path: root/net/rds/cong.c
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-23rds: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Andy Grover <andy.grover@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rds: stop including asm-generic/bitops/le.h directlyAkinobu Mita
asm-generic/bitops/le.h is only intended to be included directly from asm-generic/bitops/ext2-non-atomic.h or asm-generic/bitops/minix-le.h which implements generic ext2 or minix bit operations. This stops including asm-generic/bitops/le.h directly and use ext2 non-atomic bit operations instead. It seems odd to use ext2_*_bit() on rds, but it will replaced with __{set,clear,test}_bit_le() after introducing little endian bit operations for all architectures. This indirect step is necessary to maintain bisectability for some architectures which have their own little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Andy Grover <andy.grover@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-08RDS: Bypass workqueue when queueing cong updatesAndy Grover
Now that rds_send_xmit() does not block, we can call it directly instead of going through the helper thread. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: cleanup: remove "== NULL"s and "!= NULL"s in ptr comparisonsAndy Grover
Favor "if (foo)" style over "if (foo != NULL)". Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-16RDS: Fix congestion issues for loopbackAndy Grover
We have two kinds of loopback: software (via loop transport) and hardware (via IB). sw is used for 127.0.0.1, and doesn't support rdma ops. hw is used for sends to local device IPs, and supports rdma. Both are used in different cases. For both of these, when there is a congestion map update, we want to call rds_cong_map_updated() but not actually send anything -- since loopback local and foreign congestion maps point to the same spot, they're already in sync. The old code never called sw loop's xmit_cong_map(),so rds_cong_map_updated() wasn't being called for it. sw loop ports would not work right with the congestion monitor. Fixing that meant that hw loopback now would send congestion maps to itself. This is also undesirable (racy), so we check for this case in the ib-specific xmit code. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30RDS: Do not send congestion updates to loopback connectionsAndy Grover
This issue was discovered by HP's Pradeep and fixed in OFED 1.3, but not fixed in later versions, since the fix's implementation was not immediately applyable to the later code. This patch should do the trick for 1.4+ codebases. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23RDS: Export symbols from core RDSAndy Grover
Now that rdma and tcp transports will be modularized, we need to export a number of functions so they can call them. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02rds: Fix build on powerpc.David S. Miller
As reported by Stephen Rothwell. > Today's linux-next build (powerpc allyesconfig) failed like this: > > net/rds/cong.c: In function 'rds_cong_set_bit': > net/rds/cong.c:284: error: implicit declaration of function 'generic___set_le_bit' > net/rds/cong.c: In function 'rds_cong_clear_bit': > net/rds/cong.c:298: error: implicit declaration of function 'generic___clear_le_bit' > net/rds/cong.c: In function 'rds_cong_test_bit': > net/rds/cong.c:309: error: implicit declaration of function 'generic_test_le_bit' Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26RDS: Congestion-handling codeAndy Grover
RDS handles per-socket congestion by updating peers with a complete congestion map (8KB). This code keeps track of these maps for itself and ones received from peers. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
