path: root/net/netfilter/xt_TCPMSS.c
2011-04-04netfilter: af_info: add 'strict' parameter to limit lookup to .oifFlorian Westphal
ipv6 fib lookup can set RT6_LOOKUP_F_IFACE flag to restrict search to an interface, but this flag cannot be set via struct flowi. Also, it cannot be set via ip6_route_output: this function uses the passed sock struct to determine if this flag is required (by testing for nonzero sk_bound_dev_if). Work around this by passing in an artificial struct sk in case 'strict' argument is true. This is required to replace the rt6_lookup call in xt_addrtype.c with nf_afinfo->route(). Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-04-04netfilter: af_info: add network namespace parameter to route hookFlorian Westphal
This is required to eventually replace the rt6_lookup call in xt_addrtype.c with nf_afinfo->route(). Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-03-12netfilter: Use flowi4 and flowi6 in xt_TCPMSSDavid S. Miller
2010-06-15tcp: unify tcp flag macrosChangli Gao
unify tcp flag macros: TCPHDR_FIN, TCPHDR_SYN, TCPHDR_RST, TCPHDR_PSH, TCPHDR_ACK, TCPHDR_URG, TCPHDR_ECE and TCPHDR_CWR. TCBCB_FLAG_* are replaced with the corresponding TCPHDR_*. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- include/net/tcp.h | 24 ++++++------- net/ipv4/tcp.c | 8 ++-- net/ipv4/tcp_input.c | 2 - net/ipv4/tcp_output.c | 59 ++++++++++++++++----------------- net/netfilter/nf_conntrack_proto_tcp.c | 32 ++++++----------- net/netfilter/xt_TCPMSS.c | 4 -- 6 files changed, 58 insertions(+), 71 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-11netfilter: xtables: substitute temporary defines by final nameJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-04-20Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: Documentation/feature-removal-schedule.txt net/ipv6/netfilter/ip6t_REJECT.c net/netfilter/xt_limit.c Signed-off-by: Patrick McHardy <kaber@trash.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-25netfilter: xtables: change targets to return error codeJan Engelhardt
Part of the transition of done by this semantic patch: // <smpl> @ rule1 @ struct xt_target ops; identifier check; @@ ops.checkentry = check; @@ identifier rule1.check; @@ check(...) { <... -return true; +return 0; ...> } @@ identifier rule1.check; @@ check(...) { <... -return false; +return -EINVAL; ...> } // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: xtables: change xt_target.checkentry return typeJan Engelhardt
Restore function signatures from bool to int so that we can report memory allocation failures or similar using -ENOMEM rather than always having to pass -EINVAL back. // <smpl> @@ type bool; identifier check, par; @@ -bool check +int check (struct xt_tgchk_param *par) { ... } // </smpl> Minus the change it does to xt_ct_find_proto. Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: xt extensions: use pr_<level> (2)Jan Engelhardt
Supplement to 1159683ef48469de71dc26f0ee1a9c30d131cf89. Downgrade the log level to INFO for most checkentry messages as they are, IMO, just an extra information to the -EINVAL code that is returned as part of a parameter "constraint violation". Leave errors to real errors, such as being unable to create a LED trigger. Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-18netfilter: xt extensions: use pr_<level>Jan Engelhardt
2010-02-24netfilter: xtables: replace XT_MATCH_ITERATE macroJan Engelhardt
The macro is replaced by a list.h-like foreach loop. This makes the code more inspectable. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-02-02netfilter: xt_TCPMSS: SYN packets are allowed to contain dataSimon Arlott
The TCPMSS target is dropping SYN packets where: 1) There is data, or 2) The data offset makes the TCP header larger than the packet. Both of these result in an error level printk. This printk has been removed. This change avoids dropping SYN packets containing data. If there is also no MSS option (as well as data), one will not be added because of possible complications due to the increased packet size. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (5/6)Jan Engelhardt
This patch does this for target extensions' checkentry functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (4/6)Jan Engelhardt
This patch does this for target extensions' target functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: x_tables: use NFPROTO_* in extensionsJan Engelhardt
2008-07-21netfilter: xt_TCPMSS: collapse tcpmss_reverse_mtu{4,6} into one functionJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: xt_TCPMSS: consider reverse route's MTU in clamp-to-pmtuJan Engelhardt
The TCPMSS target in Xtables should consider the MTU of the reverse route on forwarded packets as part of the path MTU. Point in case: IN=ppp0, OUT=eth0. MSS set to 1460 in spite of MTU of ppp0 being 1392. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Update modules' descriptionsJan Engelhardt
Updates the MODULE_DESCRIPTION() tags for all Netfilter modules, actually describing what the module does and not just "netfilter XYZ target". Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: xt_TCPMSS: don't allow netfilter --setmss to increase mssBenjamin LaHaise
When terminating DSL connections for an assortment of random customers, I've found it necessary to use iptables to clamp the MSS used for connections to work around the various ICMP blackholes in the greater net. Unfortunately, the current behaviour in Linux is imperfect and actually make things worse, so I'm proposing the following: increasing the MSS in a packet can never be a good thing, so make --set-mss only lower the MSS in a packet. Yes, I am aware of --clamp-mss-to-pmtu, but it doesn't work for outgoing connections from clients (ie web traffic), as it only looks at the PMTU on the destination route, not the source of the packet (the DSL interfaces in question have a 1442 byte MTU while the destination ethernet interface is 1500 -- there are problematic hosts which use a 1300 byte MTU). Reworking that is probably a good idea at some point, but it's more work than this is. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: x_tables: consistent and unique symbol namesJan Engelhardt
Give all Netfilter modules consistent and unique symbol names. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Convert old checksum helper namesPatrick McHardy
Kill the defines again, convert to the new checksum helper names and remove the dependency of NET_ACT_NAT on NETFILTER. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-30[NETFILTER]: xt_TCPMSS: remove network triggerable WARN_ONPatrick McHardy
ipv6_skip_exthdr() returns -1 for invalid packets. don't WARN_ON that. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Avoid skb_copy/pskb_copy/skb_realloc_headroomHerbert Xu
This patch replaces unnecessary uses of skb_copy, pskb_copy and skb_realloc_headroom by functions such as skb_make_writable and pskb_expand_head. This allows us to remove the double pointers later. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Do not copy skb in skb_make_writableHerbert Xu
Now that all callers of netfilter can guarantee that the skb is not shared, we no longer have to copy the skb in skb_make_writable. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: x_tables: mark matches and targets __read_mostlyPatrick McHardy
2007-07-10[NETFILTER]: Remove redundant parentheses/bracesJan Engelhardt
Removes redundant parentheses and braces (And add one pair in a xt_tcpudp.c macro). Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: x_tables: switch xt_target->checkentry to boolJan Engelhardt
Switch the return type of target checkentry functions to boolean. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NETFILTER]: add IPv6-capable TCPMSS targetPatrick McHardy
