path: root/net/rxrpc/ar-error.c
2015-03-08ip: fix error queue empty skb handlingWillem de Bruijn
When reading from the error queue, msg_name and msg_control are only populated for some errors. A new exception for empty timestamp skbs added a false positive on icmp errors without payload. `traceroute -M udpconn` only displayed gateways that return payload with the icmp error: the embedded network headers are pulled before sock_queue_err_skb, leaving an skb with skb->len == 0 otherwise. Fix this regression by refining when msg_name and msg_control branches are taken. The solutions for the two fields are independent. msg_name only makes sense for errors that configure serr->port and serr->addr_offset. Test the first instead of skb->len. This also fixes another issue. saddr could hold the wrong data, as serr->addr_offset is not initialized in some code paths, pointing to the start of the network header. It is only valid when serr->port is set (non-zero). msg_control support differs between IPv4 and IPv6. IPv4 only honors requests for ICMP and timestamps with SOF_TIMESTAMPING_OPT_CMSG. The skb->len test can simply be removed, because skb->dev is also tested and never true for empty skbs. IPv6 honors requests for all errors aside from local errors and timestamps on empty skbs. In both cases, make the policy more explicit by moving this logic to a new function that decides whether to process msg_control and that optionally prepares the necessary fields in skb->cb[]. After this change, the IPv4 and IPv6 paths are more similar. The last case is rxrpc. Here, simply refine to only match timestamps. Fixes: 49ca0d8bfaf3 ("net-timestamp: no-payload option") Reported-by: Jan Niehusmann <jan@gondor.com> Signed-off-by: Willem de Bruijn <willemb@google.com> ---- Changes v1->v2 - fix local origin test inversion in ip6_datagram_support_cmsg - make v4 and v6 code paths more similar by introducing analogous ipv4_datagram_support_cmsg - fix compile bug in rxrpc Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-02net-timestamp: no-payload optionWillem de Bruijn
Add timestamping option SOF_TIMESTAMPING_OPT_TSONLY. For transmit timestamps, this loops timestamps on top of empty packets. Doing so reduces the pressure on SO_RCVBUF. Payload inspection and cmsg reception (aside from timestamps) are no longer possible. This works together with a follow on patch that allows administrators to only allow tx timestamping if it does not loop payload or metadata. Signed-off-by: Willem de Bruijn <willemb@google.com> ---- Changes (rfc -> v1) - add documentation - remove unnecessary skb->len test (thanks to Richard Cochran) Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-01sock: deduplicate errqueue dequeueWillem de Bruijn
sk->sk_error_queue is dequeued in four locations. All share the exact same logic. Deduplicate. Also collapse the two critical sections for dequeue (at the top of the recv handler) and signal (at the bottom). This moves signal generation for the next packet forward, which should be harmless. It also changes the behavior if the recv handler exits early with an error. Previously, a signal for follow-up packets on the errqueue would then not be scheduled. The new behavior, to always signal, is arguably a bug fix. For rxrpc, the change causes the same function to be called repeatedly for each queued packet (because the recv handler == sk_error_report). It is likely that all packets will fail for the same reason (e.g., memory exhaustion). This code runs without sk_lock held, so it is not safe to trust that sk->sk_err is immutable inbetween releasing q->lock and the subsequent test. Introduce int err just to avoid this potential race. Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-26af_rxrpc: Fix UDP MTU calculation from ICMP_FRAG_NEEDEDDavid Howells
AF_RXRPC sends UDP packets with the "Don't Fragment" bit set in an attempt to determine the maximum packet size between the local socket and the peer by invoking the generation of ICMP_FRAG_NEEDED packets. Once a packet is sent with the "Don't Fragment" bit set, it is then inconvenient to break it up as that requires recalculating all the rxrpc serial and sequence numbers and reencrypting all the fragments, so we switch off the "Don't Fragment" service temporarily and send the bounced packet again. Future packets then use the new MTU. That's all fine. The problem lies in rxrpc_UDP_error_report() where the code that deals with ICMP_FRAG_NEEDED packets lives. Packets of this type have a field (ee_info) to indicate the maximum packet size at the reporting node - but sometimes ee_info isn't filled in and is just left as 0 and the code must allow for this. When ee_info is 0, the code should take the MTU size we're currently using and reduce it for the next packet we want to send. However, it takes ee_info (which is known to be 0) and tries to reduce that instead. This was discovered by Coverity. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2012-06-11ipv4: Kill ip_rt_frag_needed().David S. Miller
There is zero point to this function. It's only real substance is to perform an extremely outdated BSD4.2 ICMP check, which we can safely remove. If you really have a MTU limited link being routed by a BSD4.2 derived system, here's a nickel go buy yourself a real router. The other actions of ip_rt_frag_needed(), checking and conditionally updating the peer, are done by the per-protocol handlers of the ICMP event. TCP, UDP, et al. have a handler which will receive this event and transmit it back into the associated route via dst_ops->update_pmtu(). This simplification is important, because it eliminates the one place where we do not have a proper route context in which to make an inetpeer lookup. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-19rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()David S. Miller
2008-10-31net: replace NIPQUAD() in net/*/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[AF_RXRPC]: Sort out MTU handling.David Howells
Sort out the MTU determination and handling in AF_RXRPC: (1) If it's present, parse the additional information supplied by the peer at the end of the ACK packet (struct ackinfo) to determine the MTU sizes that peer is willing to support. (2) Initialise the MTU size to that peer from the kernel's routing records. (3) Send ACKs rather than ACKALLs as the former carry the additional info, and the latter do not. (4) Declare the interface MTU size in outgoing ACKs as a maximum amount of data that can be stuffed into an RxRPC packet without it having to be fragmented to come in this computer's NIC. (5) If sendmsg() is given MSG_MORE then it should allocate an skb of the maximum size rather than one just big enough for the data it's got left to process on the theory that there is more data to come that it can append to that packet. This means, for example, that if AFS does a large StoreData op, all the packets barring the last will be filled to the maximum unfragmented size. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Add an interface to the AF_RXRPC module for the AFS filesystem ↵David Howells
to use Add an interface to the AF_RXRPC module so that the AFS filesystem module can more easily make use of the services available. AFS still opens a socket but then uses the action functions in lieu of sendmsg() and registers an intercept functions to grab messages before they're queued on the socket Rx queue. This permits AFS (or whatever) to: (1) Avoid the overhead of using the recvmsg() call. (2) Use different keys directly on individual client calls on one socket rather than having to open a whole slew of sockets, one for each key it might want to use. (3) Avoid calling request_key() at the point of issue of a call or opening of a socket. This is done instead by AFS at the point of open(), unlink() or other VFS operation and the key handed through. (4) Request the use of something other than GFP_KERNEL to allocate memory. Furthermore: (*) The socket buffer markings used by RxRPC are made available for AFS so that it can interpret the cooked RxRPC messages itself. (*) rxgen (un)marshalling abort codes are made available. The following documentation for the kernel interface is added to Documentation/networking/rxrpc.txt: ========================= AF_RXRPC KERNEL INTERFACE ========================= The AF_RXRPC module also provides an interface for use by in-kernel utilities such as the AFS filesystem. This permits such a utility to: (1) Use different keys directly on individual client calls on one socket rather than having to open a whole slew of sockets, one for each key it might want to use. (2) Avoid having RxRPC call request_key() at the point of issue of a call or opening of a socket. Instead the utility is responsible for requesting a key at the appropriate point. AFS, for instance, would do this during VFS operations such as open() or unlink(). The key is then handed through when the call is initiated. (3) Request the use of something other than GFP_KERNEL to allocate memory. (4) Avoid the overhead of using the recvmsg() call. RxRPC messages can be intercepted before they get put into the socket Rx queue and the socket buffers manipulated directly. To use the RxRPC facility, a kernel utility must still open an AF_RXRPC socket, bind an addess as appropriate and listen if it's to be a server socket, but then it passes this to the kernel interface functions. The kernel interface functions are as follows: (*) Begin a new client call. struct rxrpc_call * rxrpc_kernel_begin_call(struct socket *sock, struct sockaddr_rxrpc *srx, struct key *key, unsigned long user_call_ID, gfp_t gfp); This allocates the infrastructure to make a new RxRPC call and assigns call and connection numbers. The call will be made on the UDP port that the socket is bound to. The call will go to the destination address of a connected client socket unless an alternative is supplied (srx is non-NULL). If a key is supplied then this will be used to secure the call instead of the key bound to the socket with the RXRPC_SECURITY_KEY sockopt. Calls secured in this way will still share connections if at all possible. The user_call_ID is equivalent to that supplied to sendmsg() in the control data buffer. It is entirely feasible to use this to point to a kernel data structure. If this function is successful, an opaque reference to the RxRPC call is returned. The caller now holds a reference on this and it must be properly ended. (*) End a client call. void rxrpc_kernel_end_call(struct rxrpc_call *call); This is used to end a previously begun call. The user_call_ID is expunged from AF_RXRPC's knowledge and will not be seen again in association with the specified call. (*) Send data through a call. int rxrpc_kernel_send_data(struct rxrpc_call *call, struct msghdr *msg, size_t len); This is used to supply either the request part of a client call or the reply part of a server call. msg.msg_iovlen and msg.msg_iov specify the data buffers to be used. msg_iov may not be NULL and must point exclusively to in-kernel virtual addresses. msg.msg_flags may be given MSG_MORE if there will be subsequent data sends for this call. The msg must not specify a destination address, control data or any flags other than MSG_MORE. len is the total amount of data to transmit. (*) Abort a call. void rxrpc_kernel_abort_call(struct rxrpc_call *call, u32 abort_code); This is used to abort a call if it's still in an abortable state. The abort code specified will be placed in the ABORT message sent. (*) Intercept received RxRPC messages. typedef void (*rxrpc_interceptor_t)(struct sock *sk, unsigned long user_call_ID, struct sk_buff *skb); void rxrpc_kernel_intercept_rx_messages(struct socket *sock, rxrpc_interceptor_t interceptor); This installs an interceptor function on the specified AF_RXRPC socket. All messages that would otherwise wind up in the socket's Rx queue are then diverted to this function. Note that care must be taken to process the messages in the right order to maintain DATA message sequentiality. The interceptor function itself is provided with the address of the socket and handling the incoming message, the ID assigned by the kernel utility to the call and the socket buffer containing the message. The skb->mark field indicates the type of message: MARK MEANING =============================== ======================================= RXRPC_SKB_MARK_DATA Data message RXRPC_SKB_MARK_FINAL_ACK Final ACK received for an incoming call RXRPC_SKB_MARK_BUSY Client call rejected as server busy RXRPC_SKB_MARK_REMOTE_ABORT Call aborted by peer RXRPC_SKB_MARK_NET_ERROR Network error detected RXRPC_SKB_MARK_LOCAL_ERROR Local error encountered RXRPC_SKB_MARK_NEW_CALL New incoming call awaiting acceptance The remote abort message can be probed with rxrpc_kernel_get_abort_code(). The two error messages can be probed with rxrpc_kernel_get_error_number(). A new call can be accepted with rxrpc_kernel_accept_call(). Data messages can have their contents extracted with the usual bunch of socket buffer manipulation functions. A data message can be determined to be the last one in a sequence with rxrpc_kernel_is_data_last(). When a data message has been used up, rxrpc_kernel_data_delivered() should be called on it.. Non-data messages should be handled to rxrpc_kernel_free_skb() to dispose of. It is possible to get extra refs on all types of message for later freeing, but this may pin the state of a call until the message is finally freed. (*) Accept an incoming call. struct rxrpc_call * rxrpc_kernel_accept_call(struct socket *sock, unsigned long user_call_ID); This is used to accept an incoming call and to assign it a call ID. This function is similar to rxrpc_kernel_begin_call() and calls accepted must be ended in the same way. If this function is successful, an opaque reference to the RxRPC call is returned. The caller now holds a reference on this and it must be properly ended. (*) Reject an incoming call. int rxrpc_kernel_reject_call(struct socket *sock); This is used to reject the first incoming call on the socket's queue with a BUSY message. -ENODATA is returned if there were no incoming calls. Other errors may be returned if the call had been aborted (-ECONNABORTED) or had timed out (-ETIME). (*) Record the delivery of a data message and free it. void rxrpc_kernel_data_delivered(struct sk_buff *skb); This is used to record a data message as having been delivered and to update the ACK state for the call. The socket buffer will be freed. (*) Free a message. void rxrpc_kernel_free_skb(struct sk_buff *skb); This is used to free a non-DATA socket buffer intercepted from an AF_RXRPC socket. (*) Determine if a data message is the last one on a call. bool rxrpc_kernel_is_data_last(struct sk_buff *skb); This is used to determine if a socket buffer holds the last data message to be received for a call (true will be returned if it does, false if not). The data message will be part of the reply on a client call and the request on an incoming call. In the latter case there will be more messages, but in the former case there will not. (*) Get the abort code from an abort message. u32 rxrpc_kernel_get_abort_code(struct sk_buff *skb); This is used to extract the abort code from a remote abort message. (*) Get the error number from a local or network error message. int rxrpc_kernel_get_error_number(struct sk_buff *skb); This is used to extract the error number from a message indicating either a local error occurred or a network error occurred. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Provide secure RxRPC sockets for use by userspace and kernel bothDavid Howells
Provide AF_RXRPC sockets that can be used to talk to AFS servers, or serve answers to AFS clients. KerberosIV security is fully supported. The patches and some example test programs can be found in: http://people.redhat.com/~dhowells/rxrpc/ This will eventually replace the old implementation of kernel-only RxRPC currently resident in net/rxrpc/. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
