path: root/net/sched/cls_basic.c
2016-12-10net, sched: respect rcu grace period on cls destructionDaniel Borkmann
[ Upstream commit d936377414fadbafb4d17148d222fe45ca5442d4 ] Roi reported a crash in flower where tp->root was NULL in ->classify() callbacks. Reason is that in ->destroy() tp->root is set to NULL via RCU_INIT_POINTER(). It's problematic for some of the classifiers, because this doesn't respect RCU grace period for them, and as a result, still outstanding readers from tc_classify() will try to blindly dereference a NULL tp->root. The tp->root object is strictly private to the classifier implementation and holds internal data the core such as tc_ctl_tfilter() doesn't know about. Within some classifiers, such as cls_bpf, cls_basic, etc, tp->root is only checked for NULL in ->get() callback, but nowhere else. This is misleading and seemed to be copied from old classifier code that was not cleaned up properly. For example, d3fa76ee6b4a ("[NET_SCHED]: cls_basic: fix NULL pointer dereference") moved tp->root initialization into ->init() routine, where before it was part of ->change(), so ->get() had to deal with tp->root being NULL back then, so that was indeed a valid case, after d3fa76ee6b4a, not really anymore. We used to set tp->root to NULL long ago in ->destroy(), see 47a1a1d4be29 ("pkt_sched: remove unnecessary xchg() in packet classifiers"); but the NULLifying was reintroduced with the RCUification, but it's not correct for every classifier implementation. In the cases that are fixed here with one exception of cls_cgroup, tp->root object is allocated and initialized inside ->init() callback, which is always performed at a point in time after we allocate a new tp, which means tp and thus tp->root was not globally visible in the tp chain yet (see tc_ctl_tfilter()). Also, on destruction tp->root is strictly kfree_rcu()'ed in ->destroy() handler, same for the tp which is kfree_rcu()'ed right when we return from ->destroy() in tcf_destroy(). This means, the head object's lifetime for such classifiers is always tied to the tp lifetime. The RCU callback invocation for the two kfree_rcu() could be out of order, but that's fine since both are independent. Dropping the RCU_INIT_POINTER(tp->root, NULL) for these classifiers here means that 1) we don't need a useless NULL check in fast-path and, 2) that outstanding readers of that tp in tc_classify() can still execute under respect with RCU grace period as it is actually expected. Things that haven't been touched here: cls_fw and cls_route. They each handle tp->root being NULL in ->classify() path for historic reasons, so their ->destroy() implementation can stay as is. If someone actually cares, they could get cleaned up at some point to avoid the test in fast path. cls_u32 doesn't set tp->root to NULL. For cls_rsvp, I just added a !head should anyone actually be using/testing it, so it at least aligns with cls_fw and cls_route. For cls_flower we additionally need to defer rhashtable destruction (to a sleepable context) after RCU grace period as concurrent readers might still access it. (Note that in this case we need to hold module reference to keep work callback address intact, since we only wait on module unload for all call_rcu()s to finish.) This fixes one race to bring RCU grace period guarantees back. Next step as worked on by Cong however is to fix 1e052be69d04 ("net_sched: destroy proto tp when all filters are gone") to get the order of unlinking the tp in tc_ctl_tfilter() for the RTM_DELTFILTER case right by moving RCU_INIT_POINTER() before tcf_destroy() and let the notification for removal be done through the prior ->delete() callback. Both are independant issues. Once we have that right, we can then clean tp->root up for a number of classifiers by not making them RCU pointers, which requires a new callback (->uninit) that is triggered from tp's RCU callback, where we just kfree() tp->root from there. Fixes: 1f947bf151e9 ("net: sched: rcu'ify cls_bpf") Fixes: 9888faefe132 ("net: sched: cls_basic use RCU") Fixes: 70da9f0bf999 ("net: sched: cls_flow use RCU") Fixes: 77b9900ef53a ("tc: introduce Flower classifier") Fixes: bf3994d2ed31 ("net/sched: introduce Match-all classifier") Fixes: 952313bd6258 ("net: sched: cls_cgroup use RCU") Reported-by: Roi Dayan <roid@mellanox.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Cc: Cong Wang <xiyou.wangcong@gmail.com> Cc: John Fastabend <john.fastabend@gmail.com> Cc: Roi Dayan <roid@mellanox.com> Cc: Jiri Pirko <jiri@mellanox.com> Acked-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-09net_sched: destroy proto tp when all filters are goneCong Wang
Kernel automatically creates a tp for each (kind, protocol, priority) tuple, which has handle 0, when we add a new filter, but it still is left there after we remove our own, unless we don't specify the handle (literally means all the filters under the tuple). For example this one is left: # tc filter show dev eth0 filter parent 8001: protocol arp pref 49152 basic The user-space is hard to clean up these for kernel because filters like u32 are organized in a complex way. So kernel is responsible to remove it after all filters are gone. Each type of filter has its own way to store the filters, so each type has to provide its way to check if all filters are gone. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Jamal Hadi Salim<jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-26net: cls_basic: return from walking on match in basic_getDaniel Borkmann
As soon as we've found a matching handle in basic_get(), we can return it. There's no need to continue walking until the end of a filter chain, since they are unique anyway. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Jiri Pirko <jiri@resnulli.us> Cc: Thomas Graf <tgraf@suug.ch> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-09net: sched: cls_basic: fix error path in basic_change()Jiri Pirko
Signed-off-by: Jiri Pirko <jiri@resnulli.us> Reviewed-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-09net: sched: cls: remove unused op put from tcf_proto_opsJiri Pirko
It is never called and implementations are void. So just remove it. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-08net_sched: cls_basic: remove unnecessary iteration and use passed argJiri Pirko
Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-06net: sched: do not use tcf_proto 'tp' argument from call_rcuJohn Fastabend
Using the tcf_proto pointer 'tp' from inside the classifiers callback is not valid because it may have been cleaned up by another call_rcu occuring on another CPU. 'tp' is currently being used by tcf_unbind_filter() in this patch we move instances of tcf_unbind_filter outside of the call_rcu() context. This is safe to do because any running schedulers will either read the valid class field or it will be zeroed. And all schedulers today when the class is 0 do a lookup using the same call used by the tcf_exts_bind(). So even if we have a running classifier hit the null class pointer it will do a lookup and get to the same result. This is particularly fragile at the moment because the only way to verify this is to audit the schedulers call sites. Reported-by: Cong Wang <xiyou.wangconf@gmail.com> Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-06net: sched: remove tcf_proto from ematch callsJohn Fastabend
This removes the tcf_proto argument from the ematch code paths that only need it to reference the net namespace. This allows simplifying qdisc code paths especially when we need to tear down the ematch from an RCU callback. In this case we can not guarentee that the tcf_proto structure is still valid. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-28net_sched: remove the first parameter from tcf_exts_destroy()WANG Cong
Cc: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Jamal Hadi Salim <hadi@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-13net: sched: cls_basic use RCUJohn Fastabend
Enable basic classifier for RCU. Dereferencing tp->root may look a bit strange here but it is needed by my accounting because it is allocated at init time and needs to be kfree'd at destroy time. However because it may be referenced in the classify() path we must wait an RCU grace period before free'ing it. We use kfree_rcu() and rcu_ APIs to enforce this. This pattern is used in all the classifiers. Also the hgenerator can be incremented without concern because it is always incremented under RTNL. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-27sched, cls: check if we could overwrite actions when changing a filterCong Wang
When actions are attached to a filter, they are a part of the filter itself, so when changing a filter we should allow to overwrite the actions inside as well. In my specific case, when I tried to _append_ a new action to an existing filter which already has an action, I got EEXIST since kernel refused to overwrite the existing one in kernel. This patch checks if we are changing the filter checking NLM_F_CREATE flag (Sigh, filters don't use NLM_F_REPLACE...) and then passes the boolean down to actions. This fixes the problem above. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13net_sched: avoid casting void pointerWANG Cong
tp->root is a void* pointer, no need to cast it. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13net_sched: add struct net pointer to tcf_proto_ops->dumpWANG Cong
It will be needed by the next patch. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-18net_sched: cls: refactor out struct tcf_ext_mapWANG Cong
These information can be saved in tcf_exts, and this will simplify the code. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-18net_sched: act: use standard struct list_headWANG Cong
Currently actions are chained by a singly linked list, therefore it is a bit hard to add and remove a specific entry. Convert it to struct list_head so that in the latter patch we can remove an action without finding its head. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-30qdisc: basic classifier - remove unnecessary initializationstephen hemminger
err is set once, then first code resets it. err = tcf_exts_validate(...) Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Acked-by: Jamal Hadi Salim <hadi@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-14pkt_sched: namespace aware act_mirredBenjamin LaHaise
Eric Dumazet pointed out that act_mirred needs to find the current net_ns, and struct net pointer is not provided in the call chain. His original patch made use of current->nsproxy->net_ns to find the network namespace, but this fails to work correctly for userspace code that makes use of netlink sockets in different network namespaces. Instead, pass the "struct net *" down along the call chain to where it is needed. This version removes the ifb changes as Eric has submitted that patch separately, but is otherwise identical to the previous version. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Tested-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14net sched: Pass the skb into change so it can access NETLINK_CBEric W. Biederman
cls_flow.c plays with uids and gids. Unless I misread that code it is possible for classifiers to depend on the specific uid and gid values. Therefore I need to know the user namespace of the netlink socket that is installing the packet classifiers. Pass in the rtnetlink skb so I can access the NETLINK_CB of the passed packet. In particular I want access to sk_user_ns(NETLINK_CB(in_skb).ssk). Pass in not the user namespace but the incomming rtnetlink skb into the the classifier change routines as that is generally the more useful parameter. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-01pkt_sched: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-06net: sched: constify tcf_proto and tc_actionEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19net_sched: cleanupsEric Dumazet
Cleanup net/sched code to current CodingStyle and practices. Reduce inline abuse Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-08classifier: report statistics for basic classifierstephen hemminger
The basic classifier keeps statistics but does not report it to user space. This showed up when using basic classifier (with police) as a default catch all on ingress; no statistics were reported. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-11-20pkt_sched: remove unnecessary xchg() in packet classifiersPatrick McHardy
The use of xchg() hasn't been necessary since 2.2.something when proper locking was added to packet schedulers. In the case of classifiers they mostly weren't even necessary before that since they're mainly used to assign a NULL pointer to the filter root in the ->destroy path; the root is destroyed immediately after that. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NET_SCHED]: Constify struct tcf_ext_mapPatrick McHardy
2008-01-28[NET_SCHED]: Use nla_policy for attribute validation in classifiersPatrick McHardy
2008-01-28[NET_SCHED]: Use typeful attribute parsing helpersPatrick McHardy
2008-01-28[NET_SCHED]: Use typeful attribute construction helpersPatrick McHardy
2008-01-28[NET_SCHED]: Use nla_nest_start/nla_nest_endPatrick McHardy
Use nla_nest_start/nla_nest_end for dumping nested attributes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Propagate nla_parse return valuePatrick McHardy
nla_parse() returns more detailed errno codes, propagate them back on error. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Convert classifiers from rtnetlink to new netlink APIPatrick McHardy
2008-01-28[NET_SCHED]: mark classifier ops __read_mostlyPatrick McHardy
Additionally remove unnecessary NULL initilizations of the next pointer. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET_SCHED]: Remove unnecessary includesPatrick McHardy
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-02[NET_SCHED]: cls_basic: fix memory leak in basic_destroyPatrick McHardy
tp->root is not freed on destruction. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-25[NET_SCHED]: cls_basic: fix NULL pointer dereferencePatrick McHardy
cls_basic doesn't allocate tp->root before it is linked into the active classifier list, resulting in a NULL pointer dereference when packets hit the classifier before its ->change function is called. Reported by Chris Madden <chris@reflexsecurity.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] SCHED: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[PKT_SCHED] cls_basic: Use unsigned int when generating handleKim Nordlund
Prevents filters from being added if the first generated handle already exists. Signed-off-by: Kim Nordlund <kim.nordlund@nokia.com> Signed-off-by: Thomas Graf <tgraf@suug.ch>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-08[PKT_SCHED]: Dump classification result for basic classifierThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
