path: root/net/netrom/nr_in.c
2007-04-25[SK_BUFF]: Some more conversions to skb_copy_from_linear_dataArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-21[NETROM]: Fix three if-statements in nr_state1_machine()Mika Kukkonen
I found these while compiling with extra gcc warnings; considering the indenting surely they are not intentional? Signed-off-by: Mika Kukkonen <mikukkon@iki.fi> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[NETROM]: Implement G8PZT Circuit reset for NET/ROMRalf Baechle
NET/ROM is lacking a connection reset like TCP's RST flag which at times may result in a connecting having to slowly timing out instead of just being reset. An earlier attempt to reset the connection by sending a NR_CONNACK | NR_CHOKE_FLAG transport was inacceptable as it did result in crashes of BPQ systems. An alternative approach of introducing a new transport type 7 (NR_RESET) has be implemented several years ago in Paula Jayne Dowie G8PZT's Xrouter. Implement NR_RESET for Linux's NET/ROM but like any messing with the state engine consider this experimental for now and thus control it by a sysctl (net.netrom.reset) which for the time being defaults to off. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[AX25/NETROM/ROSE]: Kill net/ip.h inclusionRalf Baechle
All these are claiming to include <net/ip.h> to get ip_rcv() but in fact don't need the header at all, so away with the inclusion. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
