ip_vs_mutext is used by both netns shutdown code and startup
and both implicit uses sk_lock-AF_INET mutex.
cleanup CPU-1 startup CPU-2
ip_vs_dst_event() ip_vs_genl_set_cmd()
sk_lock-AF_INET __ip_vs_mutex
sk_lock-AF_INET
__ip_vs_mutex
* DEAD LOCK *
A new mutex placed in ip_vs netns struct called sync_mutex is added.
Comments from Julian and Simon added.
This patch has been running for more than 3 month now and it seems to work.
Ver. 3
IP_VS_SO_GET_DAEMON in do_ip_vs_get_ctl protected by sync_mutex
instead of __ip_vs_mutex as sugested by Julian.
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
Replace the open coded initialization with the init function.
Acked-by: Hans Schillstrom <hans.schillstrom@ericsson.com>
GRE connections cause ctnetlink event flood because the ASSURED event
is set for every packet received.
Reported-by: Denys Fedoryshchenko <denys@visp.net.lb>
Tested-by: Denys Fedoryshchenko <denys@visp.net.lb>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
tcp_sack skips fastpath
The wrong multiplication of TCPOLEN_TSTAMP_ALIGNED by 4 skips the fast path
for the timestamp-only option. Bug reported by Michael M. Builov (netfilter
bugzilla #738).
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Michael M. Builov reported that in the tcp_options and tcp_sack functions
of netfilter TCP conntrack the incorrect handling of invalid TCP option
with too big opsize may lead to read access beyond tcp-packet or buffer
allocated on stack (netfilter bugzilla #738). The fix is to stop parsing
the options at detecting the broken option.
When both the server and the client are NATed, the set-link-info control
packet containing the peer's call-id field is not properly translated.
I have verified that it was working in 2.6.16.13 kernel previously but
due to rewrite, this scenario stopped working (Not knowing exact version
when it stopped working).
Signed-off-by: Sanket Shah <sanket.shah@elitecore.com>
A userspace listener may send (bogus) NF_STOLEN verdict, which causes skb leak.
This problem was previously fixed via
64507fdbc29c3a622180378210ecea8659b14e40 (netfilter:
nf_queue: fix NF_STOLEN skb leak) but this had to be reverted because
NF_STOLEN can also be returned by a netfilter hook when iterating the
rules in nf_reinject.
Reject userspace NF_STOLEN verdict, as suggested by Michal Miroslaw.
This is complementary to commit fad54440438a7c231a6ae347738423cbabc936d9
(netfilter: avoid double free in nf_reinject).
Cc: Julian Anastasov <ja@ssi.bg>
NF_STOLEN means skb was already freed
Signed-off-by: Julian Anastasov <ja@ssi.bg>
commit 4a5a5c73b7cfee (slightly better error reporting) added some
useless code in xt_rateest_mt_checkentry().
Fix this so that different error codes can really be returned.
CC: Jan Engelhardt <jengelh@medozas.de>
git://git.kernel.org/pub/scm/linux/kernel/git/horms/ipvs-2.6
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: Fix wrong check in list_splice_init_rcu()
net,rcu: Convert call_rcu(xt_rateest_free_rcu) to kfree_rcu()
sysctl,rcu: Convert call_rcu(free_head) to kfree
vmalloc,rcu: Convert call_rcu(rcu_free_vb) to kfree_rcu()
vmalloc,rcu: Convert call_rcu(rcu_free_va) to kfree_rcu()
ipc,rcu: Convert call_rcu(ipc_immediate_free) to kfree_rcu()
ipc,rcu: Convert call_rcu(free_un) to kfree_rcu()
security,rcu: Convert call_rcu(sel_netport_free) to kfree_rcu()
security,rcu: Convert call_rcu(sel_netnode_free) to kfree_rcu()
ia64,rcu: Convert call_rcu(sn_irq_info_free) to kfree_rcu()
block,rcu: Convert call_rcu(disk_free_ptbl_rcu_cb) to kfree_rcu()
scsi,rcu: Convert call_rcu(fc_rport_free_rcu) to kfree_rcu()
audit_tree,rcu: Convert call_rcu(__put_tree) to kfree_rcu()
security,rcu: Convert call_rcu(whitelist_item_free) to kfree_rcu()
md,rcu: Convert call_rcu(free_conf) to kfree_rcu()
This resolves a panic on module removal.
Reported-by: Dave Jones <davej@redhat.com>
Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
different interfaces
If overlapping networks with different interfaces was added to
the set, the type did not handle it properly. Example
ipset create test hash:net,iface
ipset add test 192.168.0.0/16,eth0
ipset add test 192.168.0.0/24,eth1
Now, if a packet was sent from 192.168.0.0/24,eth0, the type returned
a match.
In the patch the algorithm is fixed in order to correctly handle
overlapping networks.
Limitation: the same network cannot be stored with more than 64 different
interfaces in a single set.
The RCU callback xt_rateest_free_rcu() just calls kfree(), so we can
use kfree_rcu() instead of call_rcu(). This also allows us to dispense
with an rcu_barrier() call, speeding up unloading of this module.
Cc: Patrick McHardy <kaber@trash.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Introduces a new nfnetlink type that applies a given
verdict to all queued packets with an id <= the id in the verdict
message.
If a mark is provided it is applied to all matched packets.
This reduces the number of verdicts that have to be sent.
Applications that make use of this feature need to maintain
a timeout to send a batchverdict periodically to avoid starvation.
Packet identifier is currently setup in nfqnl_build_packet_message(),
using one atomic_inc_return().
Problem is that since several cpus might concurrently call
nfqnl_enqueue_packet() for the same queue, we can deliver packets to
consumer in non monotonic way (packet N+1 being delivered after packet
N)
This patch moves the packet id setup from nfqnl_build_packet_message()
to nfqnl_enqueue_packet() to guarantee correct delivery order.
This also removes one atomic operation.
CC: Florian Westphal <fw@strlen.de>
CC: Pablo Neira Ayuso <pablo@netfilter.org>
CC: Eric Leblond <eric@regit.org>
nenetlink_queue operations on SMP are not efficent if several queues are
used, because of nfnl_mutex contention when applications give packet
verdict.
Use new call_rcu field in struct nfnl_callback to advertize a callback
that is called under rcu_read_lock instead of nfnl_mutex.
On my 2x4x2 machine, I was able to reach 2.000.000 pps going through
user land returning NF_ACCEPT verdicts without losses, instead of less
than 500.000 pps before patch.
Goal of this patch is to permit nfnetlink providers not mandate
nfnl_mutex being held while nfnetlink_rcv_msg() calls them.
If struct nfnl_callback contains a non NULL call_rcu(), then
nfnetlink_rcv_msg() will use it instead of call() field, holding
Make the case labels the same indent as the switch.
git diff -w shows miscellaneous 80 column wrapping,
comment reflowing and a comment for a useless gcc
warning for an otherwise unused default: case.
In this revision the conversion of secid to SELinux context and adding it
to the audit log is moved from xt_AUDIT.c to audit.c with the aid of a
separate helper function - audit_log_secctx - which does both the conversion
and logging of SELinux context, thus also preventing internal secid number
being leaked to userspace. If conversion is not successful an error is raised.
With the introduction of this helper function the work done in xt_AUDIT.c is
much more simplified. It also opens the possibility of this helper function
being used by other modules (including auditd itself), if desired. With this
addition, typical (raw auditd) output after applying the patch would be:
type=NETFILTER_PKT msg=audit(1305852240.082:31012): action=0 hook=1 len=52 inif=? outif=eth0 saddr=10.1.1.7 daddr=10.1.2.1 ipid=16312 proto=6 sport=56150 dport=22 obj=system_u:object_r:ssh_client_packet_t:s0
type=NETFILTER_PKT msg=audit(1306772064.079:56): action=0 hook=3 len=48 inif=eth0 outif=? smac=00:05:5d:7c:27:0b dmac=00:02:b3:0a:7f:81 macproto=0x0800 saddr=10.1.2.1 daddr=10.1.1.7 ipid=462 proto=6 sport=22 dport=3561 obj=system_u:object_r:ssh_server_packet_t:s0
Acked-by: Eric Paris <eparis@redhat.com>
Signed-off-by: Mr Dash Four <mr.dash.four@googlemail.com>
There are enough instances of this:
iph->frag_off & htons(IP_MF | IP_OFFSET)
that a helper function is probably warranted.
It was suggested by "make versioncheck" that the follwing includes of
linux/version.h are redundant:
/home/jj/src/linux-2.6/net/caif/caif_dev.c: 14 linux/version.h not needed.
/home/jj/src/linux-2.6/net/caif/chnl_net.c: 10 linux/version.h not needed.
/home/jj/src/linux-2.6/net/ipv4/gre.c: 19 linux/version.h not needed.
/home/jj/src/linux-2.6/net/netfilter/ipset/ip_set_core.c: 20 linux/version.h not needed.
/home/jj/src/linux-2.6/net/netfilter/xt_set.c: 16 linux/version.h not needed.
and it seems that it is right.
Beyond manually inspecting the source files I also did a few build
tests with various configs to confirm that including the header in
those files is indeed not needed.
Here's a patch to remove the pointless includes.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
net/netfilter/ipvs/ip_vs_core.c
The hash:net,iface type makes possible to store network address and
interface name pairs in a set. It's mostly suitable for egress
and ingress filtering. Examples:
# ipset create test hash:net,iface
# ipset add test 192.168.0.0/16,eth0
# ipset add test 192.168.0.0/24,eth1
ipset API change
With the change the sets can use any parameter available for the match
and target extensions, like input/output interface. It's required for
the hash:net,iface set type.
creating the set
When creating a set from a range expressed as a network like
10.1.1.172/29, the from address was taken as the IP address part and
not masked with the netmask from the cidr.
hash:*net* types
The range internally is converted to the network(s) equal to the range.
Example:
# ipset new test hash:net
# ipset add test 10.2.0.0-10.2.1.12
# ipset list test
Type: hash:net
Header: family inet hashsize 1024 maxelem 65536
Size in memory: 16888
References: 0
Members:
10.2.1.12
10.2.1.0/29
10.2.0.0/24
10.2.1.8/30
A set type may have multiple revisions, for example when syntax is
extended. Support continuous revision ranges in set types.
When ranges are added to hash types, the elements may trigger rehashing
the set. However, the last successfully added element was not kept track
so the adding started again with the first element after the rehashing.
Bug reported by Mr Dash Four.
Current listing makes possible to list sets with full content only.
The patch adds support partial listings, i.e. listing just
the existing setnames or listing set headers, without set members.
The support makes possible to specify the timeout value for
the SET target and a flag to reset the timeout for already existing
entries.
When an element to a set with timeout added, one can change the timeout
by "readding" the element with the "-exist" flag. That means the timeout
value is reset to the specified one (or to the default from the set
specification if the "timeout n" option is not used). Example
ipset add foo 1.2.3.4 timeout 10
ipset add foo 1.2.3.4 timeout 600 -exist
By default, when broadcast or multicast packet are sent from a local
application, they are sent to the interface then looped by the kernel
to other local applications, going throught netfilter hooks in the
process.
These looped packet have their MAC header removed from the skb by the
kernel looping code. This confuse various netfilter's netlink queue,
netlink log and the legacy ip_queue, because they try to extract a
hardware address from these packets, but extracts a part of the IP
header instead.
This patch prevent NFQUEUE, NFLOG and ip_QUEUE to include a MAC header
if there is none in the packet.
Signed-off-by: Nicolas Cavallari <cavallar@lri.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/horms/ipvs-next-2.6
After restructuring, there is some unused or empty functions
left to be removed.
Put goto labels at the beginig of row
acording to coding style example.
Quote from Patric Mc Hardy
"This looks like nfnetlink.c excited and destroyed the nfnl socket, but
ip_vs was still holding a reference to a conntrack. When the conntrack
got destroyed it created a ctnetlink event, causing an oops in
netlink_has_listeners when trying to use the destroyed nfnetlink
socket."
If nf_conntrack_netlink is loaded before ip_vs this is not a problem.
This patch simply avoids calling ip_vs_conn_drop_conntrack()
when netns is dying as suggested by Julian.
Make it more clear what the functions does,
on request by Julian.
Change the parsing of FTP commands and responses to
support skip character. It allows to detect variations in
the 227 PASV response.
The message size allocated for rtnl ifinfo dumps was limited to
a single page. This is not enough for additional interface info
available with devices that support SR-IOV and caused a bug in
which VF info would not be displayed if more than approximately
40 VFs were created per interface.
Implement a new function pointer for the rtnl_register service that will
calculate the amount of data required for the ifinfo dump and allocate
enough data to satisfy the request.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
