commit e76aadc572288a158ae18ae1c10fe395c7bca066 upstream. Backport note: This patch it's a full revert of commit b23b025f "mac80211: Optimize scans on current operating channel.". On upstrem revert e76aadc5 we keep some bits from that commit, which are needed for upstream version of mac80211. The on-channel work optimisations have caused a number of issues, and the code is unfortunately very complex and almost impossible to follow. Instead of attempting to put in more workarounds let's just remove those optimisations, we can work on them again later, after we change the whole auth/assoc design. This should fix rate_control_send_low() warnings, see RH bug 731365. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25mac80211: fix rx->key NULL pointer dereference in promiscuous modeStanislaw Gruszka
commit 1140afa862842ac3e56678693050760edc4ecde9 upstream. Since: commit 816c04fe7ef01dd9649f5ccfe796474db8708be5 Author: Christian Lamparter <chunkeey@googlemail.com> Date: Sat Apr 30 15:24:30 2011 +0200 mac80211: consolidate MIC failure report handling is possible to that we dereference rx->key == NULL when driver set RX_FLAG_MMIC_STRIPPED and not RX_FLAG_IV_STRIPPED and we are in promiscuous mode. This happen with rt73usb and rt61pci at least. Before the commit we always check rx->key against NULL, so I assume fix should be done in mac80211 (also mic_fail path has similar check). References: https://bugzilla.redhat.com/show_bug.cgi?id=769766 http://rt2x00.serialmonkey.com/pipermail/users_rt2x00.serialmonkey.com/2012-January/004395.html Reported-by: Stuart D Gathman <stuart@gathman.org> Reported-by: Kai Wohlfahrt <kai.scorpio@gmail.com> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2011-12-07mac80211: fix another race in aggregation startJohannes Berg
Emmanuel noticed that when mac80211 stops the queues for aggregation that can leave a packet pending. This packet will be given to the driver after the AMPDU callback, but as a non-aggregated packet which messes up the sequence number etc. I also noticed by looking at the code that if packets are being processed while we clear the WANT_START bit, they might see it cleared already and queue up on tid_tx->pending. If the driver then rejects the new aggregation session we leak the packet. Fix both of these issues by changing this code to not stop the queues at all. Instead, let packets queue up on the tid_tx->pending queue instead of letting them get to the driver, and add code to recover properly in case the driver rejects the session. (The patch looks large because it has to move two functions to before their new use.) Cc: stable@vger.kernel.org Reported-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-05Merge branch 'master' of ↵John W. Linville
2011-12-01Revert "mac80211: clear sta.drv_priv on reconfiguration"John W. Linville
This reverts commit f785d83a19bca326f79d127a413e35769afc0105. This was provoking WARNINGs from the iwlegacy drivers. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-30mac80211: fill rate filter for internal scan requestsSimon Wunderlich
The rates bitmap for internal scan requests shoud be filled, otherwise there will be probe requests with zero rates supported. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Cc: stable@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-30Merge branch 'master' of ↵John W. Linville
2011-11-28mac80211: fix race between the AGG SM and the Tx data pathEmmanuel Grumbach
When a packet is supposed to sent be as an a-MPDU, mac80211 sets IEEE80211_TX_CTL_AMPDU to let the driver know. On the other hand, mac80211 configures the driver for aggregration with the ampdu_action callback. There is race between these two mechanisms since the following scenario can occur when the BA agreement is torn down: Tx softIRQ drv configuration ========== ================= check OPERATIONAL bit Set the TX_CTL_AMPDU bit in the packet clear OPERATIONAL bit stop Tx AGG Pass Tx packet to the driver. In that case the driver would get a packet with TX_CTL_AMPDU set although it has already been notified that the BA session has been torn down. To fix this, we need to synchronize all the Qdisc activity after we cleared the OPERATIONAL bit. After that step, all the following packets will be buffered until the driver reports it is ready to get new packets for this RA / TID. This buffering allows not to run into another race that would send packets with TX_CTL_AMPDU unset while the driver hasn't been requested to tear down the BA session yet. This race occurs in practice and iwlwifi complains with a WARN_ON when it happens. Cc: stable@kernel.org Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: fix race condition caused by late addBA responseNikolay Martynov
If addBA responses comes in just after addba_resp_timer has expired mac80211 will still accept it and try to open the aggregation session. This causes drivers to be confused and in some cases even crash. This patch fixes the race condition and makes sure that if addba_resp_timer has expired addBA response is not longer accepted and we do not try to open half-closed session. Cc: stable@vger.kernel.org Signed-off-by: Nikolay Martynov <mar.kolya@gmail.com> [some adjustments] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: don't stop a single aggregation session twiceJohannes Berg
Nikolay noticed (by code review) that mac80211 can attempt to stop an aggregation session while it is already being stopped. So to fix it, check whether stop is already being done and bail out if so. Also move setting the STOPPING state into the lock so things are properly atomic. Cc: stable@vger.kernel.org Reported-by: Nikolay Martynov <mar.kolya@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-22Merge branch 'master' of ↵John W. Linville
2011-11-21mac80211: Fix endian bug in radiotap header generationHelmut Schaa
I intoduced this bug in commit a2fe81667410723d941a688e1958a49d67ca3346 "mac80211: Build TX radiotap header dynamically" Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-21mac80211: Fix AMSDU rate printout in debugfs.Ben Greear
It was flipped. See section 7.3.2.56 of the 802.11n spec for details. Signed-off-by: Ben Greear <greearb@candelatech.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-11Merge branch 'master' of ↵John W. Linville
2011-11-09Merge branch 'for-davem' of ↵David S. Miller
2011-11-09mac80211: fix race between connection monitor & suspendJohannes Berg
When the connection monitor timer fires right before suspend, the following will happen: timer fires -> monitor_work gets queued suspend calls ieee80211_sta_quiesce ieee80211_sta_quiesce: - deletes timer - cancels monitor_work synchronously, running it [note wrong order of these steps] monitor_work runs, re-arming the timer later, timer fires while system should be quiesced This causes a warning: WARNING: at net/mac80211/util.c:540 ieee80211_can_queue_work+0x35/0x40 [mac80211]() but is otherwise harmless. I'm not completely sure this is the scenario Thomas stumbled across, but it is the only way I can right now see the warning in a scenario like the one he reported. Reported-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09mac80211: fix bug in ieee80211_build_probe_reqJohannes Berg
ieee80211_probereq_get() can return NULL in which case we should clean up & return NULL in ieee80211_build_probe_req() as well. Cc: stable@vger.kernel.org Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09mac80211: fix NULL dereference in radiotap codeJohannes Berg
When receiving failed PLCP frames is enabled, there won't be a rate pointer when we add the radiotap header and thus the kernel will crash. Fix this by not assuming the rate pointer is always valid. It's still always valid for frames that have good PLCP though, and that is checked & enforced. This was broken by my commit fc88518916793af8ad6a02e05ff254d95c36d875 Author: Johannes Berg <johannes.berg@intel.com> Date: Fri Jul 30 13:23:12 2010 +0200 mac80211: don't check rates on PLCP error frames where I removed the check in this case but didn't take into account that the rate info would be used. Reported-by: Xiaokang Qin <xiaokang.qin@intel.com> Cc: stable@vger.kernel.org Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) forcedeth: fix a few sparse warnings (variable shadowing) forcedeth: Improve stats counters forcedeth: remove unneeded stats updates forcedeth: Acknowledge only interrupts that are being processed forcedeth: fix race when unloading module MAINTAINERS/rds: update maintainer wanrouter: Remove kernel_lock annotations usbnet: fix oops in usbnet_start_xmit ixgbe: Fix compile for kernel without CONFIG_PCI_IOV defined etherh: Add MAINTAINERS entry for etherh bonding: comparing a u8 with -1 is always false sky2: fix regression on Yukon Optima netlink: clarify attribute length check documentation netlink: validate NLA_MSECS length i825xx:xscale:8390:freescale: Fix Kconfig dependancies macvlan: receive multicast with local address tg3: Update version to 3.121 tg3: Eliminate timer race with reset_task tg3: Schedule at most one tg3_reset_task run tg3: Obtain PCI function number from device ...
2011-11-07mac80211: uAPSD - fix IEEE80211_FCTL_MOREDATA bit settingJanusz.Dziedzic@tieto.com
Set IEEE80211_FCTL_MOREDATA bit also in case we have buffered frames (more than one) only for one AC. Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-07mac80211: use min rate as basic rate for buggy APsEliad Peller
Some buggy APs (and even P2P_GO) don't advertise their basic rates in the association response. In such case, use the min supported rate as the basic rate. Reported-by: Pontus Fuchs <pontus.fuchs@gmail.com> Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-02mac80211: disable powersave for broken APsJohannes Berg
Only AID values 1-2007 are valid, but some APs have been found to send random bogus values, in the reported case an AP that was sending the AID field value 0xffff, an AID of 0x3fff (16383). There isn't much we can do but disable powersave since there's no way it can work properly in this case. Cc: stable@vger.kernel.org Reported-by: Bill C Riemers <briemers@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-02mac80211: Fix TDLS support validation in add_station handlerJouni Malinen
We need to verify whether the command is successful before allocating the station entry to avoid extra processing. This also fixes a memory leak on the error path. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-02mac80211: config hw when going back on-channelEliad Peller
When going back on-channel, we should reconfigure the hw iff the hardware is not already configured to the operational channel. Signed-off-by: Eliad Peller <eliad@wizery.com> Cc: stable@kernel.org # 2.6.39+ Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-02mac80211: fix remain_off_channel regressionEliad Peller
The offchannel code is currently broken - we should remain_off_channel if the work was started, and the work's channel and channel_type are the same as local->tmp_channel and local->tmp_channel_type. However, if wk->chan_type and local->tmp_channel_type coexist (e.g. have the same channel type), we won't remain_off_channel. This behavior was introduced by commit da2fd1f ("mac80211: Allow work items to use existing channel type.") Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Eliad Peller <eliad@wizery.com> Cc: stable@kernel.org # 2.6.39+ Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31net: add moduleparam.h for users of module_param/MODULE_PARM_DESCPaul Gortmaker
These files were getting access to these two via the implicit presence of module.h everywhere. They aren't modules, so they don't need the full module.h inclusion though. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31net: Fix files explicitly needing to include module.hPaul Gortmaker
With calls to modular infrastructure, these files really needs the full module.h header. Call it out so some of the cleanups of implicit and unrequired includes elsewhere can be cleaned up. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-25Merge branch 'pm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (63 commits) PM / Clocks: Remove redundant NULL checks before kfree() PM / Documentation: Update docs about suspend and CPU hotplug ACPI / PM: Add Sony VGN-FW21E to nonvs blacklist. ARM: mach-shmobile: sh7372 A4R support (v4) ARM: mach-shmobile: sh7372 A3SP support (v4) PM / Sleep: Mark devices involved in wakeup signaling during suspend PM / Hibernate: Improve performance of LZO/plain hibernation, checksum image PM / Hibernate: Do not initialize static and extern variables to 0 PM / Freezer: Make fake_signal_wake_up() wake TASK_KILLABLE tasks too PM / Hibernate: Add resumedelay kernel param in addition to resumewait MAINTAINERS: Update linux-pm list address PM / ACPI: Blacklist Vaio VGN-FW520F machine known to require acpi_sleep=nonvs PM / ACPI: Blacklist Sony Vaio known to require acpi_sleep=nonvs PM / Hibernate: Add resumewait param to support MMC-like devices as resume file PM / Hibernate: Fix typo in a kerneldoc comment PM / Hibernate: Freeze kernel threads after preallocating memory PM: Update the policy on default wakeup settings PM / VT: Cleanup #if defined uglyness and fix compile error PM / Suspend: Off by one in pm_suspend() PM / Hibernate: Include storage keys in hibernation image on s390 ...
2011-10-17Merge branch 'master' of ↵John W. Linville
git://git.infradead.org/users/linville/wireless-next into for-davem
2011-10-14mac80211: Provide station flags to cfg80211Helmut Schaa
Only station flags that are already defined in nl80211 are added for now. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-14mac80211: fix TID for null poll responseJohannes Berg
The queue mapping/TID for non-QoS null data responses to is never set, making it default to BK. Fix that. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-14mac80211: reformat TX unauthorised checkJohannes Berg
Reformat the check, the indentation is completely strange. Also change the last part of the condition to make the code shorter. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-14mac80211: Populate radiotap header with MCS info for TX framesHelmut Schaa
mac80211 already filled in the MCS rate info for rx'ed frames but tx'ed frames that are sent to a monitor interface during the status callback lack this information. Add the radiotap fields for MCS info to ieee80211_tx_status_rtap_hdr and populate them when sending tx'ed frames to the monitors. The needed headroom is only extended by one byte since we don't include legacy rate information in the rtap header for HT frames. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-14mac80211: Build TX radiotap header dynamicallyHelmut Schaa
Get rid of the ieee80211_tx_status_rtap_hdr struct and instead build the rtap header dynamically. This makes it easier to extend the rtap header generation in the future. Add ieee80211_tx_radiotap_len to calculate the expected size of the rtap header before generating it. Since we can't check if the rtap header fits into the requested headroom during compile time anymore add a WARN_ON_ONCE. Also move the actual rtap header generation into its own function. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-11mac80211: dont orphan TX skbJohannes Berg
This was another workaround for truesize "bugs". The reason we did this was that when we orphaned the SKB it wouldn't be truesize-checked later. Now that the check is gone (and we just charge the former smaller size to the socket) there's no longer a reason to orphan the skb here. Keep the skb charged to the socket until it is really freed (or orphaned in TX status). This helps flow control and allows us to get at the socket later for other purposes. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-11mac80211: dont adjust truesizeJohannes Berg
There's no need to adjust truesize. The history of this was that we always ran into skb_truesize_bug (via skb_truesize_check) which has since been removed in commit 92a0acce186cd. skb_truesize_check() checked that truesize was bigger or equal to the actual allocation, which would trigger in mac80211 due to header adding. The check no longer exists and we shouldn't be messing with the truesize anwyay. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-11mac80211: parse radiotap header earlierJohannes Berg
We can now move the radiotap header parsing into ieee80211_monitor_start_xmit(). This moves it out of the hotpath, and also helps the code since now the radiotap header will no longer be present in ieee80211_xmit() etc. which is easier to understand. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
