path: root/net/netfilter/nf_conntrack_sane.c
2011-06-06netfilter: add more values to enum ip_conntrack_infoEric Dumazet
Following error is raised (and other similar ones) : net/ipv4/netfilter/nf_nat_standalone.c: In function ‘nf_nat_fn’: net/ipv4/netfilter/nf_nat_standalone.c:119:2: warning: case value ‘4’ not in enumerated type ‘enum ip_conntrack_info’ gcc barfs on adding two enum values and getting a not enumerated result : case IP_CT_RELATED+IP_CT_IS_REPLY: Add missing enum values Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: David Miller <davem@davemloft.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-11-17netfilter: nf_conntrack: connection tracking helper name persistent aliasesPablo Neira Ayuso
This patch adds the macro MODULE_ALIAS_NFCT_HELPER that defines a way to provide generic and persistent aliases for the connection tracking helpers. This next patch requires this patch. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: replace NF_CT_DUMP_TUPLE macro indrection by ↵Jan Engelhardt
function call Directly call IPv4 and IPv6 variants where the address family is easily known. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: add tuplehash l3num/protonum accessorsPatrick McHardy
Add accessors for l3num and protonum and get rid of some overly long expressions. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-03-25[NETFILTER]: nf_conntrack: introduce expectation classes and policiesPatrick McHardy
Introduce expectation classes and policies. An expectation class is used to distinguish different types of expectations by the same helper (for example audio/video/t.120). The expectation policy is used to hold the maximum number of expectations and the initial timeout for each class. The individual classes are isolated from each other, which means that for example an audio expectation will only evict other audio expectations. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: nf_conntrack_sane: annotate SANE helper with constJan Engelhardt
Annotate nf_conntrack_sane variables with const qualifier and remove a few casts. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: Convert DEBUGP to pr_debugPatrick McHardy
Convert DEBUGP to pr_debug and fix lots of non-compiling debug statements. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack: mark helpers __read_mostlyPatrick McHardy
Most are __read_mostly already, this changes the remaining ones. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack: reduce masks to a subset of tuplesPatrick McHardy
Since conntrack currently allows to use masks for every bit of both helper and expectation tuples, we can't hash them and have to keep them on two global lists that are searched for every new connection. This patch removes the never used ability to use masks for the destination part of the expectation tuple and completely removes masks from helpers since the only reasonable choice is a full match on l3num, protonum and src.u.all. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack_expect: function naming unificationPatrick McHardy
Currently there is a wild mix of nf_conntrack_expect_, nf_ct_exp_, expect_, exp_, ... Consistently use nf_ct_ as prefix for exported functions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NETFILTER]: Add SANE connection tracking helperMichal Schmidt
This is nf_conntrack_sane, a netfilter connection tracking helper module for the SANE protocol used by the 'saned' daemon to make scanners available via network. The SANE protocol uses separate control & data connections, similar to passive FTP. The helper module is needed to recognize the data connection as RELATED to the control one. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
