path: root/net/rds/rdma_transport.c
2010-10-21rds: make local functions/variables staticstephen hemminger
The RDS protocol has lots of functions that should be declared static. rds_message_get/add_version_extension is removed since it defined but never used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08RDS/IB: print string constants in more placesZach Brown
This prints the constant identifier for work completion status and rdma cm event types, like we already do for IB event types. A core string array helper is added that each string type uses. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: remove __init and __exit annotationZach Brown
The trivial amount of memory saved isn't worth the cost of dealing with section mismatches. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-04-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e100.c drivers/net/e1000e/netdev.c
2010-04-22rdma: potential ERR_PTR dereferenceDan Carpenter
In the original code, the "goto out" calls "rdma_destroy_id(cm_id);" That isn't needed here and would cause problems because "cm_id" is an ERR_PTR. The new code just returns directly. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: Turn down alarming reconnect messagesAndy Grover
RDS's error messages when a connection goes down are a little extreme. A connection may go down, and it will be re-established, and everything is fine. This patch links these messages through rdsdebug(), instead of to printk directly. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: Do not BUG() on error returned from ib_post_sendAndy Grover
BUGging on a runtime error code should be avoided. This patch also eliminates all other BUG()s that have no real reason to exist. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23RDS: Modularize RDMA and TCP transportsAndy Grover
Enable the building of transports as modules. Also, improve consistency of Kconfig messages in relation to other protocols, and move build dependency on IB from the RDS core code to the rds_rdma module. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net/rds: Use AF_INET for sin_family fieldJulia Lawall
Elsewhere the sin_family field holds a value with a name of the form AF_..., so it seems reasonable to do so here as well. Also the values of PF_INET and AF_INET are the same. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ struct sockaddr_in sip; @@ ( sip.sin_family == - PF_INET + AF_INET | sip.sin_family != - PF_INET + AF_INET | sip.sin_family = - PF_INET + AF_INET ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-20RDS/RDMA: Fix cut-n-paste errors in printks in rdma_transport.cAndy Grover
2009-04-09RDS: Correct some iw references in rdma_transport.cAndy Grover
Had some lingering instances of _iw_ variable names from when the listen code was centralized into rdma_transport.c Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26RDS: Common RDMA transport codeAndy Grover
Although most of IB and iWARP are separated from each other, there is some common code required to handle their shared CM listen port. This code listens for CM events and then dispatches the event to the appropriate transport, either IB or iWARP. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
