path: root/net/netfilter/xt_set.c
2011-06-21Remove redundant linux/version.h includes from net/Jesper Juhl
It was suggested by "make versioncheck" that the follwing includes of linux/version.h are redundant: /home/jj/src/linux-2.6/net/caif/caif_dev.c: 14 linux/version.h not needed. /home/jj/src/linux-2.6/net/caif/chnl_net.c: 10 linux/version.h not needed. /home/jj/src/linux-2.6/net/ipv4/gre.c: 19 linux/version.h not needed. /home/jj/src/linux-2.6/net/netfilter/ipset/ip_set_core.c: 20 linux/version.h not needed. /home/jj/src/linux-2.6/net/netfilter/xt_set.c: 16 linux/version.h not needed. and it seems that it is right. Beyond manually inspecting the source files I also did a few build tests with various configs to confirm that including the header in those files is indeed not needed. Here's a patch to remove the pointless includes. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-16netfilter: ipset: whitespace and coding fixes detected by checkpatch.plJozsef Kadlecsik
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-06-16netfilter: ipset: add xt_action_param to the variant level kadt functions, ↵Jozsef Kadlecsik
ipset API change With the change the sets can use any parameter available for the match and target extensions, like input/output interface. It's required for the hash:net,iface set type. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-06-16netfilter: ipset: options and flags support added to the kernel APIJozsef Kadlecsik
The support makes possible to specify the timeout value for the SET target and a flag to reset the timeout for already existing entries. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-04-13netfilter: ipset: set match and SET target fixesJozsef Kadlecsik
The SET target with --del-set did not work due to using wrongly the internal dimension of --add-set instead of --del-set. Also, the checkentries did not release the set references when returned an error. Bugs reported by Lennert Buytenhek. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-02-01netfilter: xtables: "set" match and "SET" target supportJozsef Kadlecsik
The patch adds the combined module of the "SET" target and "set" match to netfilter. Both the previous and the current revisions are supported. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
