path: root/net/mac80211
2007-06-11[PATCH] mac80211: Don't stop tx queue on master device while scanning.Mattias Nissler
mac80211 stops the tx queues during scans. This is wrong with respect to the master deivce tx queue, since stopping it prevents any probes from being sent during the scan. Instead, they accumulate in the queue and are only sent after the scan is finished, which is obviously wrong. Signed-off-by: Mattias Nissler <mattias.nissler@gmx.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-06-11[PATCH] mac80211: fix debugfs tx power reduction outputJohannes Berg
This patch fixes a typo in mac80211's debugfs.c. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-29[PATCH] mac80211: avoid null ptr deref in ieee80211_ibss_add_staJohn W. Linville
avoid sdata null pointer dereference in ieee80211_ibss_add_sta. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-29[PATCH] mac80211: always set carrier status on openMichael Wu
ieee80211_open should always set the carrier status since we may have set it to off before. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-29[PATCH] mac80211: fix memory leak when defrag fragmentsHong Liu
We forget to free all the fragments when defraging them into one packet. Signed-off-by: Hong Liu <hong.liu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-29[PATCH] mac80211: fail back to use associate from reassociateZhu Yi
Some APs have strict checking between associate and reassociate. In a case when an AP is restarted during a connection, it denies the mac80211 reassoc request since this is a new association for the AP. To fix this problem, we need to check the status code against WLAN_STATUS_REASSOC_NO_ASSOC and clear ifsta->prev_bssid_set in handling the association failure response. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-10[MAC80211]: include <linux/delay.h> instead of <asm/delay.h>Geert Uytterhoeven
| CC net/mac80211/ieee80211_sta.o | In file included from linux/net/mac80211/ieee80211_sta.c:31: | include2/asm/delay.h: In function '__const_udelay': | include2/asm/delay.h:33: error: 'loops_per_jiffy' undeclared (first use in this function) | include2/asm/delay.h:33: error: (Each undeclared identifier is reported only once | include2/asm/delay.h:33: error: for each function it appears in.) Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-05[MAC80211]: Add debugfs attributes.Jiri Benc
Export various mac80211 internal variables through debugfs. Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-05[MAC80211]: Add mac80211 wireless stack.Jiri Benc
Add mac80211, the IEEE 802.11 software MAC layer. Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
