path: root/net/netrom
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[NET]: Add a dev_ioctl() fallback to sock_ioctl()Christoph Hellwig
Currently all network protocols need to call dev_ioctl as the default fallback in their ioctl implementations. This patch adds a fallback to dev_ioctl to sock_ioctl if the protocol returned -ENOIOCTLCMD. This way all the procotol ioctl handlers can be simplified and we don't need to export dev_ioctl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NETROM]: Remove unessecary lock_sock calls in netrom_ioctl()Christoph Hellwig
lock_sock is needed only in very few cases, so do it there instead of around the switch statement. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-21[NETROM]: Fix three if-statements in nr_state1_machine()Mika Kukkonen
I found these while compiling with extra gcc warnings; considering the indenting surely they are not intentional? Signed-off-by: Mika Kukkonen <mikukkon@iki.fi> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-05[AX.25]: Fix packet socket crashRalf Baechle
Since changeset 98a82febb6340466824c3a453738d4fbd05db81a AX.25 is passing received IP and ARP packets to the stack through netif_rx() but we don't set the skb->mac.raw to right value which may result in a crash with applications that use a packet socket. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[NETROM]: Introduct stuct nr_privateRalf Baechle
NET/ROM's virtual interfaces don't have a proper private data structure yet. Create struct nr_private and put the statistics there. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[NETROM]: Implement G8PZT Circuit reset for NET/ROMRalf Baechle
NET/ROM is lacking a connection reset like TCP's RST flag which at times may result in a connecting having to slowly timing out instead of just being reset. An earlier attempt to reset the connection by sending a NR_CONNACK | NR_CHOKE_FLAG transport was inacceptable as it did result in crashes of BPQ systems. An alternative approach of introducing a new transport type 7 (NR_RESET) has be implemented several years ago in Paula Jayne Dowie G8PZT's Xrouter. Implement NR_RESET for Linux's NET/ROM but like any messing with the state engine consider this experimental for now and thus control it by a sysctl (net.netrom.reset) which for the time being defaults to off. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[NETROM]: NET/ROM has no ARPRalf Baechle
ARP over NET/ROM does not exist so it's obviously not implemented on any NET/ROM stack, so the NET/ROM interfaces really should default to IFF_NOARP. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[NETROM] NET/ROM has no txqueueRalf Baechle
NET/ROM uses virtual interfaces so setting a queue length is wrong. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[NETROM/AX.25/ROSE]: Remove useless testsRalf Baechle
Remove error tests that have already been performed by the caller. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[NETROM]: statistics fixRalf Baechle
Calling an incoming NET/ROM-encapsulated IP packet an error if the interface isn't up is probably a bit over the top, so count it as dropped instead of an error. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[NETROM]: Fix rebuild header messRalf Baechle
For reason that probably nobody recalls NET/ROM does it's actual packet transmission in nr_rebuild_header and even treats invocation of it's hard_start_xmit method nr_xmit as a bug. Fix that by splitting the job done by nr_rebuild_header into two halves. Along with that we now also can get rid of the silly clone of the skb on transmit. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-09[PATCH] timer initialization cleanup: DEFINE_TIMERIngo Molnar
Clean up timer initialization by introducing DEFINE_TIMER a'la DEFINE_SPINLOCK. Build and boot-tested on x86. A similar patch has been been in the -RT tree for some time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-06[AX25]: Make ax2asc thread-proofRalf Baechle
Ax2asc was still using a static buffer for all invocations which isn't exactly SMP-safe. Change ax2asc to take an additional result buffer as the argument. Change all callers to provide such a buffer. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[AX25/NETROM/ROSE]: Kill net/ip.h inclusionRalf Baechle
All these are claiming to include <net/ip.h> to get ip_rcv() but in fact don't need the header at all, so away with the inclusion. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[AX25/NETROM]: Cleanup direct calls into IP stackRalf Baechle
Get rid of the calls to ip_rcv and arp_rcv which were layering violations anyway. With those being replaced by netif_rx, less parts of AX.25 and relatives depend on INET support actually being enabled. This also will make PF_PACKET sockets work for IP and ARP packets received over AX.25 and for IP packets over NET/ROM. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->listDavid S. Miller
Remove the "list" member of struct sk_buff, as it is entirely redundant. All SKB list removal callers know which list the SKB is on, so storing this in sk_buff does nothing other than taking up some space. Two tricky bits were SCTP, which I took care of, and two ATM drivers which Francois Romieu <romieu@fr.zoreil.com> fixed up. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-08-23[AX25]: UID fixesRalf Baechle
o Brown paperbag bug - ax25_findbyuid() was always returning a NULL pointer as the result. Breaks ROSE completly and AX.25 if UID policy set to deny. o While the list structure of AX.25's UID to callsign mapping table was properly protected by a spinlock, it's elements were not refcounted resulting in a race between removal and usage of an element. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-23[NET]: Fix socket bitop damageRalf Baechle
The socket flag cleanups that went into 2.6.12-rc1 are basically oring the flags of an old socket into the socket just being created. Unfortunately that one was just initialized by sock_init_data(), so already has SOCK_ZAPPED set. As the result zapped sockets are created and all incoming connection will fail due to this bug which again was carefully replicated to at least AX.25, NET/ROM or ROSE. In order to keep the abstraction alive I've introduced sock_copy_flags() to copy the socket flags from one sockets to another and used that instead of the bitwise copy thing. Anyway, the idea here has probably been to copy all flags, so sock_copy_flags() should be the right thing. With this the ham radio protocols are usable again, so I hope this will make it into 2.6.13. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
