commit e323d865b36134e8c5c82c834df89109a5c60dab upstream.
iproute2 package is well behaved, but malicious user space can
provide illegal shift values and trigger UBSAN reports.
Add stab parameter to red_check_params() to validate user input.
syzbot reported:
UBSAN: shift-out-of-bounds in ./include/net/red.h:312:18
shift exponent 111 is too large for 64-bit type 'long unsigned int'
CPU: 1 PID: 14662 Comm: syz-executor.3 Not tainted 5.12.0-rc2-syzkaller #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:79 [inline]
dump_stack+0x141/0x1d7 lib/dump_stack.c:120
ubsan_epilogue+0xb/0x5a lib/ubsan.c:148
__ubsan_handle_shift_out_of_bounds.cold+0xb1/0x181 lib/ubsan.c:327
red_calc_qavg_from_idle_time include/net/red.h:312 [inline]
red_calc_qavg include/net/red.h:353 [inline]
choke_enqueue.cold+0x18/0x3dd net/sched/sch_choke.c:221
__dev_xmit_skb net/core/dev.c:3837 [inline]
__dev_queue_xmit+0x1943/0x2e00 net/core/dev.c:4150
neigh_hh_output include/net/neighbour.h:499 [inline]
neigh_output include/net/neighbour.h:508 [inline]
ip6_finish_output2+0x911/0x1700 net/ipv6/ip6_output.c:117
__ip6_finish_output net/ipv6/ip6_output.c:182 [inline]
__ip6_finish_output+0x4c1/0xe10 net/ipv6/ip6_output.c:161
ip6_finish_output+0x35/0x200 net/ipv6/ip6_output.c:192
NF_HOOK_COND include/linux/netfilter.h:290 [inline]
ip6_output+0x1e4/0x530 net/ipv6/ip6_output.c:215
dst_output include/net/dst.h:448 [inline]
NF_HOOK include/linux/netfilter.h:301 [inline]
NF_HOOK include/linux/netfilter.h:295 [inline]
ip6_xmit+0x127e/0x1eb0 net/ipv6/ip6_output.c:320
inet6_csk_xmit+0x358/0x630 net/ipv6/inet6_connection_sock.c:135
dccp_transmit_skb+0x973/0x12c0 net/dccp/output.c:138
dccp_send_reset+0x21b/0x2b0 net/dccp/output.c:535
dccp_finish_passive_close net/dccp/proto.c:123 [inline]
dccp_finish_passive_close+0xed/0x140 net/dccp/proto.c:118
dccp_terminate_connection net/dccp/proto.c:958 [inline]
dccp_close+0xb3c/0xe60 net/dccp/proto.c:1028
inet_release+0x12e/0x280 net/ipv4/af_inet.c:431
inet6_release+0x4c/0x70 net/ipv6/af_inet6.c:478
__sock_release+0xcd/0x280 net/socket.c:599
sock_close+0x18/0x20 net/socket.c:1258
__fput+0x288/0x920 fs/file_table.c:280
task_work_run+0xdd/0x1a0 kernel/task_work.c:140
tracehook_notify_resume include/linux/tracehook.h:189 [inline]
Fixes: 8afa10cbe281 ("net_sched: red: Avoid illegal values")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit bd1248f1ddbc48b0c30565fce897a3b6423313b8 ]
Check Scell_log shift size in red_check_params() and modify all callers
of red_check_params() to pass Scell_log.
This prevents a shift out-of-bounds as detected by UBSAN:
UBSAN: shift-out-of-bounds in ./include/net/red.h:252:22
shift exponent 72 is too large for 32-bit type 'int'
Reported-by: syzbot+97c5bd9cc81eca63d36e@syzkaller.appspotmail.com
Cc: Nogah Frankel <nogahf@mellanox.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Jiri Pirko <jiri@resnulli.us>
Cc: netdev@vger.kernel.org
Cc: Jakub Kicinski <kuba@kernel.org>
[ Upstream commit 8738c85c72b3108c9b9a369a39868ba5f8e10ae0 ]
If choke_init() could not allocate q->tab, we would crash later
in choke_reset().
BUG: KASAN: null-ptr-deref in memset include/linux/string.h:366 [inline]
BUG: KASAN: null-ptr-deref in choke_reset+0x208/0x340 net/sched/sch_choke.c:326
Write of size 8 at addr 0000000000000000 by task syz-executor822/7022
CPU: 1 PID: 7022 Comm: syz-executor822 Not tainted 5.7.0-rc1-syzkaller #0
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x188/0x20d lib/dump_stack.c:118
__kasan_report.cold+0x5/0x4d mm/kasan/report.c:515
kasan_report+0x33/0x50 mm/kasan/common.c:625
check_memory_region_inline mm/kasan/generic.c:187 [inline]
check_memory_region+0x141/0x190 mm/kasan/generic.c:193
memset+0x20/0x40 mm/kasan/common.c:85
qdisc_reset+0x6b/0x520 net/sched/sch_generic.c:910
dev_deactivate_queue.constprop.0+0x13c/0x240 net/sched/sch_generic.c:1138
netdev_for_each_tx_queue include/linux/netdevice.h:2197 [inline]
dev_deactivate_many+0xe2/0xba0 net/sched/sch_generic.c:1195
dev_deactivate+0xf8/0x1c0 net/sched/sch_generic.c:1233
qdisc_graft+0xd25/0x1120 net/sched/sch_api.c:1051
tc_modify_qdisc+0xbab/0x1a00 net/sched/sch_api.c:1670
rtnetlink_rcv_msg+0x44e/0xad0 net/core/rtnetlink.c:5454
netlink_rcv_skb+0x15a/0x410 net/netlink/af_netlink.c:2469
netlink_unicast_kernel net/netlink/af_netlink.c:1303 [inline]
netlink_unicast+0x537/0x740 net/netlink/af_netlink.c:1329
netlink_sendmsg+0x882/0xe10 net/netlink/af_netlink.c:1918
sock_sendmsg_nosec net/socket.c:652 [inline]
sock_sendmsg+0xcf/0x120 net/socket.c:672
____sys_sendmsg+0x6bf/0x7e0 net/socket.c:2362
___sys_sendmsg+0x100/0x170 net/socket.c:2416
__sys_sendmsg+0xec/0x1b0 net/socket.c:2449
do_syscall_64+0xf6/0x7d0 arch/x86/entry/common.c:295
Fixes: 77e62da6e60c ("sch_choke: drop all packets in queue during reset")
[ Upstream commit 8afa10cbe281b10371fee5a87ab266e48d71a7f9 ]
Check the qmin & qmax values doesn't overflow for the given Wlog value.
Check that qmin <= qmax.
Fixes: a783474591f2 ("[PKT_SCHED]: Generic RED layer")
Signed-off-by: Nogah Frankel <nogahf@mellanox.com>
[ Upstream commit 2ccccf5fb43ff62b2b96cc58d95fc0b3596516e4 ]
When the bottom qdisc decides to, for example, drop some packet,
it calls qdisc_tree_decrease_qlen() to update the queue length
for all its ancestors, we need to update the backlog too to
keep the stats on root qdisc accurate.
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
It looks like this has never been used at all.
Signed-off-by: Phil Sutter <phil@nwl.cc>
The flags argument will allow control of the dissection process (for
instance whether to parse beyond L3).
Signed-off-by: Tom Herbert <tom@herbertland.com>
For classifiers getting invoked via tc_classify(), we always need an
extra function call into tc_classify_compat(), as both are being
exported as symbols and tc_classify() itself doesn't do much except
handling of reclassifications when tp->classify() returned with
TC_ACT_RECLASSIFY.
CBQ and ATM are the only qdiscs that directly call into tc_classify_compat(),
all others use tc_classify(). When tc actions are being configured
out in the kernel, tc_classify() effectively does nothing besides
delegating.
We could spare this layer and consolidate both functions. pktgen on
single CPU constantly pushing skbs directly into the netif_receive_skb()
path with a dummy classifier on ingress qdisc attached, improves
slightly from 22.3Mpps to 23.1Mpps.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
add couple of empty lines on the way.
Call make_flow_keys_digest to get a digest from flow keys and
use that to pass skbuff cb and for comparing flows.
This adds helpers to manipulate qstats logic and replaces locations
that touch the counters directly. This simplifies future patches
to push qstats onto per cpu counters.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
arch/mips/net/bpf_jit.c
drivers/net/can/flexcan.c
Both the flexcan and MIPS bpf_jit conflicts were cases of simple
overlapping changes.
We cannot make struct qdisc_skb_cb bigger without impacting IPoIB,
or increasing skb->cb[] size.
Commit e0f31d849867 ("flow_keys: Record IP layer protocol in
skb_flow_dissect()") broke IPoIB.
Only current offender is sch_choke, and this one do not need an
absolutely precise flow key.
If we store 17 bytes of flow key, its more than enough. (Its the actual
size of flow_keys if it was a packed structure, but we might add new
fields at the end of it later)
Fixes: e0f31d849867 ("flow_keys: Record IP layer protocol in skb_flow_dissect()")
rcu'ify tcf_proto this allows calling tc_classify() without holding
any locks. Updaters are protected by RTNL.
This patch prepares the core net_sched infrastracture for running
the classifier/action chains without holding the qdisc lock however
it does nothing to ensure cls_xxx and act_xxx types also work without
locking. Additional patches are required to address the fall out.
It is available since v3.15-rc5.
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Many functions have open coded a function that returns a random
number in range [0,N-1]. Under the assumption that we have a PRNG
such as taus113 with being well distributed in [0, ~0U] space,
we can implement such a function as uword t = (n*m')>>32, where
m' is a random number obtained from PRNG, n the right open interval
border and t our resulting random number, with n,m',t in u32 universe.
Lets go with Joe and simply call it prandom_u32_max(), although
technically we have an right open interval endpoint, but that we
have documented. Other users can further be migrated to the new
prandom_u32_max() function later on; for now, we need to make sure
to migrate reciprocal_divide() users for the reciprocal_divide()
follow-up fixup since their function signatures are going to change.
Joint work with Hannes Frederic Sowa.
Cc: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Don't emit OOM warnings when k.alloc calls fail when
there there is a v.alloc immediately afterwards.
Converted a kmalloc/vmalloc with memset to kzalloc/vzalloc.
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
Use preferable function name which implies using a pseudo-random
number generator.
Cc: Stephen Hemminger <shemminger@vyatta.com>
Use qdisc_drop() helper where possible.
These macros contain a hidden goto, and are thus extremely error
prone and make code hard to audit.
Just like skb->cb[], so that qdisc_skb_cb can be encapsulated inside
of other data structures.
This is intended to be used by IPoIB so that it can remember
addressing information stored at hard_header_ops->create() time that
it can fetch when the packet gets to the transmit routine.
This patch splits the red_parms structure into two components.
One holding the RED 'constant' parameters, and one containing the
variables.
This permits a size reduction of GRED qdisc, and is a preliminary step
to add an optional RED unit to SFQ.
SFQRED will have a single red_parms structure shared by all flows, and a
private red_vars per flow.
CC: Dave Taht <dave.taht@gmail.com>
CC: Stephen Hemminger <shemminger@vyatta.com>
Now RED uses a Q0.32 number to store max_p (max probability), allow
RED/GRED/CHOKE to use/report full resolution at config/dump time.
Old tc binaries are non aware of new attributes, and still set/get Plog.
New tc binary set/get both Plog and max_p for backward compatibility,
they display "probability value" if they get max_p from new kernels.
# tc -d qdisc show dev ...
qdisc red 10: parent 1:1 limit 360Kb min 30Kb max 90Kb ecn ewma 5
probability 0.09 Scell_log 15
Make sure we avoid potential divides by 0 in reciprocal_value(), if
(max_th - min_th) is big.
Instead of using a custom flow dissector, use skb_flow_dissect() and
benefit from tunnelling support.
Remove the assumption that skb_get_rxhash() makes IP header and ports
linear, and use skb_header_pointer() instead in choke_match_flow()
This permits __skb_get_rxhash() to use skb_header_pointer() eventually.
There are enough instances of this:
iph->frag_off & htons(IP_MF | IP_OFFSET)
that a helper function is probably warranted.
Better document choke skb->cb[] use, like we did in netem and sfb
This adds a compile time check to make sure we dont exhaust skb->cb[]
space.
CC: Patrick McHardy <kaber@trash.net>
CHOKe ("CHOose and Kill" or "CHOose and Keep") is an alternative
packet scheduler based on the Random Exponential Drop (RED) algorithm.
The core idea is:
For every packet arrival:
Calculate Qave
if (Qave < minth)
Queue the new packet
else
Select randomly a packet from the queue
if (both packets from same flow)
then Drop both the packets
else if (Qave > maxth)
Drop packet
else
Admit packet with proability p (same as RED)
See also:
Rong Pan, Balaji Prabhakar, Konstantinos Psounis, "CHOKe: a stateless active
queue management scheme for approximating fair bandwidth allocation",
Proceeding of INFOCOM'2000, March 2000.
Help from:
