path: root/net/mac802154
2013-12-22mac802154: fix following checkpath.pl warning Prefer pr_warn(... to ↵Weilong Chen
pr_warning(... This patch fixes checkpath.pl: WARNING: Prefer pr_warn(... to pr_warning(... #447: FILE: ./wpan.c:447: Signed-off-by: Weilong Chen <chenweilong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-306lowpan: set and use mac_len for mac header lengthAlexander Aring
Set the mac header length while creating the 802.15.4 mac header. Drop the function for recalculate mac header length in upper layers which was static and works for intra pan communication only. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Reviewed-by: Werner Almesberger <werner@almesberger.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-30mac802154: Use pr_err(...) rather than printk(KERN_ERR ...)Chen Weilong
This change is inspired by checkpatch. Signed-off-by: Weilong Chen <chenweilong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c drivers/net/ethernet/emulex/benet/be.h include/net/tcp.h net/mac802154/mac802154.h Most conflicts were minor overlapping stuff. The be2net driver brought in some fixes that added __vlan_put_tag calls, which in net-next take an additional argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-29net: mac802154: comparision issue of type cast, finding by EXTRA_CFLAGS=-WChen Gang
Change MAC802154_CHAN_NONE from ~(u8)0 to 0xff, or the comparison in mac802154_wpan_xmit() for ``chan == MAC802154_CHAN_NONE'' will not succeed. This bug can be boiled down to ``u8 foo = 0xff; if (foo == ~(u8)0) [...] else [...]'' where the condition will always take the else branch. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-08mac802154: Keep track of the channel when changedAlan Ott
Two sections checked whether the current channel != the new channel without ever setting the current channel variables. 1. net/mac802154/tx.c: Prevent set_channel() from getting called every time a packet is sent. 2. net/mac802154/mib.c: Lock (pib_lock) accesses to current_channel and current_page and make sure they are updated when the channel has been changed. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07mac802154: Increase tx_buffer_lenAlan Ott
Increase the buffer length from 10 to 300 packets. Consider that traffic on mac802154 devices will often be 6LoWPAN, and a full-length (1280 octet) IPv6 packet will fragment into 15 6LoWPAN fragments (because the MTU of IEEE 802.15.4 is 127). A 300-packet queue is really 20 full-length IPv6 packets. With a queue length of 10, an entire IPv6 packet was unable to get queued at one time, causing fragments to be dropped, and making reassembly impossible. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07mac802154: Use netif flow controlAlan Ott
Use netif_stop_queue() and netif_wake_queue() to control the flow of packets to mac802154 devices. Since many IEEE 802.15.4 devices have no output buffer, and since the mac802154 xmit() function is designed to block, netif_stop_queue() is called after each packet. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07mac802154: Do not try to resend failed packetsAlan Ott
When ops->xmit() fails, drop the packet. Devices which support hardware ack and retry (which include all devices currently supported by mainline), will automatically retry sending the packet (in the hardware) up to 3 times, per the 802.15.4 spec. There is no need, and it is incorrect to try to do it in mac802154. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26mac802154: add mac802154_dev_get_dsn()Tony Cheneau
Bring-over mac802154_dev_get_dsn() function that was present in the Linux ZigBee kernel. This function is called by the 6LoWPAN code in order to properly set the DSN (Data Sequence Number) value in the IEEE 802.15.4 frame. Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26mac802154: turn on ACK when enabled by the upper layersTony Cheneau
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-06wpan: use stack buffer instead of heapAlexander Aring
head buffer is only temporary available in mac802154_header_create. So it's not necessary to put it on the heap. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-06wpan: whitespace fixAlexander Aring
2013-01-11net/mac802154: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> CC: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: David S. Miller <davem@davemloft.net>
2013-01-04mac802154: fix NOHZ local_softirq_pending 08 warningAlexander Aring
When using nanosleep() in an userspace application we get a ratelimit warning NOHZ: local_softirq_pending 08 for 10 times. This patch replaces netif_rx() with netif_rx_ni() which has to be used from process/softirq context. The process/softirq context will be called from fakelb driver. See linux-kernel commit 481a819 for similar fix. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-14mac802154: fix destructon ordering for ieee802154 devicesKonstantin Khlebnikov
mutex_destroy() must be called before wpan_phy_free(), because it puts the last reference and frees memory. Catched as overwritten poison in kmalloc-2048. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: linux-zigbee-devel@lists.sourceforge.net Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-30mac802154: use kfree_skb() instead of dev_kfree_skb()Alan Ott
kfree_skb() indicates failure, which is where this is being used. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-30mac802154: fix memory leaksAlan Ott
kfree_skb() was not getting called in the case of some failures. This was pointed out by Eric Dumazet. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-12mac802154: sparse warnings: make symbols staticalex.bluesman.smirnov@gmail.com
Make symbols static to avoid the following warning shown up by sparse: warning: symbol ... was not declared. Should it be static? Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-12mac802154: add get short address methodalex.bluesman.smirnov@gmail.com
Add method to get the device short 802.15.4 address. This call needed by ieee802154 layer to satisfy 'iz list' request from the user space. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/caif/caif_hsi.c drivers/net/usb/qmi_wwan.c The qmi_wwan merge was trivial. The caif_hsi.c, on the other hand, was not. It's a conflict between 1c385f1fdf6f9c66d982802cd74349c040980b50 ("caif-hsi: Replace platform device with ops structure.") in the net-next tree and commit 39abbaef19cd0a30be93794aa4773c779c3eb1f3 ("caif-hsi: Postpone init of HIS until open()") in the net tree. I did my best with that one and will ask Sjur to check it out. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-26mac802154: add monitor listener to TX datapathalex.bluesman.smirnov@gmail.com
Add monitor receive callback to the TX datapath to catch all the data sent to transceivers. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-26mac802154: mlme start requestalex.bluesman.smirnov@gmail.com
Basic preparations to start the interface. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-26mac802154: page and channel setteralex.bluesman.smirnov@gmail.com
A new method to set page and channel values for a transceiver was added to the MIB. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-26mac802154: short address setteralex.bluesman.smirnov@gmail.com
A method to assign the IEEE802.15.4 short address was added to the MIB implementation. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-26mac802154: set and get PAN idalex.bluesman.smirnov@gmail.com
Two methods intended to get and set the Private Area Network identifier were added to the MIB implementation. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-26mac802154: add wpan device-class supportalex.bluesman.smirnov@gmail.com
Every real 802.15.4 transceiver, which works with software MAC layer, can be classified as a wpan device in this stack. So the wpan device implementation provides missing link in datapath between the device drivers and the Linux network queue. According to the IEEE 802.15.4 standard each packet can be one of the following types: - beacon - MAC layer command - ACK - data This patch adds support for the data packet-type only, but this is enough to perform data transmission and receiving over radio. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-25mac802154: add missed bracesalex.bluesman.smirnov@gmail.com
Add missed braces after 'if' operator. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: monitor device supportalex.bluesman.smirnov@gmail.com
Support for monitor device intended to capture all the network activity. This interface could be used by networks sniffers and is already supported by WireShark. That's a good test point to check that basic MAC support works. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: slaves management supportalex.bluesman.smirnov@gmail.com
This patch adds functionality for registration and removing slaves in the stack. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: basic mib supportalex.bluesman.smirnov@gmail.com
Basic support for IEEE 802.15.4 management information base. Current implementation contains a command to set HW address only. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: basic MAC commands interface supportalex.bluesman.smirnov@gmail.com
Declare set of MAC-commands for reduced functionality interface. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: slave interfaces declarationalex.bluesman.smirnov@gmail.com
Slaves represent typical network interfaces available from userspace. Each ieee802154 device/transceiver may have several slaves and able to be associated with several networks at the same time. So this patch adds structure for slaves declaration. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: TX data pathalex.bluesman.smirnov@gmail.com
Main TX data path implementation between upper and physical layers. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: RX data pathalex.bluesman.smirnov@gmail.com
Main RX data path implementation between physical and mac layers. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: allocation of ieee802154 devicealex.bluesman.smirnov@gmail.com
An interface to allocate and register ieee802154 compatible device. The allocated device has the following representation in memory: +-----------------------+ | struct wpan_phy | +-----------------------+ | struct mac802154_priv | +-----------------------+ | driver's private data | +-----------------------+ Used by device drivers to register new instance in the stack. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
