path: root/net/phonet
2010-10-20phonet: remove the unused variable pnChangli Gao
Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-13Phonet: 'connect' socket implementation for Pipe controllerKumar Sanghvi
Based on suggestion by Rémi Denis-Courmont to implement 'connect' for Pipe controller logic, this patch implements 'connect' socket call for the Pipe controller logic. The patch does following:- - Removes setsockopts for PNPIPE_CREATE and PNPIPE_DESTROY - Adds setsockopt for setting the Pipe handle value - Implements connect socket call - Updates the Pipe controller logic User-space should now follow below sequence with Pipe controller:- -socket -bind -setsockopt for PNPIPE_PIPE_HANDLE -connect -setsockopt for PNPIPE_ENCAP_IP -setsockopt for PNPIPE_ENABLE GPRS/3G data has been tested working fine with this. Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-08Phonet: mark the pipe controller as EXPERIMENTALRémi Denis-Courmont
There are a bunch of issues that need to be fixed, including: - GFP_KERNEL allocations from atomic context (and GFP_ATOMIC in process context), - abuse of the setsockopt() call convention, - unprotected/unlocked static variables... IMHO, we will need to alter the userspace ABI when we fix it. So mark the configuration option as EXPERIMENTAL for the time being (or should it be BROKEN instead?). Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-08Phonet: cleanup pipe enable socket optionRémi Denis-Courmont
The current code works like this: int garbage, status; socklen_t len = sizeof(status); /* enable pipe */ setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &garbage, sizeof(garbage)); /* disable pipe */ setsockopt(fd, SOL_PNPIPE, PNPIPE_DISABLE, &garbage, sizeof(garbage)); /* get status */ getsockopt(fd, SOL_PNPIPE, PNPIPE_INQ, &status, &len); ...which does not follow the usual socket option pattern. This patch merges all three "options" into a single gettable&settable option, before Linux 2.6.37 gets out: int status; socklen_t len = sizeof(status); /* enable pipe */ status = 1; setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, sizeof(status)); /* disable pipe */ status = 0; setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, sizeof(status)); /* get status */ getsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, &len); This also fixes the error code from EFAULT to ENOTCONN. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Cc: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-08Phonet: advise against enabling the pipe controllerRémi Denis-Courmont
As it currently is, the new code path is not compatible with existing Nokia modems. This would break existing userspace for Nokia modem, such as the existing oFono ISI driver. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-04Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/Kconfig net/ipv4/tcp_timer.c
2010-09-30Phonet: restore flow control credits when sending failsRémi Denis-Courmont
This patch restores the below flow control patch submitted by Rémi Denis-Courmont, which accidentaly got lost due to Pipe controller patch on Phonet. commit 1a98214feef2221cd7c24b17cd688a5a9d85b2ea Author: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Date: Mon Aug 30 12:57:03 2010 +0000 Phonet: restore flow control credits when sending fails Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-29Phonet: Correct header retrieval after pskb_may_pullKumar Sanghvi
Retrieve the header after doing pskb_may_pull since, pskb_may_pull could change the buffer structure. This is based on the comment given by Eric Dumazet on Phonet Pipe controller patch for a similar problem. Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27Phonet: Implement Pipe Controller to support Nokia Slim ModemsKumar Sanghvi
Phonet stack assumes the presence of Pipe Controller, either in Modem or on Application Processing Engine user-space for the Pipe data. Nokia Slim Modems like WG2.5 used in ST-Ericsson U8500 platform do not implement Pipe controller in them. This patch adds Pipe Controller implemenation to Phonet stack to support Pipe data over Phonet stack for Nokia Slim Modems. Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15phonet: Fix build warning.David S. Miller
net/phonet/socket.c: In function ‘pn_res_seq_show’: net/phonet/socket.c:726: warning: format ‘%02X’ expects type ‘unsigned int’, but argument 3 has type ‘long int’ Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15Phonet: list subscribed resources via proc_fsRémi Denis-Courmont
2010-09-15Phonet: look up the resource routing table when forwardingRémi Denis-Courmont
2010-09-15Phonet: hook resource routing to userspace via ioctl()'sRémi Denis-Courmont
I wish we could use something cleaner, such as bind(). But that would not work since resource subscription is orthogonal/in addition to the normal object ID allocated via bind(). This is similar to multicasting which also uses ioctl()'s. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15Phonet: resource routing backendRémi Denis-Courmont
When both destination device and object are nul, Phonet routes the packet according to the resource field. In fact, this is the most common pattern when sending Phonet "request" packets. In this case, the packet is delivered to whichever endpoint (socket) has registered the resource. This adds a new table so that Linux processes can register their Phonet sockets to Phonet resources, if they have adequate privileges. (Namespace support is not implemented at the moment.) Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15Phonet: remove dangling pipe if an endpoint is closed earlyRémi Denis-Courmont
Closing a pipe endpoint is not normally allowed by the Phonet pipe, other than as a side after-effect of removing the pipe between two endpoints. But there is no way to prevent Linux userspace processes from being killed or suffering from bugs, so this can still happen. We might as well forcefully close Phonet pipe endpoints then. The cellular modem supports only a few existing pipes at a time. So we really should not leak them. This change instructs the modem to destroy the pipe if either of the pipe's endpoint (Linux socket) is closed too early. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-31Phonet: do not set POLLOUT in case of send buffer overflowRémi Denis-Courmont
2010-08-31Phonet: correct sendmsg() error code from sock_alloc_send_skb()Rémi Denis-Courmont
2010-08-31Phonet: restore flow control credits when sending failsRémi Denis-Courmont
2010-08-28phonet: use for_each_set_bitAkinobu Mita
Replace open-coded loop with for_each_set_bit(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/vhost/net.c net/bridge/br_device.c Fix merge conflict in drivers/vhost/net.c with guidance from Stephen Rothwell. Revert the effects of net-2.6 commit 573201f36fd9c7c6d5218cdcd9948cee700b277d since net-next-2.6 has fixes that make bridge netpoll work properly thus we don't need it disabled. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-08Phonet: fix skb leak in pipe endpoint accept()Rémi Denis-Courmont
2010-06-09phonet: use call_rcu for phonet device freeJiri Pirko
Use call_rcu rather than synchronize_rcu. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-29Phonet: listening socket lock protects the connected socket listRémi Denis-Courmont
The accept()'d socket need to be unhashed while the (listen()'ing) socket lock is held. This fixes a race condition that could lead to an OOPS. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-25Phonet: fix potential use-after-free in pep_sock_close()Rémi Denis-Courmont
sk_common_release() might destroy our last reference to the socket. So an extra temporary reference is needed during cleanup. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-01net: sock_def_readable() and friends RCU conversionEric Dumazet
sk_callback_lock rwlock actually protects sk->sk_sleep pointer, so we need two atomic operations (and associated dirtying) per incoming packet. RCU conversion is pretty much needed : 1) Add a new structure, called "struct socket_wq" to hold all fields that will need rcu_read_lock() protection (currently: a wait_queue_head_t and a struct fasync_struct pointer). [Future patch will add a list anchor for wakeup coalescing] 2) Attach one of such structure to each "struct socket" created in sock_alloc_inode(). 3) Respect RCU grace period when freeing a "struct socket_wq" 4) Change sk_sleep pointer in "struct sock" by sk_wq, pointer to "struct socket_wq" 5) Change sk_sleep() function to use new sk->sk_wq instead of sk->sk_sleep 6) Change sk_has_sleeper() to wq_has_sleeper() that must be used inside a rcu_read_lock() section. 7) Change all sk_has_sleeper() callers to : - Use rcu_read_lock() instead of read_lock(&sk->sk_callback_lock) - Use wq_has_sleeper() to eventually wakeup tasks. - Use rcu_read_unlock() instead of read_unlock(&sk->sk_callback_lock) 8) sock_wake_async() is modified to use rcu protection as well. 9) Exceptions : macvtap, drivers/net/tun.c, af_unix use integrated "struct socket_wq" instead of dynamically allocated ones. They dont need rcu freeing. Some cleanups or followups are probably needed, (possible sk_callback_lock conversion to a spinlock for example...). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26phonet: use phonet_pernet instead of directly net_genericJiri Pirko
As in for example pppoe introduce phonet_pernet and use it instead of calling net_generic directly. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-15phonet: use for_each_set_bit()Akinobu Mita
Replace open-coded loop with for_each_set_bit(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07Phonet: reject unsupported sendmsg/recvmsg flagsRémi Denis-Courmont
2010-01-07Phonet: zero-copy GPRS TXRémi Denis-Courmont
Send aligned pipe payload if requested to do so. Then, the socket buffer needs not be fragmented anymore. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07Phonet: zero-copy aligned GPRS RXRémi Denis-Courmont
Newer Nokia cellular modems can use aligned payload for their GPRS pipe. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-12-01net: Simplify phonet pernet operations.Eric W. Biederman
Take advantage of the new pernet automatic storage management, and stop using compatibility network namespace functions. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Phonet: convert devices list to RCURémi Denis-Courmont
2009-11-18netns: net_identifiers should be read_mostlyEric Dumazet
2009-11-17Phonet: missing rcu_dereference()Rémi Denis-Courmont
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13Phonet: convert routing table to RCURémi Denis-Courmont
2009-11-13Phonet: put protocols array under RCURémi Denis-Courmont
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-10Phonet: allocate and copy for pipe TX without sock lockRémi Denis-Courmont
2009-11-10Phonet: put sockets in a hash tableRémi Denis-Courmont
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04Phonet: remove tautologiesRémi Denis-Courmont
These checks don't make sense anymore since rtnl_notify() cannot fail. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15Phonet: hold socket before giving it to sk_deliver_skb()Rémi Denis-Courmont
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14net: sk_drops consolidationEric Dumazet
sock_queue_rcv_skb() can update sk_drops itself, removing need for callers to take care of it. This is more consistent since sock_queue_rcv_skb() also reads sk_drops when queueing a skb. This adds sk_drops managment to many protocols that not cared yet. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14Phonet: forward incoming packetsRémi Denis-Courmont
2009-10-14Phonet: route outgoing packetsRémi Denis-Courmont
2009-10-14Phonet: routing table Netlink interfaceRémi Denis-Courmont
