path: root/net/rds/ib.c
2013-12-27rds: prevent dereference of a NULL deviceSasha Levin
Binding might result in a NULL device, which is dereferenced causing this BUG: [ 1317.260548] BUG: unable to handle kernel NULL pointer dereference at 000000000000097 4 [ 1317.261847] IP: [<ffffffff84225f52>] rds_ib_laddr_check+0x82/0x110 [ 1317.263315] PGD 418bcb067 PUD 3ceb21067 PMD 0 [ 1317.263502] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC [ 1317.264179] Dumping ftrace buffer: [ 1317.264774] (ftrace buffer empty) [ 1317.265220] Modules linked in: [ 1317.265824] CPU: 4 PID: 836 Comm: trinity-child46 Tainted: G W 3.13.0-rc4- next-20131218-sasha-00013-g2cebb9b-dirty #4159 [ 1317.267415] task: ffff8803ddf33000 ti: ffff8803cd31a000 task.ti: ffff8803cd31a000 [ 1317.268399] RIP: 0010:[<ffffffff84225f52>] [<ffffffff84225f52>] rds_ib_laddr_check+ 0x82/0x110 [ 1317.269670] RSP: 0000:ffff8803cd31bdf8 EFLAGS: 00010246 [ 1317.270230] RAX: 0000000000000000 RBX: ffff88020b0dd388 RCX: 0000000000000000 [ 1317.270230] RDX: ffffffff8439822e RSI: 00000000000c000a RDI: 0000000000000286 [ 1317.270230] RBP: ffff8803cd31be38 R08: 0000000000000000 R09: 0000000000000000 [ 1317.270230] R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000000 [ 1317.270230] R13: 0000000054086700 R14: 0000000000a25de0 R15: 0000000000000031 [ 1317.270230] FS: 00007ff40251d700(0000) GS:ffff88022e200000(0000) knlGS:000000000000 0000 [ 1317.270230] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 1317.270230] CR2: 0000000000000974 CR3: 00000003cd478000 CR4: 00000000000006e0 [ 1317.270230] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 1317.270230] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000090602 [ 1317.270230] Stack: [ 1317.270230] 0000000054086700 5408670000a25de0 5408670000000002 0000000000000000 [ 1317.270230] ffffffff84223542 00000000ea54c767 0000000000000000 ffffffff86d26160 [ 1317.270230] ffff8803cd31be68 ffffffff84223556 ffff8803cd31beb8 ffff8800c6765280 [ 1317.270230] Call Trace: [ 1317.270230] [<ffffffff84223542>] ? rds_trans_get_preferred+0x42/0xa0 [ 1317.270230] [<ffffffff84223556>] rds_trans_get_preferred+0x56/0xa0 [ 1317.270230] [<ffffffff8421c9c3>] rds_bind+0x73/0xf0 [ 1317.270230] [<ffffffff83e4ce62>] SYSC_bind+0x92/0xf0 [ 1317.270230] [<ffffffff812493f8>] ? context_tracking_user_exit+0xb8/0x1d0 [ 1317.270230] [<ffffffff8119313d>] ? trace_hardirqs_on+0xd/0x10 [ 1317.270230] [<ffffffff8107a852>] ? syscall_trace_enter+0x32/0x290 [ 1317.270230] [<ffffffff83e4cece>] SyS_bind+0xe/0x10 [ 1317.270230] [<ffffffff843a6ad0>] tracesys+0xdd/0xe2 [ 1317.270230] Code: 00 8b 45 cc 48 8d 75 d0 48 c7 45 d8 00 00 00 00 66 c7 45 d0 02 00 89 45 d4 48 89 df e8 78 49 76 ff 41 89 c4 85 c0 75 0c 48 8b 03 <80> b8 74 09 00 00 01 7 4 06 41 bc 9d ff ff ff f6 05 2a b6 c2 02 [ 1317.270230] RIP [<ffffffff84225f52>] rds_ib_laddr_check+0x82/0x110 [ 1317.270230] RSP <ffff8803cd31bdf8> [ 1317.270230] CR2: 0000000000000974 Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-31net: Fix files explicitly needing to include module.hPaul Gortmaker
With calls to modular infrastructure, these files really needs the full module.h header. Call it out so some of the cleanups of implicit and unrequired includes elsewhere can be cleaned up. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-25RDMA/cma: Pass QP type into rdma_create_id()Sean Hefty
The RDMA CM currently infers the QP type from the port space selected by the user. In the future (eg with RDMA_PS_IB or XRC), there may not be a 1-1 correspondence between port space and QP type. For netlink export of RDMA CM state, we want to export the QP type to userspace, so it is cleaner to explicitly associate a QP type to an ID. Modify rdma_create_id() to allow the user to specify the QP type, and use it to make our selections of datagram versus connected mode. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-02-01rds/ib: use system_wq instead of rds_ib_fmr_wqTejun Heo
With cmwq, there's no reason to use dedicated rds_ib_fmr_wq - it's not in the memory reclaim path and the maximum number of concurrent work items is bound by the number of devices. Drop it and use system_wq instead. This rds_ib_fmr_init/exit() noops. Both removed. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Andy Grover <andy.grover@oracle.com>
2010-10-21rds: make local functions/variables staticstephen hemminger
The RDS protocol has lots of functions that should be declared static. rds_message_get/add_version_extension is removed since it defined but never used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08RDS/IB: protect the list of IB devicesZach Brown
The RDS IB device list wasn't protected by any locking. Traversal in both the get_mr and FMR flushing paths could race with additon and removal. List manipulation is done with RCU primatives and is protected by the write side of a rwsem. The list traversal in the get_mr fast path is protected by a rcu read critical section. The FMR list traversal is more problematic because it can block while traversing the list. We protect this with the read side of the rwsem. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: remove __init and __exit annotationZach Brown
The trivial amount of memory saved isn't worth the cost of dealing with section mismatches. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: create a work queue for FMR flushingZach Brown
This patch moves the FMR flushing work in to its own mult-threaded work queue. This is to maintain performance in preparation for returning the main krdsd work queue back to a single threaded work queue to avoid deep-rooted concurrency bugs. This is also good because it further separates FMRs, which might be removed some day, from the rest of the code base. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: destroy connections on rmmodZach Brown
IB connections were not being destroyed during rmmod. First, recently IB device removal callback was changed to disconnect connections that used the removing device rather than destroying them. So connections with devices during rmmod were not being destroyed. Second, rds_ib_destroy_nodev_conns() was being called before connections are disassociated with devices. It would almost never find connections in the nodev list. We first get rid of rds_ib_destroy_conns(), which is no longer called, and refactor the existing caller into the main body of the function and get rid of the list and lock wrappers. Then we call rds_ib_destroy_nodev_conns() *after* ib_unregister_client() has removed the IB device from all the conns and put the conns on the nodev list. The result is that IB connections are destroyed by rmmod. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: wait for IB dev freeing work to finish during rmmodZach Brown
The RDS IB client removal callback can queue work to drop the final reference to an IB device. We have to make sure that this function has returned before we complete rmmod or the work threads can try to execute freed code. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: disconnect when IB devices are removedZach Brown
Currently IB device removal destroys connections which are associated with the device. This prevents connections from being re-established when replacement devices are added. Instead we'll queue shutdown work on the connections as their devices are removed. When we see that devices are added we triger connection attempts on all connections that don't currently have a device. The result is that RDS sockets can resume device-independent work (bcopy, not RDMA) across IB device removal and restoration. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: add refcount tracking to struct rds_ib_deviceZach Brown
The RDS IB client .remove callback used to free the rds_ibdev for the given device unconditionally. This could race other users of the struct. This patch adds refcounting so that we only free the rds_ibdev once all of its users are done. Many rds_ibdev users are tied to connections. We give the connection a reference and change these users to reference the device in the connection instead of looking it up in the IB client data. The only user of the IB client data remaining is the first lookup of the device as connections are built up. Incrementing the reference count of a device found in the IB client data could race with final freeing so we use an RCU grace period to make sure that freeing won't happen until those lookups are done. MRs need the rds_ibdev to get at the pool that they're freed in to. They exist outside a connection and many MRs can reference different devices from one socket, so it was natural to have each MR hold a reference. MR refs can be dropped from interrupt handlers and final device teardown can block so we push it off to a work struct. Pool teardown had to be fixed to cancel its pending work instead of deadlocking waiting for all queued work, including itself, to finish. MRs get their reference from the global device list, which gets a reference. It is left unprotected by locks and remains racy. A simple global lock would be a significant bottleneck. More scalable (complicated) locking should be done carefully in a later patch. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: add _to_node() macros for numa and use {k,v}malloc_node()Andy Grover
Allocate send/recv rings in memory that is node-local to the HCA. This significantly helps performance. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08rds: rcu-ize rds_ib_get_device()Chris Mason
rds_ib_get_device is called very often as we turn an ip address into a corresponding device structure. It currently take a global spinlock as it walks different lists to find active devices. This commit changes the lists over to RCU, which isn't very complex because they are not updated very often at all. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-09-08RDS: Stop supporting old cong map sending methodAndy Grover
We now ask the transport to give us a rm for the congestion map, and then we handle it normally. Previously, the transport defined a function that we would call to send a congestion map. Convert TCP and loop transports to new cong map method. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: inc_purge() transport function unused - remove itAndy Grover
2010-09-08RDS: Base init_depth and responder_resources on hw valuesAndy Grover
Instead of using a constant for initiator_depth and responder_resources, read the per-QP values when the device is enumerated, and then use these values when creating the connection. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: Implement atomic operationsAndy Grover
Implement a CMSG-based interface to do FADD and CSWP ops. Alter send routines to handle atomic ops. Add atomic counters to stats. Add xmit_atomic() to struct rds_transport Inline rds_ib_send_unmap_rdma into unmap_rm Signed-off-by: Andy Grover <andy.grover@oracle.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-19RDMA/cm: fix loopback address supportSean Hefty
The RDMA CM is intended to support the use of a loopback address when establishing a connection; however, the behavior of the CM when loopback addresses are used is confusing and does not always work, depending on whether loopback was specified by the server, the client, or both. The defined behavior of rdma_bind_addr is to associate an RDMA device with an rdma_cm_id, as long as the user specified a non- zero address. (ie they weren't just trying to reserve a port) Currently, if the loopback address is passed to rdam_bind_addr, no device is associated with the rdma_cm_id. Fix this. If a loopback address is specified by the client as the destination address for a connection, it will fail to establish a connection. This is true even if the server is listing across all addresses or on the loopback address itself. The issue is that the server tries to translate the IP address carried in the REQ message to a local net_device address, which fails. The translation is not needed in this case, since the REQ carries the actual HW address that should be used. Finally, cleanup loopback support to be more transport neutral. Replace separate calls to get/set the sgid and dgid from the device address to a single call that behaves correctly depending on the format of the device address. And support both IPv4 and IPv6 address formats. Signed-off-by: Sean Hefty <sean.hefty@intel.com> [ Fixed RDS build by s/ib_addr_get/rdma_addr_get/ - Roland ] Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-08-23RDS: Track transports via an array, not a listAndy Grover
Now that transports can be loaded in arbitrary order, it is important for rds_trans_get_preferred() to look for them in a particular order, instead of walking the list until it finds a transport that works for a given address. Now, each transport registers for a specific transport slot, and these are ordered so that preferred transports come first, and then if they are not loaded, other transports are queried. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-20RDS/IB: Always use PAGE_SIZE for FMR page sizeAndy Grover
While FMRs allow significant flexibility in what size of pages they can use, we really just want FMR pages to match CPU page size. Roland says we can count on this always being supported, so this simplifies things. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-20RDS: Set retry_count to 2 and make modifiable via modparamAndy Grover
This will be default cause IB connections to failover faster, but allow a longer retry count to be used if desired. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-09ERR_PTR() dereference in net/rds/ib.cDan Carpenter
rdma_create_id() doesn't return NULL, only ERR_PTR(). Found by smatch (http://repo.or.cz/w/smatch.git). Compile tested. regards, dan carpenter Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-02RDS: Rewrite connection cleanup, fixing oops on rmmodAndy Grover
This fixes a bug where a connection was unexpectedly not on *any* list while being destroyed. It also cleans up some code duplication and regularizes some function names. * Grab appropriate lock in conn_free() and explain in comment * Ensure via locking that a conn is never not on either a dev's list or the nodev list * Add rds_xx_remove_conn() to match rds_xx_add_conn() * Make rds_xx_add_conn() return void * Rename remove_{,nodev_}conns() to destroy_{,nodev_}conns() and unify their implementation in a helper function * Document lock ordering as nodev conn_lock before dev_conn_lock Reported-by: Yosef Etigin <yosefe@voltaire.com> Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26RDS/IB: Infiniband transportAndy Grover
Registers as an RDS transport and an IB client, and uses IB CM API to allocate ids, queue pairs, and the rest of that fun stuff. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
