path: root/net/netrom/nr_subr.c
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-02-10[NET] NETROM: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[NETROM]: Implement G8PZT Circuit reset for NET/ROMRalf Baechle
NET/ROM is lacking a connection reset like TCP's RST flag which at times may result in a connecting having to slowly timing out instead of just being reset. An earlier attempt to reset the connection by sending a NR_CONNACK | NR_CHOKE_FLAG transport was inacceptable as it did result in crashes of BPQ systems. An alternative approach of introducing a new transport type 7 (NR_RESET) has be implemented several years ago in Paula Jayne Dowie G8PZT's Xrouter. Implement NR_RESET for Linux's NET/ROM but like any messing with the state engine consider this experimental for now and thus control it by a sysctl (net.netrom.reset) which for the time being defaults to off. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->listDavid S. Miller
Remove the "list" member of struct sk_buff, as it is entirely redundant. All SKB list removal callers know which list the SKB is on, so storing this in sk_buff does nothing other than taking up some space. Two tricky bits were SCTP, which I took care of, and two ATM drivers which Francois Romieu <romieu@fr.zoreil.com> fixed up. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
