path: root/net/netlabel/netlabel_user.h
2006-12-02[GENL]: Add genlmsg_put_reply() to simplify building reply headersThomas Graf
By modyfing genlmsg_put() to take a genl_family and by adding genlmsg_put_reply() the process of constructing the netlink and generic netlink headers is simplified. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-29[NetLabel]: audit fixups due to delayed feedbackPaul Moore
Fix some issues Steve Grubb had with the way NetLabel was using the audit subsystem. This should make NetLabel more consistent with other kernel generated audit messages specifying configuration changes. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[NetLabel]: add audit support for configuration changesPaul Moore
This patch adds audit support to NetLabel, including six new audit message types shown below. #define AUDIT_MAC_UNLBL_ACCEPT 1406 #define AUDIT_MAC_UNLBL_DENY 1407 #define AUDIT_MAC_CIPSOV4_ADD 1408 #define AUDIT_MAC_CIPSOV4_DEL 1409 #define AUDIT_MAC_MAP_ADD 1410 #define AUDIT_MAC_MAP_DEL 1411 Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[NetLabel]: rework the Netlink attribute handling (part 1)Paul Moore
At the suggestion of Thomas Graf, rewrite NetLabel's use of Netlink attributes to better follow the common Netlink attribute usage. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NetLabel]: add some missing #includes to various header filesPaul Moore
Add some missing include files to the NetLabel related header files. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NetLabel]: core NetLabel subsystemPaul Moore
Add a new kernel subsystem, NetLabel, to provide explicit packet labeling services (CIPSO, RIPSO, etc.) to LSM developers. NetLabel is designed to work in conjunction with a LSM to intercept and decode security labels on incoming network packets as well as ensure that outgoing network packets are labeled according to the security mechanism employed by the LSM. The NetLabel subsystem is configured through a Generic NETLINK interface described in the header files included in this patch. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
