path: root/net/rfkill
2011-11-30rfkill: Introduce CONFIG_RFKILL_PM and use instead of CONFIG_PM to power downNick Pelly
Some platforms do not want to power down rfkill devices on suspend. Change-Id: I62a11630521c636d54a4a02ab9037a43435925f5 Signed-off-by: Nick Pelly <npelly@google.com>
2011-05-19net: rfkill: add generic gpio rfkill driverRhyland Klein
This adds a new generic gpio rfkill driver to support rfkill switches which are controlled by gpios. The driver also supports passing in data about the clock for the radio, so that when rfkill is blocking, it can disable the clock. This driver assumes platform data is passed from the board files to configure it for specific devices. Original-patch-by: Anantha Idapalapati <aidapalapati@nvidia.com> Signed-off-by: Rhyland Klein <rklein@nvidia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16net/rfkill/core.c: Avoid leaving freed data in a listJulia Lawall
The list_for_each_entry loop can fail, in which case the list element is not removed from the list rfkill_fds. Since this list is not accessed by the loop, the addition of &data->list into the list is just moved after the loop. The sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E,E1,E2; identifier l; @@ *list_add(&E->l,E1); ... when != E1 when != list_del(&E->l) when != list_del_init(&E->l) when != E = E2 *kfree(E);// </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-19rfkill: Regulator consumer driver for rfkillAntonio Ospite
Add a regulator consumer driver for rfkill to enable controlling radio transmitters connected to voltage regulators using the regulator framework. A new "vrfkill" virtual supply is provided to use in platform code. Signed-off-by: Guiming Zhuo <gmzhuo@gmail.com> Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-15rfkill: remove dead codeStephen Hemminger
The following code is defined but never used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-19rename new rfkill sysfs knobsflorian@mickler.org
This patch renames the (never officially released) sysfs-knobs "blocked_hw" and "blocked_sw" to "hard" and "soft", as the hardware vs software conotation is misleading. It also gets rid of not needed locks around u32-read-access. Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10enhance sysfs rfkill interfaceflorian@mickler.org
This commit introduces two new sysfs knobs. /sys/class/rfkill/rfkill[0-9]+/blocked_hw: (ro) hardblock kill state /sys/class/rfkill/rfkill[0-9]+/blocked_sw: (rw) softblock kill state Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-02rfkill: Add support for KEY_RFKILLMatthew Garrett
Add support for handling KEY_RFKILL in the rfkill input module. This simply toggles the state of all rfkill devices. The comment in rfkill.h is also updated to reflect that RFKILL_TYPE_ALL may be used inside the kernel. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-07net/rfkill/core.c: work around gcc-4.0.2 sillinessAndrew Morton
net/rfkill/core.c: In function 'rfkill_type_show': net/rfkill/core.c:610: warning: control may reach end of non-void function 'rfkill_get_type_str' being inlined A gcc bug, but simple enough to squish. Cc: John W. Linville <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-29Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/ieee802154/fakehard.c drivers/net/e1000e/ich8lan.c drivers/net/e1000e/phy.c drivers/net/netxen/netxen_nic_init.c drivers/net/wireless/ath/ath9k/main.c
2009-11-23Merge branch 'master' of ↵David S. Miller
2009-11-23rfkill: fix miscdev opsJohannes Berg
The /dev/rfkill ops don't refer to the module, so it is possible to unload the module while file descriptors are open. Fix this oversight. Reported-by: Maxim Levitsky <maximlevitsky@gmail.com> Cc: stable@kernel.org Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-18rfkill: Add constant for RFKILL_TYPE_FM radio devicesMarcel Holtmann
Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Janakiram Sistla <janakiram.sistla@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-04headers: remove sched.h from poll.hAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-04rfkill: add the GPS radio typeTomas Winkler
Althoug GPS is a technology w/o transmitting radio and thus not a primary candidate for rfkill switch, rfkill gives unified interface point for devices with wireless technology. The input key is not supplied as it is too be deprecated. Cc: johannes@sipsolutions.net Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-23Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwmc3200wifi/netdev.c net/wireless/scan.c
2009-07-21rfkill: fix rfkill_set_states() to set the hw stateAlan Jenkins
The point of this function is to set the software and hardware state at the same time. When I tried to use it, I found it was only setting the software state. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-21rfkill: allow toggling soft state in sysfs againJohannes Berg
Apparently there actually _are_ tools that try to set this in sysfs even though it wasn't supposed to be used this way without claiming first. Guess what: now that I've cleaned it all up it doesn't matter and we can simply allow setting the soft-block state in sysfs. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Tested-By: Darren Salt <linux@youmustbejoking.demon.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10rfkill: prep for rfkill API changesJohannes Berg
We've designed the /dev/rfkill API in a way that we can increase the event struct by adding members at the end, should it become necessary. To validate the events, userspace and the kernel need to have the proper event size to check for -- when reading from the other end they need to verify that it's at least version 1 of the event API, with the current struct size, so define a constant for that and make the code a little more 'future proof'. Not that I expect that we'll have to change the event size any time soon, but it's better to write the code in a way that lends itself to extending. Due to the current size of the event struct, the code is currently equivalent, but should the event struct ever need to be increased the new code might not need changing. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19rfkill: export persistent attribute in sysfsAlan Jenkins
This information allows userspace to implement a hybrid policy where it can store the rfkill soft-blocked state in platform non-volatile storage if available, and if not then file-based storage can be used. Some users prefer platform non-volatile storage because of the behaviour when dual-booting multiple versions of Linux, or if the rfkill setting is changed in the BIOS setting screens, or if the BIOS responds to wireless-toggle hotkeys itself before the relevant platform driver has been loaded. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19rfkill: don't restore software blocked state on persistent devicesAlan Jenkins
The setting of the "persistent" flag is also made more explicit using a new rfkill_init_sw_state() function, instead of special-casing rfkill_set_sw_state() when it is called before registration. Suspend is a bit of a corner case so we try to get away without adding another hack to rfkill-input - it's going to be removed soon. If the state does change over suspend, users will simply have to prod rfkill-input twice in order to toggle the state. Userspace policy agents will be able to implement a more consistent user experience. For example, they can avoid the above problem if they toggle devices individually. Then there would be no "global state" to get out of sync. Currently there are only two rfkill drivers with persistent soft-blocked state. thinkpad-acpi already checks the software state on resume. eeepc-laptop will require modification. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> CC: Marcel Holtmann <marcel@holtmann.org> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19rfkill: rfkill_set_block() when suspended nitpickAlan Jenkins
If we return after fiddling with the state, userspace will see the wrong state and rfkill_set_sw_state() won't work until the next call to rfkill_set_block(). At the moment rfkill_set_block() will always be called from rfkill_resume(), but this will change in future. Also, presumably the point of this test is to avoid bothering devices which may be suspended. If we don't want to call set_block(), we probably don't want to call query() either :-). Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10rfkill: don't impose global states on resume (just restore the previous states)Alan Jenkins
Once rfkill-input is disabled, the "global" states will only be used as default initial states. Since the states will always be the same after resume, we shouldn't generate events on resume. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10rfkill: remove set_global_sw_stateAlan Jenkins
rfkill_set_global_sw_state() (previously rfkill_set_default()) will no longer be exported by the rewritten rfkill core. Instead, platform drivers which can provide persistent soft-rfkill state across power-down/reboot should indicate their initial state by calling rfkill_set_sw_state() before registration. Otherwise, they will be initialized to a default value during registration by a set_block call. We remove existing calls to rfkill_set_sw_state() which happen before registration, since these had no effect in the old model. If these drivers do have persistent state, the calls can be put back (subject to testing :-). This affects hp-wmi and acer-wmi. Drivers with persistent state will affect the global state only if rfkill-input is enabled. This is required, otherwise booting with wireless soft-blocked and pressing the wireless-toggle key once would have no apparent effect. This special case will be removed in future along with rfkill-input, in favour of a more flexible userspace daemon (see Documentation/feature-removal-schedule.txt). Now rfkill_global_states[n].def is only used to preserve global states over EPO, it is renamed to ".sav". Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10rfkill: remove input KconfigJohannes Berg
Now that we added the ioctl, there's no need to ask the user to configure this. We will keep it enabled for now, and eventually swap the default to n. Also let embedded users select it only if they need it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10rfkill: print events when input handler is disabled/enabledJohannes Berg
It is useful for debugging when we know if something disabled the in-kernel rfkill input handler. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: always init poll delayed workJohannes Berg
The rfkill core didn't initialise the poll delayed work because it assumed that polling was always done by specifying the poll function. cfg80211, however, would like to start polling only later, which is a valid use case and easy to support, so change rfkill to always initialise the poll delayed work and thus allow starting polling by calling the rfkill_resume_polling() function after registration. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: add function to query stateJohannes Berg
Sometimes it is necessary to know how the state is, and it is easier to query rfkill than keep track of it somewhere else, so add a function for that. This could later be expanded to return hard/soft block, but so far that isn't necessary. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: create useful userspace interfaceJohannes Berg
The new code added by this patch will make rfkill create a misc character device /dev/rfkill that userspace can use to control rfkill soft blocks and get status of devices as well as events when the status changes. Using it is very simple -- when you open it you can read a number of times to get the initial state, and every further read blocks (you can poll) on getting the next event from the kernel. The same structure you read is also used when writing to it to change the soft block of a given device, all devices of a given type, or all devices. This also makes CONFIG_RFKILL_INPUT selectable again in order to be able to test without it present since its functionality can now be replaced by userspace entirely and distros and users may not want the input part of rfkill interfering with their userspace code. We will also write a userspace daemon to handle all that and consequently add the input code to the feature removal schedule. In order to have rfkilld support both kernels with and without CONFIG_RFKILL_INPUT (or new kernels after its eventual removal) we also add an ioctl (that only exists if rfkill-input is present) to disable rfkill-input. It is not very efficient, but at least gives the correct behaviour in all cases. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: rewriteJohannes Berg
This patch completely rewrites the rfkill core to address the following deficiencies: * all rfkill drivers need to implement polling where necessary rather than having one central implementation * updating the rfkill state cannot be done from arbitrary contexts, forcing drivers to use schedule_work and requiring lots of code * rfkill drivers need to keep track of soft/hard blocked internally -- the core should do this * the rfkill API has many unexpected quirks, for example being asymmetric wrt. alloc/free and register/unregister * rfkill can call back into a driver from within a function the driver called -- this is prone to deadlocks and generally should be avoided * rfkill-input pointlessly is a separate module * drivers need to #ifdef rfkill functions (unless they want to depend on or select RFKILL) -- rfkill should provide inlines that do nothing if it isn't compiled in * the rfkill structure is not opaque -- drivers need to initialise it correctly (lots of sanity checking code required) -- instead force drivers to pass the right variables to rfkill_alloc() * the documentation is hard to read because it always assumes the reader is completely clueless and contains way TOO MANY CAPS * the rfkill code needlessly uses a lot of locks and atomic operations in locked sections * fix LED trigger to actually change the LED when the radio state changes -- this wasn't done before Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> [thinkpad] Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06net/rfkill/rfkill.c: fix build with CONFIG_RFKILL_LEDS=nAndrew Morton
net/rfkill/rfkill.c: In function 'update_rfkill_state': net/rfkill/rfkill.c:99: error: implicit declaration of function 'rfkill_led_trigger' Caused by : commit 492301fb5d12e4a77a1010ad2b6f1ed306014123 : Author: Larry Finger <Larry.Finger@lwfinger.net> : Date: Thu Apr 9 22:14:19 2009 -0500 : : rfkill: Fix broken rfkill LED in 2.6.30-rc1 Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Ivo van Doorn <IvDoorn@gmail.com> Cc: Michael Buesch <mb@bu3sch.de> Cc: David S. Miller <davem@davemloft.net> Cc: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22rfkill: Fix broken rfkill LED in 2.6.30-rc1Larry Finger
The rfkill system fails to issue a LED trigger event when the rfkill state changes. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22rfkill-input: remove unused codeJohannes Berg
There's a lot of rfkill-input code that cannot ever be compiled and is useless until somebody needs and tests it -- therefore remove it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22rfkill: remove user_claim stuffJohannes Berg
Almost all drivers do not support user_claim, so remove it completely and always report -EOPNOTSUPP to userspace. Since userspace cannot really drive rfkill _anyway_ (due to the odd restrictions imposed by the documentation) having this code is just pointless. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-04net/rfkill/rfkill.c: fix unused rfkill_led_trigger() warningSimon Holm Thøgersen
commit 4dec9b807be757780ca3611a959ac22c28d292a7 ("rfkill: strip pointless notifier chain") removed the only user of rfkill_led_trigger() that was not guarded by #ifdef CONFIG_RFKILL_LEDS. Therefore, move rfkill_led_trigger() completely inside #ifdef CONFIG_RFKILL_LEDS and avoid the compile time warning: net/rfkill/rfkill.c:59: warning: 'rfkill_led_trigger' defined but not used Signed-off-by: Simon Holm Thøgersen <odie@cs.aau.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12rfkill: strip pointless notifier chainJohannes Berg
No users, so no reason to have it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-26rfkill: always call get_state() hook on resumeHenrique de Moraes Holschuh
We "optimize" away the get_state() hook call on rfkill_toggle_radio when doing a forced state change. This means the resume path is not calling get_state() as it should. Call it manually on the resume handler, as we don't want to mess with the EPO path by removing the optimization. This has the added benefit of making it explicit that rfkill->state could have been modified before we hit the rfkill_toggle_radio() call in the class resume handler. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-26rfkill: preserve state across suspendHenrique de Moraes Holschuh
The rfkill class API requires that the driver connected to a class call rfkill_force_state() on resume to update the real state of the rfkill controller, OR that it provides a get_state() hook. This means there is potentially a hidden call in the resume code flow that changes rfkill->state (i.e. rfkill_force_state()), so the previous state of the transmitter was being lost. The simplest and most future-proof way to fix this is to explicitly store the pre-sleep state on the rfkill structure, and restore from that on resume. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-10net: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath5k/base.c net/8021q/vlan_core.c
2008-11-06Fix logic error in rfkill_check_duplicityJonathan McDowell
> I'll have a prod at why the [hso] rfkill stuff isn't working next Ok, I believe this is due to the addition of rfkill_check_duplicity in rfkill and the fact that test_bit actually returns a negative value rather than the postive one expected (which is of course equally true). So when the second WLAN device (the hso device, with the EEE PC WLAN being the first) comes along rfkill_check_duplicity returns a negative value and so rfkill_register returns an error. Patch below fixes this for me. Signed-Off-By: Jonathan McDowell <noodles@earth.li> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31rfkill: rate-limit rfkill-input workqueue usage (v3)Henrique de Moraes Holschuh
Limit the number of "expensive" rfkill workqueue operations per second, in order to not hog system resources too much when faced with a rogue source of rfkill input events. The old rfkill-input code (before it was refactored) had such a limit in place. It used to drop new events that were past the rate limit. This behaviour was not implemented as an anti-DoS measure, but rather as an attempt to work around deficiencies in input device drivers which would issue multiple KEY_FOO events too soon for a given key FOO (i.e. ones that do not implement mechanical debouncing properly). However, we can't really expect such issues to be worked around by every input handler out there, and also by every userspace client of input devices. It is the input device driver's responsability to do debouncing instead of spamming the input layer with bogus events. The new limiter code is focused only on anti-DoS behaviour, and tries to not lose events (instead, it coalesces them when possible). The transmitters are updated once every 200ms, maximum. Care is taken not to delay a request to _enter_ rfkill transmitter Emergency Power Off (EPO) mode. If mistriggered (e.g. by a jiffies counter wrap), the code delays processing *once* by 200ms. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Ivo van Doorn <IvDoorn@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31rfkill: honour EPO state when resuming a rfkill controllerHenrique de Moraes Holschuh
rfkill_resume() would always restore the rfkill controller state to its pre-suspend state. Now that we know when we are under EPO, kick the rfkill controller to SOFT_BLOCKED state instead of to its pre-suspend state when it is resumed while EPO mode is active. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31rfkill: add master_switch_mode and EPO lock to rfkill and rfkill-inputHenrique de Moraes Holschuh
Add of software-based sanity to rfkill and rfkill-input so that it can reproduce what hardware-based EPO switches do, blocking all transmitters and locking down any further attempts to unblock them until the switch is deactivated. rfkill-input is responsible for issuing the EPO control requests, like before. While an rfkill EPO is active, all transmitters are locked to one of the BLOCKED states and all attempts to change that through the rfkill API (userspace and kernel) will be either ignored or return -EPERM errors. The lock will be released upon receipt of EV_SW SW_RFKILL_ALL ON by rfkill-input, or should modular rfkill-input be unloaded. This makes rfkill and rfkill-input extend the operation of an existing wireless master kill switch to all wireless devices in the system, even those that are not under hardware or firmware control. Since the above is the expected operational behavior for the master rfkill switch, the EPO lock functionality is not optional. Also, extend rfkill-input to allow for three different behaviors when it receives an EV_SW SW_RFKILL_ALL ON input event. The user can set which behavior he wants through the master_switch_mode parameter: master_switch_mode = 0: EV_SW SW_RFKILL_ALL ON just unlocks rfkill controller state changes (so that the rfkill userspace and kernel APIs can now be used to change rfkill controller states again), but doesn't change any of their states (so they will all remain blocked). This is the safest mode of operation, as it requires explicit operator action to re-enable a transmitter. master_switch_mode = 1: EV_SW SW_RFKILL_ALL ON causes rfkill-input to attempt to restore the system to the state before the last EV_SW SW_RFKILL_ALL OFF event, or to the default global states if no EV_SW SW_RFKILL_ALL OFF ever happened. This is the recommended mode of operation for laptops. master_switch_mode = 2: tries to unblock all rfkill controllers (i.e. enable all transmitters) when an EV_SW SW_RFKILL_ALL ON event is received. This is the default mode of operation, as it mimics the previous behavior of rfkill-input. In order to implement these features in a clean way, the entire event handling of rfkill-input was refactored into a single worker function. Protection against input event DoS (repeatedly firing rfkill events for rfkill-input to process) was removed during the code refactoring. It will be added back in a future patch. Note that with these changes, rfkill-input doesn't need to explicitly handle any radio types for which KEY_<radio type> or SW_<radio type> events do not exist yet. Code to handle EV_SW SW_{WLAN,WWAN,BLUETOOTH,WIMAX,...} was added as it might be needed in the future (and its implementation is not that obvious), but is currently #ifdef'd out to avoid wasting resources. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Ivo van Doorn <IvDoorn@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: John W. Linville <linville@tuxdriver.com>
