In qrtr_tun_write_iter the allocated kbuf should be release in case of
error or success return.
v2 Update: Thanks to David Miller for pointing out the release on success
path as well.
Signed-off-by: Navid Emamdoost <navid.emamdoost@gmail.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 and
only version 2 as published by the free software foundation this
program is distributed in the hope that it will be useful but
without any warranty without even the implied warranty of
merchantability or fitness for a particular purpose see the gnu
general public license for more details
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 294 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190529141900.825281744@linutronix.de
Pull networking fixes from David Miller:
1) Clear up some recent tipc regressions because of registration
ordering. Fix from Junwei Hu.
2) tipc's TLV_SET() can read past the end of the supplied buffer during
the copy. From Chris Packham.
3) ptp example program doesn't match the kernel, from Richard Cochran.
4) Outgoing message type fix in qrtr, from Bjorn Andersson.
5) Flow control regression in stmmac, from Tan Tee Min.
6) Fix inband autonegotiation in phylink, from Russell King.
7) Fix sk_bound_dev_if handling in rawv6_bind(), from Mike Manning.
8) Fix usbnet crash after disconnect, from Kloetzke Jan.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (21 commits)
usbnet: fix kernel crash after disconnect
selftests: fib_rule_tests: use pre-defined DEV_ADDR
net-next: net: Fix typos in ip-sysctl.txt
ipv6: Consider sk_bound_dev_if when binding a raw socket to an address
net: phylink: ensure inband AN works correctly
usbnet: ipheth: fix racing condition
net: stmmac: dma channel control register need to be init first
net: stmmac: fix ethtool flow control not able to get/set
net: qrtr: Fix message type of outgoing packets
networking: : fix typos in code comments
ptp: Fix example program to match kernel.
fddi: fix typos in code comments
selftests: fib_rule_tests: enable forwarding before ipv4 from/iif test
selftests: fib_rule_tests: fix local IPv4 address typo
tipc: Avoid copying bytes beyond the supplied data
2/2] net: xilinx_emaclite: use readx_poll_timeout() in mdio wait function
1/2] net: axienet: use readx_poll_timeout() in mdio wait function
vlan: Mark expected switch fall-through
macvlan: Mark expected switch fall-through
net/mlx4_en: ethtool, Remove unsupported SFP EEPROM high pages query
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
QRTR packets has a message type in the header, which is repeated in the
control header. For control packets we therefor copy the type from
beginning of the outgoing payload and use that as message type.
For non-control messages an endianness fix introduced in v5.2-rc1 caused the
type to be 0, rather than QRTR_TYPE_DATA, causing all messages to be dropped by
the receiver. Fix this by converting and using qrtr_type, which will remain
QRTR_TYPE_DATA for non-control messages.
Fixes: 8f5e24514cbd ("net: qrtr: use protocol endiannes variable")
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
sparse was unable to verify endiannes correctness due to reassignment
from le32_to_cpu to the same variable - fix this warning up by providing
a proper __le32 type and initializing it. This is not actually fixing
any bug - rather just addressing the sparse warning.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
We currently have two levels of strict validation:
1) liberal (default)
- undefined (type >= max) & NLA_UNSPEC attributes accepted
- attribute length >= expected accepted
- garbage at end of message accepted
2) strict (opt-in)
- NLA_UNSPEC attributes accepted
Split out parsing strictness into four different options:
* TRAILING - check that there's no trailing data after parsing
attributes (in message or nested)
* MAXTYPE - reject attrs > max known type
* UNSPEC - reject attributes with NLA_UNSPEC policy entries
* STRICT_ATTRS - strictly validate attribute size
The default for future things should be *everything*.
The current *_strict() is a combination of TRAILING and MAXTYPE,
and is renamed to _deprecated_strict().
The current regular parsing has none of this, and is renamed to
*_parse_deprecated().
Additionally it allows us to selectively set one of the new flags
even on old policies. Notably, the UNSPEC flag could be useful in
this case, since it can be arranged (by filling in the policy) to
not be an incompatible userspace ABI change, but would then going
forward prevent forgetting attribute entries. Similar can apply
to the POLICY flag.
We end up with the following renames:
* nla_parse -> nla_parse_deprecated
* nla_parse_strict -> nla_parse_deprecated_strict
* nlmsg_parse -> nlmsg_parse_deprecated
* nlmsg_parse_strict -> nlmsg_parse_deprecated_strict
* nla_parse_nested -> nla_parse_nested_deprecated
* nla_validate_nested -> nla_validate_nested_deprecated
Using spatch, of course:
expression TB, MAX, HEAD, LEN, POL, EXT;
-nla_parse(TB, MAX, HEAD, LEN, POL, EXT)
+nla_parse_deprecated(TB, MAX, HEAD, LEN, POL, EXT)
expression NLH, HDRLEN, TB, MAX, POL, EXT;
-nlmsg_parse(NLH, HDRLEN, TB, MAX, POL, EXT)
+nlmsg_parse_deprecated(NLH, HDRLEN, TB, MAX, POL, EXT)
-nlmsg_parse_strict(NLH, HDRLEN, TB, MAX, POL, EXT)
+nlmsg_parse_deprecated_strict(NLH, HDRLEN, TB, MAX, POL, EXT)
expression TB, MAX, NLA, POL, EXT;
-nla_parse_nested(TB, MAX, NLA, POL, EXT)
+nla_parse_nested_deprecated(TB, MAX, NLA, POL, EXT)
expression START, MAX, POL, EXT;
-nla_validate_nested(START, MAX, POL, EXT)
+nla_validate_nested_deprecated(START, MAX, POL, EXT)
expression NLH, HDRLEN, MAX, POL, EXT;
-nlmsg_validate(NLH, HDRLEN, MAX, POL, EXT)
+nlmsg_validate_deprecated(NLH, HDRLEN, MAX, POL, EXT)
For this patch, don't actually add the strict, non-renamed versions
yet so that it breaks compile if I get it wrong.
Also, while at it, make nla_validate and nla_parse go down to a
common __nla_validate_parse() function to avoid code duplication.
Ultimately, this allows us to have very strict validation for every
new caller of nla_parse()/nlmsg_parse() etc as re-introduced in the
next patch, while existing things will continue to work as is.
In effect then, this adds fully strict validation for any new command.
The SIOCGSTAMP/SIOCGSTAMPNS ioctl commands are implemented by many
socket protocol handlers, and all of those end up calling the same
sock_get_timestamp()/sock_get_timestampns() helper functions, which
results in a lot of duplicate code.
With the introduction of 64-bit time_t on 32-bit architectures, this
gets worse, as we then need four different ioctl commands in each
socket protocol implementation.
To simplify that, let's add a new .gettstamp() operation in
struct proto_ops, and move ioctl implementation into the common
sock_ioctl()/compat_sock_ioctl_trans() functions that these all go
through.
We can reuse the sock_get_timestamp() implementation, but generalize
it so it can deal with both native and compat mode, as well as
timeval and timespec structures.
Acked-by: Stefan Schmidt <stefan@datenfreihafen.org>
Acked-by: Marc Kleine-Budde <mkl@pengutronix.de>
Link: https://lore.kernel.org/lkml/CAK8P3a038aDQQotzua_QtKGhq8O9n+rdiz2=WDCp82ys8eUT+A@mail.gmail.com/
Acked-by: Willem de Bruijn <willemb@google.com>
Patch series "Replace all open encodings for NUMA_NO_NODE", v3.
All these places for replacement were found by running the following
grep patterns on the entire kernel code. Please let me know if this
might have missed some instances. This might also have replaced some
false positives. I will appreciate suggestions, inputs and review.
1. git grep "nid == -1"
2. git grep "node == -1"
3. git grep "nid = -1"
4. git grep "node = -1"
This patch (of 2):
At present there are multiple places where invalid node number is
encoded as -1. Even though implicitly understood it is always better to
have macros in there. Replace these open encodings for an invalid node
number with the global macro NUMA_NO_NODE. This helps remove NUMA
related assumptions like 'invalid node' from various places redirecting
them to a common definition.
Link: http://lkml.kernel.org/r/1545127933-10711-2-git-send-email-anshuman.khandual@arm.com
Signed-off-by: Anshuman Khandual <anshuman.khandual@arm.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> [ixgbe]
Acked-by: Jens Axboe <axboe@kernel.dk> [mtip32xx]
Acked-by: Vinod Koul <vkoul@kernel.org> [dmaengine.c]
Acked-by: Michael Ellerman <mpe@ellerman.id.au> [powerpc]
Acked-by: Doug Ledford <dledford@redhat.com> [drivers/infiniband]
Cc: Joseph Qi <jiangqi903@gmail.com>
Cc: Hans Verkuil <hverkuil@xs4all.nl>
All the control messages broadcast to remote routers are using
QRTR_NODE_BCAST instead of using local router NODE ID which cause
the packets to be dropped on remote router due to invalid NODE ID.
Signed-off-by: Arun Kumar Neelakantam <aneela@codeaurora.org>
The broadcast node id should only be sent with the control port id.
The poll() changes were not well thought out, and completely
unexplained. They also caused a huge performance regression, because
"->poll()" was no longer a trivial file operation that just called down
to the underlying file operations, but instead did at least two indirect
calls.
Indirect calls are sadly slow now with the Spectre mitigation, but the
performance problem could at least be largely mitigated by changing the
"->get_poll_head()" operation to just have a per-file-descriptor pointer
to the poll head instead. That gets rid of one of the new indirections.
But that doesn't fix the new complexity that is completely unwarranted
for the regular case. The (undocumented) reason for the poll() changes
was some alleged AIO poll race fixing, but we don't make the common case
slower and more complex for some uncommon special case, so this all
really needs way more explanations and most likely a fundamental
redesign.
[ This revert is a revert of about 30 different commits, not reverted
individually because that would just be unnecessarily messy - Linus ]
Pull networking updates from David Miller:
1) Add Maglev hashing scheduler to IPVS, from Inju Song.
2) Lots of new TC subsystem tests from Roman Mashak.
3) Add TCP zero copy receive and fix delayed acks and autotuning with
SO_RCVLOWAT, from Eric Dumazet.
4) Add XDP_REDIRECT support to mlx5 driver, from Jesper Dangaard
Brouer.
5) Add ttl inherit support to vxlan, from Hangbin Liu.
6) Properly separate ipv6 routes into their logically independant
components. fib6_info for the routing table, and fib6_nh for sets of
nexthops, which thus can be shared. From David Ahern.
7) Add bpf_xdp_adjust_tail helper, which can be used to generate ICMP
messages from XDP programs. From Nikita V. Shirokov.
8) Lots of long overdue cleanups to the r8169 driver, from Heiner
Kallweit.
9) Add BTF ("BPF Type Format"), from Martin KaFai Lau.
10) Add traffic condition monitoring to iwlwifi, from Luca Coelho.
11) Plumb extack down into fib_rules, from Roopa Prabhu.
12) Add Flower classifier offload support to igb, from Vinicius Costa
Gomes.
13) Add UDP GSO support, from Willem de Bruijn.
14) Add documentation for eBPF helpers, from Quentin Monnet.
15) Add TLS tx offload to mlx5, from Ilya Lesokhin.
16) Allow applications to be given the number of bytes available to read
on a socket via a control message returned from recvmsg(), from
Soheil Hassas Yeganeh.
17) Add x86_32 eBPF JIT compiler, from Wang YanQing.
18) Add AF_XDP sockets, with zerocopy support infrastructure as well.
From Björn Töpel.
19) Remove indirect load support from all of the BPF JITs and handle
these operations in the verifier by translating them into native BPF
instead. From Daniel Borkmann.
20) Add GRO support to ipv6 gre tunnels, from Eran Ben Elisha.
21) Allow XDP programs to do lookups in the main kernel routing tables
for forwarding. From David Ahern.
22) Allow drivers to store hardware state into an ELF section of kernel
dump vmcore files, and use it in cxgb4. From Rahul Lakkireddy.
23) Various RACK and loss detection improvements in TCP, from Yuchung
Cheng.
24) Add TCP SACK compression, from Eric Dumazet.
25) Add User Mode Helper support and basic bpfilter infrastructure, from
Alexei Starovoitov.
26) Support ports and protocol values in RTM_GETROUTE, from Roopa
Prabhu.
27) Support bulking in ->ndo_xdp_xmit() API, from Jesper Dangaard
Brouer.
28) Add lots of forwarding selftests, from Petr Machata.
29) Add generic network device failover driver, from Sridhar Samudrala.
* ra.kernel.org:/pub/scm/linux/kernel/git/davem/net-next: (1959 commits)
strparser: Add __strp_unpause and use it in ktls.
rxrpc: Fix terminal retransmission connection ID to include the channel
net: hns3: Optimize PF CMDQ interrupt switching process
net: hns3: Fix for VF mailbox receiving unknown message
net: hns3: Fix for VF mailbox cannot receiving PF response
bnx2x: use the right constant
Revert "net: sched: cls: Fix offloading when ingress dev is vxlan"
net: dsa: b53: Fix for brcm tag issue in Cygnus SoC
enic: fix UDP rss bits
netdev-FAQ: clarify DaveM's position for stable backports
rtnetlink: validate attributes in do_setlink()
mlxsw: Add extack messages for port_{un, }split failures
netdevsim: Add extack error message for devlink reload
devlink: Add extack to reload and port_{un, }split operations
net: metrics: add proper netlink validation
ipmr: fix error path when ipmr_new_table fails
ip6mr: only set ip6mr_table from setsockopt when ip6mr_new_table succeeds
net: hns3: remove unused hclgevf_cfg_func_mta_filter
netfilter: provide udp*_lib_lookup for nf_tproxy
qed*: Utilize FW 8.37.2.0
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
This implements a misc character device named "qrtr-tun" for the purpose
of allowing user space applications to implement endpoints in the qrtr
network.
This allows more advanced (and dynamic) testing of the qrtr code as well
as opens up the ability of tunneling qrtr over a network or USB link.
To ensure that qrtr can be loaded automatically, when needed, if it is compiled
as module.
Signed-off-by: Nicolas Dechesne <nicolas.dechesne@linaro.org>
All of the conflicts were cases of overlapping changes.
In net/core/devlink.c, we have to make care that the
resouce size_params have become a struct member rather
than a pointer to such an object.
Added MODULE_ALIAS("rpmsg:IPCRTR") to ensure qrtr-smd and qrtr will load
when IPCRTR channel is detected.
Signed-off-by: Ramon Fried <rfried@codeaurora.org>
Changes since v1:
Added changes in these files:
drivers/infiniband/hw/usnic/usnic_transport.c
drivers/staging/lustre/lnet/lnet/lib-socket.c
drivers/target/iscsi/iscsi_target_login.c
drivers/vhost/net.c
fs/dlm/lowcomms.c
fs/ocfs2/cluster/tcp.c
security/tomoyo/network.c
Before:
All these functions either return a negative error indicator,
or store length of sockaddr into "int *socklen" parameter
and return zero on success.
"int *socklen" parameter is awkward. For example, if caller does not
care, it still needs to provide on-stack storage for the value
it does not need.
None of the many FOO_getname() functions of various protocols
ever used old value of *socklen. They always just overwrite it.
This change drops this parameter, and makes all these functions, on success,
return length of sockaddr. It's always >= 0 and can be differentiated
from an error.
Tests in callers are changed from "if (err)" to "if (err < 0)", where needed.
rpc_sockname() lost "int buflen" parameter, since its only use was
to be passed to kernel_getsockname() as &buflen and subsequently
not used in any way.
Userspace API is not changed.
30108430 2633624 873672 33615726 200ef6e vmlinux.before.o
30108109 2633612 873672 33615393 200ee21 vmlinux.o
Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com>
CC: David S. Miller <davem@davemloft.net>
CC: linux-kernel@vger.kernel.org
CC: netdev@vger.kernel.org
CC: linux-bluetooth@vger.kernel.org
CC: linux-decnet-user@lists.sourceforge.net
CC: linux-wireless@vger.kernel.org
CC: linux-rdma@vger.kernel.org
CC: linux-sctp@vger.kernel.org
CC: linux-nfs@vger.kernel.org
CC: linux-x25@vger.kernel.org
all of these can be compiled as a module, so use new
_module version to make sure module can no longer be removed
while callback/dump is in use.
Simple cases of overlapping changes in the packet scheduler.
Must easier to resolve this time.
Which probably means that I screwed it up somehow.
Registering qrtr with module_init makes the ability of typical platform
code to create AF_QIPCRTR socket during probe a matter of link order
luck. Moving qrtr to postcore_initcall() avoids this.
Files removed in 'net-next' had their license header updated
in 'net'. We take the remove from 'net-next'.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Add the necessary logic for decoding incoming messages of version 2 as
well. Also make sure there's room for the bigger of version 1 and 2
headers in the code allocating skbs for outgoing messages.
Rather than parsing the header of incoming messages throughout the
implementation do it once when we retrieve the message and store the
relevant information in the "cb" member of the sk_buff.
This allows us to, in a later commit, decode version 2 messages into
this same structure.
As the message header generation is deferred the internal functions for
generating control packets can be simplified.
This patch modifies qrtr_alloc_ctrl_packet() to, in addition to the
sk_buff, return a reference to a struct qrtr_ctrl_pkt, which clarifies
and simplifies the helpers to the point that these functions can be
folded back into the callers.
Defer writing the message header to the skb until its time to enqueue
the packet. As the receive path is reworked to decode the message header
as it's received from the transport and only pass around the payload in
the skb this change means that we do not have to fill out the full
message header just to decode it immediately in qrtr_local_enqueue().
In the future this change also makes it possible to prepend message
headers based on the version of each link.
The QMUX protocol specification defines structure of the special control
packet messages being sent between handlers of the control port.
Add these to the uapi header, as this structure and the associated types
are shared between the kernel and all userspace handlers of control
messages.
The constants are used by both the name server and clients, so clarify
their value and move them to the uapi header.
Rather than manually waking up any context sleeping on the sock to
signal an error we should call sk_error_report(). This has the added
benefit that in-kernel consumers can override this notification with
its own callback.
This change allows us to later indicate to rtnetlink core that certain
doit functions should be called without acquiring rtnl_mutex.
This change should have no effect, we simply replace the last (now
unused) calcit argument with the new flag.
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
There were many places that my previous spatch didn't find,
as pointed out by yuan linyu in various patches.
The following spatch found many more and also removes the
now unnecessary casts:
identifier p, p2;
expression len;
expression skb;
type t, t2;
+p = skb_put_zero(skb, len);
... when != p
p2 = (t2)p;
-memset(p2, 0, len);
-memset(p, 0, len);
type t, t2;
identifier p, p2;
expression skb;
t *p;
+p = skb_put_zero(skb, sizeof(t));
... when != p
p2 = (t2)p;
-memset(p2, 0, sizeof(*p));
-memset(p, 0, sizeof(*p));
expression skb, len;
-memset(skb_put(skb, len), 0, len);
+skb_put_zero(skb, len);
Apply it to the tree (with one manual fixup to keep the
comment in vxlan.c, which spatch removed.)
As the higher level communication only deals with "services" the
a service directory is required to keep track of local and remote
services. In order for qrtr clients to be informed about when the
service directory implementation is available some event needs to be
passed to them.
Rather than introducing support for broadcasting such a message in-band
to all open local sockets we flag each socket with ENETRESET, as there
are no other expected operations that would benefit from having support
from locally broadcasting messages.
Cc: Courtney Cavin <ccavin@gmail.com>
Per the QMUXv2 protocol specificiation a DEL_CLIENT message should be
broadcasted when an endpoint is disconnected.
The protocol specification does suggest that the router can keep track
of which nodes the endpoint has been communicating with to not wake up
sleeping remotes unecessarily, but implementation of this suggestion is
left for the future.
Per the QMUX protocol specification a terminating node can send a BYE
control message to signal that the link is going down, upon receiving
this all information about remote services should be discarded and local
clients should be notified.
In the event that the link was brought down abruptly the router is
supposed to act like a BYE message has arrived. As there is no harm in
receiving an extra BYE from the remote this patch implements the latter
by injecting a BYE when the link to the remote is unregistered.
The name service will receive the BYE and can implement the notification
to the local clients.
Extract the allocation and filling in the control message header fields
to a separate function in order to reuse this in subsequent patches.
Both conflict were simple overlapping changes.
In the kaweth case, Eric Dumazet's skb_cow() bug fix overlapped the
conversion of the driver in net-next to use in-netdev stats.
If skb_pad() fails then it frees the skb so we should check for errors.
Fixes: bdabad3e363d ("net: Add Qualcomm IPC router")
Add netlink_ext_ack arg to rtnl_doit_func. Pass extack arg to nlmsg_parse
for doit functions that call it directly.
This is the first step to using extended error reporting in rtnetlink.
>From here individual subsystems can be updated to set netlink_ext_ack as
needed.
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Pass the new extended ACK reporting struct to all of the generic
netlink parsing functions. For now, pass NULL in almost all callers
(except for some in the core.)
By moving these client drivers to use RPMSG instead of the direct SMD
API we can reuse them ontop of the newly added GLINK wire-protocol
support found in the 820 and 835 Qualcomm platforms.
As the new (RPMSG-based) and old SMD implementations are mutually
exclusive we have to change all client drivers in one commit, to make
sure we have a working system before and after this transition.
Acked-by: Andy Gross <andy.gross@linaro.org>
Acked-by: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Failure to mark this pointer as __le32 causes checkers like
sparse to complain:
net/qrtr/qrtr.c:274:16: warning: incorrect type in assignment (different base types)
net/qrtr/qrtr.c:274:16: expected unsigned int [unsigned] [usertype] <noident>
net/qrtr/qrtr.c:274:16: got restricted __le32 [usertype] <noident>
net/qrtr/qrtr.c:275:16: warning: incorrect type in assignment (different base types)
net/qrtr/qrtr.c:275:16: expected unsigned int [unsigned] [usertype] <noident>
net/qrtr/qrtr.c:275:16: got restricted __le32 [usertype] <noident>
net/qrtr/qrtr.c:276:16: warning: incorrect type in assignment (different base types)
net/qrtr/qrtr.c:276:16: expected unsigned int [unsigned] [usertype] <noident>
net/qrtr/qrtr.c:276:16: got restricted __le32 [usertype] <noident>
Silence it.
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Merge tag 'qcom-soc-for-4.7-2' into net-next
This merges the Qualcomm SOC tree with the net-next, solving the
merge conflict in the SMD API between the two.
Having multiple loadable modules with the same name cannot work
with modprobe, and having both net/qrtr/smd.ko and drivers/soc/qcom/smd.ko
results in a (somewhat cryptic) build error:
ERROR: "qcom_smd_driver_unregister" [net/qrtr/smd.ko] undefined!
ERROR: "qcom_smd_driver_register" [net/qrtr/smd.ko] undefined!
ERROR: "qcom_smd_set_drvdata" [net/qrtr/smd.ko] undefined!
ERROR: "qcom_smd_send" [net/qrtr/smd.ko] undefined!
ERROR: "qcom_smd_get_drvdata" [net/qrtr/smd.ko] undefined!
ERROR: "qcom_smd_driver_unregister" [drivers/soc/qcom/wcnss_ctrl.ko] undefined!
ERROR: "qcom_smd_driver_register" [drivers/soc/qcom/wcnss_ctrl.ko] undefined!
ERROR: "qcom_smd_set_drvdata" [drivers/soc/qcom/wcnss_ctrl.ko] undefined!
ERROR: "qcom_smd_send" [drivers/soc/qcom/wcnss_ctrl.ko] undefined!
ERROR: "qcom_smd_get_drvdata" [drivers/soc/qcom/wcnss_ctrl.ko] undefined!
Also, the qrtr driver uses the SMD interface and has a Kconfig dependency,
but also allows for compile-testing when SMD is disabled. However, if
with QCOM_SMD=m and COMPILE_TEST=y we can end up with QRTR_SMD=y and
that fails with a related link error.
The changes the dependency so we can still compile-test the driver but
not have it built-in if SMD is a module, to avoid running in the broken
configuration, and changes the Makefile to provide the driver under
a different module name.
Add an implementation of Qualcomm's IPC router protocol, used to
communicate with service providing remote processors.
Signed-off-by: Courtney Cavin <courtney.cavin@sonymobile.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
[bjorn: Cope with 0 being a valid node id and implement RTM_NEWADDR]
