path: root/net/phonet
2011-06-09rtnetlink: Compute and store minimum ifinfo dump sizeGreg Rose
The message size allocated for rtnl ifinfo dumps was limited to a single page. This is not enough for additional interface info available with devices that support SR-IOV and caused a bug in which VF info would not be displayed if more than approximately 40 VFs were created per interface. Implement a new function pointer for the rtnl_register service that will calculate the amount of data required for the ifinfo dump and allocate enough data to satisfy the request. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-05-24net: convert %p usage to %pKDan Rosenberg
The %pK format specifier is designed to hide exposed kernel pointers, specifically via /proc interfaces. Exposing these pointers provides an easy target for kernel write vulnerabilities, since they reveal the locations of writable structures containing easily triggerable function pointers. The behavior of %pK depends on the kptr_restrict sysctl. If kptr_restrict is set to 0, no deviation from the standard %p behavior occurs. If kptr_restrict is set to 1, the default, if the current user (intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG (currently in the LSM tree), kernel pointers using %pK are printed as 0's. If kptr_restrict is set to 2, kernel pointers using %pK are printed as 0's regardless of privileges. Replacing with 0's was chosen over the default "(null)", which cannot be parsed by userland %p, which expects "(nil)". The supporting code for kptr_restrict and %pK are currently in the -mm tree. This patch converts users of %p in net/ to %pK. Cases of printing pointers to the syslog are not covered, since this would eliminate useful information for postmortem debugging and the reading of the syslog is already optionally protected by the dmesg_restrict sysctl. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: James Morris <jmorris@namei.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Thomas Graf <tgraf@infradead.org> Cc: Eugene Teo <eugeneteo@kernel.org> Cc: Kees Cook <kees.cook@canonical.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-07net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu()Lai Jiangshan
The rcu callback phonet_device_rcu_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(phonet_device_rcu_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-02net: dont hold rtnl mutex during netlink dump callbacksEric Dumazet
Four years ago, Patrick made a change to hold rtnl mutex during netlink dump callbacks. I believe it was a wrong move. This slows down concurrent dumps, making good old /proc/net/ files faster than rtnetlink in some situations. This occurred to me because one "ip link show dev ..." was _very_ slow on a workload adding/removing network devices in background. All dump callbacks are able to use RCU locking now, so this patch does roughly a revert of commits : 1c2d670f366 : [RTNETLINK]: Hold rtnl_mutex during netlink dump callbacks 6313c1e0992 : [RTNETLINK]: Remove unnecessary locking in dump callbacks This let writers fight for rtnl mutex and readers going full speed. It also takes care of phonet : phonet_route_get() is now called from rcu read section. I renamed it to phonet_route_get_rcu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14Phonet: convert bound sockets hash list to RCURémi Denis-Courmont
This gets rid of the last spinlock in the Phonet stack proper. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15Phonet: fix aligned-mode pipe socket buffer header reserveRémi Denis-Courmont
When the pipe uses aligned-mode data packets, we must reserve 4 bytes instead of 3 for the pipe protocol header. Otherwise the Phonet header would not be aligned, resulting in potentially corrupted headers with later unaligned memory writes. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: kill the ST-Ericsson pipe controller KconfigRémi Denis-Courmont
This is now a run-time choice so that a single kernel can support both old and new generation ISI modems. Support for manually enabling the pipe flow is removed as it did not work properly, does not fit well with the socket API, and I am not aware of any use at the moment. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: support active connection without pipe controller on modemRémi Denis-Courmont
This provides support for newer ISI modems with no need for the earlier experimental compile-time alternative choice. With this, we can now use the same kernel and userspace with both types of modems. This also avoids confusing two different and incompatible state machines, actively connected vs accepted sockets, and adds connection response error handling (processing "SYN/RST" of sorts). Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: provide pipe socket option to retrieve the pipe identifierRémi Denis-Courmont
User-space sometimes needs this information. In particular, the GPRS context or the AT commands pipe setups may use the pipe handle as a reference. This removes the settable pipe handle with CONFIG_PHONET_PIPECTRLR. It did not handle error cases correctly. Furthermore, the kernel *could* implement a smart scheme for allocating handles (if ever needed), but userspace really cannot. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: allocate sock from accept syscall rather than soft IRQRémi Denis-Courmont
This moves most of the accept logic to process context like other socket stacks do. Then we can use a few more common socket helpers and simplify a bit. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: factor common code to send control messagesRémi Denis-Courmont
With the addition of the pipe controller, there is now quite a bit of repetitive code for small signaling messages. Lets factor it. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: correct pipe backlog callback return valuesRémi Denis-Courmont
In some cases, the Phonet pipe backlog callbacks returned negative errno instead of NET_RX_* values. In other cases, NET_RX_DROP was returned for invalid packets, even though it seems only intended for buffering problems (not for deliberately discarded packets). Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: return an error when packet TX failsRémi Denis-Courmont
Phonet assumes that packets are never dropped. We try our best to avoid this situation. But lets return ENOBUFS if queueing to the network device fails so that the caller knows things went wrong. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: fix NULL dereference on TX path with implicit sourceRémi Denis-Courmont
The previous Phonet patch series introduced per-socket implicit destination (i.e. connect()). In that case, the destination socket address is NULL in the transmit function. However commit a8059512b120362b15424f152b2548fe8b11bd0c ("Phonet: implement per-socket destination/peer address") is incomplete and would trigger a NULL dereference. (Fortunately, the code is not in released kernel, and in fact currently not reachable.) Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25phonet: Protect pipe_do_remove() with appropriate ifdefs.David S. Miller
It is only used when CONFIG_PHONET_PIPECTRLR is not set. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25Phonet: fix flawed "SYN/ACK" logicRémi Denis-Courmont
* Do not fail if the peer supports more or less than 3 algorithms. * Ignore unknown congestion control algorithms instead of failing. * Simplify congestion algorithm negotiation (largest is best). * Do not use a static buffer. * Fix off-by-two read overflow. * Avoid extra memory copy (in addition to skb_copy_bits()). The previous code really made no sense. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25Phonet: don't bother with transaction IDs (especially for indications)Rémi Denis-Courmont
2011-02-25Phonet: remove redumdant pep->pipe_stateRémi Denis-Courmont
sk->sk_state already contains the pipe state. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25Phonet: use socket destination in pipe protocolRémi Denis-Courmont
2011-02-25Phonet: implement per-socket destination/peer addressRémi Denis-Courmont
2011-02-25Phonet: allow multiple listen() and fix small race conditionRémi Denis-Courmont
2011-01-10phonet: some signedness bugsDan Carpenter
Dan Rosenberg pointed out that there were some signed comparison bugs in the phonet protocol. http://marc.info/?l=full-disclosure&m=129424528425330&w=2 The problem is that we check for array overflows but "protocol" is signed and we don't check for array underflows. If you have already have CAP_SYS_ADMIN then you could use the bugs to get root, or someone could cause an oops by mistake. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22Net: phonet: Makefile: Remove deprecated kbuild goal definitionsTracey Dent
Changed Makefile to use <modules>-y instead of <modules>-objs because -objs is deprecated and not mentioned in Documentation/kbuild/makefiles.txt. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-20phonet: remove the unused variable pnChangli Gao
Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-13Phonet: 'connect' socket implementation for Pipe controllerKumar Sanghvi
Based on suggestion by Rémi Denis-Courmont to implement 'connect' for Pipe controller logic, this patch implements 'connect' socket call for the Pipe controller logic. The patch does following:- - Removes setsockopts for PNPIPE_CREATE and PNPIPE_DESTROY - Adds setsockopt for setting the Pipe handle value - Implements connect socket call - Updates the Pipe controller logic User-space should now follow below sequence with Pipe controller:- -socket -bind -setsockopt for PNPIPE_PIPE_HANDLE -connect -setsockopt for PNPIPE_ENCAP_IP -setsockopt for PNPIPE_ENABLE GPRS/3G data has been tested working fine with this. Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-08Phonet: mark the pipe controller as EXPERIMENTALRémi Denis-Courmont
There are a bunch of issues that need to be fixed, including: - GFP_KERNEL allocations from atomic context (and GFP_ATOMIC in process context), - abuse of the setsockopt() call convention, - unprotected/unlocked static variables... IMHO, we will need to alter the userspace ABI when we fix it. So mark the configuration option as EXPERIMENTAL for the time being (or should it be BROKEN instead?). Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-08Phonet: cleanup pipe enable socket optionRémi Denis-Courmont
The current code works like this: int garbage, status; socklen_t len = sizeof(status); /* enable pipe */ setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &garbage, sizeof(garbage)); /* disable pipe */ setsockopt(fd, SOL_PNPIPE, PNPIPE_DISABLE, &garbage, sizeof(garbage)); /* get status */ getsockopt(fd, SOL_PNPIPE, PNPIPE_INQ, &status, &len); ...which does not follow the usual socket option pattern. This patch merges all three "options" into a single gettable&settable option, before Linux 2.6.37 gets out: int status; socklen_t len = sizeof(status); /* enable pipe */ status = 1; setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, sizeof(status)); /* disable pipe */ status = 0; setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, sizeof(status)); /* get status */ getsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, &len); This also fixes the error code from EFAULT to ENOTCONN. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Cc: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-08Phonet: advise against enabling the pipe controllerRémi Denis-Courmont
As it currently is, the new code path is not compatible with existing Nokia modems. This would break existing userspace for Nokia modem, such as the existing oFono ISI driver. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-04Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/Kconfig net/ipv4/tcp_timer.c
2010-09-30Phonet: restore flow control credits when sending failsRémi Denis-Courmont
This patch restores the below flow control patch submitted by Rémi Denis-Courmont, which accidentaly got lost due to Pipe controller patch on Phonet. commit 1a98214feef2221cd7c24b17cd688a5a9d85b2ea Author: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Date: Mon Aug 30 12:57:03 2010 +0000 Phonet: restore flow control credits when sending fails Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-29Phonet: Correct header retrieval after pskb_may_pullKumar Sanghvi
Retrieve the header after doing pskb_may_pull since, pskb_may_pull could change the buffer structure. This is based on the comment given by Eric Dumazet on Phonet Pipe controller patch for a similar problem. Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27Phonet: Implement Pipe Controller to support Nokia Slim ModemsKumar Sanghvi
Phonet stack assumes the presence of Pipe Controller, either in Modem or on Application Processing Engine user-space for the Pipe data. Nokia Slim Modems like WG2.5 used in ST-Ericsson U8500 platform do not implement Pipe controller in them. This patch adds Pipe Controller implemenation to Phonet stack to support Pipe data over Phonet stack for Nokia Slim Modems. Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15phonet: Fix build warning.David S. Miller
net/phonet/socket.c: In function ‘pn_res_seq_show’: net/phonet/socket.c:726: warning: format ‘%02X’ expects type ‘unsigned int’, but argument 3 has type ‘long int’ Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15Phonet: list subscribed resources via proc_fsRémi Denis-Courmont
2010-09-15Phonet: look up the resource routing table when forwardingRémi Denis-Courmont
2010-09-15Phonet: hook resource routing to userspace via ioctl()'sRémi Denis-Courmont
I wish we could use something cleaner, such as bind(). But that would not work since resource subscription is orthogonal/in addition to the normal object ID allocated via bind(). This is similar to multicasting which also uses ioctl()'s. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15Phonet: resource routing backendRémi Denis-Courmont
When both destination device and object are nul, Phonet routes the packet according to the resource field. In fact, this is the most common pattern when sending Phonet "request" packets. In this case, the packet is delivered to whichever endpoint (socket) has registered the resource. This adds a new table so that Linux processes can register their Phonet sockets to Phonet resources, if they have adequate privileges. (Namespace support is not implemented at the moment.) Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15Phonet: remove dangling pipe if an endpoint is closed earlyRémi Denis-Courmont
Closing a pipe endpoint is not normally allowed by the Phonet pipe, other than as a side after-effect of removing the pipe between two endpoints. But there is no way to prevent Linux userspace processes from being killed or suffering from bugs, so this can still happen. We might as well forcefully close Phonet pipe endpoints then. The cellular modem supports only a few existing pipes at a time. So we really should not leak them. This change instructs the modem to destroy the pipe if either of the pipe's endpoint (Linux socket) is closed too early. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-31Phonet: do not set POLLOUT in case of send buffer overflowRémi Denis-Courmont
2010-08-31Phonet: correct sendmsg() error code from sock_alloc_send_skb()Rémi Denis-Courmont
2010-08-31Phonet: restore flow control credits when sending failsRémi Denis-Courmont
2010-08-28phonet: use for_each_set_bitAkinobu Mita
Replace open-coded loop with for_each_set_bit(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/vhost/net.c net/bridge/br_device.c Fix merge conflict in drivers/vhost/net.c with guidance from Stephen Rothwell. Revert the effects of net-2.6 commit 573201f36fd9c7c6d5218cdcd9948cee700b277d since net-next-2.6 has fixes that make bridge netpoll work properly thus we don't need it disabled. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-08Phonet: fix skb leak in pipe endpoint accept()Rémi Denis-Courmont
2010-06-09phonet: use call_rcu for phonet device freeJiri Pirko
Use call_rcu rather than synchronize_rcu. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-29Phonet: listening socket lock protects the connected socket listRémi Denis-Courmont
The accept()'d socket need to be unhashed while the (listen()'ing) socket lock is held. This fixes a race condition that could lead to an OOPS. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-25Phonet: fix potential use-after-free in pep_sock_close()Rémi Denis-Courmont
sk_common_release() might destroy our last reference to the socket. So an extra temporary reference is needed during cleanup. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-01net: sock_def_readable() and friends RCU conversionEric Dumazet
sk_callback_lock rwlock actually protects sk->sk_sleep pointer, so we need two atomic operations (and associated dirtying) per incoming packet. RCU conversion is pretty much needed : 1) Add a new structure, called "struct socket_wq" to hold all fields that will need rcu_read_lock() protection (currently: a wait_queue_head_t and a struct fasync_struct pointer). [Future patch will add a list anchor for wakeup coalescing] 2) Attach one of such structure to each "struct socket" created in sock_alloc_inode(). 3) Respect RCU grace period when freeing a "struct socket_wq" 4) Change sk_sleep pointer in "struct sock" by sk_wq, pointer to "struct socket_wq" 5) Change sk_sleep() function to use new sk->sk_wq instead of sk->sk_sleep 6) Change sk_has_sleeper() to wq_has_sleeper() that must be used inside a rcu_read_lock() section. 7) Change all sk_has_sleeper() callers to : - Use rcu_read_lock() instead of read_lock(&sk->sk_callback_lock) - Use wq_has_sleeper() to eventually wakeup tasks. - Use rcu_read_unlock() instead of read_unlock(&sk->sk_callback_lock) 8) sock_wake_async() is modified to use rcu protection as well. 9) Exceptions : macvtap, drivers/net/tun.c, af_unix use integrated "struct socket_wq" instead of dynamically allocated ones. They dont need rcu freeing. Some cleanups or followups are probably needed, (possible sk_callback_lock conversion to a spinlock for example...). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26phonet: use phonet_pernet instead of directly net_genericJiri Pirko
As in for example pppoe introduce phonet_pernet and use it instead of calling net_generic directly. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
