Consitfy nlmsghdr arguments to a couple of functions as preparation
for the next patch, which will constify the netlink message data in
all nfnetlink users.
Wireless extensions have the unfortunate problem that events
are multicast netlink messages, and are not independent of
pointer size. Thus, currently 32-bit tasks on 64-bit platforms
cannot properly receive events and fail with all kinds of
strange problems, for instance wpa_supplicant never notices
disassociations, due to the way the 64-bit event looks (to a
32-bit process), the fact that the address is all zeroes is
lost, it thinks instead it is 00:00:00:00:01:00.
The same problem existed with the ioctls, until David Miller
fixed those some time ago in an heroic effort.
A different problem caused by this is that we cannot send the
ASSOCREQIE/ASSOCRESPIE events because sending them causes a
32-bit wpa_supplicant on a 64-bit system to overwrite its
internal information, which is worse than it not getting the
information at all -- so we currently resort to sending a
custom string event that it then parses. This, however, has a
severe size limitation we are frequently hitting with modern
access points; this limitation would can be lifted after this
patch by sending the correct binary, not custom, event.
A similar problem apparently happens for some other netlink
users on x86_64 with 32-bit tasks due to the alignment for
64-bit quantities.
In order to fix these problems, I have implemented a way to
send compat messages to tasks. When sending an event, we send
the non-compat event data together with a compat event data in
skb_shinfo(main_skb)->frag_list. Then, when the event is read
from the socket, the netlink code makes sure to pass out only
the skb that is compatible with the task. This approach was
suggested by David Miller, my original approach required
always sending two skbs but that had various small problems.
To determine whether compat is needed or not, I have used the
MSG_CMSG_COMPAT flag, and adjusted the call path for recv and
recvfrom to include it, even if those calls do not have a cmsg
parameter.
I have not solved one small part of the problem, and I don't
think it is necessary to: if a 32-bit application uses read()
rather than any form of recvmsg() it will still get the wrong
(64-bit) event. However, neither do applications actually do
this, nor would it be a regression.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
This makes generic netlink network namespace aware. No
generic netlink families except for the controller family
are made namespace aware, they need to be checked one by
one and then set the family->netnsok member to true.
A new function genlmsg_multicast_netns() is introduced to
allow sending a multicast message in a given namespace,
for example when it applies to an object that lives in
that namespace, a new function genlmsg_multicast_allns()
to send a message to all network namespaces (for objects
that do not have an associated netns).
The function genlmsg_multicast() is changed to multicast
the message in just init_net, which is currently correct
for all generic netlink families since they only work in
init_net right now. Some will later want to work in all
net namespaces because they do not care about the netns
at all -- those will have to be converted to use one of
the new functions genlmsg_multicast_allns() or
genlmsg_multicast_netns() whenever they are made netns
aware in some way.
After this patch families can easily decide whether or
not they should be available in all net namespaces. Many
genl families us it for objects not related to networking
and should therefore be available in all namespaces, but
that will have to be done on a per family basis.
Note that this doesn't touch on the checkpoint/restart
problem where network namespaces could be used, genl
families and multicast groups are numbered globally and
I see no easy way of changing that, especially since it
must be possible to multicast to all network namespaces
for those families that do not care about netns.
For the network namespace work in generic netlink I need
to be able to call this function under rcu_read_lock(),
otherwise the locking becomes a nightmare and more locks
would be needed. Instead, just embed a struct rcu_head
(actually a struct listeners_rcu_head that also carries
the pointer to the memory block) into the listeners
memory so we can use call_rcu() instead of synchronising
and then freeing. No rcu_barrier() is needed since this
code cannot be modular.
I added those myself in commits b4ff4f04 and 84659eb5,
but I see no reason now why they should be exported,
only generic netlink uses them which cannot be modular.
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
(net: No more expensive sock_hold()/sock_put() on each tx)
changed initial sk_wmem_alloc value.
We need to take into account this offset when reporting
sk_wmem_alloc to user, in PROC_FS files or various
ioctls (SIOCOUTQ/TIOCOUTQ)
This introduces genl_register_family_with_ops() that registers a genetlink
family along with operations from a table. This is used to kill copy'n'paste
occurrences in following patches.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
drivers/net/wimax/i2400m/usb-notif.c
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (29 commits)
crypto: sha512-s390 - Add missing block size
hwrng: timeriomem - Breaks an allyesconfig build on s390:
nlattr: Fix build error with NET off
crypto: testmgr - add zlib test
crypto: zlib - New zlib crypto module, using pcomp
crypto: testmgr - Add support for the pcomp interface
crypto: compress - Add pcomp interface
netlink: Move netlink attribute parsing support to lib
crypto: Fix dead links
hwrng: timeriomem - New driver
crypto: chainiv - Use kcrypto_wq instead of keventd_wq
crypto: cryptd - Per-CPU thread implementation based on kcrypto_wq
crypto: api - Use dedicated workqueue for crypto subsystem
crypto: testmgr - Test skciphers with no IVs
crypto: aead - Avoid infinite loop when nivaead fails selftest
crypto: skcipher - Avoid infinite loop when cipher fails selftest
crypto: api - Fix crypto_alloc_tfm/create_create_tfm return convention
crypto: api - crypto_alg_mod_lookup either tested or untested
crypto: amcc - Add crypt4xx driver
crypto: ansi_cprng - Add maintainer
This patch adds the NETLINK_NO_ENOBUFS socket flag. This flag can
be used by unicast and broadcast listeners to avoid receiving
ENOBUFS errors.
Generally speaking, ENOBUFS errors are useful to notify two things
to the listener:
a) You may increase the receiver buffer size via setsockopt().
b) You have lost messages, you may be out of sync.
In some cases, ignoring ENOBUFS errors can be useful. For example:
a) nfnetlink_queue: this subsystem does not have any sort of resync
method and you can decide to ignore ENOBUFS once you have set a
given buffer size.
b) ctnetlink: you can use this together with the socket flag
NETLINK_BROADCAST_SEND_ERROR to stop getting ENOBUFS errors as
you do not need to resync (packets whose event are not delivered
are drop to provide reliable logging and state-synchronization).
Moreover, the use of NETLINK_NO_ENOBUFS also reduces a "go up, go down"
effect in terms of performance which is due to the netlink congestion
control when the listener cannot back off. The effect is the following:
1) throughput rate goes up and netlink messages are inserted in the
receiver buffer.
2) Then, netlink buffer fills and overruns (set on nlk->state bit 0).
3) While the listener empties the receiver buffer, netlink keeps
dropping messages. Thus, throughput goes dramatically down.
4) Then, once the listener has emptied the buffer (nlk->state
bit 0 is set off), goto step 1.
This effect is easy to trigger with netlink broadcast under heavy
load, and it is more noticeable when using a big receiver buffer.
You can find some results in [1] that show this problem.
[1] http://1984.lsi.us.es/linux/netlink/
This patch also includes the use of sk_drop to account the number of
netlink messages drop due to overrun. This value is shown in
/proc/net/netlink.
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
This patch adds nfnetlink_set_err() to propagate the error to netlink
broadcast listener in case of memory allocation errors in the
message building.
drivers/net/tokenring/tmspci.c
drivers/net/ucc_geth_mii.c
The callers of netlink_set_err() currently pass a negative value
as parameter for the error code. However, sk->sk_err wants a
positive error value. Without this patch, skb_recv_datagram() called
by netlink_recvmsg() may return a positive value to report an error.
Another choice to fix this is to change callers to pass a positive
error value, but this seems a bit inconsistent and error prone
to me. Indeed, the callers of netlink_set_err() assumed that the
(usual) negative value for error codes was fine before this patch :).
This patch also includes some documentation in docbook format
for netlink_set_err() to avoid this sort of confusion.
Netlink attribute parsing may be used even if CONFIG_NET is not set.
Move it from net/netlink to lib and control its inclusion based on the new
config symbol CONFIG_NLATTR, which is selected by CONFIG_NET.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Remove some pointless conditionals before kfree_skb().
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
This patch changes the return value of nlmsg_notify() as follows:
If NETLINK_BROADCAST_ERROR is set by any of the listeners and
an error in the delivery happened, return the broadcast error;
else if there are no listeners apart from the socket that
requested a change with the echo flag, return the result of the
unicast notification. Thus, with this patch, the unicast
notification is handled in the same way of a broadcast listener
that has set the NETLINK_BROADCAST_ERROR socket flag.
This patch is useful in case that the caller of nlmsg_notify()
wants to know the result of the delivery of a netlink notification
(including the broadcast delivery) and take any action in case
that the delivery failed. For example, ctnetlink can drop packets
if the event delivery failed to provide reliable logging and
state-synchronization at the cost of dropping packets.
This patch also modifies the rtnetlink code to ignore the return
value of rtnl_notify() in all callers. The function rtnl_notify()
(before this patch) returned the error of the unicast notification
which makes rtnl_set_sk_err() reports errors to all listeners. This
is not of any help since the origin of the change (the socket that
requested the echoing) notices the ENOBUFS error if the notification
fails and should resync itself.
Acked-by: Patrick McHardy <kaber@trash.net>
This patch adds NETLINK_BROADCAST_ERROR which is a netlink
socket option that the listener can set to make netlink_broadcast()
return errors in the delivery to the caller. This option is useful
if the caller of netlink_broadcast() do something with the result
of the message delivery, like in ctnetlink where it drops a network
packet if the event delivery failed, this is used to enable reliable
logging and state-synchronization. If this socket option is not set,
netlink_broadcast() only reports ESRCH errors and silently ignore
ENOBUFS errors, which is what most netlink_broadcast() callers
should do.
This socket option is based on a suggestion from Patrick McHardy.
Patrick McHardy can exchange this patch for a beer from me ;).
Currently, netlink_broadcast() reports errors to the caller if no
messages at all were delivered:
1) If, at least, one message has been delivered correctly, returns 0.
2) Otherwise, if no messages at all were delivered due to skb_clone()
failure, return -ENOBUFS.
3) Otherwise, if there are no listeners, return -ESRCH.
With this patch, the caller knows if the delivery of any of the
messages to the listeners have failed:
1) If it fails to deliver any message (for whatever reason), return
-ENOBUFS.
2) Otherwise, if all messages were delivered OK, returns 0.
3) Otherwise, if no listeners, return -ESRCH.
In the current ctnetlink code and in Netfilter in general, we can add
reliable logging and connection tracking event delivery by dropping the
packets whose events were not successfully delivered over Netlink. Of
course, this option would be settable via /proc as this approach reduces
performance (in terms of filtered connections per seconds by a stateful
firewall) but providing reliable logging and event delivery (for
conntrackd) in return.
This patch also changes some clients of netlink_broadcast() that
may report ENOBUFS errors via printk. This error handling is not
of any help. Instead, the userspace daemons that are listening to
those netlink messages should resync themselves with the kernel-side
if they hit ENOBUFS.
BTW, netlink_broadcast() clients include those that call
cn_netlink_send(), nlmsg_multicast() and genlmsg_multicast() since they
internally call netlink_broadcast() and return its error value.
Add an EXPORT_SYMBOL() to genl_unregister_mc_group(), to allow
unregistering groups on the run. EXPORT_SYMBOL_GPL() is not used as
the rest of the functions exported by this module (eg:
genl_register_mc_group) are also not _GPL().
Cleanup is currently done when unregistering a family, but there is
no way to unregister a single multicast group due to that function not
being exported. Seems to be a mistake as it is documented as for
external consumption.
This is needed by the WiMAX stack to be able to cleanup unused mc
groups.
Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
validate_nla() currently doesn't allow empty nested attributes. This
makes userspace code unnecessarily complicated when starting and ending
the nested attribute is done by generic upper level code and the inner
attributes are dumped by a module.
Add a special case to accept empty nested attributes. When the nested
attribute is non empty, the same checks as before are performed.
There is still a call to sock_prot_inuse_add() in af_netlink
while in a preemptable section. Add explicit BH disable around
this call.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
The rule of calling sock_prot_inuse_add() is that BHs must
be disabled. Some new calls were added where this was not
true and this tiggers warnings as reported by Ilpo.
Fix this by adding explicit BH disabling around those call sites.
In order to have relevant information for NETLINK protocol, in
/proc/net/protocols, we should use sock_prot_inuse_add() to
update a (percpu and pernamespace) counter of inuse sockets.
Some code here depends on CONFIG_KMOD to not try to load
protocol modules or similar, replace by CONFIG_MODULES
where more than just request_module depends on CONFIG_KMOD
and and also use try_then_request_module in ebtables.
Clean up the various different email addresses of mine listed in the code
to a single current and valid address. As Dave says his network merges
for 2.6.28 are now done this seems a good point to send them in where
they won't risk disrupting real changes.
Signed-off-by: Alan Cox <alan@redhat.com>
Removes legacy reinvent-the-wheel type thing. The generic
machinery integrates much better to automated debugging aids
such as kerneloops.org (and others), and is unambiguous due to
better naming. Non-intuively BUG_TRAP() is actually equal to
WARN_ON() rather than BUG_ON() though some might actually be
promoted to BUG_ON() but I left that to future.
I could make at least one BUILD_BUG_ON conversion.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Documentation/feature-removal-schedule.txt
drivers/net/wan/hdlc_fr.c
drivers/net/wireless/iwlwifi/iwl-4965.c
drivers/net/wireless/iwlwifi/iwl3945-base.c
We already have a variable, which has the same capability.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
drivers/net/wireless/iwlwifi/iwl4965-base.c
Fix some doc comments to match function and attribute names in
net/netlink/attr.c.
Signed-off-by: Julius Volz <juliusv@google.com>
net/mac80211/tx.c
genetlink has a circular locking dependency when dumping the registered
families:
- dump start:
genl_rcv() : take genl_mutex
genl_rcv_msg() : call netlink_dump_start() while holding genl_mutex
netlink_dump_start(),
netlink_dump() : take nlk->cb_mutex
ctrl_dumpfamily() : try to detect this case and not take genl_mutex a
second time
- dump continuance:
netlink_rcv() : call netlink_dump
netlink_dump : take nlk->cb_mutex
ctrl_dumpfamily() : take genl_mutex
Register genl_lock as callback mutex with netlink to fix this. This slightly
widens an already existing module unload race, the genl ops used during the
dump might go away when the module is unloaded. Thomas Graf is working on a
seperate fix for this.
drivers/net/tg3.c
drivers/net/wireless/rt2x00/rt2x00dev.c
net/mac80211/ieee80211_i.h
Signed-off-by: Denis V. Lunev <den@openvz.org>
Make nlmsg_trim(), nlmsg_cancel(), genlmsg_cancel(), and
nla_nest_cancel() void functions.
Return -EMSGSIZE instead of -1 if the provided message buffer is not
big enough.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Previously I added sessionid output to all audit messages where it was
available but we still didn't know the sessionid of the sender of
netlink messages. This patch adds that information to netlink messages
so we can audit who sent netlink messages.
Signed-off-by: Eric Paris <eparis@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
security: fix up documentation for security_module_enable
Security: Introduce security= boot parameter
Audit: Final renamings and cleanup
SELinux: use new audit hooks, remove redundant exports
Audit: internally use the new LSM audit hooks
LSM/Audit: Introduce generic Audit LSM hooks
SELinux: remove redundant exports
Netlink: Use generic LSM hook
Audit: use new LSM hooks instead of SELinux exports
SELinux: setup new inode/ipc getsecid hooks
LSM: Introduce inode_getsecid and ipc_getsecid hooks
Don't use SELinux exported selinux_get_task_sid symbol.
Use the generic LSM equivalent instead.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com>
Acked-by: James Morris <jmorris@namei.org>
Reviewed-by: Paul Moore <paul.moore@hp.com>
Introduce an inline net_eq() to compare two namespaces.
Without CONFIG_NET_NS, since no namespace other than &init_net
exists, it is always 1.
We do not need to convert 1) inline vs inline and
2) inline vs &init_net comparisons.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Without CONFIG_NET_NS, no namespace other than &init_net exists,
no need to store net in seq_net_private.
Introduce per-sock inlines: sock_net(), sock_net_set()
and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Make socket filters work for netlink unicast and notifications.
This is useful for applications like Zebra that get overrun with
messages that are then ignored.
Note: netlink messages are in host byte order, but packet filter
state machine operations are done as network byte order.
This staff will be needed for non-netlink kernel sockets, which should
also not pin a namespace like tcp_socket and icmp_socket.
Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Merge it to netlink_kernel_release.
The genl_unregister_family() calls the genl_unregister_mc_groups(),
which takes and releases the genl_lock and then locks and releases
this lock itself.
Relax this behavior, all the more so the genl_unregister_mc_groups()
is called from genl_unregister_family() only.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
all callers pass something->audit_context
The comment about "race free view of the set of network
namespaces" was a bit hasty. Look (there even can be only
one CPU, as discovered by Alexey Dobriyan and Denis Lunev):
put_net()
if (atomic_dec_and_test(&net->refcnt))
/* true */
__put_net(net);
queue_work(...);
* note: the net now has refcnt 0, but still in
* the global list of net namespaces
== re-schedule ==
register_pernet_subsys(&some_ops);
register_pernet_operations(&some_ops);
(*some_ops)->init(net);
* we call netlink_kernel_create() here
* in some places
netlink_kernel_create();
sk_alloc();
get_net(net); /* refcnt = 1 */
* now we drop the net refcount not to
* block the net namespace exit in the
* future (or this can be done on the
* error path)
put_net(sk->sk_net);
if (atomic_dec_and_test(&...))
* true. BOOOM! The net is
* scheduled for release twice
When thinking on this problem, I decided, that getting and
putting the net in init callback is wrong. If some init
callback needs to have a refcount-less reference on the struct
net, _it_ has to be careful himself, rather than relying on
the infrastructure to handle this correctly.
In case of netlink_kernel_create(), the problem is that the
sk_alloc() gets the given namespace, but passing the info
that we don't want to get it inside this call is too heavy.
Instead, I propose to crate the socket inside an init_net
namespace and then re-attach it to the desired one right
after the socket is created.
After doing this, we also have to be careful on error paths
not to drop the reference on the namespace, we didn't get
the one on.
Acked-by: Denis Lunev <den@openvz.org>
Used to append data to a message without a header or padding.
