[ Upstream commit fdf5fd3975666804118e62c69de25dc85cc0909c ]
The broadcast node id should only be sent with the control port id.
Signed-off-by: Arun Kumar Neelakantam <aneela@codeaurora.org>
[ Upstream commit c77f5fbbefc04612755117775e8555c2a7006cac ]
Added MODULE_ALIAS("rpmsg:IPCRTR") to ensure qrtr-smd and qrtr will load
when IPCRTR channel is detected.
Signed-off-by: Ramon Fried <rfried@codeaurora.org>
Registering qrtr with module_init makes the ability of typical platform
code to create AF_QIPCRTR socket during probe a matter of link order
luck. Moving qrtr to postcore_initcall() avoids this.
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This change allows us to later indicate to rtnetlink core that certain
doit functions should be called without acquiring rtnl_mutex.
This change should have no effect, we simply replace the last (now
unused) calcit argument with the new flag.
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
There were many places that my previous spatch didn't find,
as pointed out by yuan linyu in various patches.
The following spatch found many more and also removes the
now unnecessary casts:
identifier p, p2;
expression len;
expression skb;
type t, t2;
+p = skb_put_zero(skb, len);
... when != p
p2 = (t2)p;
-memset(p2, 0, len);
-memset(p, 0, len);
type t, t2;
identifier p, p2;
expression skb;
t *p;
+p = skb_put_zero(skb, sizeof(t));
... when != p
p2 = (t2)p;
-memset(p2, 0, sizeof(*p));
-memset(p, 0, sizeof(*p));
expression skb, len;
-memset(skb_put(skb, len), 0, len);
+skb_put_zero(skb, len);
Apply it to the tree (with one manual fixup to keep the
comment in vxlan.c, which spatch removed.)
As the higher level communication only deals with "services" the
a service directory is required to keep track of local and remote
services. In order for qrtr clients to be informed about when the
service directory implementation is available some event needs to be
passed to them.
Rather than introducing support for broadcasting such a message in-band
to all open local sockets we flag each socket with ENETRESET, as there
are no other expected operations that would benefit from having support
from locally broadcasting messages.
Cc: Courtney Cavin <ccavin@gmail.com>
Per the QMUXv2 protocol specificiation a DEL_CLIENT message should be
broadcasted when an endpoint is disconnected.
The protocol specification does suggest that the router can keep track
of which nodes the endpoint has been communicating with to not wake up
sleeping remotes unecessarily, but implementation of this suggestion is
left for the future.
Per the QMUX protocol specification a terminating node can send a BYE
control message to signal that the link is going down, upon receiving
this all information about remote services should be discarded and local
clients should be notified.
In the event that the link was brought down abruptly the router is
supposed to act like a BYE message has arrived. As there is no harm in
receiving an extra BYE from the remote this patch implements the latter
by injecting a BYE when the link to the remote is unregistered.
The name service will receive the BYE and can implement the notification
to the local clients.
Extract the allocation and filling in the control message header fields
to a separate function in order to reuse this in subsequent patches.
Both conflict were simple overlapping changes.
In the kaweth case, Eric Dumazet's skb_cow() bug fix overlapped the
conversion of the driver in net-next to use in-netdev stats.
If skb_pad() fails then it frees the skb so we should check for errors.
Fixes: bdabad3e363d ("net: Add Qualcomm IPC router")
Add netlink_ext_ack arg to rtnl_doit_func. Pass extack arg to nlmsg_parse
for doit functions that call it directly.
This is the first step to using extended error reporting in rtnetlink.
>From here individual subsystems can be updated to set netlink_ext_ack as
needed.
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Pass the new extended ACK reporting struct to all of the generic
netlink parsing functions. For now, pass NULL in almost all callers
(except for some in the core.)
By moving these client drivers to use RPMSG instead of the direct SMD
API we can reuse them ontop of the newly added GLINK wire-protocol
support found in the 820 and 835 Qualcomm platforms.
As the new (RPMSG-based) and old SMD implementations are mutually
exclusive we have to change all client drivers in one commit, to make
sure we have a working system before and after this transition.
Acked-by: Andy Gross <andy.gross@linaro.org>
Acked-by: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Failure to mark this pointer as __le32 causes checkers like
sparse to complain:
net/qrtr/qrtr.c:274:16: warning: incorrect type in assignment (different base types)
net/qrtr/qrtr.c:274:16: expected unsigned int [unsigned] [usertype] <noident>
net/qrtr/qrtr.c:274:16: got restricted __le32 [usertype] <noident>
net/qrtr/qrtr.c:275:16: warning: incorrect type in assignment (different base types)
net/qrtr/qrtr.c:275:16: expected unsigned int [unsigned] [usertype] <noident>
net/qrtr/qrtr.c:275:16: got restricted __le32 [usertype] <noident>
net/qrtr/qrtr.c:276:16: warning: incorrect type in assignment (different base types)
net/qrtr/qrtr.c:276:16: expected unsigned int [unsigned] [usertype] <noident>
net/qrtr/qrtr.c:276:16: got restricted __le32 [usertype] <noident>
Silence it.
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Merge tag 'qcom-soc-for-4.7-2' into net-next
This merges the Qualcomm SOC tree with the net-next, solving the
merge conflict in the SMD API between the two.
Having multiple loadable modules with the same name cannot work
with modprobe, and having both net/qrtr/smd.ko and drivers/soc/qcom/smd.ko
results in a (somewhat cryptic) build error:
ERROR: "qcom_smd_driver_unregister" [net/qrtr/smd.ko] undefined!
ERROR: "qcom_smd_driver_register" [net/qrtr/smd.ko] undefined!
ERROR: "qcom_smd_set_drvdata" [net/qrtr/smd.ko] undefined!
ERROR: "qcom_smd_send" [net/qrtr/smd.ko] undefined!
ERROR: "qcom_smd_get_drvdata" [net/qrtr/smd.ko] undefined!
ERROR: "qcom_smd_driver_unregister" [drivers/soc/qcom/wcnss_ctrl.ko] undefined!
ERROR: "qcom_smd_driver_register" [drivers/soc/qcom/wcnss_ctrl.ko] undefined!
ERROR: "qcom_smd_set_drvdata" [drivers/soc/qcom/wcnss_ctrl.ko] undefined!
ERROR: "qcom_smd_send" [drivers/soc/qcom/wcnss_ctrl.ko] undefined!
ERROR: "qcom_smd_get_drvdata" [drivers/soc/qcom/wcnss_ctrl.ko] undefined!
Also, the qrtr driver uses the SMD interface and has a Kconfig dependency,
but also allows for compile-testing when SMD is disabled. However, if
with QCOM_SMD=m and COMPILE_TEST=y we can end up with QRTR_SMD=y and
that fails with a related link error.
The changes the dependency so we can still compile-test the driver but
not have it built-in if SMD is a module, to avoid running in the broken
configuration, and changes the Makefile to provide the driver under
a different module name.
Add an implementation of Qualcomm's IPC router protocol, used to
communicate with service providing remote processors.
Signed-off-by: Courtney Cavin <courtney.cavin@sonymobile.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
[bjorn: Cope with 0 being a valid node id and implement RTM_NEWADDR]
