Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Updates the MODULE_DESCRIPTION() tags for all Netfilter modules,
actually describing what the module does and not just
"netfilter XYZ target".
Give all Netfilter modules consistent and unique symbol names.
It doesn't seem to have any effect on the x86 architecture but it does
have effect on the Axis CRIS architecture.
Signed-off-by: Jesper Bengtsson <jesper.bengtsson@axis.com>
Removes redundant parentheses and braces (And add one pair in a
xt_tcpudp.c macro).
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Switch the return type of match functions to boolean
Switch the "hotdrop" variables to boolean
This is a revision of the previously submitted patch, which alters
the way files are organized and compiled in the following manner:
* UDP and UDP-Lite now use separate object files
* source file dependencies resolved via header files
net/ipv{4,6}/udp_impl.h
* order of inclusion files in udp.c/udplite.c adapted
accordingly
[NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828)
This patch adds support for UDP-Lite to the IPv4 stack, provided as an
extension to the existing UDPv4 code:
* generic routines are all located in net/ipv4/udp.c
* UDP-Lite specific routines are in net/ipv4/udplite.c
* MIB/statistics support in /proc/net/snmp and /proc/net/udplite
* shared API with extensions for partial checksum coverage
[NET/IPv6]: Extension for UDP-Lite over IPv6
It extends the existing UDPv6 code base with support for UDP-Lite
in the same manner as per UDPv4. In particular,
* UDPv6 generic and shared code is in net/ipv6/udp.c
* UDP-Litev6 specific extensions are in net/ipv6/udplite.c
* MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6
* support for IPV6_ADDRFORM
* aligned the coding style of protocol initialisation with af_inet6.c
* made the error handling in udpv6_queue_rcv_skb consistent;
to return `-1' on error on all error cases
* consolidation of shared code
[NET]: UDP-Lite Documentation and basic XFRM/Netfilter support
The UDP-Lite patch further provides
* API documentation for UDP-Lite
* basic xfrm support
* basic netfilter support for IPv4 and IPv6 (LOG target)
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
The size is verified by x_tables and isn't needed by the modules anymore.
"xt_unregister_match(AF_INET, &tcp_matchstruct)" is called twice,
leaving "udp_matchstruct" registered, in case of a failure in the
registration of the udp6 structure.
Signed-off-by: Yuri Gushin <yuri@ecl-labs.org>
Every netfilter module uses `init' for its module_init() function and
`fini' or `cleanup' for its module_exit() function.
Problem is, this creates uninformative initcall_debug output and makes
ctags rather useless.
So go through and rename them all to $(filename)_init and
$(filename)_fini.
Set the family field in xt_[matches|targets] registered.
This monster-patch tries to do the best job for unifying the data
structures and backend interfaces for the three evil clones ip_tables,
ip6_tables and arp_tables. In an ideal world we would never have
allowed this kind of copy+paste programming... but well, our world
isn't (yet?) ideal.
o introduce a new x_tables module
o {ip,arp,ip6}_tables depend on this x_tables module
o registration functions for tables, matches and targets are only
wrappers around x_tables provided functions
o all matches/targets that are used from ip_tables and ip6_tables
are now implemented as xt_FOOBAR.c files and provide module aliases
to ipt_FOOBAR and ip6t_FOOBAR
o header files for xt_matches are in include/linux/netfilter/,
include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers
around the xt_FOOBAR.h headers
Based on this patchset we're going to further unify the code,
gradually getting rid of all the layer 3 specific assumptions.
Signed-off-by: Harald Welte <laforge@netfilter.org>
