path: root/net/netfilter/core.c
2011-02-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/e1000e/netdev.c net/xfrm/xfrm_policy.c
2011-02-14netfilter: nf_iterate: fix incorrect RCU usagePatrick McHardy
As noticed by Eric, nf_iterate doesn't use RCU correctly by accessing the prev pointer of a RCU protected list element when a verdict of NF_REPEAT is issued. Fix by jumping backwards to the hook invocation directly instead of loading the previous list element before continuing the list iteration. Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-01-18netfilter: allow NFQUEUE bypass if no listener is availableFlorian Westphal
If an skb is to be NF_QUEUE'd, but no program has opened the queue, the packet is dropped. This adds a v2 target revision of xt_NFQUEUE that allows packets to continue through the ruleset instead. Because the actual queueing happens outside of the target context, the 'bypass' flag has to be communicated back to the netfilter core. Unfortunately the only choice to do this without adding a new function argument is to use the target function return value (i.e. the verdict). In the NF_QUEUE case, the upper 16bit already contain the queue number to use. The previous patch reduced NF_VERDICT_MASK to 0xff, i.e. we now have extra room for a new flag. If a hook issued a NF_QUEUE verdict, then the netfilter core will continue packet processing if the queueing hook returns -ESRCH (== "this queue does not exist") and the new NF_VERDICT_FLAG_QUEUE_BYPASS flag is set in the verdict value. Note: If the queue exists, but userspace does not consume packets fast enough, the skb will still be dropped. Signed-off-by: Florian Westphal <fwestphal@astaro.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-01-18netfilter: reduce NF_VERDICT_MASK to 0xffFlorian Westphal
NF_VERDICT_MASK is currently 0xffff. This is because the upper 16 bits are used to store errno (for NF_DROP) or the queue number (NF_QUEUE verdict). As there are up to 0xffff different queues available, there is no more room to store additional flags. At the moment there are only 6 different verdicts, i.e. we can reduce NF_VERDICT_MASK to 0xff to allow storing additional flags in the 0xff00 space. NF_VERDICT_BITS would then be reduced to 8, but because the value is exported to userspace, this might cause breakage; e.g.: e.g. 'queuenr = (1 << NF_VERDICT_BITS) | NF_QUEUE' would now break. Thus, remove NF_VERDICT_BITS usage in the kernel and move the old value to the 'userspace compat' section. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-01-18netfilter: nfnetlink_queue: do not free skb on errorFlorian Westphal
Move free responsibility from nf_queue to caller. This enables more flexible error handling; we can now accept the skb instead of freeing it. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-01-18netfilter: nfnetlink_queue: return error number to callerFlorian Westphal
instead of returning -1 on error, return an error number to allow the caller to handle some errors differently. ECANCELED is used to indicate that the hook is going away and should be ignored. A followup patch will introduce more 'ignore this hook' conditions, (depending on queue settings) and will move kfree_skb responsibility to the caller. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-01-13Merge branch 'master' of ↵Simon Horman
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6 into HEAD
2010-11-17netfilter: allow hooks to pass error code back up the stackEric Paris
SELinux would like to pass certain fatal errors back up the stack. This patch implements the generic netfilter support for this functionality. Based-on-patch-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15netfilter: add __rcu annotationsEric Dumazet
Add some __rcu annotations and use helpers to reduce number of sparse warnings (CONFIG_SPARSE_RCU_POINTER=y) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
2010-10-04netfilter: unregister nf hooks, matches and targets in the reverse orderChangli Gao
Since we register nf hooks, matches and targets in order, we'd better unregister them in the reverse order. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-08-19net/netfilter: __rcu annotationsArnd Bergmann
Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Patrick McHardy <kaber@trash.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-02-18netfilter: remove unneeded gotoJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: enable netfilter in netnsAlexey Dobriyan
From kernel perspective, allow entrance in nf_hook_slow(). Stuff which uses nf_register_hook/nf_register_hooks, but otherwise not netns-ready: DECnet netfilter ipt_CLUSTERIP nf_nat_standalone.c together with XFRM (?) IPVS several individual match modules (like hashlimit) ctnetlink NOTRACK all sorts of queueing and reporting to userspace L3 and L4 protocol sysctls, bridge sysctls probably something else Anyway critical mass has been achieved, there is no reason to hide netfilter any longer. From userspace perspective, allow to manipulate all sorts of iptables/ip6tables/arptables rules. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: Introduce NFPROTO_* constantsJan Engelhardt
The netfilter subsystem only supports a handful of protocols (much less than PF_*) and even non-PF protocols like ARP and pseudo-protocols like PF_BRIDGE. By creating NFPROTO_*, we can earn a few memory savings on arrays that previously were always PF_MAX-sized and keep the pseudo-protocols to ourselves. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: Use unsigned types for hooknum and pf varsJan Engelhardt
and (try to) consistently use u_int8_t for the L3 family. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-24[NETNS]: Process netfilter hooks in initial namespace only.Denis V. Lunev
There were no packets in the namespace other than initial previously. This will be changed in the neareast future. Netfilters are not namespace aware and should be processed in the initial namespace only for now. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: kill nf_sysctl.cPatrick McHardy
Since there now is generic support for shared sysctl paths, the only remains are the net/netfilter and net/ipv4/netfilter paths. Move them to net/netfilter/core.c and net/ipv4/netfilter.c and kill nf_sysctl.c. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: constify nf_afinfoPatrick McHardy
2008-01-28[NETFILTER]: remove annoying debugging messagePatrick McHardy
Don't log "nf_hook: Verdict = QUEUE." message with NETFILTER_DEBUG=y. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_queue: remove unnecessary hook existance checkPatrick McHardy
We hold a module reference for each queued packet, so the hook that queued the packet can't disappear. Also remove an obsolete comment stating the opposite. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: replace list_for_each with list_for_each_entryLi Zefan
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Move netfilter checksum helpers to net/core/utils.cPatrick McHardy
This allows to get rid of the CONFIG_NETFILTER dependency of NET_ACT_NAT. This patch redefines the old names to keep the noise low, the next patch converts all users. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Do not copy skb in skb_make_writableHerbert Xu
Now that all callers of netfilter can guarantee that the skb is not shared, we no longer have to copy the skb in skb_make_writable. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: add some consts, remove some castsJan Engelhardt
Make a number of variables const and/or remove unneeded casts. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[SKBUFF]: Keep track of writable header len of headerless clonesPatrick McHardy
Currently NAT (and others) that want to modify cloned skbs copy them, even if in the vast majority of cases its not necessary because the skb is a clone made by TCP and the portion NAT wants to modify is actually writable because TCP release the header reference before cloning. The problem is that there is no clean way for NAT to find out how long the writable header area is, so this patch introduces skb->hdr_len to hold this length. When a headerless skb is cloned skb->hdr_len is set to the current headroom, for regular clones it is copied from the original. A new function skb_clone_writable(skb, len) returns whether the skb is writable up to len bytes from skb->data. To avoid enlarging the skb the mac_len field is reduced to 16 bit and the new hdr_len field is put in the remaining 16 bit. I've done a few rough benchmarks of NAT (not with this exact patch, but a very similar one). As expected it saves huge amounts of system time in case of sendfile, bringing it down to basically the same amount as without NAT, with sendmsg it only helps on loopback, probably because of the large MTU. Transmit a 1GB file using sendfile/sendmsg over eth0/lo with and without NAT: - sendfile eth0, no NAT: sys 0m0.388s - sendfile eth0, NAT: sys 0m1.835s - sendfile eth0: NAT + path: sys 0m0.370s (~ -80%) - sendfile lo, no NAT: sys 0m0.258s - sendfile lo, NAT: sys 0m2.609s - sendfile lo, NAT + patch: sys 0m0.260s (~ -90%) - sendmsg eth0, no NAT: sys 0m2.508s - sendmsg eth0, NAT: sys 0m2.539s - sendmsg eth0, NAT + patch: sys 0m2.445s (no change) - sendmsg lo, no NAT: sys 0m2.151s - sendmsg lo, NAT: sys 0m3.557s - sendmsg lo, NAT + patch: sys 0m2.159s (~ -40%) I expect other users can see a similar performance improvement, packet mangling iptables targets, ipip and ip_gre come to mind .. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nf_conntrack: kill destroy() in struct nf_conntrack for dietYasuyuki Kozakai
The destructor per conntrack is unnecessary, then this replaces it with system wide destructor. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nf_conntrack: don't use nfct in skb if conntrack is disabledYasuyuki Kozakai
2007-04-25[NETFILTER]: Remove changelogs and CVS IDsPatrick McHardy
2007-02-12[NETFILTER]: Fix whitespace errorsYOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: Switch nf_register_hook/nf_unregister_hook to mutexPatrick McHardy
The spinlock is only used in process context (register/unregister) since RCU is used for the nf_hook lists, switch to a mutex. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: Switch nf_register_afinfo/nf_unregister_afinfo to mutexPatrick McHardy
The spinlock is only used in process context (register/unregister), switch to a mutex. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: Remove unnecessary synchronize_net() in nf_register_hookPatrick McHardy
We're only adding to the list, no need to synchronize. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: Properly use RCU in nf_ct_attachPatrick McHardy
Use rcu_assign_pointer/rcu_dereference for ip_ct_attach pointer instead of self-made RCU and use rcu_read_lock to make sure the conntrack module doesn't disappear below us while calling it, since this function can be called from outside the netfilter hooks. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: More __read_mostly annotationsMartin Josefsson
Place rarely written variables in the read-mostly section by using __read_mostly Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NET]: netfilter checksum annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETFILTER]: nf_queue: handle GSO packetsPatrick McHardy
Handle GSO packets in nf_queue by segmenting them before queueing to avoid breaking GSO in case they get mangled. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETFILTER]: Get rid of HW checksum invalidationPatrick McHardy
Update hardware checksums incrementally to avoid breaking GSO. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Introduce infrastructure for address family specific operationsPatrick McHardy
Change the queue rerouter intrastructure to a generic usable infrastructure for address family specific operations as a base for some cleanups. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Add helper functions for mass hook registration/unregistrationPatrick McHardy
2005-08-29[NETFILTER]: split net/core/netfilter.c into net/netfilter/*.cHarald Welte
This patch doesn't introduce any code changes, but merely splits the core netfilter code into four separate files. It also moves it from it's old location in net/core/ to the recently-created net/netfilter/ directory. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
