If an skb is to be NF_QUEUE'd, but no program has opened the queue, the
packet is dropped.
This adds a v2 target revision of xt_NFQUEUE that allows packets to
continue through the ruleset instead.
Because the actual queueing happens outside of the target context, the
'bypass' flag has to be communicated back to the netfilter core.
Unfortunately the only choice to do this without adding a new function
argument is to use the target function return value (i.e. the verdict).
In the NF_QUEUE case, the upper 16bit already contain the queue number
to use. The previous patch reduced NF_VERDICT_MASK to 0xff, i.e.
we now have extra room for a new flag.
If a hook issued a NF_QUEUE verdict, then the netfilter core will
continue packet processing if the queueing hook
returns -ESRCH (== "this queue does not exist") and the new
NF_VERDICT_FLAG_QUEUE_BYPASS flag is set in the verdict value.
Note: If the queue exists, but userspace does not consume packets fast
enough, the skb will still be dropped.
Signed-off-by: Florian Westphal <fwestphal@astaro.com>
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
When extended status codes are available, such as ENOMEM on failed
allocations, or subsequent functions (e.g. nf_ct_get_l3proto), passing
them up to userspace seems like a good idea compared to just always
EINVAL.
Part of the transition of done by this semantic patch:
// <smpl>
@ rule1 @
struct xt_target ops;
identifier check;
ops.checkentry = check;
identifier rule1.check;
check(...) { <...
-return true;
+return 0;
check(...) { <...
-return false;
+return -EINVAL;
// </smpl>
Restore function signatures from bool to int so that we can report
memory allocation failures or similar using -ENOMEM rather than
always having to pass -EINVAL back.
// <smpl>
type bool;
identifier check, par;
-bool check
+int check
(struct xt_tgchk_param *par) { ... }
// </smpl>
Minus the change it does to xt_ct_find_proto.
Supplement to aa5fa3185791aac71c9172d4fda3e8729164b5d1.
The semantic patch for this change is:
// <smpl>
struct xt_target_param *par;
-par->target->family
+par->family
struct xt_tgchk_param *par;
+par->family
struct xt_tgdtor_param *par;
+par->family
// </smpl>
"It is deliberately not done in the init function, since we might not
have sufficient random while booting."
net/netfilter/xt_NFQUEUE.c:46:9: warning: incorrect type in assignment (different base types)
net/netfilter/xt_NFQUEUE.c:46:9: expected unsigned int [unsigned] [usertype] ipaddr
net/netfilter/xt_NFQUEUE.c:46:9: got restricted unsigned int
net/netfilter/xt_NFQUEUE.c:68:10: warning: incorrect type in assignment (different base types)
net/netfilter/xt_NFQUEUE.c:68:10: expected unsigned int [unsigned] <noident>
net/netfilter/xt_NFQUEUE.c:68:10: got restricted unsigned int
net/netfilter/xt_NFQUEUE.c:69:10: warning: incorrect type in assignment (different base types)
net/netfilter/xt_NFQUEUE.c:69:10: expected unsigned int [unsigned] <noident>
net/netfilter/xt_NFQUEUE.c:69:10: got restricted unsigned int
net/netfilter/xt_NFQUEUE.c:70:10: warning: incorrect type in assignment (different base types)
net/netfilter/xt_NFQUEUE.c:70:10: expected unsigned int [unsigned] <noident>
net/netfilter/xt_NFQUEUE.c:70:10: got restricted unsigned int
net/netfilter/xt_NFQUEUE.c:71:10: warning: incorrect type in assignment (different base types)
net/netfilter/xt_NFQUEUE.c:71:10: expected unsigned int [unsigned] <noident>
net/netfilter/xt_NFQUEUE.c:71:10: got restricted unsigned int
net/netfilter/xt_cluster.c:20:55: warning: incorrect type in return expression (different base types)
net/netfilter/xt_cluster.c:20:55: expected unsigned int
net/netfilter/xt_cluster.c:20:55: got restricted unsigned int const [usertype] ip
Adds support for specifying a range of queues instead of a single queue
id. Flows will be distributed across the given range.
This is useful for multicore systems: Instead of having a single
application read packets from a queue, start multiple
instances on queues x, x+1, .. x+n. Each instance can process
flows independently.
Packets for the same connection are put into the same queue.
Signed-off-by: Holger Eitzenberger <heitzenberger@astaro.com>
We can use wildcard matching here, just like
ab4f21e6fb1c09b13c4c3cb8357babe8223471bd ("xtables: use NFPROTO_UNSPEC
in more extensions").
(Supplements: ee999d8b9573df1b547aacdc6d79f86eb79c25cd)
NFPROTO_ARP actually has a different value from NF_ARP, so ensure all
callers use the new value so that packets _do_ get delivered to the
registered hooks.
This patch does this for target extensions' target functions.
Updates the MODULE_DESCRIPTION() tags for all Netfilter modules,
actually describing what the module does and not just
"netfilter XYZ target".
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Give all Netfilter modules consistent and unique symbol names.
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Every netfilter module uses `init' for its module_init() function and
`fini' or `cleanup' for its module_exit() function.
Problem is, this creates uninformative initcall_debug output and makes
ctags rather useless.
So go through and rename them all to $(filename)_init and
$(filename)_fini.
Set the family field in xt_[matches|targets] registered.
This monster-patch tries to do the best job for unifying the data
structures and backend interfaces for the three evil clones ip_tables,
ip6_tables and arp_tables. In an ideal world we would never have
allowed this kind of copy+paste programming... but well, our world
isn't (yet?) ideal.
o introduce a new x_tables module
o {ip,arp,ip6}_tables depend on this x_tables module
o registration functions for tables, matches and targets are only
wrappers around x_tables provided functions
o all matches/targets that are used from ip_tables and ip6_tables
are now implemented as xt_FOOBAR.c files and provide module aliases
to ipt_FOOBAR and ip6t_FOOBAR
o header files for xt_matches are in include/linux/netfilter/,
include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers
around the xt_FOOBAR.h headers
Based on this patchset we're going to further unify the code,
gradually getting rid of all the layer 3 specific assumptions.
Signed-off-by: Harald Welte <laforge@netfilter.org>
