path: root/net/netfilter/nf_internals.h
2010-05-13netfilter: cleanup printk messagesStephen Hemminger
Make sure all printk messages have a severity level. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: Use unsigned types for hooknum and pf varsJan Engelhardt
and (try to) consistently use u_int8_t for the L3 family. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: Fix whitespace errorsYOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETFILTER]: nf_queue: handle GSO packetsPatrick McHardy
Handle GSO packets in nf_queue by segmenting them before queueing to avoid breaking GSO in case they get mangled. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: split net/core/netfilter.c into net/netfilter/*.cHarald Welte
This patch doesn't introduce any code changes, but merely splits the core netfilter code into four separate files. It also moves it from it's old location in net/core/ to the recently-created net/netfilter/ directory. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
