Upstream commit 656caff:
Commit 55b69e91 (netfilter: implement NFPROTO_UNSPEC as a wildcard
for extensions) broke revision probing for matches and targets that
are registered with NFPROTO_UNSPEC.
Fix by continuing the search on the NFPROTO_UNSPEC list if nothing
is found on the af-specific lists.
TIME_WAIT sockets need to be handled specially, and the socket match
casted inet_timewait_sock instances to inet_sock, which are not
compatible.
Handle this special case by checking sk->sk_state.
Signed-off-by: Balazs Scheidler <bazsi@balabit.hu>
The previous fix for the conntrack creation race (netfilter: ctnetlink:
fix conntrack creation race) missed a GFP_KERNEL allocation that is
now performed while holding a spinlock. Switch to GFP_ATOMIC.
Reported-and-tested-by: Zoltan Borbely <bozo@andrews.hu>
Conntrack creation through ctnetlink has two races:
- the timer may expire and free the conntrack concurrently, causing an
invalid memory access when attempting to put it in the hash tables
- an identical conntrack entry may be created in the packet processing
path in the time between the lookup and hash insertion
Hold the conntrack lock between the lookup and insertion to avoid this.
Reported-by: Zoltan Borbely <bozo@andrews.hu>
payload_len is a be16 value, not cpu_endian, also the size of a ponter
to a struct ipv6hdr was being added, not the size of the struct itself.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
netns list (just list) is under RTNL. But helper and proto unregistration
happen during rmmod when RTNL is not held, and that's how it was tested:
modprobe/rmmod vs clone(CLONE_NEWNET)/exit.
BUG: unable to handle kernel paging request at 0000000000100100 <===
IP: [<ffffffffa009890f>] nf_conntrack_l4proto_unregister+0x96/0xae [nf_conntrack]
PGD 15e300067 PUD 15e1d8067 PMD 0
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
last sysfs file: /sys/kernel/uevent_seqnum
CPU 0
Modules linked in: nf_conntrack_proto_sctp(-) nf_conntrack_proto_dccp(-) af_packet iptable_nat nf_nat nf_conntrack_ipv4 nf_conntrack nf_defrag_ipv4 iptable_filter ip_tables xt_tcpudp ip6table_filter ip6_tables x_tables ipv6 sr_mod cdrom [last unloaded: nf_conntrack_proto_sctp]
Pid: 16758, comm: rmmod Not tainted 2.6.28-rc2-netns-xfrm #3
RIP: 0010:[<ffffffffa009890f>] [<ffffffffa009890f>] nf_conntrack_l4proto_unregister+0x96/0xae [nf_conntrack]
RSP: 0018:ffff88015dc1fec8 EFLAGS: 00010212
RAX: 0000000000000000 RBX: 00000000001000f8 RCX: 0000000000000000
RDX: ffffffffa009575c RSI: 0000000000000003 RDI: ffffffffa00956b5
RBP: ffff88015dc1fed8 R08: 0000000000000002 R09: 0000000000000000
R10: 0000000000000000 R11: ffff88015dc1fe48 R12: ffffffffa0458f60
R13: 0000000000000880 R14: 00007fff4c361d30 R15: 0000000000000880
FS: 00007f624435a6f0(0000) GS:ffffffff80521580(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000100100 CR3: 0000000168969000 CR4: 00000000000006e0
Process rmmod (pid: 16758, threadinfo ffff88015dc1e000, task ffff880179864218)
Stack:
ffffffffa0459100 0000000000000000 ffff88015dc1fee8 ffffffffa0457934
ffff88015dc1ff78 ffffffff80253fef 746e6e6f635f666e 6f72705f6b636172
00707463735f6f74 ffffffff8024cb30 00000000023b8010 0000000000000000
Call Trace:
[<ffffffffa0457934>] nf_conntrack_proto_sctp_fini+0x10/0x1e [nf_conntrack_proto_sctp]
[<ffffffff80253fef>] sys_delete_module+0x19f/0x1fe
[<ffffffff8024cb30>] ? trace_hardirqs_on_caller+0xf0/0x114
[<ffffffff803ea9b2>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff8020b52b>] system_call_fastpath+0x16/0x1b
Code: 13 35 e0 e8 c4 6c 1a e0 48 8b 1d 6d c6 46 e0 eb 16 48 89 df 4c 89 e2 48 c7 c6 fc 85 09 a0 e8 61 cd ff ff 48 8b 5b 08 48 83 eb 08 <48> 8b 43 08 0f 18 08 48 8d 43 08 48 3d 60 4f 50 80 75 d3 5b 41
RIP [<ffffffffa009890f>] nf_conntrack_l4proto_unregister+0x96/0xae [nf_conntrack]
RSP <ffff88015dc1fec8>
---[ end trace bde8ac82debf7192 ]---
register_pernet_gen_device() can't be used is nf_conntrack_pptp module is
also used (compiled in or loaded).
Right now, proto_gre_net_exit() is called before nf_conntrack_pptp_net_exit().
The former shutdowns and frees GRE piece of netns, however the latter
absolutely needs it to flush keymap. Oops is inevitable.
Switch to shiny new register_pernet_gen_subsys() to get correct ordering in
netns ops list.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
netfilter: replace old NF_ARP calls with NFPROTO_ARP
netfilter: fix compilation error with NAT=n
netfilter: xt_recent: use proc_create_data()
netfilter: snmp nat leaks memory in case of failure
netfilter: xt_iprange: fix range inversion match
netfilter: netns: use NFPROTO_NUMPROTO instead of NUMPROTO for tables array
netfilter: ctnetlink: remove obsolete NAT dependency from Kconfig
pkt_sched: sch_generic: Fix oops in sch_teql
dccp: Port redirection support for DCCP
tcp: Fix IPv6 fallout from 'Port redirection support for TCP'
netdev: change name dropping error codes
ipvs: Update CONFIG_IP_VS_IPV6 description and help text
(Supplements: ee999d8b9573df1b547aacdc6d79f86eb79c25cd)
NFPROTO_ARP actually has a different value from NF_ARP, so ensure all
callers use the new value so that packets _do_ get delivered to the
registered hooks.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
This patch fixes the compilation of ctnetlink when the NAT support
is not enabled.
/home/benh/kernels/linux-powerpc/net/netfilter/nf_conntrack_netlink.c:819: warning: enum nf_nat_manip_type\u2019 declared inside parameter list
/home/benh/kernels/linux-powerpc/net/netfilter/nf_conntrack_netlink.c:819: warning: its scope is only this definition or declaration, which is probably not what you want
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Reported by: Ingo Molnar <mingo@elte.hu>
Fixes a crash in recent_seq_start:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000100
IP: [<ffffffffa002119c>] recent_seq_start+0x4c/0x90 [xt_recent]
PGD 17d33c067 PUD 107afe067 PMD 0
CPU 0
Modules linked in: ipt_LOG xt_recent af_packet iptable_nat nf_nat nf_conntrack_ipv4 nf_conntrack nf_defrag_ipv4 xt_tcpudp iptable_filter ip_tables x_tables ext2 nls_utf8 fuse sr_mod cdrom [last unloaded: ntfs]
Pid: 32373, comm: cat Not tainted 2.6.27-04ab591808565f968d4406f6435090ad671ebdab #6
RIP: 0010:[<ffffffffa002119c>] [<ffffffffa002119c>] recent_seq_start+0x4c/0x90 [xt_recent]
RSP: 0018:ffff88015fed7e28 EFLAGS: 00010246
Inverted IPv4 v1 and IPv6 v0 matches don't match anything since 2.6.25-rc1!
Acked-by: Jan Engelhardt <jengelh@medozas.de>
Now that ctnetlink doesn't have any NAT module depenencies anymore,
we can also remove them from Kconfig.
This adds a URL to further info to the CONFIG_IP_VS_IPV6 Kconfig help
text. Also, I think it should be ok to remove the "DANGEROUS" label in the
description line at this point to get people to try it out and find all
the bugs ;) It's still marked as experimental, of course.
Signed-off-by: Julius Volz <juliusv@google.com>
net: Remove CONFIG_KMOD from net/ (towards removing CONFIG_KMOD entirely)
ipv4: Add a missing rcu_assign_pointer() in routing cache.
[netdrvr] ibmtr: PCMCIA IBMTR is ok on 64bit
xen-netfront: Avoid unaligned accesses to IP header
lmc: copy_*_user under spinlock
[netdrvr] myri10ge, ixgbe: remove broken select INTEL_IOATDMA
Some code here depends on CONFIG_KMOD to not try to load
protocol modules or similar, replace by CONFIG_MODULES
where more than just request_module depends on CONFIG_KMOD
and and also use try_then_request_module in ebtables.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (46 commits)
UIO: Fix mapping of logical and virtual memory
UIO: add automata sercos3 pci card support
UIO: Change driver name of uio_pdrv
UIO: Add alignment warnings for uio-mem
Driver core: add bus_sort_breadthfirst() function
NET: convert the phy_device file to use bus_find_device_by_name
kobject: Cleanup kobject_rename and !CONFIG_SYSFS
kobject: Fix kobject_rename and !CONFIG_SYSFS
sysfs: Make dir and name args to sysfs_notify() const
platform: add new device registration helper
sysfs: use ilookup5() instead of ilookup5_nowait()
PNP: create device attributes via default device attributes
Driver core: make bus_find_device_by_name() more robust
usb: turn dev_warn+WARN_ON combos into dev_WARN
debug: use dev_WARN() rather than WARN_ON() in device_pm_add()
debug: Introduce a dev_WARN() function
sysfs: fix deadlock
device model: Do a quickcheck for driver binding before doing an expensive check
Driver core: Fix cleanup in device_create_vargs().
Driver core: Clarify device cleanup.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits)
decnet: Fix compiler warning in dn_dev.c
IPV6: Fix default gateway criteria wrt. HIGH/LOW preference radv option
net/802/fc.c: Fix compilation warnings
netns: correct mib stats in ip6_route_me_harder()
netns: fix net_generic array leak
rt2x00: fix regression introduced by "mac80211: free up 2 bytes in skb->cb"
rtl8187: Add USB ID for Belkin F5D7050 with RTL8187B chip
p54usb: Device ID updates
mac80211: fixme for kernel-doc
ath9k/mac80211: disallow fragmentation in ath9k, report to userspace
libertas : Remove unused variable warning for "old_channel" from cmd.c
mac80211: Fix scan RX processing oops
orinoco: fix unsafe locking in spectrum_cs_suspend
orinoco: fix unsafe locking in orinoco_cs_resume
cfg80211: fix debugfs error handling
mac80211: fix debugfs netdev rename
iwlwifi: fix ct kill configuration for 5350
mac80211: fix HT information element parsing
p54: Fix compilation problem on PPC
mac80211: fix debugfs lockup
Signed-off-by: Danny ter Haar <dth@cistron.nl>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Avi Kivity <avi@qumranet.com>
Base infrastructure to enable per-module debug messages.
I've introduced CONFIG_DYNAMIC_PRINTK_DEBUG, which when enabled centralizes
control of debugging statements on a per-module basis in one /proc file,
currently, <debugfs>/dynamic_printk/modules. When, CONFIG_DYNAMIC_PRINTK_DEBUG,
is not set, debugging statements can still be enabled as before, often by
defining 'DEBUG' for the proper compilation unit. Thus, this patch set has no
affect when CONFIG_DYNAMIC_PRINTK_DEBUG is not set.
The infrastructure currently ties into all pr_debug() and dev_dbg() calls. That
is, if CONFIG_DYNAMIC_PRINTK_DEBUG is set, all pr_debug() and dev_dbg() calls
can be dynamically enabled/disabled on a per-module basis.
Future plans include extending this functionality to subsystems, that define
their own debug levels and flags.
Usage:
Dynamic debugging is controlled by the debugfs file,
<debugfs>/dynamic_printk/modules. This file contains a list of the modules that
can be enabled. The format of the file is as follows:
<module_name> <enabled=0/1>
<module_name> : Name of the module in which the debug call resides
<enabled=0/1> : whether the messages are enabled or not
For example:
snd_hda_intel enabled=0
fixup enabled=1
driver enabled=0
Enable a module:
$echo "set enabled=1 <module_name>" > dynamic_printk/modules
Disable a module:
$echo "set enabled=0 <module_name>" > dynamic_printk/modules
Enable all modules:
$echo "set enabled=1 all" > dynamic_printk/modules
Disable all modules:
$echo "set enabled=0 all" > dynamic_printk/modules
Finally, passing "dynamic_printk" at the command line enables
debugging for all modules. This mode can be turned off via the above
disable command.
[gkh: minor cleanups and tweaks to make the build work quietly]
Signed-off-by: Jason Baron <jbaron@redhat.com>
nf_nat
This patch removes the module dependency between ctnetlink and
nf_nat by means of an indirect call that is initialized when
nf_nat is loaded. Now, nf_conntrack_netlink only requires
nf_conntrack and nfnetlink.
This patch puts nfnetlink_parse_nat_setup_hook into the
nf_conntrack_core to avoid dependencies between ctnetlink,
nf_conntrack_ipv4 and nf_conntrack_ipv6.
This patch also introduces the function ctnetlink_change_nat
that is only invoked from the creation path. Actually, the
nat handling cannot be invoked from the update path since
this is not allowed. By introducing this function, we remove
the useless nat handling in the update path and we avoid
deadlock-prone code.
This patch also adds the required EAGAIN logic for nfnetlink.
The file(s) below do not use LINUX_VERSION_CODE nor KERNEL_VERSION.
net/netfilter/nf_tproxy_core.c
This patch removes the said #include <version.h>.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Linus noted a build failure case:
net/netfilter/ipvs/ip_vs_xmit.c: In function 'ip_vs_tunnel_xmit':
net/netfilter/ipvs/ip_vs_xmit.c:616: error: implicit declaration of function 'ip_select_ident'
The proper include file (net/ip.h) is being included in ip_vs_xmit.c to get
that declaration. So the only possible case where this can happen is if
CONFIG_INET is not enabled.
This seems to be purely a missing dependency in the ipvs/Kconfig file IP_VS
entry.
Also, while we're here, remove the out of date "EXPERIMENTAL" string in the
IP_VS config help header line. IP_VS no longer depends upon CONFIG_EXPERIMENTAL
git://git.kernel.org/pub/scm/linux/kernel/git/horms/lvs-2.6
net/netfilter/Kconfig
Lots of extensions are completely family-independent, so squash some code.
Using ->family in struct xt_*_param, multiple struct xt_{match,target}
can be squashed together.
By passing in the family through which extensions were invoked, a bit
of data space can be reclaimed. The "family" member will be added to
the parameter structures and the check functions be adjusted.
This patch does this for target extensions' destroy functions.
This patch does this for target extensions' checkentry functions.
This patch does this for target extensions' target functions.
This patch does this for match extensions' destroy functions.
This patch does this for match extensions' checkentry functions.
The function signatures for Xtables extensions have grown over time.
It involves a lot of typing/replication, and also a bit of stack space
even if they are not used. Realize an NFWS2008 idea and pack them into
structs. The skb remains outside of the struct so gcc can continue to
apply its optimizations.
This patch does this for match extensions' match functions.
A few ambiguities have also been addressed. The "offset" parameter for
example has been renamed to "fragoff" (there are so many different
offsets already) and "protoff" to "thoff" (there is more than just one
protocol here, so clarify).
It used to be that {ip,ip6,etc}_tables called extension->checkentry
themselves, but this can be moved into the xtables core.
It is a mask, and masks are most useful in hex.
The TPROXY target implements redirection of non-local TCP/UDP traffic to local
sockets. Additionally, it's possible to manipulate the packet mark if and only
if a socket has been found. (We need this because we cannot use multiple
targets in the same iptables rule.)
Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu>
Add iptables 'socket' match, which matches packets for which a TCP/UDP
socket lookup succeeds.
The iptables tproxy core is a module that contains the common routines used by
various tproxy related modules (TPROXY target and socket match)
From kernel perspective, allow entrance in nf_hook_slow().
Stuff which uses nf_register_hook/nf_register_hooks, but otherwise not netns-ready:
DECnet netfilter
ipt_CLUSTERIP
nf_nat_standalone.c together with XFRM (?)
IPVS
several individual match modules (like hashlimit)
ctnetlink
NOTRACK
all sorts of queueing and reporting to userspace
L3 and L4 protocol sysctls, bridge sysctls
probably something else
Anyway critical mass has been achieved, there is no reason to hide netfilter any longer.
From userspace perspective, allow to manipulate all sorts of
iptables/ip6tables/arptables rules.
* make keymap list per-netns
* per-netns keymal lock (not strictly necessary)
* flush keymap at netns stop and module unload.
Add init_net checks to not remove kmem_caches twice and so on.
Refactor functions to split code which should be executed only for
init_net into one place.
ip_ct_attach and ip_ct_destroy assignments remain separate, because
they're separate stages in setup and teardown.
NOTE: NOTRACK code is in for-every-net part. It will be made per-netns
after we decidce how to do it correctly.
net.netfilter.nf_conntrack_log_invalid sysctl
