[ Upstream commit 468479e6043c84f5a65299cc07cb08a22a28c2b1 ]
PACKET_FANOUT_LB computes f->rr_cur such that it is modulo
f->num_members. It returns the old value unconditionally, but
f->num_members may have changed since the last store. Ensure
that the return value is always < num.
When modifying the logic, simplify it further by replacing the loop
with an unconditional atomic increment.
Fixes: dc99f600698d ("packet: Add fanout support.")
Suggested-by: Eric Dumazet <edumazet@google.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit f98f4514d07871da7a113dd9e3e330743fd70ae4 ]
We need to tell compiler it must not read f->num_members multiple
times. Otherwise testing if num is not zero is flaky, and we could
attempt an invalid divide by 0 in fanout_demux_cpu()
Note bug was present in packet_rcv_fanout_hash() and
packet_rcv_fanout_lb() but final 3.1 had a simple location
after commit 95ec3eb417115fb ("packet: Add 'cpu' fanout policy.")
Fixes: dc99f600698dc ("packet: Add fanout support.")
Cc: Willem de Bruijn <willemb@google.com>
[ Upstream commit dc808110bb62b64a448696ecac3938902c92e1ab ]
af_packet can currently overwrite kernel memory by out of bound
accesses, because it assumed a [new] block can always hold one frame.
This is not generally the case, even if most existing tools do it right.
This patch clamps too long frames as API permits, and issue a one time
error on syslog.
[ 394.357639] tpacket_rcv: packet too big, clamped from 5042 to 3966. macoff=82
In this example, packet header tp_snaplen was set to 3966,
and tp_len was set to 5042 (skb->len)
Fixes: f6fb8f100b80 ("af-packet: TPACKET_V3 flexible buffer implementation.")
Acked-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 90f62cf30a78721641e08737bda787552428061e ]
It is possible by passing a netlink socket to a more privileged
executable and then to fool that executable into writing to the socket
data that happens to be valid netlink message to do something that
privileged executable did not intend to do.
To keep this from happening replace bare capable and ns_capable calls
with netlink_capable, netlink_net_calls and netlink_ns_capable calls.
Which act the same as the previous calls except they verify that the
opener of the socket had the desired permissions as well.
Reported-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit a53b72c83a4216f2eb883ed45a0cbce014b8e62d ]
The permission check in sock_diag_put_filterinfo is wrong, and it is so removed
from it's sources it is not clear why it is wrong. Move the computation
into packet_diag_dump and pass a bool of the result into sock_diag_filterinfo.
This does not yet correct the capability check but instead simply moves it to make
it clear what is going on.
[ Upstream commit 78541c1dc60b65ecfce5a6a096fc260219d6784e ]
The caller needs capabilities on the namespace being queried, not on
their own namespace. This is a security bug, although it likely has
only a minor impact.
Cc: stable@vger.kernel.org
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
At first glance it looks like there is a missing curly brace but
actually the code works the same either way. I have adjusted the
indenting but left the code the same.
Mathias reported that on an AMD Geode LX embedded board (ALiX)
with ath9k driver PACKET_QDISC_BYPASS, introduced in commit
d346a3fae3ff ("packet: introduce PACKET_QDISC_BYPASS socket
option"), triggers a WARN_ON() coming from the driver itself
via 066dae93bdf ("ath9k: rework tx queue selection and fix
queue stopping/waking").
The reason why this happened is that ndo_select_queue() call
is not invoked from direct xmit path i.e. for ieee80211 subsystem
that sets queue and TID (similar to 802.1d tag) which is being
put into the frame through 802.11e (WMM, QoS). If that is not
set, pending frame counter for e.g. ath9k can get messed up.
So the WARN_ON() in ath9k is absolutely legitimate. Generally,
the hw queue selection in ieee80211 depends on the type of
traffic, and priorities are set according to ieee80211_ac_numbers
mapping; working in a similar way as DiffServ only on a lower
layer, so that the AP can favour frames that have "real-time"
requirements like voice or video data frames.
Therefore, check for presence of ndo_select_queue() in netdev
ops and, if available, invoke it with a fallback handler to
__packet_pick_tx_queue(), so that driver such as bnx2x, ixgbe,
or mlx4 can still select a hw queue for transmission in
relation to the current CPU while e.g. ieee80211 subsystem
can make their own choices.
Reported-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
This patch adds a queue mapping mode to the fanout operation of af_packet
sockets. This allows user space af_packet users to better filter on flows
ingressing and egressing via a specific hardware queue, and avoids the potential
packet reordering that can occur when FANOUT_CPU is being used and irq affinity
varies.
Tested successfully by myself. applies to net-next
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: "David S. Miller" <davem@davemloft.net>
As David Laight suggests, we shouldn't necessarily call this
reciprocal_divide() when users didn't requested a reciprocal_value();
lets keep the basic idea and call it reciprocal_scale(). More
background information on this topic can be found in [1].
Joint work with Hannes Frederic Sowa.
[1] http://homepage.cs.uiowa.edu/~jones/bcd/divide.html
Suggested-by: David Laight <david.laight@aculab.com>
Cc: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Many functions have open coded a function that returns a random
number in range [0,N-1]. Under the assumption that we have a PRNG
such as taus113 with being well distributed in [0, ~0U] space,
we can implement such a function as uword t = (n*m')>>32, where
m' is a random number obtained from PRNG, n the right open interval
border and t our resulting random number, with n,m',t in u32 universe.
Lets go with Joe and simply call it prandom_u32_max(), although
technically we have an right open interval endpoint, but that we
have documented. Other users can further be migrated to the new
prandom_u32_max() function later on; for now, we need to make sure
to migrate reciprocal_divide() users for the reciprocal_divide()
follow-up fixup since their function signatures are going to change.
Doesn't bring much, but also doesn't hurt us to fix 'em:
1) In tpacket_rcv() flush dcache page we can restirct the scope
for start and end and remove one layer of indent.
2) In tpacket_destruct_skb() we can restirct the scope for ph.
3) In alloc_one_pg_vec_page() we can remove the NULL assignment
and change spacing a bit.
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
In PF_PACKET's packet mmap(), we can avoid using one atomic_inc()
and one atomic_dec() call in skb destructor and use a percpu
reference count instead in order to determine if packets are
still pending to be sent out. Micro-benchmark with [1] that has
been slightly modified (that is, protcol = 0 in socket(2) and
bind(2)), example on a rather crappy testing machine; I expect
it to scale and have even better results on bigger machines:
./packet_mm_tx -s7000 -m7200 -z700000 em1, avg over 2500 runs:
With patch: 4,022,015 cyc
Without patch: 4,812,994 cyc
time ./packet_mm_tx -s64 -c10000000 em1 > /dev/null, stable:
With patch:
real 1m32.241s
user 0m0.287s
sys 1m29.316s
Without patch:
real 1m38.386s
user 0m0.265s
sys 1m35.572s
In function tpacket_snd(), it is okay to use packet_read_pending()
since in fast-path we short-circuit the condition already with
ph != NULL, since we have next frames to process. In case we have
MSG_DONTWAIT, we also do not execute this path as need_wait is
false here anyway, and in case of _no_ MSG_DONTWAIT flag, it is
okay to call a packet_read_pending(), because when we ever reach
that path, we're done processing outgoing frames anyway and only
look if there are skbs still outstanding to be orphaned. We can
stay lockless in this percpu counter since it's acceptable when we
reach this path for the sum to be imprecise first, but we'll level
out at 0 after all pending frames have reached the skb destructor
eventually through tx reclaim. When people pin a tx process to
particular CPUs, we expect overflows to happen in the reference
counter as on one CPU we expect heavy increase; and distributed
through ksoftirqd on all CPUs a decrease, for example. As
David Laight points out, since the C language doesn't define the
result of signed int overflow (i.e. rather than wrap, it is
allowed to saturate as a possible outcome), we have to use
unsigned int as reference count. The sum over all CPUs when tx
is complete will result in 0 again.
The BUG_ON() in tpacket_destruct_skb() we can remove as well. It
can _only_ be set from inside tpacket_snd() path and we made sure
to increase tx_ring.pending in any case before we called po->xmit(skb).
So testing for tx_ring.pending == 0 is not too useful. Instead, it
would rather have been useful to test if lower layers didn't orphan
the skb so that we're missing ring slots being put back to
TP_STATUS_AVAILABLE. But such a bug will be caught in user space
already as we end up realizing that we do not have any
TP_STATUS_AVAILABLE slots left anymore. Therefore, we're all set.
Btw, in case of RX_RING path, we do not make use of the pending
member, therefore we also don't need to use up any percpu memory
here. Also note that __alloc_percpu() already returns a zero-filled
percpu area, so initialization is done already.
[1] http://wiki.ipxwarzone.com/index.php5?title=Linux_packet_mmap
In tpacket_snd(), when we've discovered a first frame that is
not in status TP_STATUS_SEND_REQUEST, and return a NULL buffer,
we exit the send routine in case of MSG_DONTWAIT, since we've
finished traversing the mmaped send ring buffer and don't care
about pending frames.
While doing so, we still unconditionally call an expensive
schedule() in the packet_current_frame() "error" path, which
is unnecessary in this case since it's enough to just quit
the function.
Also, in case MSG_DONTWAIT is not set, we should rather test
for need_resched() first and do schedule() only if necessary
since meanwhile pending frames could already have finished
processing and called skb destructor.
Most people acquire PF_PACKET sockets with a protocol argument in
the socket call, e.g. libpcap does so with htons(ETH_P_ALL) for
all its sockets. Most likely, at some point in time a subsequent
bind() call will follow, e.g. in libpcap with ...
memset(&sll, 0, sizeof(sll));
sll.sll_family = AF_PACKET;
sll.sll_ifindex = ifindex;
sll.sll_protocol = htons(ETH_P_ALL);
... as arguments. What happens in the kernel is that already
in socket() syscall, we install a proto hook via register_prot_hook()
if our protocol argument is != 0. Yet, in bind() we're almost
doing the same work by doing a unregister_prot_hook() with an
expensive synchronize_net() call in case during socket() the proto
was != 0, plus follow-up register_prot_hook() with a bound device
to it this time, in order to limit traffic we get.
In the case when the protocol and user supplied device index (== 0)
does not change from socket() to bind(), we can spare us doing
the same work twice. Similarly for re-binding to the same device
and protocol. For these scenarios, we can decrease create/bind
latency from ~7447us (sock-bind-2 case) to ~89us (sock-bind-1 case)
with this patch.
Alternatively, for the first case, if people care, they should
simply create their sockets with proto == 0 argument and define
the protocol during bind() as this saves a call to synchronize_net()
as well (sock-bind-3 case).
In all other cases, we're tied to user space behaviour we must not
change, also since a bind() is not strictly required. Thus, we need
the synchronize_net() to make sure no asynchronous packet processing
paths still refer to the previous elements of po->prot_hook.
In case of mmap()ed sockets, the workflow that includes bind() is
socket() -> setsockopt(<ring>) -> bind(). In that case, a pair of
{__unregister, register}_prot_hook is being called from setsockopt()
in order to install the new protocol receive handler. Thus, when
we call bind and can skip a re-hook, we have already previously
installed the new handler. For fanout, this is handled different
entirely, so we should be good.
Timings on an i7-3520M machine:
* sock-bind-1: 89 us
* sock-bind-2: 7447 us
* sock-bind-3: 75 us
sock-bind-1:
socket(PF_PACKET, SOCK_RAW, htons(ETH_P_IP)) = 3
bind(3, {sa_family=AF_PACKET, proto=htons(ETH_P_IP), if=all(0),
pkttype=PACKET_HOST, addr(0)={0, }, 20) = 0
sock-bind-2:
bind(3, {sa_family=AF_PACKET, proto=htons(ETH_P_IP), if=lo(1),
sock-bind-3:
socket(PF_PACKET, SOCK_RAW, 0) = 3
Cleanup checkpatch errors.Specially,the second changed line
is exactly 80 columns long.
Signed-off-by: Weilong Chen <chenweilong@huawei.com>
This enables userspace to get VLAN TPID as well as the VLAN TCI.
Signed-off-by: Atzm Watanabe <atzm@stratosphere.co.jp>
struct tpacket{2,3}_hdr is aligned to a multiple of TPACKET_ALIGNMENT.
Explicitly defining and zeroing the gap of this makes additional changes
easier.
We may add members to them until current aligned size without forcing
userspace to call getsockopt(..., PACKET_HDRLEN, ...).
Changing name of function as part of making the hash in skbuff to be
generic property, not just for receive path.
Signed-off-by: Tom Herbert <therbert@google.com>
This patches fixes the following warning by replacing smp_processor_id()
with raw_smp_processor_id():
[ 11.120893] BUG: using smp_processor_id() in preemptible [00000000] code: arping/3510
[ 11.120913] caller is .packet_sendmsg+0xc14/0xe68
[ 11.120920] CPU: 13 PID: 3510 Comm: arping Not tainted 3.13.0-rc3-next-20131211-dirty #1
[ 11.120926] Call Trace:
[ 11.120932] [c0000001f803f6f0] [c0000000000138dc] .show_stack+0x110/0x25c (unreliable)
[ 11.120942] [c0000001f803f7e0] [c00000000083dd24] .dump_stack+0xa0/0x37c
[ 11.120951] [c0000001f803f870] [c000000000493fd4] .debug_smp_processor_id+0xfc/0x12c
[ 11.120959] [c0000001f803f900] [c0000000007eba78] .packet_sendmsg+0xc14/0xe68
[ 11.120968] [c0000001f803fa80] [c000000000700968] .sock_sendmsg+0xa0/0xe0
[ 11.120975] [c0000001f803fbf0] [c0000000007014d8] .SyS_sendto+0x100/0x148
[ 11.120983] [c0000001f803fd60] [c0000000006fff10] .SyS_socketcall+0x1c4/0x2e8
[ 11.120990] [c0000001f803fe30] [c00000000000a1e4] syscall_exit+0x0/0x9c
Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
This patch introduces a PACKET_QDISC_BYPASS socket option, that
allows for using a similar xmit() function as in pktgen instead
of taking the dev_queue_xmit() path. This can be very useful when
PF_PACKET applications are required to be used in a similar
scenario as pktgen, but with full, flexible packet payload that
needs to be provided, for example.
On default, nothing changes in behaviour for normal PF_PACKET
TX users, so everything stays as is for applications. New users,
however, can now set PACKET_QDISC_BYPASS if needed to prevent
own packets from i) reentering packet_rcv() and ii) to directly
push the frame to the driver.
In doing so we can increase pps (here 64 byte packets) for
PF_PACKET a bit:
# CPUs -- QDISC_BYPASS -- qdisc path -- qdisc path[**]
1 CPU == 1,509,628 pps -- 1,208,708 -- 1,247,436
2 CPUs == 3,198,659 pps -- 2,536,012 -- 1,605,779
3 CPUs == 4,787,992 pps -- 3,788,740 -- 1,735,610
4 CPUs == 6,173,956 pps -- 4,907,799 -- 1,909,114
5 CPUs == 7,495,676 pps -- 5,956,499 -- 2,014,422
6 CPUs == 9,001,496 pps -- 7,145,064 -- 2,155,261
7 CPUs == 10,229,776 pps -- 8,190,596 -- 2,220,619
8 CPUs == 11,040,732 pps -- 9,188,544 -- 2,241,879
9 CPUs == 12,009,076 pps -- 10,275,936 -- 2,068,447
10 CPUs == 11,380,052 pps -- 11,265,337 -- 1,578,689
11 CPUs == 11,672,676 pps -- 11,845,344 -- 1,297,412
20 CPUs == 11,363,192 pps -- 11,014,933 -- 1,245,081
[**]: qdisc path with packet_rcv(), how probably most people
seem to use it (hopefully not anymore if not needed)
The test was done using a modified trafgen, sending a simple
static 64 bytes packet, on all CPUs. The trick in the fast
"qdisc path" case, is to avoid reentering packet_rcv() by
setting the RAW socket protocol to zero, like:
socket(PF_PACKET, SOCK_RAW, 0);
Tradeoffs are documented as well in this patch, clearly, if
queues are busy, we will drop more packets, tc disciplines are
ignored, and these packets are not visible to taps anymore. For
a pktgen like scenario, we argue that this is acceptable.
The pointer to the xmit function has been placed in packet
socket structure hole between cached_dev and prot_hook that
is hot anyway as we're working on cached_dev in each send path.
Done in joint work together with Jesper Dangaard Brouer.
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Merge 'net' into 'net-next' to get the AF_PACKET bug fix that
Daniel's direct transmit changes depend upon.
Commit e40526cb20b5 introduced a cached dev pointer, that gets
hooked into register_prot_hook(), __unregister_prot_hook() to
update the device used for the send path.
We need to fix this up, as otherwise this will not work with
sockets created with protocol = 0, plus with sll_protocol = 0
passed via sockaddr_ll when doing the bind.
So instead, assign the pointer directly. The compiler can inline
these helper functions automagically.
While at it, also assume the cached dev fast-path as likely(),
and document this variant of socket creation as it seems it is
not widely used (seems not even the author of TX_RING was aware
of that in his reference example [1]). Tested with reproducer
from e40526cb20b5.
[1] http://wiki.ipxwarzone.com/index.php5?title=Linux_packet_mmap#Example
Fixes: e40526cb20b5 ("packet: fix use after free race in send path when dev is released")
Tested-by: Salam Noureddine <noureddine@aristanetworks.com>
Tested-by: Jesper Dangaard Brouer <brouer@redhat.com>
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Currently we're using plain spin_lock() in prb_shutdown_retire_blk_timer(),
however the timer might fire right in the middle and thus try to re-aquire
the same spinlock, leaving us in a endless loop.
To fix that, use the spin_lock_bh() to block it.
CC: Daniel Borkmann <dborkman@redhat.com>
CC: Willem de Bruijn <willemb@google.com>
CC: Phil Sutter <phil@nwl.cc>
CC: Eric Dumazet <edumazet@google.com>
Reported-by: Jan Stancek <jstancek@redhat.com>
Tested-by: Jan Stancek <jstancek@redhat.com>
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
Salam reported a use after free bug in PF_PACKET that occurs when
we're sending out frames on a socket bound device and suddenly the
net device is being unregistered. It appears that commit 827d9780
introduced a possible race condition between {t,}packet_snd() and
packet_notifier(). In the case of a bound socket, packet_notifier()
can drop the last reference to the net_device and {t,}packet_snd()
might end up suddenly sending a packet over a freed net_device.
To avoid reverting 827d9780 and thus introducing a performance
regression compared to the current state of things, we decided to
hold a cached RCU protected pointer to the net device and maintain
it on write side via bind spin_lock protected register_prot_hook()
and __unregister_prot_hook() calls.
In {t,}packet_snd() path, we access this pointer under rcu_read_lock
through packet_cached_dev_get() that holds reference to the device
to prevent it from being freed through packet_notifier() while
we're in send path. This is okay to do as dev_put()/dev_hold() are
per-cpu counters, so this should not be a performance issue. Also,
the code simplifies a bit as we don't need need_rls_dev anymore.
Fixes: 827d978037d7 ("af-packet: Use existing netdev reference for bound sockets.")
Reported-by: Salam Noureddine <noureddine@aristanetworks.com>
Signed-off-by: Salam Noureddine <noureddine@aristanetworks.com>
Cc: Ben Greear <greearb@candelatech.com>
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Instead of hard-coding reciprocal_divide function, use the inline
function from reciprocal_div.h.
We currently allow for different fanout scheduling policies in pf_packet
such as scheduling by skb's rxhash, round-robin, by cpu, and rollover.
Also allow for a random, equidistributed selection of the socket from the
fanout process group.
drivers/net/wireless/iwlwifi/pcie/trans.c
include/linux/inetdevice.h
The inetdevice.h conflict involves moving the IPV4_DEVCONF values
into a UAPI header, overlapping additions of some new entries.
The iwlwifi conflict is a context overlap.
getsockopt PACKET_STATISTICS returns tp_packets + tp_drops. Commit
ee80fbf301 ("packet: account statistics only in tpacket_stats_u")
cleaned up the getsockopt PACKET_STATISTICS code.
This also changed semantics. Historically, tp_packets included
tp_drops on return. The commit removed the line that adds tp_drops
into tp_packets.
This patch reinstates the old semantics.
Adding paged frags skbs to af_unix sockets introduced a performance
regression on large sends because of additional page allocations, even
if each skb could carry at least 100% more payload than before.
We can instruct sock_alloc_send_pskb() to attempt high order
allocations.
Most of the time, it does a single page allocation instead of 8.
I added an additional parameter to sock_alloc_send_pskb() to
let other users to opt-in for this new feature on followup patches.
Tested:
Before patch :
$ netperf -t STREAM_STREAM
STREAM STREAM TEST
Recv Send Send
Socket Socket Message Elapsed
Size Size Size Time Throughput
bytes bytes bytes secs. 10^6bits/sec
2304 212992 212992 10.00 46861.15
After patch :
STREAM STREAM TEST
Recv Send Send
2304 212992 212992 10.00 57981.11
This reverts commits:
0f75b09c798ed00c30d7d5551b896be883bc2aeb
cbd89acb9eb257ed3b2be867142583fdcf7fdc5b
c483e02614551e44ced3fe6eedda8e36d3277ccc
Amongst other things, it's modifies the SKB header
to pull the ethernet headers off via eth_type_trans()
on the output path which is bogus.
It's causing serious regressions for people.
For ethernet frames, eth_type_trans() already parses the header, so one
can skip this when checking the frame size.
Signed-off-by: Phil Sutter <phil@nwl.cc>
Since tpacket_fill_skb() parses the protocol field in ethernet frames'
headers, it's easy to see if any passed frame is a VLAN one and account
for the extended size.
But as the real protocol does not turn up before tpacket_fill_skb()
runs which in turn also checks the frame length, move the max frame
length calculation into the function.
This may be necessary when the SKB is passed to other layers on the go,
which check the protocol field on their own. An example is a VLAN packet
sent out using AF_PACKET on a bridge interface. The bridging code checks
the SKB size, accounting for any VLAN header only if the protocol field
is set accordingly.
Note that eth_type_trans() sets skb->dev to the passed argument, so this
can be skipped in packet_snd() for ethernet frames, as well.
This patch moves the private error queue delivery function from the
af_packet code to the core socket method. In this way, network layers
only needing the error queue for transmit time stamping can share common
code.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
drivers/net/wireless/ath/ath9k/Kconfig
drivers/net/xen-netback/netback.c
net/batman-adv/bat_iv_ogm.c
net/wireless/nl80211.c
The ath9k Kconfig conflict was a change of a Kconfig option name right
next to the deletion of another option.
The xen-netback conflict was overlapping changes involving the
handling of the notify list in xen_netbk_rx_action().
Batman conflict resolution provided by Antonio Quartulli, basically
keep everything in both conflict hunks.
The nl80211 conflict is a little more involved. In 'net' we added a
dynamic memory allocation to nl80211_dump_wiphy() to fix a race that
Linus reported. Meanwhile in 'net-next' the handlers were converted
to use pre and post doit handlers which use a flag to determine
whether to hold the RTNL mutex around the operation.
However, the dump handlers to not use this logic. Instead they have
to explicitly do the locking. There were apparent bugs in the
conversion of nl80211_dump_wiphy() in that we were not dropping the
RTNL mutex in all the return paths, and it seems we very much should
be doing so. So I fixed that whilst handling the overlapping changes.
To simplify the initial returns, I take the RTNL mutex after we try
to allocate 'tb'.
uaddr->sa_data is exactly of size 14, which is hard-coded here and
passed as a size argument to strncpy(). A device name can be of size
IFNAMSIZ (== 16), meaning we might leave the destination string
unterminated. Thus, use strlcpy() and also sizeof() while we're
at it. We need to memset the data area beforehand, since strlcpy
does not padd the remaining buffer with zeroes for user space, so
that we do not possibly leak anything.
So far, only net_device * could be passed along with netdevice notifier
event. This patch provides a possibility to pass custom structure
able to provide info that event listener needs to know.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
v2->v3: fix typo on simeth
shortened dev_getter
shortened notifier_info struct name
v1->v2: fix notifier_call parameter in call_netdevice_notifier()
Jakub reported that it is fairly easy to trigger the BUG() macro
from user space with TPACKET_V3's RX_RING by just giving a wrong
header status flag. We already had a similar situation in commit
7f5c3e3a80e6654 (``af_packet: remove BUG statement in
tpacket_destruct_skb'') where this was the case in the TX_RING
side that could be triggered from user space. So really, don't use
BUG() or BUG_ON() unless there's really no way out, and i.e.
don't use it for consistency checking when there's user space
involved, no excuses, especially not if you're slapping the user
with WARN + dump_stack + BUG all at once. The two functions are
of concern:
prb_retire_current_block() [when block status != TP_STATUS_KERNEL]
prb_open_block() [when block_status != TP_STATUS_KERNEL]
Calls to prb_open_block() are guarded by ealier checks if block_status
is really TP_STATUS_KERNEL (racy!), but the first one BUG() is easily
triggable from user space. System behaves still stable after they are
removed. Also remove that yoda condition entirely, since it's already
guarded.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
This patch allows to dump BPF filters attached to a socket with
SO_ATTACH_FILTER.
Note that we check CAP_SYS_ADMIN before allowing to dump this info.
For now, only AF_PACKET sockets use this feature.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
sk_rmem_alloc is disclosed via /proc/net/packet but not via netlink messages.
The goal is to have the same level of information.
This value is disclosed via /proc/net/packet but not via netlink messages.
Currently, packet_sock has a struct tpacket_stats stats member for
TPACKET_V1 and TPACKET_V2 statistic accounting, and with TPACKET_V3
``union tpacket_stats_u stats_u'' was introduced, where however only
statistics for TPACKET_V3 are held, and when copied to user space,
TPACKET_V3 does some hackery and access also tpacket_stats' stats,
although everything could have been done within the union itself.
Unify accounting within the tpacket_stats_u union so that we can
remove 8 bytes from packet_sock that are there unnecessary. Note that
even if we switch to TPACKET_V3 and would use non mmap(2)ed option,
this still works due to the union with same types + offsets, that are
exposed to the user space.
There's a 4 byte hole in packet_ring_buffer structure before
prb_bdqc, that can be filled with 'pending' member, thus we can
reduce the overall structure size from 224 bytes to 216 bytes.
This also has the side-effect, that in struct packet_sock 2*4 byte
holes after the embedded packet_ring_buffer members are removed,
and overall, packet_sock can be reduced by 1 cacheline:
Before: size: 1344, cachelines: 21, members: 24
After: size: 1280, cachelines: 20, members: 24
Currently, there is no way to find out which timestamp is reported in
tpacket{,2,3}_hdr's tp_sec, tp_{n,u}sec members. It can be one of
SOF_TIMESTAMPING_SYS_HARDWARE, SOF_TIMESTAMPING_RAW_HARDWARE,
SOF_TIMESTAMPING_SOFTWARE, or a fallback variant late call from the
PF_PACKET code in software.
Therefore, report in the tp_status member of the ring buffer which
timestamp has been reported for RX and TX path. This should not break
anything for the following reasons: i) in RX ring path, the user needs
to test for tp_status & TP_STATUS_USER, and later for other flags as
well such as TP_STATUS_VLAN_VALID et al, so adding other flags will
do no harm; ii) in TX ring path, time stamps with PACKET_TIMESTAMP
socketoption are not available resp. had no effect except that the
application setting this is buggy. Next to TP_STATUS_AVAILABLE, the
user also should check for other flags such as TP_STATUS_WRONG_FORMAT
to reclaim frames to the application. Thus, in case TX ts are turned
off (default case), nothing happens to the application logic, and in
case we want to use this new feature, we now can also check which of
the ts source is reported in the status field as provided in the docs.
Reported-by: Richard Cochran <richardcochran@gmail.com>
Acked-by: Willem de Bruijn <willemb@google.com>
Currently, we only have software timestamping for the TX ring buffer
path, but this limitation stems rather from the implementation. By
just reusing tpacket_get_timestamp(), we can also allow hardware
timestamping just as in the RX path.
