Do not send DS Channel parameter for directed probe requests
in order to maximize the chance that we get a response. Some
badly-behaved APs don't respond when this parameter is included.
Signed-off-by: Paul Stewart <pstew@chromium.org>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
When forming a Rx BA session, sometimes the ADDBA response gets lost.
This leads to a situation where the session is configured locally, but
doesn't exist on the remote side. Subsequent ADDBA requests are declined
by mac80211.
Fix this by assuming the session state of the initiator is the correct
one. When receiving an unexpected ADDBA request on a TID with an active
Rx BA session, delete the existing one and establish a new session.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Advertise only user-requested bitrates in a HW scan.
Note that the hw_scan API doesn't currently have a
way of asking for a specific probe request bitrate,
so we might end up using a bitrate that we don't
advertise as supported. I'll fix that later.
Also add a hexdump printk to hwsim to verify this.
Move all that mac80211 has into the generic
ieee80211.h header file and use them. At the
same time move them from mask+shift to just
bits and rename them for consistent names.
Sometimes when reporting a MIC failure rx->key may be unset. This
code path is hit when receiving a packet meant for a multicast
address, and decryption is performed in HW.
Fortunately, the failing key_idx is not used for anything up to
(and including) usermode, so we allow ourselves to drop it on the
way up when a key cannot be retrieved.
Cc: stable@kernel.org
Cancel all relevant timers/works before suspending (wowlan).
This patch handles the following warning:
WARNING: at net/mac80211/util.c:565 queueing ieee80211 work while going to suspend
Backtrace:
[<bf07b598>] (ieee80211_can_queue_work+0x0/0x4c [mac80211])
[<bf07c28c>] (ieee80211_queue_work+0x0/0x30 [mac80211])
[<bf0690dc>] (ieee80211_sta_timer+0x0/0x3c [mac80211])
[<c00a3008>] (run_timer_softirq+0x0/0x220)
[<c009e530>] (__do_softirq+0x0/0x130)
[<c009e660>] (irq_exit+0x0/0xb4)
[<c004c4a0>] (ipi_timer+0x0/0x4c)
[<c0046350>] (do_local_timer+0x0/0x88)
[<c00488ec>] (cpu_idle+0x0/0xe0)
[<c05294e8>] (rest_init+0x0/0xe0)
[<c0008958>] (start_kernel+0x0/0x314)
Signed-off-by: Eliad Peller <eliad@wizery.com>
When suspending, __ieee80211_suspend() calls ieee80211_scan_cancel(),
which will only cancel sw scan. In order to cancel hw scan, the
low-level driver has to cancel it in the suspend() callback. however,
this is too late, as a new scan_work will be enqueued (while the driver
is going into suspend).
Add a new cancel_hw_scan() callback, asking the driver to cancel an
active hw scan, and call it in ieee80211_scan_cancel().
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
Trigger connection monitor on resume from suspend. Since we
have been sleeping, there is reason to suspect that we might
not still be associated. The speed of detecting loss of
{connection,authentication} is worth the cost of the small
additional traffic at resume.
Function ieee80211_reconfig in net/mac80211/util.c contains label wake_up
which is defined unconditionally, but only used with CONFIG_PM. Gcc
warns about this when CONFIG_PM is not defined.
This patch makes the label's definition dependent on CONFIG_PM too,
eliminating the warning.
The issue was apparently introduced in git commit
eecc48000afe2ca6da22122d553b7cad294e42fc.
Signed-off-by: Vincent Zweije <vincent@zweije.nl>
Add ieee80211_get_operstate() function to get the operstate
of the netdevice.
This is needed for drivers that need to know when the interface
is IF_OPER_UP (e.g. wl12xx), and block notifiers can't be used
(e.g. because the interface is already IF_OPER_UP, like after
resuming from suspend)
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
Ignacy reports that sometimes after leaving an IBSS
joining a new one didn't work because there still
were stations on the list. He fixed it by flushing
stations when attempting to join a new IBSS, but
this shouldn't be happening in the first case. When
I looked into it I saw a race condition in teardown
that could cause stations to be added after flush,
and thus cause this situation. Ignacy confirms that
after applying my patch he hasn't seen this happen
again.
Reported-by: Ignacy Gawedzki <i@lri.fr>
Debugged-by: Ignacy Gawedzki <i@lri.fr>
Tested-by: Ignacy Gawedzki <i@lri.fr>
Some devices support BT/WLAN co-existence algorigthms.
In order not to harm the system performance and user experience, the device
requests not to allow any RX BA session and tear down existing RX BA sessions
based on system constraints such as periodic BT activity that needs to limit
WLAN activity (eg.SCO or A2DP).
In such cases, the intention is to limit the duration of the RX PPDU and
therefore prevent the peer device to use A-MPDU aggregation.
Adding ieee80211_stop_rx_ba_session() callback
that can be used by the driver to stop existing BA sessions.
Signed-off-by: Shahar Levi <shahar_levi@ti.com>
This reverts commit 1d38c16ce4156f63b45abbd09dd28ca2ef5172b4.
The mac80211 maintainer raised complaints about abuse of the CSA stop
reason, and about whether this patch actually serves its intended
purpose at all.
This reverts commit aac6af5534fade2b18682a0b9efad1a6c04c34c6.
net/mac80211/key.c
That commit has a race that causes a warning, as documented in the thread
here:
http://marc.info/?l=linux-wireless&m=130717684914101&w=2
This partially reverts 1c5cae815d19ffe02bdfda1260949ef2b1806171, because
the netdev name is copied into sdata->name, which is used for debugging
messages, for example. Otherwise, we get messages like this:
wlan%d: authenticated
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: "John W. Linville" <linville@tuxdriver.com>
Found several threads about fixed rate mode in minstrel_ht for test
environments, but no patches for it.
This patch provides such a mode through debugfs.
This adds dump support to testmode. The testmode
dump support in nl80211 requires using two of the
six cb->args, the rest can be used by the driver
to figure out where the dump position is at or to
store other data across invocations.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
Commit 79f460ca49d8d5700756ab7071c951311c7f29cc add a duplicate
linux/slab.h include to net/mac80211/scan.c - remove it.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Luciano Coelho <coelho@ti.com>
local->ps_data wasn't cleared on disassociation, which
(in some corner cases) caused reconnections to enter
psm before association completed.
Stop tx queues before updating rate control to ensure
proper rate selection. Otherwise packets can be transmitted
in 40 Mhz whereas hw is configured in HT20.
Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com>
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits)
Revert "rcu: Decrease memory-barrier usage based on semi-formal proof"
net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree
batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu
batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree()
batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu
net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu()
net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu()
net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu()
perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu()
perf,rcu: convert call_rcu(free_ctx) to kfree_rcu()
net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(net_generic_release) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu()
security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu()
net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu()
net,rcu: convert call_rcu(xps_map_release) to kfree_rcu()
net,rcu: convert call_rcu(rps_map_release) to kfree_rcu()
After commit 1928ecab620907a0953f811316d05f367f3f4dba (mac80211: fix and
simplify mesh locking) mesh table allocation is performed with the
pathtbl_resize_lock taken. Under those conditions one should not sleep.
This patch makes the allocations GFP_ATOMIC to prevent that.
Signed-off-by: Javier Cardona <javier@cozybit.com>
drivers/net/vmxnet3/vmxnet3_ethtool.c
net/core/dev.c
drivers/net/wireless/iwlwifi/iwl-agn-tx.c
net/mac80211/sta_info.h
This adds proper RCU annotations to the mesh path
table code, and fixes a number of bugs in the code
that I found while checking the sparse warnings I
got as a result of the annotations.
Some things like the changes in mesh_path_add() or
mesh_pathtbl_init() only serve to shut up sparse,
but other changes like the changes surrounding the
for_each_mesh_entry() macro fix real RCU bugs in
the code.
The locking in mesh_{mpath,mpp}_table_grow not only
has an rcu_read_unlock() missing, it's also racy
(though really only technically since it's invoked
from a single function only) since it obtains the
new size of the table without any locking, so two
invocations of the function could attempt the same
resize.
Additionally, it uses synchronize_rcu() which is
rather expensive and can be avoided trivially here.
Modify the functions to only use the table lock
and use call_rcu() instead of synchronize_rcu().
mac80211 uses call_rcu() with functions that are
defined in the module, so it must use rcu_barrier()
at module exit time.
Luckily, this seems to not be a problem in practice
as module unload and unregistration takes a long
time and probably does multiple synchronize_rcu().
As long as no delay is required b/w channel change, scan work
is proceeding without scheduling a new work. In such case, we
can not abort scan work when the card was unplugged. This patch
completes the scanning immediately whenever the device goes down.
Drivers shouldn't attempt to advertise support
for more than one IBSS interface since mac80211
doesn't support that. Check and return an error
from ieee80211_register_hw() in that case.
Mesh paths are deleted via mesh_path_del() which properly
deactivates the timer associated to a mesh path. But if paths were
deleted by mesh_table_free(..., true) timers would not be deactivated.
This fixes this case.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Currently the devices that have already stripped IEEE 802.11
header from the AMSDU SKB can not use ieee80211_amsdu_to_8023s
routine. This patch enhances ieee80211_amsdu_to_8023s() API by
changing mandatory removing of IEEE 802.11 header from AMSDU
to optional.
Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
These definitions need to be exposed now that we can set the peer link
states via NL80211_ATTR_STA_PLINK_STATE. They were already being
(opaquely) reported by NL80211_STA_INFO_PLINK_STATE.
This adds sparse RCU annotations to most of
mac80211, only the mesh code remains to be
done.
Due the the previous patches, the annotations
are pretty simple. The only thing that this
actually changes is removing the RCU usage of
key->sta in debugfs since this pointer isn't
actually an RCU-managed pointer (it only has
a single assignment done before the key even
goes live). As that is otherwise harmless, I
decided to make it part of this patch.
During my quest to make mac80211 not have any RCU
warnings from sparse, I came across the a-MPDU code
again and it wasn't quite clear why it isn't racy.
So instead of assigning the tid_tx array with just
the spinlock held in ieee80211_start_tx_ba_session
use a separate temporary array protected only by
the spinlock and protect all assignments to the
"live" array by both the spinlock and the mutex so
that other code is easily verified to be correct.
Due to pointer assignment atomicity I don't think
this is a real issue, but I'm not sure, especially
on Alpha the current code might be problematic.
Add the ability to advertise interface combinations in nl80211.
This allows the driver to indicate what the combinations are
that it supports. "Combinations" of just a single interface are
implicit, as previously. Note that cfg80211 will enforce that
the restrictions are met, but not for all drivers yet (once all
drivers are updated, we can remove the flag and enforce for all).
When no combinations are actually supported, an empty list will
be exported so that userspace can know if the kernel exported
this info or not (although it isn't clear to me what tools using
the info should do if the kernel didn't export it).
Since some interface types are purely virtual/software and don't
fit the restrictions, those are exposed in a new list of pure SW
types, not subject to restrictions. This mainly exists to handle
AP-VLAN and monitor interfaces in mac80211.
There's no need to have table functions in one
file and all users in another, move the functions
to the right file and make them static. Also move
a static variable to the beginning of the file to
make it easier to find.
When sched_scan_stopped was called by the driver, mac80211 calls
cfg80211, which in turn was calling mac80211 back with a flag
"driver_initiated". This flag was used so that mac80211 would do the
necessary cleanup but would not call the driver. This was enough to
prevent the bounce back between the driver and mac80211, but not
between mac80211 and cfg80211.
To fix this, we now do the cleanup in mac80211 before calling
cfg80211. To help with locking issues, the workqueue was moved from
cfg80211 to mac80211.
Signed-off-by: Luciano Coelho <coelho@ti.com>
A few configuration functions correctly do
rcu_read_lock() but don't correctly reference
some pointers protected by RCU. Fix that.
The code here is only not racy because all the
places that assign the pointers it uses are
holding the sta_mtx as well as the key_mtx and
so can't race against this because this code
holds the sta_mtx. But that's not intuitive,
so fix it to hold the key_mtx.
The code in ieee80211_del_key() doesn't acquire the
key_mtx properly when it dereferences the keys. It
turns out that isn't actually necessary since the
key_mtx itself seems to be redundant since all key
manipulations are done under the RTNL, but as long
as we have the key_mtx we should use it the right
way too.
The code here to RCU-dereference a pointer that's
on the stack is totally pointless, RCU isn't magic
(like say Java's weak references are), so the code
can't work like whoever wrote it thought it might.
Remove it so readers don't get confused. Note that
it seems that a bug is there anyway: I don't see
any code that cancels the timer when a mesh path
struct is destroyed.
When transmitting a frame, the transmitter waits a random number of
slots between 0 and cw. Thus, the contention time is (cw / 2) * t_slot
which we can represent instead as (cw * t_slot) >> 1. Also fix a few
other accounting bugs around contention time, and add comments.
Signed-off-by: Daniel Halperin <dhalperi@cs.washington.edu>
net/mac80211/cfg.c: In function ‘sta_apply_parameters’:
net/mac80211/cfg.c:746: error: ‘struct sta_info’ has no member named ‘plink_state’
make[1]: *** [net/mac80211/cfg.o] Error 1
make: *** [net/mac80211/mac80211.ko] Error 2
Implement support for HW scheduled scan. The mac80211 code doesn't perform
scheduled scans itself, but calls the driver to start and stop scheduled
scans.
This patch also creates a trace event class to be used by drv_hw_scan
and the new drv_sched_scan_start and drv_sched_stop functions, in
order to avoid duplicate code.
